Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details you
should have received a copy of the gnu general public license along
with this program if not write to the free software foundation inc
59 temple place suite 330 boston ma 02111 1307 usa
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1334 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.113240726@linutronix.de
snd_pcm_ops are not supposed to change at runtime. All functions
working with snd_pcm_ops provided by <sound/pcm.h> work with
const snd_pcm_ops. So mark the non-const structs as const.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Make these const as they are only used in a copy operation.
Done using Coccinelle.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
The iounmap() function performs also input parameter validation.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
snd_ml403_ac97cr_pcm() takes a pointer to a pointer of a PCM where if this
parameter is provided the newly allocated PCM is stored. All callers pass
NULL though, so remove the parameter. This makes the code a bit cleaner and
shorter.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Also remove superfluous snd_card_set_dev() calls.
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no
driver is bound) removes the need to set driver data field to
NULL.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
This patch converts the drivers in sound/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
The implicit presence of module.h lured several users into
incorrectly thinking that they only needed/used modparam.h
but once we clean up the module.h presence, these will show
up as build failures, so fix 'em now.
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled],
We run all interrupt handlers with interrupts disabled
and we even check and yell when an interrupt handler
returns with interrupts enabled (see commit [b738a50a:
genirq: Warn when handler enables interrupts]).
So now this flag is a NOOP and can be removed.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Convert from snd_card_new() to the new snd_card_create() function
in other sound subdirectories.
[stripped sound/isa/* changes, replaced with the next patch -- tiwai]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is
prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable sound
platform drivers, to re-enable auto loading.
[dbrownell@users.sourceforge.net: more drivers, registration fixes]
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
We want to have snd_card_set_dev() in _probe(), but not a second one in
snd_ml403_ac97cr_create().
Signed-off-by: Joachim Foerster <JOFT@gmx.de>
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Added the missing call of snd_card_set_dev() in drivers/*
We have to do fairly accurate counting of the minimal periods, instead
of being lazy and just setting the number to zero as soon as one period
elapses.
Add ALSA support for the opb_ac97_controller_ref_v1_00_a ip core found
in Xilinx' ML403 reference design.
Known issue: Currently this driver hits a WARN_ON_ONCE(1) statement in
kernel/irq/resend.c (line 70). According to Linus
(http://lkml.org/lkml/2007/8/5/5) this may be ignored, right? I haven't
had a look into this 'problem' yet.
