path: root/sound/drivers/Makefile
2008-04-24[ALSA] Add PC-speaker sound driverStas Sergeev
Added PC-speaker sound driver (snd-pcsp). Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Xilinx ML403 AC97 Controller Reference device driverJoachim Foerster
Add ALSA support for the opb_ac97_controller_ref_v1_00_a ip core found in Xilinx' ML403 reference design. Known issue: Currently this driver hits a WARN_ON_ONCE(1) statement in kernel/irq/resend.c (line 70). According to Linus (http://lkml.org/lkml/2007/8/5/5) this may be ignored, right? I haven't had a look into this 'problem' yet. Signed-off-by: Joachim Foerster <JOFT@gmx.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-02-09[ALSA] Add snd-portman2x4 driver for Midiman Portman 2x4 MIDI deviceMatthias Koenig
snd-portman2x4 driver supports Midiman Portman 2x4 parallel port MIDI device. Signed-off-by: Matthias Koenig <mkoenig@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Add snd-mts64 driver for ESI Miditerminal 4140Matthias Koenig
Added snd-mts64 driver for Ego Systems (ESI) Miditerminal 4140 by Matthias Koenig <mk@phasorlab.de>. The driver requires parport (CONFIG_PARPORT). Signed-off-by: Matthias Koenig <mk@phasorlab.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
