path: root/sound/drivers/pcsp/pcsp.c
2009-11-01ALSA: snd-pcsp: add nopcm modeStas Sergeev
Currently, if the high-res timers are unavailable, snd-pcsp does not initialize. People who choose it over pcspkr, loose their console beeps in that case and get annoyed. With this patch, the console beeps remain regardless of the high-res timers. Additionally, the "nopcm" modparam is added to forcibly disable the PCM capabilities of the driver. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-24Merge branch 'topic/misc' into for-linusTakashi Iwai
2009-02-05ALSA: Add missing KERN_* prefix to printk in sound/driversTakashi Iwai
2009-01-12ALSA: Convert to snd_card_create() in other sound/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in other sound subdirectories. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-30Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: hrtimers: fix warning in kernel/hrtimer.c x86: make sure we really have an hpet mapping before using it x86: enable HPET on Fujitsu u9200 linux/timex.h: cleanup for userspace posix-timers: simplify de_thread()->exit_itimers() path posix-timers: check ->it_signal instead of ->it_pid to validate the timer posix-timers: use "struct pid*" instead of "struct task_struct*" nohz: suppress needless timer reprogramming clocksource, acpi_pm.c: put acpi_pm_read_slow() under CONFIG_PCI nohz: no softirq pending warnings for offline cpus hrtimer: removing all ur callback modes, fix hrtimer: removing all ur callback modes, fix hotplug hrtimer: removing all ur callback modes x86: correct link to HPET timer specification rtc-cmos: export second NVRAM bank Fixed up conflicts in sound/drivers/pcsp/pcsp.c and sound/core/hrtimer.c manually.
2008-11-25hrtimer: removing all ur callback modesPeter Zijlstra
Impact: cleanup, move all hrtimer processing into hardirq context This is an attempt at removing some of the hrtimer complexity by reducing the number of callback modes to 1. This means that all hrtimer callback functions will be ran from HARD-irq context. I went through all the 30 odd hrtimer callback functions in the kernel and saw only one that I'm not quite sure of, which is the one in net/can/bcm.c - hence I'm CC-ing the folks responsible for that code. Furthermore, the hrtimer core now calls callbacks directly with IRQs disabled in case you try to enqueue an expired timer. If this timer is a periodic timer (which should use hrtimer_forward() to advance its time) then it might be possible to end up in an inf. recursive loop due to the fact that hrtimer_forward() doesn't round up to the next timer granularity, and therefore keeps on calling the callback - obviously this needs a fix. Aside from that, this seems to compile and actually boot on my dual core test box - although I'm sure there are some bugs in, me not hitting any makes me certain :-) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-14ALSA: pcsp - Use HRTIMER_CB_IRQSAFE_UNLOCKEDTakashi Iwai
HRTIMER_CB_IRQSAFE was removed in the upstream. Try to use HRTIMER_CB_IRQSAFE_UNLOCKED instead. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-20ALSA: pcsp - Fix locking messes in snd-pcspTakashi Iwai
snd-pcsp driver takes chip->substream_lock together with PCM substream lock. These are even mixed up with hrtimer's lock, resulting in messy lock depencies. Right now, snd-pcsp driver resolves the deadlock by using HRTIMER_CB_SOFTIRQ. However, this isn't nice for a really fast path like bit-flipping. This patch introduces a tasklet for PCM period handling so that the hrtimer callback can be handled fast. This also reduce the use of chip->substream_lock to avoid deadlocks. It's still used in pointer callback, but even this could be removed with a proper barrier. Another good solution is to introduce async trigger callback. But, this will involve with a major rewrite of the PCM core code, so I take first this easy fix. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-20snd-pcsp: use HRTIMER_CB_SOFTIRQStas Sergeev
Change HRTIMER_CB_IRQSAFE to HRTIMER_CB_SOFTIRQ, as suggested by Thomas Gleixner. That solves the lock dependancy reported in Bug #10701. That also allows to call hrtimer_start() directly, tasklet "stupid hack" removed. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-05[ALSA] pcsp: Fix build with CONFIG_PM=nJohann Felix Soden
sound/drivers/pcsp/pcsp.c: In function 'pcsp_suspend': sound/drivers/pcsp/pcsp.c:201: error: implicit declaration of function 'snd_pcm_suspend_all' Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net> CC: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] pcsp: fix wording in DEBUG_PAGEALLOC warningStas Sergeev
Signed-off-by: Stas Sergeev <stsp@aknet.ru> (fixed invalid KERN_WARNING by tiwai) Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound/drivers/pcsp/pcsp.c build fixMariusz Kozlowski
sound/drivers/pcsp/pcsp.c: In function 'snd_pcsp_create': sound/drivers/pcsp/pcsp.c:54: error: 'loops_per_jiffy' undeclared (first use in\ this function) sound/drivers/pcsp/pcsp.c:54: error: (Each undeclared identifier is reported on\ ly once sound/drivers/pcsp/pcsp.c:54: error: for each function it appears in.) Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] pcsp: locking fixStas Sergeev
pcsp: locking fix. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] pcsp: improve "enable" option handlingStas Sergeev
Simplify init code. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] pcsp - clean upsStas Sergeev
- make pcsp_start_timer_tasklet static - remove redundant includes. <asm/i8253.h> is not available on all platforms. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Add PC-speaker sound driverStas Sergeev
Added PC-speaker sound driver (snd-pcsp). Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
