path: root/sound/core
2009-06-12Merge branch 'topic/misc' into for-linusTakashi Iwai
* topic/misc: ALSA: use card device as parent for jack input-devices
2009-06-10ALSA: use card device as parent for jack input-devicesKay Sievers
This moves the jack devices from the PCI device into the ALSA card device, which makes it easier for userspace to find all devices belonging to a specific card while granting access to logged-in users. Jack input devices from sound cards can now simply be matched with udev by doing: SUBSYSTEM="input", SUBSYSTEMS="sound", ... ls -l /sys/devices/pci0000:00/0000:00:1b.0/sound/card0 controlC0 device -> ../../../0000:00:1b.0 id input10 input11 input8 input9 number pcmC0D0c pcmC0D0p pcmC0D1p power subsystem -> ../../../../../class/sound uevent Cc: Lennart Poettering <lennart@0pointer.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-10Merge branch 'topic/seq-kconfig-cleanup' into for-linusTakashi Iwai
* topic/seq-kconfig-cleanup: ALSA: clean up the logic for building sequencer modules
2009-06-10Merge branch 'topic/pcm-jiffies-check' into for-linusTakashi Iwai
* topic/pcm-jiffies-check: ALSA: pcm - A helper function to compose PCM stream name for debug prints ALSA: pcm - Fix update of runtime->hw_ptr_interrupt ALSA: pcm - Fix a typo in hw_ptr update check ALSA: PCM midlevel: lower jiffies check margin using runtime->delay value ALSA: PCM midlevel: Do not update hw_ptr_jiffies when hw_ptr is not changed ALSA: PCM midlevel: introduce mask for xrun_debug() macro ALSA: PCM midlevel: improve fifo_size handling
2009-06-10Merge branch 'topic/pcm-delay' into for-linusTakashi Iwai
* topic/pcm-delay: ALSA: usbaudio - Add delay account ALSA: Add extra delay count in PCM
2009-06-10Merge branch 'topic/div64-cleanup' into for-linusTakashi Iwai
* topic/div64-cleanup: ALSA: Clean up 64bit division functions
2009-06-08ALSA: pcm - A helper function to compose PCM stream name for debug printsTakashi Iwai
Use a common helper function for the PCM stream name displayed in XRUN and buffer-pointer debug prints. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-07ALSA: pcm - Fix update of runtime->hw_ptr_interruptTakashi Iwai
The commit 13f040f9e55d41e92e485389123654971e03b819 made another regression, the missing update of runtime->hw_ptr_interrupt. Since this field is only checked in snd_pcmupdate__hw_ptr_interrupt(), not in snd_pcm_update_hw_ptr(), it must be updated before the hw_ptr change check. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-06ALSA: pcm - Fix a typo in hw_ptr update checkJaroslav Kysela
Fix a typo in the commit 13f040f9e55d41e92e485389123654971e03b819 ALSA: PCM midlevel: Do not update hw_ptr_jiffies when hw_ptr is not changed which causes obvious problems with PA. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-05ALSA: Clean up 64bit division functionsTakashi Iwai
Replace the house-made div64_32() with the standard div_u64*() functions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-04ALSA: Core - clean up snd_card_set_id* calls and remove possible id collisionJaroslav Kysela
Move locking outside snd_card_set_id_internal() function and rename it to snd_card_set_id_no_lock() for better function description. User defined id is just copied to card structure at allocation time. The real unique id procedure is called in snd_card_register() to ensure real atomicity. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-03ALSA: Fix double locking of card list in snd_card_register()Mark Brown
The introduction of snd_card_set_id() added a lock on the card list to the old choose_default_id() function when using it to implement the new API call. This lock is needed to allow us to walk the list and check to see if our new name is a duplicate. Unfortunately this causes a lockup when called from snd_card_register() (in cases where no ID is supplied for the card) since the card list is already locked there. Fix this fairly hideously by factoring out the implementation and using a flag to indicate if the lock should be held. A better fix would probably be to refactor snd_card_register() to move the _set_id() outside the locking region but I can't immediately see anything I can convince myself is safe. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-02ALSA: Core - add snd_card_set_id() functionJaroslav Kysela
Introduce snd_card_set_id() function to allow lowlevel drivers to set default identification name for card slot. The function checks also for identification name collisions and tries to create unique name. Also, the snd_card_create() function is simplified, because this new function is used. As bonus, proper name collision checks are evaluated at the card create time. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-29ALSA: clean up the logic for building sequencer modulesMichal Marek
Instead of mangling the CONFIG_* variables in the makefiles over and over, set a few helper variables in Kconfig. Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-29ALSA: PCM midlevel: lower jiffies check margin using runtime->delay valueJaroslav Kysela
When hardware has large FIFO, it is necessary to lower jiffies margin by count of queued samples. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-29ALSA: PCM midlevel: Do not update hw_ptr_jiffies when hw_ptr is not changedJaroslav Kysela
Some hardware might have bigger FIFOs and DMA pointer value will be updated in large chunks. Do not update hw_ptr_jiffies and position timestamp when hw_ptr value was not changed. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-29ALSA: PCM midlevel: introduce mask for xrun_debug() macroJaroslav Kysela
For debugging purposes, it is better to separate actions. Bit-values: 1: show bad PCM ring buffer pointer 2: show also stack (to debug kernel latency issues) 4: check pointer against system jiffies Example: 5: show bad PCM ring buffer pointer and do jiffies check Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-29ALSA: PCM midlevel: improve fifo_size handlingJaroslav Kysela
Move the fifo_size assignment to hw->ioctl callback to allow lowlevel drivers overwrite the default behaviour. fifo_size is in frames not bytes as specified in asound.h and alsa-lib's documentation, but most hardware have fixed byte based FIFOs. Introduce internal SNDRV_PCM_INFO_FIFO_IN_FRAMES. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-29Merge branch 'fix/pcm-jiffies-check' into topic/pcm-jiffies-checkTakashi Iwai
2009-05-27ALSA: Enable PCM hw_ptr_jiffies check only in xrun_debug modeTakashi Iwai
The PCM hw_ptr jiffies check results sometimes in problems when a hardware doesn't give smooth hw_ptr updates. So far, au88x0 and some other drivers appear not working due to this strict check. However, this check is a nice debug tool, and the capability should be still kept. Hence, we disable this check now as default unless the user enables it by setting the xrun_debug mode to the specific stream via a proc file. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-27ALSA: Fix invalid jiffies check after pauseTakashi Iwai
The hw_ptr_jiffies has to be reset properly to avoid the invalid check of jiffies delta in snd_pcm_update_hw_ptr*() functions. Especailly this patch fixes the bogus jiffies check after the puase and resume. This patch is a modified version of the original patch by Jaroslav. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-05ALSA: Add extra delay count in PCMTakashi Iwai
Added runtime->delay field to adjust the delayed samples for snd_pcm_delay(). Typically a hardware FIFO length is stored in this field, so that the extra delay between hwptr and applptr can be computed. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-28ALSA: pcm core - Avoid jiffies check for devices with BATCH flagTakashi Iwai
The hardware devices with SNDRV_PCM_INFO_BATCH flag can't give the precise current position. And such hardwares have often big FIFO in addition to the ring buffer, and it screws up the jiffies check in pcm_lib.c. This patch adds a simple check of info flag so that the driver skips the jiffies check in snd_pcm_period_elapsed() when BATCH flag is set. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-15Merge branch 'topic/memdup_user' into for-linusTakashi Iwai
* topic/memdup_user: ALSA: sound/pci: use memdup_user() ALSA: sound/usb: use memdup_user() ALSA: sound/isa: use memdup_user() ALSA: sound/core: use memdup_user()
2009-04-15Merge branch 'topic/hda' into for-linusTakashi Iwai
* topic/hda: ALSA: hda - Add quirk mask for Fujitsu Amilo laptops with ALC883 ALSA: hda - Avoid call of snd_jack_report at release ALSA: add private_data to struct snd_jack
2009-04-14ALSA: add private_data to struct snd_jackTakashi Iwai
Added private_data and private_free fields to struct snd_jack so that the caller can assign the data. It'll be helpful for avoiding the double-free of the jack instance. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-14ALSA: sound/core: use memdup_user()Li Zefan
Remove open-coded memdup_user(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-10[ALSA] pcm-midlevel: Add more strict buffer position checks based on jiffiesJaroslav Kysela
Some drivers like Intel8x0 or Intel HDA are broken for some hardware variants. This patch adds more strict buffer position checks based on jiffies when internal hw_ptr is updated. Enable xrun_debug to see mangling of wrong positions. As a side effect, the hw_ptr interrupt update routine might do slightly better job when many interrupts are lost. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2009-04-07ALSA: oss - volume control for CSWITCH and CROUTEDeepika Makhija
Added an else part to check SNDRV_MIXER_OSS_PRESENT_CVOLUME for MIC (slot 7) in commit 36c7b833e5d2501142a371e4e75281d3a29fbd6b Similarly, checks and volume control is required for SNDRV_MIXER_OSS_PRESENT_CSWITCH and SNDRV_MIXER_OSS_PRESENT_CROUTE as well. Signed-off-by: Deepika Makhija <deepika.makhija@einfochips.com> Signed-off-by: Viral Mehta <viral.mehta@einfochips.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-26Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: Rationalize fasync return values Move FASYNC bit handling to f_op->fasync() Use f_lock to protect f_flags Rename struct file->f_ep_lock
2009-03-24Merge branch 'topic/misc' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/pcm-cleanup' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/vmaster-update' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/rawmidi-fix' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/ctl-list-cleanup' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/quirk-cleanup' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/jack' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/hwdep-cleanup' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/snd_card_new-err' into for-linusTakashi Iwai
2009-03-20ALSA: pcm - Safer boundary checksTakashi Iwai
Make the boundary checks a bit safer. These caese are rare or theoretically won't happen, but nothing bad to keep the checks safer... Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-19ALSA: pcm - Fix delta calculation at boundary overlapTakashi Iwai
When the hw_ptr_interrupt reaches the boundary, it must check whether the hw_base was already lapped and corret the delta value appropriately. Also, rebasing the hw_ptr needs a correction because buffer_size isn't always aligned to period_size. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-19ALSA: pcm - Reset invalid position even without debug optionTakashi Iwai
Always reset the invalind hw_ptr position returned by the pointer callback. The behavior should be consitent independently from the debug option. Also, add the printk_ratelimit() check to avoid flooding debug prints. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-19ALSA: pcm - avoid unnecessary inlineTakashi Iwai
Remove unnecessary explicit inlininig of internal functions. Let compiler optimize. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-19ALSA: pcm - Fix a typo in error messagesTakashi Iwai
Fix a typo in error messages; forgotten after a copy&paste error. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-18ALSA: Fix vunmap and free order in snd_free_sgbuf_pages()Takashi Iwai
In snd_free_sgbuf_pags(), vunmap() is called after releasing the SG pages, and it causes errors on Xen as Xen manages the pages differently. Although no significant errors have been reported on the actual hardware, this order should be fixed other way round, first vunmap() then free pages. Cc: Jan Beulich <jbeulich@novell.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-18ALSA: pcm_oss, fix locking typoJiri Slaby
s/mutex_lock/mutex_unlock/ on 2 fail paths in snd_pcm_oss_proc_write. Probably a typo, lock should be unlocked when leaving the function. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-18ALSA: oss-mixer - Fixes recording gain controlViral Mehta
At the time of initialization, SNDRV_MIXER_OSS_PRESENT_PVOLUME bit is not set for MIC (slot 7). So, the same should not be checked when an application tries to do gain control for audio recording devices. Just check slot->present for SNDRV_MIXER_OSS_PRESENT_CVOLUME independently. Verified with a simple application which opens /dev/dsp for recording and /dev/mixer for volume control. Have tested two usb audio mic devices. Signed-off-by: Viral Mehta <viral.mehta@einfochips.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-16Rationalize fasync return valuesJonathan Corbet
Most fasync implementations do something like: return fasync_helper(...); But fasync_helper() will return a positive value at times - a feature used in at least one place. Thus, a number of other drivers do: err = fasync_helper(...); if (err < 0) return err; return 0; In the interests of consistency and more concise code, it makes sense to map positive return values onto zero where ->fasync() is called. Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-03-16Use f_lock to protect f_flagsJonathan Corbet
Traditionally, changes to struct file->f_flags have been done under BKL protection, or with no protection at all. This patch causes all f_flags changes after file open/creation time to be done under protection of f_lock. This allows the removal of some BKL usage and fixes a number of longstanding (if microscopic) races. Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
