path: root/sound/core
2012-06-12ALSA: compress_core: cleanup pointers on stopVinod Koul
as the start can be called after stop again, we need to reset state Signed-off-by: Namarta Kohli <namartax.kohli@intel.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-12ALSA: compress_core: don't wake up on pauseVinod Koul
during pause the core should maintain the status-quo on the device and pointers and not wake up. If app needs it should call DROP explcitly. Signed-off-by: Namarta Kohli <namartax.kohli@intel.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-23ALSA: core: group read of pointer, tstamp and jiffiesPierre-Louis Bossart
Group read of hw_ptr, tstamp and jiffies in a sequence for better correlation. Previous code took timestamp at the end, which could introduce delays between audio time and system time. Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-21Merge branch 'topic/misc' into for-linusTakashi Iwai
2012-05-21ALSA: pcm - Add proper state checks to snd_pcm_drain()Takashi Iwai
The handling for some PCM states is missing for snd_pcm_drain(). At least, XRUN streams should be simply dropped to SETUP, and a few initial invalid states should be rejected. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-11ALSA: pcm - Optimize the call of snd_pcm_update_hw_ptr() in read/write loopTakashi Iwai
In the PCM read/write loop, the driver calls snd_pcm_update_hw_ptr() at each time at the beginning of the loop. Russell King reported that this hogs CPU significantly. The current code assumes that the pointer callback is very fast and cheap, also not too much fine grained. It's not true in all cases. When the pointer advances short samples while the read/write copy has been performed, the driver updates the hw_ptr and gets avail > 0 again. Then it tries to read/write these small chunks. This repeats until the avail really gets to zero. For avoiding this situation, a simple workaround is to call snd_pcm_update_hw_ptr() only once at starting the loop, assuming that the read/write copy is performed fast enough. If the available count becomes short, it goes to snd_pcm_wait_avail() anyway, and this processes right. Tested-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-08ALSA: Fix the card number limit of OSS-emulationTakashi Iwai
There are left-over codes from the ancient days with the static device number limitation of 8. Actaully OSS can support up to 16 cards. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-07ALSA: jack: Update documention to reflect other userspace interfacesMark Brown
Since this is a generic API which should support any userspace interface for reporting jacks update the documentation a little to make that a bit clearer. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-18ALSA: fix core/vmaster.c kernel-doc warningRandy Dunlap
Fix kernel-doc warning in sound/core/vmaster.c: Warning(sound/core/vmaster.c:429): No description found for parameter 'private_data' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-03-30Documentation: remove references to /etc/modprobe.confLucas De Marchi
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and is no longer parsed by new kmod tool. References to this file are replaced in Documentation, comments and Kconfig according to the context. There are also some references to the old /etc/modules.conf from 2.4 kernels that are being removed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-24Merge tag 'device-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/device.h> avoidance patches from Paul Gortmaker: "Nearly every subsystem has some kind of header with a proto like: void foo(struct device *dev); and yet there is no reason for most of these guys to care about the sub fields within the device struct. This allows us to significantly reduce the scope of headers including headers. For this instance, a reduction of about 40% is achieved by replacing the include with the simple fact that the device is some kind of a struct. Unlike the much larger module.h cleanup, this one is simply two commits. One to fix the implicit <linux/device.h> users, and then one to delete the device.h includes from the linux/include/ dir wherever possible." * tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: device.h: audit and cleanup users in main include dir device.h: cleanup users outside of linux/include (C files)
2012-03-18Merge branch 'topic/jack' into for-linusTakashi Iwai
2012-03-18Merge branch 'topic/asoc' into for-linusTakashi Iwai
2012-03-18Merge branch 'topic/misc' into for-linusTakashi Iwai
2012-03-15ALSA: pcm - Avoid GFP_ATOMIC in snd_pcm_link()Takashi Iwai
GFP_ATOMIC is used in snd_pcm_link() just because the kmalloc is called inside a lock. Since this function isn't too critical for speed and is rarely called in practice, better to allocate the chunk at first before spinlock and free it in error paths, so that GFP_KERNEL can be used. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-03-15ALSA: pcm: Constify the list in snd_pcm_hw_constraint_listMark Brown
Allows the constraint lists to be declared const by drivers which seems reasonable; there's plenty of other constification we could do if we were being complete but this was easy and quick. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-03-13ALSA: control - Fixe a trailing white space errorJeffrin Jose
Fixed a trailing white space error detected in sound/core/control.c by checkpatch.pl script. Signed-off-by: Jeffrin Jose <ahiliation@yahoo.co.in> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-03-12ALSA: Add a hook capability to vmaster controlsTakashi Iwai
This patch adds a hook to vmaster control to be called at each time when the master value is changed. It'd be handy for an additional mute LED control following the Master switch, for example. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-03-11device.h: cleanup users outside of linux/include (C files)Paul Gortmaker
For files that are actively using linux/device.h, make sure that they call it out. This will allow us to clean up some of the implicit uses of linux/device.h within include/* without introducing build regressions. Yes, this was created by "cheating" -- i.e. the headers were cleaned up, and then the fallout was found and fixed, and then the two commits were reordered. This ensures we don't introduce build regressions into the git history. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-03-09ALSA: core - Refactor card id string creation codeTakashi Iwai
The code to handle the card id string is fairly messy, so here is a tidy up. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-27ALSA: Use a define for the number of jack switch typesMark Brown
This is intended to facilitate the merge of the two jack detection mechanisms. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-20ALSA: Fixed a trailing white space errorJeffrin Jose
This is a patch to the sound/core/misc.c file that fixes up a trailing white space issue found by the checkpatch.pl tool. Signed-off-by: Jeffrin Jose <ahiliation@yahoo.co.in> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-09ALSA: PCM - Add PCM creation API for internal PCMs.Liam Girdwood
The new ASoC dynamic PCM core needs to create PCMs and substreams that are for use by internal ASoC drivers only and not visible to userspace for direct IO. These new PCMs are similar to regular PCMs expect they have no device nodes or procfs entries. The ASoC component drivers use them in exactly the same way as regular PCMs for PCM and DAI operations. The intention is that a dynamic PCM based driver will register both regular PCMs and internal PCMs. The regular PCMs will be used for all IO with userspace however the internal PCMs will be used by the driver to route digital audio through numerous back end DAI links (with potentially a DSP providing different hw_params, DAI formats based on the regular front end PCM params) to devices like CODECs, MODEMs, Bluetooth, FM, DMICs, etc This patch adds a new snd_pcm_new_internal() API call to create the internal PCM without device nodes or procfs. It also adds adds a new internal flag to snd_pcm. [fixed minor coding-style issues by tiwai] Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-01-31Merge branch 'fix/asoc' into for-linusTakashi Iwai
2012-01-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Fix silent output on Haier W18 laptop ALSA: hda: set mute led polarity for laptops with buggy BIOS based on SSID ALSA: hda - Fix silent output on ASUS A6Rp ALSA: Fix memory leak on error in snd_compr_set_params() ALSA: ymfpci - Don't create invalid PCM & mixers when AC97 doesn't support
2012-01-24ALSA: Fix memory leak on error in snd_compr_set_params()Jesper Juhl
If copy_from_user() does not return 0 we'll leak the memory we allocated for 'params' when that variable goes out of scope. Also a small CodingStyle cleanup: Use braces on both branches of if/else when one branch needs it. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Vinod Koul <vinod.koul@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-01-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: virtuoso: Xonar DS: fix polarity of front output ALSA: Au88x0 - Reduce the number of playback subdevices of au8830 from 32 to 16 ALSA: Au88x0 - Support 4 channels playback when AC97 codecs has SDAC bit ALSA: HDA: Fix internal microphone on Dell Studio 16 XPS 1645 ALSA: Don't prompt for CONFIG_SND_COMPRESS_OFFLOAD ALSA: HDA: Use LPIB position fix for Macbook Pro 7,1
2012-01-13ALSA: Don't prompt for CONFIG_SND_COMPRESS_OFFLOADTakashi Iwai
CONFIG_SND_COMPRESS_OFFLOAD is an item to be selected by the dirver just like CONFIG_SND_PCM, and no need to prompt for explicit selection. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-01-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (526 commits) ASoC: twl6040 - Add method to query optimum PDM_DL1 gain ALSA: hda - Fix the lost power-setup of seconary pins after PM resume ALSA: usb-audio: add Yamaha MOX6/MOX8 support ALSA: virtuoso: add S/PDIF input support for all Xonars ALSA: ice1724 - Support for ooAoo SQ210a ALSA: ice1724 - Allow card info based on model only ALSA: ice1724 - Create capture pcm only for ADC-enabled configurations ALSA: hdspm - Provide unique driver id based on card serial ASoC: Dynamically allocate the rtd device for a non-empty release() ASoC: Fix recursive dependency due to select ATMEL_SSC in SND_ATMEL_SOC_SSC ALSA: hda - Fix the detection of "Loopback Mixing" control for VIA codecs ALSA: hda - Return the error from get_wcaps_type() for invalid NIDs ALSA: hda - Use auto-parser for HP laptops with cx20459 codec ALSA: asihpi - Fix potential Oops in snd_asihpi_cmode_info() ALSA: hdsp - Fix potential Oops in snd_hdsp_info_pref_sync_ref() ALSA: hda/cirrus - support for iMac12,2 model ASoC: cx20442: add bias control over a platform provided regulator ALSA: usb-audio - Avoid flood of frame-active debug messages ALSA: snd-usb-us122l: Delete calls to preempt_disable mfd: Put WM8994 into cache only mode when suspending ... Fix up trivial conflicts in: - arch/arm/mach-s3c64xx/mach-crag6410.c: renamed speyside_wm8962 to tobermory, added littlemill right next to it - drivers/base/regmap/{regcache.c,regmap.c}: duplicate diff that had already come in with other changes in the regmap tree
2012-01-12Merge branch 'topic/hda' into for-linusTakashi Iwai
2011-12-23ALSA: core: add makefile and kconfig file for compressVinod Koul
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com> Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-23ALSA: core: add support for compress_offloadVinod Koul
This patch adds core.c, the file which implements the ioctls and registers the devices Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com> Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-23ALSA: core: add support for compressed devicesOmair Mohammed Abdullah
Use the minor numbers 2 and 3 for audio compressed offload devices. Also add support for these devices in core Signed-off-by: Omair Mohammed Abdullah <omair.m.abdullah@intel.com> Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-19ALSA: module_param: make bool parameters really boolRusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-16ALSA: hda - Add missing inclusion of linux/export.hTakashi Iwai
This is needed newly since 3.2... Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-16ALSA: Introduce common helper functions for jack-detection controlTakashi Iwai
Now move the helper function for creating and reporting the jack-detection to the common place. The driver that needs this functionality should select CONFIG_SND_KCTL_JACK kconfig. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-13drop "select GCD" from three Kconfig filesPaul Bolle
There is no Kconfig symbol named GCD. The three select statements for that symbol are nops. Drop these. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-10ALSA: vmaster - Free slave-links when freeing the master elementTakashi Iwai
When freeing the vmaster master element, we should release slave-links properly, not only assumig that slaves will be freed soon later. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Revert the check of NO_PRESENCE pincfg default bit ALSA: hda - Fix a regression for DMA-position check with CA0110 ALSA: hda - Fix silent output regression with ALC861 ALSA: control: remove compilation warning on 32-bit ALSA: ua101: fix crash when unplugging
2011-11-06ALSA: control: remove compilation warning on 32-bitOlof Johansson
This was introduced by 'ALSA: control: add support for ENUMERATED user space controls' which adds a u64 variable that gets cast to a pointer: sound/core/control.c: In function 'snd_ctl_elem_init_enum_names': sound/core/control.c:1089: warning: cast to pointer from integer of different size Cast to uintptr_t before casting to pointer to avoid the warning. Signed-off-by: Olof Johansson <olof@lixom.net> [cl: replace long with uintptr_t] Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (24 commits) ALSA: hda/realtek - Skip invalid digital out pins ALSA: hda/sigmatel - Automatically retrieve digital I/O widgets ALSA: hda - Remove unused variables ALSA: hda/realtek - Don't create alt-stream for capture when unnecessary ALSA: hda - Add support for 92HD65 / 92HD66 family of codecs ALSA: hda - Disable power-widget control for IDT 92HD83/93 as default ALSA: hda - Check NO_PRESENCE pincfg default bit ASoC: Ensure we always delay for WM8962 FLL when starting from SYSCLK ASoC: Ensure the WM8962 oscillator and PLLs start up disabled ASoC: Ensure WM8962 PLL registers are reset ALSA: intel8x0 - Fix inclusion of kvm_para.h ALSA: hda_hwdep: Fix possible buffer overflow ASoC: Fix return value of wm5100_gpio_direction_out() ASoC: WM8904: Set `invert' bit for Capture Switch ASoC: Leave input audio data bit length settings untouched in wm8711_set_dai_fmt ASoC: wm8711: Fix wrong mask for setting input audio data bit length select ALSA: intel8x0: Improve performance in virtual environment ALSA: hdspm - Enable all firmware ranges for PCI MADI/AES cards ALSA: hdsp - Correct HDSP_VERSION_BIT constant, thus partly fixing RPM detection ALSA: hdspm - Fix MADI channel format in the status ioctl ...
2011-10-31sound: Add export.h for THIS_MODULE/EXPORT_SYMBOL where neededPaul Gortmaker
These aren't modules, but they do make use of these macros, so they will need export.h to get that definition. Previously, they got it via the implicit module.h inclusion. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31sound: Add module.h to the previously silent sound usersPaul Gortmaker
Lots of sound drivers were getting module.h via the implicit presence of it in <linux/device.h> but we are going to clean that up. So fix up those users now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31sound: add moduleparam.h to users of module_param/MODULE_PARM_DESCPaul Gortmaker
These files were getting access to these two via the implicit presence of moduleparam.h everywhere. But that is being fixed, so get these guys what they need in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31sound: fix drivers needing module.h not moduleparam.hPaul Gortmaker
The implicit presence of module.h lured several users into incorrectly thinking that they only needed/used modparam.h but once we clean up the module.h presence, these will show up as build failures, so fix 'em now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31ALSA: hwdep: silence integer overflow warningDan Carpenter
Smatch complains that if device is INT_MAX then device + 1 can overflow. It just means we would have an annoying loop while we check all the devices from -2147483648 to SNDRV_MINOR_HWDEPS. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-10-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (549 commits) ALSA: hda - Fix ADC input-amp handling for Cx20549 codec ALSA: hda - Keep EAPD turned on for old Conexant chips ALSA: hda/realtek - Fix missing volume controls with ALC260 ASoC: wm8940: Properly set codec->dapm.bias_level ALSA: hda - Fix pin-config for ASUS W90V ALSA: hda - Fix surround/CLFE headphone and speaker pins order ALSA: hda - Fix typo ALSA: Update the sound git tree URL ALSA: HDA: Add new revision for ALC662 ASoC: max98095: Convert codec->hw_write to snd_soc_write ASoC: keep pointer to resource so it can be freed ASoC: sgtl5000: Fix wrong mask in some snd_soc_update_bits calls ASoC: wm8996: Fix wrong mask for setting WM8996_AIF_CLOCKING_2 ASoC: da7210: Add support for line out and DAC ASoC: da7210: Add support for DAPM ALSA: hda/realtek - Fix DAC assignments of multiple speakers ASoC: Use SGTL5000_LINREG_VDDD_MASK instead of hardcoded mask value ASoC: Set sgtl5000->ldo in ldo_regulator_register ASoC: wm8996: Use SND_SOC_DAPM_AIF_OUT for AIF2 Capture ASoC: wm8994: Use SND_SOC_DAPM_AIF_OUT for AIF3 Capture ...
2011-10-26Merge branch 'topic/misc' into for-linusTakashi Iwai
2011-10-25Merge branch 'pm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm * 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (63 commits) PM / Clocks: Remove redundant NULL checks before kfree() PM / Documentation: Update docs about suspend and CPU hotplug ACPI / PM: Add Sony VGN-FW21E to nonvs blacklist. ARM: mach-shmobile: sh7372 A4R support (v4) ARM: mach-shmobile: sh7372 A3SP support (v4) PM / Sleep: Mark devices involved in wakeup signaling during suspend PM / Hibernate: Improve performance of LZO/plain hibernation, checksum image PM / Hibernate: Do not initialize static and extern variables to 0 PM / Freezer: Make fake_signal_wake_up() wake TASK_KILLABLE tasks too PM / Hibernate: Add resumedelay kernel param in addition to resumewait MAINTAINERS: Update linux-pm list address PM / ACPI: Blacklist Vaio VGN-FW520F machine known to require acpi_sleep=nonvs PM / ACPI: Blacklist Sony Vaio known to require acpi_sleep=nonvs PM / Hibernate: Add resumewait param to support MMC-like devices as resume file PM / Hibernate: Fix typo in a kerneldoc comment PM / Hibernate: Freeze kernel threads after preallocating memory PM: Update the policy on default wakeup settings PM / VT: Cleanup #if defined uglyness and fix compile error PM / Suspend: Off by one in pm_suspend() PM / Hibernate: Include storage keys in hibernation image on s390 ...
