path: root/sound/drivers/pcsp
2011-06-09i8253: Make pcsp sound driver use the shared i8253_lockRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Jaroslav Kysela <perex@perex.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: alsa-devel@alsa-project.org Link: http://lkml.kernel.org/r/20110601180610.532642190@duck.linux-mips.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-06-09i8253: Create linux/i8253.h and use it in all 8253 related filesRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Link: http://lkml.kernel.org/r/20110601180610.054254048@duck.linux-mips.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de> arch/arm/mach-footbridge/isa-timer.c | 2 +- arch/mips/cobalt/time.c | 2 +- arch/mips/jazz/irq.c | 2 +- arch/mips/kernel/i8253.c | 2 +- arch/mips/mti-malta/malta-time.c | 2 +- arch/mips/sgi-ip22/ip22-time.c | 2 +- arch/mips/sni/time.c | 2 +- arch/x86/kernel/apic/apic.c | 2 +- arch/x86/kernel/apm_32.c | 2 +- arch/x86/kernel/hpet.c | 2 +- arch/x86/kernel/i8253.c | 2 +- arch/x86/kernel/time.c | 2 +- drivers/block/hd.c | 2 +- drivers/clocksource/i8253.c | 2 +- drivers/input/gameport/gameport.c | 2 +- drivers/input/joystick/analog.c | 2 +- drivers/input/misc/pcspkr.c | 2 +- include/linux/i8253.h | 11 +++++++++++ sound/drivers/pcsp/pcsp.h | 2 +- 19 files changed, 29 insertions(+), 18 deletions(-)
2010-05-03Merge commit 'v2.6.34-rc6' into core/lockingIngo Molnar
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-02i8253: Convert i8253_lock to raw_spinlockThomas Gleixner
i8253_lock needs to be a real spinlock in preempt-rt, i.e. it can not be converted to a sleeping lock. Convert it to raw_spinlock and fix up all users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Jens Axboe <jens.axboe@oracle.com> LKML-Reference: <20100217163751.030764372@linutronix.de>
2009-11-05ALSA: rename "PC Speaker" and "PC Beep" controls to "Beep"Jaroslav Kysela
To avoid confusion in control names for the standard analog PC Beep generator using a small Internal PC Speaker, rename all related "PC Speaker" and "PC Beep" controls to "Beep" only. This name is more universal and can be also used on more platforms without confusion. Introduce also "Internal Speaker" in ControlNames.txt for systems with full-featured build-in internal speaker. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-01ALSA: snd-pcsp: add nopcm modeStas Sergeev
Currently, if the high-res timers are unavailable, snd-pcsp does not initialize. People who choose it over pcspkr, loose their console beeps in that case and get annoyed. With this patch, the console beeps remain regardless of the high-res timers. Additionally, the "nopcm" modparam is added to forcibly disable the PCM capabilities of the driver. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-30ALSA: pcsp - Fix nforce workaroundStas Sergeev
The attached patch fixes the problems introduced in this commit: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=eea0579fc85e64e9f05361d5aacf496fe7a151aa - Fix nForce workaround by honouring the pointer_update var - Revert "ns" to u64, as per the hrtimer API - Revert to the zero-delay timer startup, since I can't reproduce any problem with it (please, give me the hint!) Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-16time: move PIT_TICK_RATE to linux/timex.hArnd Bergmann
PIT_TICK_RATE is currently defined in four architectures, but in three different places. While linux/timex.h is not the perfect place for it, it is still a reasonable replacement for those drivers that traditionally use asm/timex.h to get CLOCK_TICK_RATE and expect it to be the PIT frequency. Note that for Alpha, the actual value changed from 1193182UL to 1193180UL. This is unlikely to make a difference, and probably can only improve accuracy. There was a discussion on the correct value of CLOCK_TICK_RATE a few years ago, after which every existing instance was getting changed to 1193182. According to the specification, it should be 1193181.818181... Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Len Brown <lenb@kernel.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-20ALSA: pcsp - fix printk format warning againTakashi Iwai
The commit 5a641bcd6398841cc4606b0a732d41a09256fd94 changed the printk format to '%lu', but the value passed seems to be dependent on the architecture. On x86-64, I got a new warning now because an int value is passed actaully. As a workaround, just cast the value always to unsigned long. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-14ALSA: pcsp: fix printk format warningRandy Dunlap
Fix printk format warning: sound/drivers/pcsp/pcsp_mixer.c:54: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-24Merge branch 'topic/misc' into for-linusTakashi Iwai
2009-02-05ALSA: Add missing KERN_* prefix to printk in sound/driversTakashi Iwai
2009-01-12ALSA: Convert to snd_card_create() in other sound/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in other sound subdirectories. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-30Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: hrtimers: fix warning in kernel/hrtimer.c x86: make sure we really have an hpet mapping before using it x86: enable HPET on Fujitsu u9200 linux/timex.h: cleanup for userspace posix-timers: simplify de_thread()->exit_itimers() path posix-timers: check ->it_signal instead of ->it_pid to validate the timer posix-timers: use "struct pid*" instead of "struct task_struct*" nohz: suppress needless timer reprogramming clocksource, acpi_pm.c: put acpi_pm_read_slow() under CONFIG_PCI nohz: no softirq pending warnings for offline cpus hrtimer: removing all ur callback modes, fix hrtimer: removing all ur callback modes, fix hotplug hrtimer: removing all ur callback modes x86: correct link to HPET timer specification rtc-cmos: export second NVRAM bank Fixed up conflicts in sound/drivers/pcsp/pcsp.c and sound/core/hrtimer.c manually.
2008-11-26ALSA: pcsp - Fix starting the stream with HRTIMER_CB_IRQSAFE_UNLOCKTakashi Iwai
With the callback mode HRTIMER_CB_IRQSAFE_UNLOCK, the start of the stream with zero delay doesn't work. Since IRQSAFE mode is removed, we have to change the pcsp start-up code. This patch splits the callback function to two parts, the triggering of the port and the calculation of the expire time, and the update of the ALSA PCM core. The first part is called both from the trigger-start and the hrtimer callback while the latter is handled only in the hrtimer callback. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-26Merge branch 'topic/misc' into topic/pcsp-fixTakashi Iwai
Conflicts: sound/drivers/pcsp/pcsp_lib.c
2008-11-25hrtimer: removing all ur callback modesPeter Zijlstra
Impact: cleanup, move all hrtimer processing into hardirq context This is an attempt at removing some of the hrtimer complexity by reducing the number of callback modes to 1. This means that all hrtimer callback functions will be ran from HARD-irq context. I went through all the 30 odd hrtimer callback functions in the kernel and saw only one that I'm not quite sure of, which is the one in net/can/bcm.c - hence I'm CC-ing the folks responsible for that code. Furthermore, the hrtimer core now calls callbacks directly with IRQs disabled in case you try to enqueue an expired timer. If this timer is a periodic timer (which should use hrtimer_forward() to advance its time) then it might be possible to end up in an inf. recursive loop due to the fact that hrtimer_forward() doesn't round up to the next timer granularity, and therefore keeps on calling the callback - obviously this needs a fix. Aside from that, this seems to compile and actually boot on my dual core test box - although I'm sure there are some bugs in, me not hitting any makes me certain :-) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-14ALSA: pcsp - Use HRTIMER_CB_IRQSAFE_UNLOCKEDTakashi Iwai
HRTIMER_CB_IRQSAFE was removed in the upstream. Try to use HRTIMER_CB_IRQSAFE_UNLOCKED instead. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-07Merge branch 'topic/fix/misc' into topic/miscTakashi Iwai
2008-11-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda: make a STAC_DELL_EQ option ALSA: emu10k1 - Add more invert_shared_spdif flag to Audigy models ALSA: hda - Add a quirk for another Acer Aspire (1025:0090) ALSA: remove direct access of dev->bus_id in sound/isa/* sound: struct device - replace bus_id with dev_name(), dev_set_name() ALSA: Fix PIT lockup on some chipsets when using the PC-Speaker ALSA: rawmidi - Add open check in rawmidi callbacks ALSA: hda - Add digital-mic for ALC269 auto-probe mode ALSA: hda - Disable broken mic auto-muting in Realtek codes
2008-11-03ALSA: Fix PIT lockup on some chipsets when using the PC-SpeakerZoltan Devai
Fix PIT lockup on some chipsets when using the PC-Speaker. Signed-off-by: Zoltan Devai <zdevai@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-20ALSA: pcsp - Fix locking messes in snd-pcspTakashi Iwai
snd-pcsp driver takes chip->substream_lock together with PCM substream lock. These are even mixed up with hrtimer's lock, resulting in messy lock depencies. Right now, snd-pcsp driver resolves the deadlock by using HRTIMER_CB_SOFTIRQ. However, this isn't nice for a really fast path like bit-flipping. This patch introduces a tasklet for PCM period handling so that the hrtimer callback can be handled fast. This also reduce the use of chip->substream_lock to avoid deadlocks. It's still used in pointer callback, but even this could be removed with a proper barrier. Another good solution is to introduce async trigger callback. But, this will involve with a major rewrite of the PCM core code, so I take first this easy fix. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-09-05hrtimer: convert sound/ to the new hrtimer apisArjan van de Ven
In order to be able to do range hrtimers we need to use accessor functions to the "expire" member of the hrtimer struct. This patch converts sound/ to these accessors. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-05-25[ALSA] snd-pcsp - fix pcsp_treble_info() to honour an item numberStas Sergeev
This solves the problem with mixers wrongly displaying the PWM freq. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-20snd-pcsp: use HRTIMER_CB_SOFTIRQStas Sergeev
Change HRTIMER_CB_IRQSAFE to HRTIMER_CB_SOFTIRQ, as suggested by Thomas Gleixner. That solves the lock dependancy reported in Bug #10701. That also allows to call hrtimer_start() directly, tasklet "stupid hack" removed. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-19snd-pcsp: silent misleading warningStas Sergeev
It appears that alsa allows a sound buffer with size not evenly devided by the period size. This triggers a warning in snd-pcsp and floods the log. As a quick fix, the warning should be disabled. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-19snd-pcsp: put back the compatibility code for the older alsa-libsStas Sergeev
The attached patch adds back the compatibility code, allowing the driver to work with older alsa-libs. The removal was premature, it breaks the real-life configs. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-05[ALSA] pcsp: Fix build with CONFIG_PM=nJohann Felix Soden
sound/drivers/pcsp/pcsp.c: In function 'pcsp_suspend': sound/drivers/pcsp/pcsp.c:201: error: implicit declaration of function 'snd_pcm_suspend_all' Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net> CC: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] pcsp: fix wording in DEBUG_PAGEALLOC warningStas Sergeev
Signed-off-by: Stas Sergeev <stsp@aknet.ru> (fixed invalid KERN_WARNING by tiwai) Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] pcsp: remove downsamplingStas Sergeev
pcsp: remove S16->U8 downsampling as dmix now supports U8 natively. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound/drivers/pcsp/pcsp.c build fixMariusz Kozlowski
sound/drivers/pcsp/pcsp.c: In function 'snd_pcsp_create': sound/drivers/pcsp/pcsp.c:54: error: 'loops_per_jiffy' undeclared (first use in\ this function) sound/drivers/pcsp/pcsp.c:54: error: (Each undeclared identifier is reported on\ ly once sound/drivers/pcsp/pcsp.c:54: error: for each function it appears in.) Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] pcsp: locking fixStas Sergeev
pcsp: locking fix. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] pcsp: improve "enable" option handlingStas Sergeev
Simplify init code. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] pcsp - clean upsStas Sergeev
- make pcsp_start_timer_tasklet static - remove redundant includes. <asm/i8253.h> is not available on all platforms. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Add PC-speaker sound driverStas Sergeev
Added PC-speaker sound driver (snd-pcsp). Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
