There are a few leftover CONFIG_PROC_FS forgotten to replace with
CONFIG_SND_PROC_FS.
Fixes: cd6a65036f0e ('ALSA: replace CONFIG_PROC_FS with CONFIG_SND_PROC_FS')
Reported-by: Jim Davis <jim.epost@gmail.com>
Minor cleanups of Makefile to build some codes conditionally so that
a few ifdefs can be reduced.
Acked-by: Jaroslav Kysela <perex@perex.cz>
When build SND_SEQUENCER in kernel then OSS sequencer(alsa_seq_oss_init)
is initialized before System (snd_seq_system_client_init) which leads to
memory leak :
unreferenced object 0xf6b0e680 (size 256):
comm "swapper", pid 1, jiffies 4294670753
backtrace:
[<c108ac5c>] create_object+0x135/0x204
[<c108adfe>] kmemleak_alloc+0x26/0x4c
[<c1087de2>] kmem_cache_alloc+0x72/0xff
[<c126d2ac>] seq_create_client1+0x22/0x160
[<c126e3b6>] snd_seq_create_kernel_client+0x72/0xef
[<c1485a05>] snd_seq_oss_create_client+0x86/0x142
[<c1485920>] alsa_seq_oss_init+0xf6/0x155
[<c1001059>] do_one_initcall+0x4f/0x111
[<c14655be>] kernel_init+0x115/0x166
[<c10032af>] kernel_thread_helper+0x7/0x10
[<ffffffff>] 0xffffffff
unreferenced object 0xf688a580 (size 64):
backtrace:
[<c126f964>] snd_seq_pool_new+0x1c/0xb8
[<c126d311>] seq_create_client1+0x87/0x160
unreferenced object 0xf6b0e480 (size 256):
comm "swapper", pid 1, jiffies 4294670754
backtrace:
[<c12725a0>] snd_seq_create_port+0x51/0x21c
[<c126de50>] snd_seq_ioctl_create_port+0x57/0x13c
[<c126d07a>] snd_seq_do_ioctl+0x4a/0x69
[<c126d0de>] snd_seq_kernel_client_ctl+0x33/0x49
[<c1485a74>] snd_seq_oss_create_client+0xf5/0x142
The correct order should be :
System (snd_seq_system_client_init) should be initialized before
OSS sequencer(alsa_seq_oss_init) which is equivalent to :
1. insmod sound/core/seq/snd-seq-device.ko
2. insmod sound/core/seq/snd-seq.ko
3. insmod sound/core/seq/snd-seq-midi-event.ko
4. insmod sound/core/seq/oss/snd-seq-oss.ko
Including sound/core/seq/oss/Makefile after other seq modules
fixes the ordering and memory leak.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Instead of mangling the CONFIG_* variables in the makefiles over and
over, set a few helper variables in Kconfig.
Remove sequencer instrument layer from the tree.
This mechanism hasn't been used much with the actual devices. The only
reasonable user was OPL3 loader, and now it was rewritten to use hwdep
instead. So, let's remove the rest of rotten codes.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
ALSA sequencer
Add the missing snd-seq-midi-emul to SND_GUS_SYNTH list.
infrastructure for it.
Let it rip!
