path: root/sound/drivers
2011-02-02ALSA: use linux/io.h to fix compile warningsTakashi Iwai
For helping to reduce Greert's regression list... src/sound/drivers/mtpav.c: error: implicit declaration of function 'inb' src/sound/drivers/mtpav.c: error: implicit declaration of function 'outb' ... Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-14ALSA: ml403-ac97cr: Use vsprintf extension %pR for struct resourceJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-20Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-10-20ALSA: snd-aloop - add pause supportJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-10-20ALSA: snd-aloop - fix locking issues (running flag updates)Jaroslav Kysela
On SMP machines, the cable->running update must be atomic, otherwise stream is not started correctly sometimes. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-10-18ALSA: snd-aloop: add cable#0 and cable#1 files to proc card treeJaroslav Kysela
Show some useful runtime information using procfs. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-10-17Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-10-14ALSA: snd-aloop - fix issue in the timer start functionJaroslav Kysela
In some circumstances (the rate shift value was changed), the irq_pos value may be higher than the fraction value in the timer start function. Check for it. Also, to avoid value overflow, decrease maximum period size. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-10-11Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-10-11ALSA: snd-aloop: Fix hw_params restrictions and checkingJaroslav Kysela
This patch fixes the hw_params restrictions when first (or playback) stream sets the final hardware parameters. Also, fix the hw_params checking in the trigger callback. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-10-04Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-10-02ALSA: snd-aloop - fix "PCM Slave Active" element read valueJaroslav Kysela
Simple coding fix. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-09-30Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-09-30ALSA: snd-aloop - fix capture buffer silenceJaroslav Kysela
In a special case, some old samples are left in the capture ring buffer. Fix it. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-09-22Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-09-15ALSA: snd-aloop - fix the "PCM Playback Channels" kcontrolJaroslav Kysela
Obvious copy-and-paste error. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-09-07sound: Remove unnecessary casts of private_dataJoe Perches
2010-08-18Merge branch 'topic/aloop' into topic/miscTakashi Iwai
2010-08-09ALSA: introduce the snd-aloop module for the PCM loopbackJaroslav Kysela
The snd-aloop module allows redirecting of the PCM playback in the kernel back to the user space using the standard ALSA PCM capture API. The module also allows time synchronization with another timing source and notifications of playback stream parameter changes. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits) ALSA: hda - Add pin-fix for HP dc5750 ALSA: als4000: Fix potentially invalid DMA mode setup ALSA: als4000: enable burst mode ALSA: hda - Fix initial capsrc selection in patch_alc269() ASoC: TWL4030: Capture route runtime DAPM ordering fix ALSA: hda - Add PC-beep whitelist for an Intel board ALSA: hda - More relax for pending period handling ALSA: hda - Define AC_FMT_* constants ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs ALSA: hda - Add support for HDMI HBR passthrough ALSA: hda - Set Stream Type in Stream Format according to AES0 ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF ASoC: wm9081: fix resource reclaim in wm9081_register error path ASoC: wm8978: fix a memory leak if a wm8978_register fail ASoC: wm8974: fix a memory leak if another WM8974 is registered ASoC: wm8961: fix resource reclaim in wm8961_register error path ASoC: wm8955: fix resource reclaim in wm8955_register error path ASoC: wm8940: fix a memory leak if wm8940_register return error ASoC: wm8904: fix resource reclaim in wm8904_register error path ...
2010-07-15ALSA: Kconfig: SND_AC97_POWER_SAVE description improvementMichael Witten
The description has been expanded to explain the time-out value provided by the power_save module parameter. Signed-off-by: Michael Witten <mfwitten@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-07-15Kconfig: fixo typo in "Xilinx'"Michael Witten
Signed-off-by: Michael Witten <mfwitten@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (250 commits) ALSA: hda: Storage class should be before const qualifier ASoC: tpa6130a2: Remove CPVSS and HPVdd supplies ASoC: tpa6130a2: Define output pins with SND_SOC_DAPM_OUTPUT ASoC: sdp4430 - add sdp4430 pcm ops to DAI. ASoC: TWL6040: Enable earphone path in codec ASoC: SDP4430: Add support for Earphone speaker ASoC: SDP4430: Add sdp4430 machine driver ASoC: tlv320dac33: Avoid powering off while in BIAS_OFF ASoC: tlv320dac33: Use dev_dbg in dac33_hard_power function ALSA: sound/pci/asihpi: Use kzalloc ALSA: hdmi - dont fail on extra nodes ALSA: intelhdmi - add id for the CougarPoint chipset ALSA: intelhdmi - user friendly codec name ALSA: intelhdmi - add dependency on SND_DYNAMIC_MINORS ALSA: asihpi: incorrect range check ALSA: asihpi: testing the wrong variable ALSA: es1688: add pedantic range checks ARM: McBSP: Add support for omap4 in McBSP driver ARM: McBSP: Fix request for irq in OMAP4 OMAP: McBSP: Add 32-bit mode support ...
2010-05-10ALSA: opl4 - Fix a wrong argument in proc write callbackTakashi Iwai
The commit 24e4a1211f691fc671de44685430dbad757d8487 ALSA: info - Use standard types for info callbacks introduced a wrong type to snd_opl4_mem_proc_write() for pos argument. Fixed now. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-03Merge commit 'v2.6.34-rc6' into core/lockingIngo Molnar
2010-04-13ALSA: info - Implement common llseek for binary modeTakashi Iwai
The llseek implementation is identical for existing driver implementations, so let's merge to the common layer. The same code for the text proc file can be used even for the binary proc file. The driver can provide its own llseek method if needed. Then the common code will be skipped. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-13ALSA: info - Check file position validity in common layerTakashi Iwai
Check the validity of the file position in the common info layer before calling read or write callbacks in assumption that entry->size is set up properly to indicate the max file size. Removed the redundant checks from the callbacks as well. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-13ALSA: info - Use standard types for info callbacksTakashi Iwai
Use loff_t, size_t and ssize_t for arguments of info callbacks to follow the standard procfs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-02i8253: Convert i8253_lock to raw_spinlockThomas Gleixner
i8253_lock needs to be a real spinlock in preempt-rt, i.e. it can not be converted to a sleeping lock. Convert it to raw_spinlock and fix up all users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Jens Axboe <jens.axboe@oracle.com> LKML-Reference: <20100217163751.030764372@linutronix.de>
2010-02-12Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-02-02ALSA: dummy driver - add model parameterJaroslav Kysela
This is a cleanup for the dummy driver. The model kernel module parameter is introduced to select the soundcard emulation. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-18ALSA: pcm - Call pgprot_noncached() for vmalloc'ed buffersTakashi Iwai
pgprot_noncached() can be set for vmalloc'ed buffers safely, and we'd need non-cached behavior more or less, even for the intermediate ring- buffers. Now snd_pcm_lib_mmap_vmalloc() is added as the common PCM mmap callback that is coupled with snd_pcm_lib_alloc_vmalloc_buffer() & co. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-18sound: vx: use vmalloc buffer helper functionsClemens Ladisch
Remove this duplicate of snd_pcm_alloc_vmalloc_buffer and use the equivalent core functions instead. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-01Merge branch 'topic/beep-rename' into topic/core-changeTakashi Iwai
2009-11-05ALSA: rename "PC Speaker" and "PC Beep" controls to "Beep"Jaroslav Kysela
To avoid confusion in control names for the standard analog PC Beep generator using a small Internal PC Speaker, rename all related "PC Speaker" and "PC Beep" controls to "Beep" only. This name is more universal and can be also used on more platforms without confusion. Introduce also "Internal Speaker" in ControlNames.txt for systems with full-featured build-in internal speaker. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-02ALSA: dummy - Fix descriptions of pcm_substreams parameterTakashi Iwai
Now up to 128 substreams are supported. Reported-by: Adrian Bridgett <adrian@smop.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-01ALSA: snd-pcsp: add nopcm modeStas Sergeev
Currently, if the high-res timers are unavailable, snd-pcsp does not initialize. People who choose it over pcspkr, loose their console beeps in that case and get annoyed. With this patch, the console beeps remain regardless of the high-res timers. Additionally, the "nopcm" modparam is added to forcibly disable the PCM capabilities of the driver. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-30ALSA: sound: Move dereference after NULL test and drop unnecessary NULL testsJulia Lawall
In pcm.c, if the NULL test on pcm is needed, then the dereference should be after the NULL test. In dummy.c and ali5451.c, the context of the calls to snd_card_dummy_new_mixer and snd_ali_free_voice show that dummy and pvoice, respectively cannot be NULL. A simplified version of the semantic match that detects this problem is as follows (http://coccinelle.lip6.fr/): // <smpl> @match exists@ expression x, E; identifier fld; @@ * x->fld ... when != \(x = E\|&x\) * x == NULL // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-30ALSA: pcsp - Fix nforce workaroundStas Sergeev
The attached patch fixes the problems introduced in this commit: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=eea0579fc85e64e9f05361d5aacf496fe7a151aa - Fix nForce workaround by honouring the pointer_update var - Revert "ns" to u64, as per the hrtimer API - Revert to the zero-delay timer startup, since I can't reproduce any problem with it (please, give me the hint!) Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-08ALSA: opl3: circular locking in the snd_opl3_note_on() and snd_opl3_note_off()Krzysztof Helt
Fix following circular locking in the opl3 driver. ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.32-rc3 #87 ------------------------------------------------------- swapper/0 is trying to acquire lock: (&opl3->voice_lock){..-...}, at: [<cca748fe>] snd_opl3_note_off+0x1e/0xe0 [snd_opl3_synth] but task is already holding lock: (&opl3->sys_timer_lock){..-...}, at: [<cca75169>] snd_opl3_timer_func+0x19/0xc0 [snd_opl3_synth] which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&opl3->sys_timer_lock){..-...}: [<c02461d5>] validate_chain+0xa25/0x1040 [<c0246aca>] __lock_acquire+0x2da/0xab0 [<c024731a>] lock_acquire+0x7a/0xa0 [<c044c300>] _spin_lock_irqsave+0x40/0x60 [<cca75046>] snd_opl3_note_on+0x686/0x790 [snd_opl3_synth] [<cca68912>] snd_midi_process_event+0x322/0x590 [snd_seq_midi_emul] [<cca74245>] snd_opl3_synth_event_input+0x15/0x20 [snd_opl3_synth] [<cca4dcc0>] snd_seq_deliver_single_event+0x100/0x200 [snd_seq] [<cca4de07>] snd_seq_deliver_event+0x47/0x1f0 [snd_seq] [<cca4e50b>] snd_seq_dispatch_event+0x3b/0x140 [snd_seq] [<cca5008c>] snd_seq_check_queue+0x10c/0x120 [snd_seq] [<cca5037b>] snd_seq_enqueue_event+0x6b/0xe0 [snd_seq] [<cca4e0fd>] snd_seq_client_enqueue_event+0xdd/0x100 [snd_seq] [<cca4eb7a>] snd_seq_write+0xea/0x190 [snd_seq] [<c02827b6>] vfs_write+0x96/0x160 [<c0282c9d>] sys_write+0x3d/0x70 [<c0202c45>] syscall_call+0x7/0xb -> #0 (&opl3->voice_lock){..-...}: [<c02467e6>] validate_chain+0x1036/0x1040 [<c0246aca>] __lock_acquire+0x2da/0xab0 [<c024731a>] lock_acquire+0x7a/0xa0 [<c044c300>] _spin_lock_irqsave+0x40/0x60 [<cca748fe>] snd_opl3_note_off+0x1e/0xe0 [snd_opl3_synth] [<cca751f0>] snd_opl3_timer_func+0xa0/0xc0 [snd_opl3_synth] [<c022ac46>] run_timer_softirq+0x166/0x1e0 [<c02269e8>] __do_softirq+0x78/0x110 [<c0226ac6>] do_softirq+0x46/0x50 [<c0226e26>] irq_exit+0x36/0x40 [<c0204bd2>] do_IRQ+0x42/0xb0 [<c020328e>] common_interrupt+0x2e/0x40 [<c021092f>] apm_cpu_idle+0x10f/0x290 [<c0201b11>] cpu_idle+0x21/0x40 [<c04443cd>] rest_init+0x4d/0x60 [<c055c835>] start_kernel+0x235/0x280 [<c055c066>] i386_start_kernel+0x66/0x70 other info that might help us debug this: 2 locks held by swapper/0: #0: (&opl3->tlist){+.-...}, at: [<c022abd0>] run_timer_softirq+0xf0/0x1e0 #1: (&opl3->sys_timer_lock){..-...}, at: [<cca75169>] snd_opl3_timer_func+0x19/0xc0 [snd_opl3_synth] stack backtrace: Pid: 0, comm: swapper Not tainted 2.6.32-rc3 #87 Call Trace: [<c0245188>] print_circular_bug+0xc8/0xd0 [<c02467e6>] validate_chain+0x1036/0x1040 [<c0247f14>] ? check_usage_forwards+0x54/0xd0 [<c0246aca>] __lock_acquire+0x2da/0xab0 [<c024731a>] lock_acquire+0x7a/0xa0 [<cca748fe>] ? snd_opl3_note_off+0x1e/0xe0 [snd_opl3_synth] [<c044c300>] _spin_lock_irqsave+0x40/0x60 [<cca748fe>] ? snd_opl3_note_off+0x1e/0xe0 [snd_opl3_synth] [<cca748fe>] snd_opl3_note_off+0x1e/0xe0 [snd_opl3_synth] [<c044c307>] ? _spin_lock_irqsave+0x47/0x60 [<cca751f0>] snd_opl3_timer_func+0xa0/0xc0 [snd_opl3_synth] [<c022ac46>] run_timer_softirq+0x166/0x1e0 [<c022abd0>] ? run_timer_softirq+0xf0/0x1e0 [<cca75150>] ? snd_opl3_timer_func+0x0/0xc0 [snd_opl3_synth] [<c02269e8>] __do_softirq+0x78/0x110 [<c044c0fd>] ? _spin_unlock+0x1d/0x20 [<c025915f>] ? handle_level_irq+0xaf/0xe0 [<c0226ac6>] do_softirq+0x46/0x50 [<c0226e26>] irq_exit+0x36/0x40 [<c0204bd2>] do_IRQ+0x42/0xb0 [<c024463c>] ? trace_hardirqs_on_caller+0x12c/0x180 [<c020328e>] common_interrupt+0x2e/0x40 [<c0208d88>] ? default_idle+0x38/0x50 [<c021092f>] apm_cpu_idle+0x10f/0x290 [<c0201b11>] cpu_idle+0x21/0x40 [<c04443cd>] rest_init+0x4d/0x60 [<c055c835>] start_kernel+0x235/0x280 [<c055c210>] ? unknown_bootoption+0x0/0x210 [<c055c066>] i386_start_kernel+0x66/0x70 Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-08ALSA: dummy - Increase MAX_PCM_SUBSTREAMS to 128Takashi Iwai
Increase the limit of PCM substreams to 128. The default value is unchanged; only the max accept value is increased. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-08ALSA: dummy - Add debug proc fileTakashi Iwai
Added the debug proc file to see or change the snd_pcm_hardware fields to emulate. The parameters can be changed by writing to a proc file like: # echo periods_min 4 > /proc/asound/card1/dummy_pcm Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-07ALSA: dummy - Fake buffer allocationsTakashi Iwai
Instead of allocating the real buffers, use a fake buffer and ignore read/write in the dummy driver so that we can save the resources. For mmap, a single page (unique to the direction, though) is reused to all buffers. When the app requires to read/write the real buffers, pass fake_buffer=0 module option at loading time. This will get back to the old behavior. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-04ALSA: dummy - Fix the timer calculation in systimer modeTakashi Iwai
Fix the expire-time calculation in the systimer mode when the buffer size isn't aligned to the period size. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-03ALSA: dummy - Better jiffies handlingTakashi Iwai
In the system-timer mode, snd-dummy driver issues each tick to update the position. This is highly inefficient and even inaccurate if the timer can't be triggered at each tick. Now rewritten to wake up only at the period boundary. The position is calculated from the current jiffies. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-03ALSA: dummy - Support high-res timer modeTakashi Iwai
Allow snd-dummy driver to use high-res timer as its timing source instead of the system timer. The new module option "hrtimer" is added to turn on/off the high-res timer support. It can be switched even dynamically via sysfs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-16time: move PIT_TICK_RATE to linux/timex.hArnd Bergmann
PIT_TICK_RATE is currently defined in four architectures, but in three different places. While linux/timex.h is not the perfect place for it, it is still a reasonable replacement for those drivers that traditionally use asm/timex.h to get CLOCK_TICK_RATE and expect it to be the PIT frequency. Note that for Alpha, the actual value changed from 1193182UL to 1193180UL. This is unlikely to make a difference, and probably can only improve accuracy. There was a discussion on the correct value of CLOCK_TICK_RATE a few years ago, after which every existing instance was getting changed to 1193182. According to the specification, it should be 1193181.818181... Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Len Brown <lenb@kernel.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-29ALSA: clean up the logic for building sequencer modulesMichal Marek
Instead of mangling the CONFIG_* variables in the makefiles over and over, set a few helper variables in Kconfig. Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-20ALSA: pcsp - fix printk format warning againTakashi Iwai
The commit 5a641bcd6398841cc4606b0a732d41a09256fd94 changed the printk format to '%lu', but the value passed seems to be dependent on the architecture. On x86-64, I got a new warning now because an int value is passed actaully. As a workaround, just cast the value always to unsigned long. Signed-off-by: Takashi Iwai <tiwai@suse.de>
