2017-09-12 | ALSA: seq: Cancel pending autoload work at unbinding device | Takashi Iwai | |
ALSA sequencer core has a mechanism to load the enumerated devices automatically, and it's performed in an off-load work. This seems causing some race when a sequencer is removed while the pending autoload work is running. As syzkaller spotted, it may lead to some use-after-free: BUG: KASAN: use-after-free in snd_rawmidi_dev_seq_free+0x69/0x70 sound/core/rawmidi.c:1617 Write of size 8 at addr ffff88006c611d90 by task kworker/2:1/567 CPU: 2 PID: 567 Comm: kworker/2:1 Not tainted 4.13.0+ #29 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Workqueue: events autoload_drivers Call Trace: __dump_stack lib/dump_stack.c:16 [inline] dump_stack+0x192/0x22c lib/dump_stack.c:52 print_address_description+0x78/0x280 mm/kasan/report.c:252 kasan_report_error mm/kasan/report.c:351 [inline] kasan_report+0x230/0x340 mm/kasan/report.c:409 __asan_report_store8_noabort+0x1c/0x20 mm/kasan/report.c:435 snd_rawmidi_dev_seq_free+0x69/0x70 sound/core/rawmidi.c:1617 snd_seq_dev_release+0x4f/0x70 sound/core/seq_device.c:192 device_release+0x13f/0x210 drivers/base/core.c:814 kobject_cleanup lib/kobject.c:648 [inline] kobject_release lib/kobject.c:677 [inline] kref_put include/linux/kref.h:70 [inline] kobject_put+0x145/0x240 lib/kobject.c:694 put_device+0x25/0x30 drivers/base/core.c:1799 klist_devices_put+0x36/0x40 drivers/base/bus.c:827 klist_next+0x264/0x4a0 lib/klist.c:403 next_device drivers/base/bus.c:270 [inline] bus_for_each_dev+0x17e/0x210 drivers/base/bus.c:312 autoload_drivers+0x3b/0x50 sound/core/seq_device.c:117 process_one_work+0x9fb/0x1570 kernel/workqueue.c:2097 worker_thread+0x1e4/0x1350 kernel/workqueue.c:2231 kthread+0x324/0x3f0 kernel/kthread.c:231 ret_from_fork+0x25/0x30 arch/x86/entry/entry_64.S:425 The fix is simply to assure canceling the autoload work at removing the device. Reported-by: Andrey Konovalov <andreyknvl@google.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> | |||
2017-06-12 | ALSA: seq: Allow the modular sequencer registration | Takashi Iwai | |
Many drivers bind the sequencer stuff in off-load by another driver module, so that it's loaded only on demand. In the current code, this mechanism doesn't work when the driver is built-in while the sequencer is module. We check with IS_REACHABLE() and enable only when the sequencer is in the same level of build. However, this is basically a overshoot. The binder code (snd-seq-device) is an individual module from the sequencer core (snd-seq), and we just have to make the former a built-in while keeping the latter a module for allowing the scenario like the above. This patch achieves that by rewriting Kconfig slightly. Now, a driver that provides the manual sequencer device binding should select CONFIG_SND_SEQ_DEVICE in a way as select SND_SEQ_DEVICE if SND_SEQUENCER != n Note that the "!=n" is needed here to avoid the influence of the sequencer core is module while the driver is built-in. Also, since rawmidi.o may be linked with snd_seq_device.o when built-in, we have to shuffle the code to make the linker happy. (the kernel linker isn't smart enough yet to handle such a case.) That is, snd_seq_device.c is moved to sound/core from sound/core/seq, as well as Makefile. Last but not least, the patch replaces the code using IS_REACHABLE() with IS_ENABLED(), since now the condition meets always when enabled. Signed-off-by: Takashi Iwai <tiwai@suse.de> |
