path: root/sound/drivers/pcsp/pcsp.h
2008-11-26ALSA: pcsp - Fix starting the stream with HRTIMER_CB_IRQSAFE_UNLOCKTakashi Iwai
With the callback mode HRTIMER_CB_IRQSAFE_UNLOCK, the start of the stream with zero delay doesn't work. Since IRQSAFE mode is removed, we have to change the pcsp start-up code. This patch splits the callback function to two parts, the triggering of the port and the calculation of the expire time, and the update of the ALSA PCM core. The first part is called both from the trigger-start and the hrtimer callback while the latter is handled only in the hrtimer callback. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-20ALSA: pcsp - Fix locking messes in snd-pcspTakashi Iwai
snd-pcsp driver takes chip->substream_lock together with PCM substream lock. These are even mixed up with hrtimer's lock, resulting in messy lock depencies. Right now, snd-pcsp driver resolves the deadlock by using HRTIMER_CB_SOFTIRQ. However, this isn't nice for a really fast path like bit-flipping. This patch introduces a tasklet for PCM period handling so that the hrtimer callback can be handled fast. This also reduce the use of chip->substream_lock to avoid deadlocks. It's still used in pointer callback, but even this could be removed with a proper barrier. Another good solution is to introduce async trigger callback. But, this will involve with a major rewrite of the PCM core code, so I take first this easy fix. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-25[ALSA] snd-pcsp - fix pcsp_treble_info() to honour an item numberStas Sergeev
This solves the problem with mixers wrongly displaying the PWM freq. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Add PC-speaker sound driverStas Sergeev
Added PC-speaker sound driver (snd-pcsp). Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
