path: root/sound/drivers/mtpav.c
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 156Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details you should have received a copy of the gnu general public license along with this program if not write to the free software foundation inc 59 temple place suite 330 boston ma 02111 1307 usa extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 1334 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Richard Fontana <rfontana@redhat.com> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070033.113240726@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-24ALSA: drivers: Convert timers to use timer_setup()Kees Cook
In preparation for unconditionally passing the struct timer_list pointer to all timer callbacks, switch to using the new timer_setup() and from_timer() to pass the timer pointer explicitly. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2017-04-20Annotate hardware config module parameters in sound/drivers/David Howells
When the kernel is running in secure boot mode, we lock down the kernel to prevent userspace from modifying the running kernel image. Whilst this includes prohibiting access to things like /dev/mem, it must also prevent access by means of configuring driver modules in such a way as to cause a device to access or modify the kernel image. To this end, annotate module_param* statements that refer to hardware configuration and indicate for future reference what type of parameter they specify. The parameter parser in the core sees this information and can skip such parameters with an error message if the kernel is locked down. The module initialisation then runs as normal, but just sees whatever the default values for those parameters is. Note that we do still need to do the module initialisation because some drivers have viable defaults set in case parameters aren't specified and some drivers support automatic configuration (e.g. PNP or PCI) in addition to manually coded parameters. This patch annotates drivers in sound/drivers/. Suggested-by: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Takashi Iwai <tiwai@suse.de> cc: Jaroslav Kysela <perex@perex.cz> cc: alsa-devel@alsa-project.org
2017-01-12ALSA: drivers: Constify snd_rawmidi_opsTakashi Iwai
Now snd_rawmidi_ops is maintained as a const pointer in snd_rawmidi, we can constify the definitions. Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-01-19ALSA: mtpav: Use setup_timer() and mod_timer()Takashi Iwai
No functional change, refactoring with the standard helpers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-10-20ALSA: drivers: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-02-12ALSA: drivers: Convert to snd_card_new() with a device pointerTakashi Iwai
Also remove superfluous snd_card_set_dev() calls. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-23ALSA: mtpav: Remove redundant platform_set_drvdata()Sachin Kamat
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no driver is bound) removes the need to set driver data field to NULL. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-07ALSA: drivers: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-02ALSA: Add missing .owner=THIS_MODULE to platform_driver definitionsTakashi Iwai
2011-10-31sound: Add module.h to the previously silent sound usersPaul Gortmaker
Lots of sound drivers were getting module.h via the implicit presence of it in <linux/device.h> but we are going to clean that up. So fix up those users now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-22sound: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-02ALSA: use linux/io.h to fix compile warningsTakashi Iwai
For helping to reduce Greert's regression list... src/sound/drivers/mtpav.c: error: implicit declaration of function 'inb' src/sound/drivers/mtpav.c: error: implicit declaration of function 'outb' ... Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-03-24Merge branch 'topic/misc' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/snd_card_new-err' into for-linusTakashi Iwai
2009-02-12ALSA: mtpav - Fix initial value for input hwportTakashi Iwai
Fix the initial value for input hwport. The old value (-1) may cause Oops when an realtime MIDI byte is received before the input port is explicitly given. Instead, now it's set to the broadcasting as default. Tested-by: Holger Dehnhardt <dehnhardt@ahdehnhardt.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-05ALSA: Add missing KERN_* prefix to printk in sound/driversTakashi Iwai
2009-01-12ALSA: Convert to snd_card_create() in other sound/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in other sound subdirectories. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-10ALSA: mtpav - Fix race in probeTakashi Iwai
Ingo reported Oops at probing mtpav driver. It's a race between the irq handler and the rawmidi instance registration. This patch fixes the order of registration to avoid the race. Signed-off-by: Takashi Iwai <tiwai@suse.de> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-02-14[ALSA] Fix __devinit and __devexit issues with sound driversPrarit Bhargava
Fix __devinit and __devexit issues with sound drivers. Resolves MODPOST warnings similar to: WARNING: sound/drivers/snd-dummy.o - Section mismatch: reference to .init.text:snd_dummy_probe from .data.rel.local between 'snd_dummy_driver' (at offset 0x0) and 'snd_dummy_controls' WARNING: sound/drivers/snd-mtpav.o - Section mismatch: reference to .init.text:snd_mtpav_probe from .data.rel.local between 'snd_mtpav_driver' (at offset 0x0) and 'snd_mtpav_input' WARNING: sound/drivers/snd-virmidi.o - Section mismatch: reference to .init.text:snd_virmidi_probe from .data.rel.local after 'snd_virmidi_driver' (at offset 0x0) Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[ALSA] unregister platform device again if probe was unsuccessfulRene Herman
This second one unregisters the platform device again when the probe is unsuccesful for sound/drivers, sound/arm/sa11xx-uda1341.c and sound/ppc/powermac.c. This gets them all. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] unregister platform devicesClemens Ladisch
Call platform_device_unregister() for all platform devices that we've registered. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] mtpav - Use platform_deviceTakashi Iwai
Modules: Generic drivers Rewrite the probe/remove code using platform_device. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: Generic driversTakashi Iwai
Modules: Generic drivers Remove xxx_t typedefs from the generic drivers (dummy, mtpav, serial-u16550 and virmidi). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove vmalloc wrapper, kfree_nocheck()Takashi Iwai
- Remove vmalloc wrapper - Add release_and_free_resource() to remove kfree_nocheck() from each driver and simplify the code Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Replace with kzalloc() - othersTakashi Iwai
Documentation,SA11xx UDA1341 driver,Generic drivers,MPU401 UART,OPL3 OPL4,Digigram VX core,I2C cs8427,I2C lib core,I2C tea6330t,L3 drivers AK4114 receiver,AK4117 receiver,PDAudioCF driver,PPC PMAC driver SPARC AMD7930 driver,SPARC cs4231 driver,Synth,Common EMU synth USB generic driver,USB USX2Y Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Add snd_card_set_generic_dev() callTakashi Iwai
ARM,SA11xx UDA1341 driver,Generic drivers,MPU401 UART,MIPS MIPS AU1x00 driver,PPC,PPC PowerMac driver,SPARC,SPARC AMD7930 driver SPARC cs4231 driver,SPARC DBRI driver - Added snd_card_set_generic_dev() call. - Added SND_GENERIC_DRIVER to Kconfig. - Clean up the error path in probe if necessary. Signed-off-by: Takashi Iwai <tiwai@suse.de>
