path: root/sound/drivers
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (250 commits) ALSA: hda: Storage class should be before const qualifier ASoC: tpa6130a2: Remove CPVSS and HPVdd supplies ASoC: tpa6130a2: Define output pins with SND_SOC_DAPM_OUTPUT ASoC: sdp4430 - add sdp4430 pcm ops to DAI. ASoC: TWL6040: Enable earphone path in codec ASoC: SDP4430: Add support for Earphone speaker ASoC: SDP4430: Add sdp4430 machine driver ASoC: tlv320dac33: Avoid powering off while in BIAS_OFF ASoC: tlv320dac33: Use dev_dbg in dac33_hard_power function ALSA: sound/pci/asihpi: Use kzalloc ALSA: hdmi - dont fail on extra nodes ALSA: intelhdmi - add id for the CougarPoint chipset ALSA: intelhdmi - user friendly codec name ALSA: intelhdmi - add dependency on SND_DYNAMIC_MINORS ALSA: asihpi: incorrect range check ALSA: asihpi: testing the wrong variable ALSA: es1688: add pedantic range checks ARM: McBSP: Add support for omap4 in McBSP driver ARM: McBSP: Fix request for irq in OMAP4 OMAP: McBSP: Add 32-bit mode support ...
2010-05-10ALSA: opl4 - Fix a wrong argument in proc write callbackTakashi Iwai
The commit 24e4a1211f691fc671de44685430dbad757d8487 ALSA: info - Use standard types for info callbacks introduced a wrong type to snd_opl4_mem_proc_write() for pos argument. Fixed now. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-03Merge commit 'v2.6.34-rc6' into core/lockingIngo Molnar
2010-04-13ALSA: info - Implement common llseek for binary modeTakashi Iwai
The llseek implementation is identical for existing driver implementations, so let's merge to the common layer. The same code for the text proc file can be used even for the binary proc file. The driver can provide its own llseek method if needed. Then the common code will be skipped. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-13ALSA: info - Check file position validity in common layerTakashi Iwai
Check the validity of the file position in the common info layer before calling read or write callbacks in assumption that entry->size is set up properly to indicate the max file size. Removed the redundant checks from the callbacks as well. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-13ALSA: info - Use standard types for info callbacksTakashi Iwai
Use loff_t, size_t and ssize_t for arguments of info callbacks to follow the standard procfs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-02i8253: Convert i8253_lock to raw_spinlockThomas Gleixner
i8253_lock needs to be a real spinlock in preempt-rt, i.e. it can not be converted to a sleeping lock. Convert it to raw_spinlock and fix up all users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Jens Axboe <jens.axboe@oracle.com> LKML-Reference: <20100217163751.030764372@linutronix.de>
2010-02-12Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-02-02ALSA: dummy driver - add model parameterJaroslav Kysela
This is a cleanup for the dummy driver. The model kernel module parameter is introduced to select the soundcard emulation. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-18ALSA: pcm - Call pgprot_noncached() for vmalloc'ed buffersTakashi Iwai
pgprot_noncached() can be set for vmalloc'ed buffers safely, and we'd need non-cached behavior more or less, even for the intermediate ring- buffers. Now snd_pcm_lib_mmap_vmalloc() is added as the common PCM mmap callback that is coupled with snd_pcm_lib_alloc_vmalloc_buffer() & co. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-18sound: vx: use vmalloc buffer helper functionsClemens Ladisch
Remove this duplicate of snd_pcm_alloc_vmalloc_buffer and use the equivalent core functions instead. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-01Merge branch 'topic/beep-rename' into topic/core-changeTakashi Iwai
2009-11-05ALSA: rename "PC Speaker" and "PC Beep" controls to "Beep"Jaroslav Kysela
To avoid confusion in control names for the standard analog PC Beep generator using a small Internal PC Speaker, rename all related "PC Speaker" and "PC Beep" controls to "Beep" only. This name is more universal and can be also used on more platforms without confusion. Introduce also "Internal Speaker" in ControlNames.txt for systems with full-featured build-in internal speaker. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-02ALSA: dummy - Fix descriptions of pcm_substreams parameterTakashi Iwai
Now up to 128 substreams are supported. Reported-by: Adrian Bridgett <adrian@smop.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-01ALSA: snd-pcsp: add nopcm modeStas Sergeev
Currently, if the high-res timers are unavailable, snd-pcsp does not initialize. People who choose it over pcspkr, loose their console beeps in that case and get annoyed. With this patch, the console beeps remain regardless of the high-res timers. Additionally, the "nopcm" modparam is added to forcibly disable the PCM capabilities of the driver. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-30ALSA: sound: Move dereference after NULL test and drop unnecessary NULL testsJulia Lawall
In pcm.c, if the NULL test on pcm is needed, then the dereference should be after the NULL test. In dummy.c and ali5451.c, the context of the calls to snd_card_dummy_new_mixer and snd_ali_free_voice show that dummy and pvoice, respectively cannot be NULL. A simplified version of the semantic match that detects this problem is as follows (http://coccinelle.lip6.fr/): // <smpl> @match exists@ expression x, E; identifier fld; @@ * x->fld ... when != \(x = E\|&x\) * x == NULL // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-30ALSA: pcsp - Fix nforce workaroundStas Sergeev
The attached patch fixes the problems introduced in this commit: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=eea0579fc85e64e9f05361d5aacf496fe7a151aa - Fix nForce workaround by honouring the pointer_update var - Revert "ns" to u64, as per the hrtimer API - Revert to the zero-delay timer startup, since I can't reproduce any problem with it (please, give me the hint!) Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-08ALSA: opl3: circular locking in the snd_opl3_note_on() and snd_opl3_note_off()Krzysztof Helt
Fix following circular locking in the opl3 driver. ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.32-rc3 #87 ------------------------------------------------------- swapper/0 is trying to acquire lock: (&opl3->voice_lock){..-...}, at: [<cca748fe>] snd_opl3_note_off+0x1e/0xe0 [snd_opl3_synth] but task is already holding lock: (&opl3->sys_timer_lock){..-...}, at: [<cca75169>] snd_opl3_timer_func+0x19/0xc0 [snd_opl3_synth] which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&opl3->sys_timer_lock){..-...}: [<c02461d5>] validate_chain+0xa25/0x1040 [<c0246aca>] __lock_acquire+0x2da/0xab0 [<c024731a>] lock_acquire+0x7a/0xa0 [<c044c300>] _spin_lock_irqsave+0x40/0x60 [<cca75046>] snd_opl3_note_on+0x686/0x790 [snd_opl3_synth] [<cca68912>] snd_midi_process_event+0x322/0x590 [snd_seq_midi_emul] [<cca74245>] snd_opl3_synth_event_input+0x15/0x20 [snd_opl3_synth] [<cca4dcc0>] snd_seq_deliver_single_event+0x100/0x200 [snd_seq] [<cca4de07>] snd_seq_deliver_event+0x47/0x1f0 [snd_seq] [<cca4e50b>] snd_seq_dispatch_event+0x3b/0x140 [snd_seq] [<cca5008c>] snd_seq_check_queue+0x10c/0x120 [snd_seq] [<cca5037b>] snd_seq_enqueue_event+0x6b/0xe0 [snd_seq] [<cca4e0fd>] snd_seq_client_enqueue_event+0xdd/0x100 [snd_seq] [<cca4eb7a>] snd_seq_write+0xea/0x190 [snd_seq] [<c02827b6>] vfs_write+0x96/0x160 [<c0282c9d>] sys_write+0x3d/0x70 [<c0202c45>] syscall_call+0x7/0xb -> #0 (&opl3->voice_lock){..-...}: [<c02467e6>] validate_chain+0x1036/0x1040 [<c0246aca>] __lock_acquire+0x2da/0xab0 [<c024731a>] lock_acquire+0x7a/0xa0 [<c044c300>] _spin_lock_irqsave+0x40/0x60 [<cca748fe>] snd_opl3_note_off+0x1e/0xe0 [snd_opl3_synth] [<cca751f0>] snd_opl3_timer_func+0xa0/0xc0 [snd_opl3_synth] [<c022ac46>] run_timer_softirq+0x166/0x1e0 [<c02269e8>] __do_softirq+0x78/0x110 [<c0226ac6>] do_softirq+0x46/0x50 [<c0226e26>] irq_exit+0x36/0x40 [<c0204bd2>] do_IRQ+0x42/0xb0 [<c020328e>] common_interrupt+0x2e/0x40 [<c021092f>] apm_cpu_idle+0x10f/0x290 [<c0201b11>] cpu_idle+0x21/0x40 [<c04443cd>] rest_init+0x4d/0x60 [<c055c835>] start_kernel+0x235/0x280 [<c055c066>] i386_start_kernel+0x66/0x70 other info that might help us debug this: 2 locks held by swapper/0: #0: (&opl3->tlist){+.-...}, at: [<c022abd0>] run_timer_softirq+0xf0/0x1e0 #1: (&opl3->sys_timer_lock){..-...}, at: [<cca75169>] snd_opl3_timer_func+0x19/0xc0 [snd_opl3_synth] stack backtrace: Pid: 0, comm: swapper Not tainted 2.6.32-rc3 #87 Call Trace: [<c0245188>] print_circular_bug+0xc8/0xd0 [<c02467e6>] validate_chain+0x1036/0x1040 [<c0247f14>] ? check_usage_forwards+0x54/0xd0 [<c0246aca>] __lock_acquire+0x2da/0xab0 [<c024731a>] lock_acquire+0x7a/0xa0 [<cca748fe>] ? snd_opl3_note_off+0x1e/0xe0 [snd_opl3_synth] [<c044c300>] _spin_lock_irqsave+0x40/0x60 [<cca748fe>] ? snd_opl3_note_off+0x1e/0xe0 [snd_opl3_synth] [<cca748fe>] snd_opl3_note_off+0x1e/0xe0 [snd_opl3_synth] [<c044c307>] ? _spin_lock_irqsave+0x47/0x60 [<cca751f0>] snd_opl3_timer_func+0xa0/0xc0 [snd_opl3_synth] [<c022ac46>] run_timer_softirq+0x166/0x1e0 [<c022abd0>] ? run_timer_softirq+0xf0/0x1e0 [<cca75150>] ? snd_opl3_timer_func+0x0/0xc0 [snd_opl3_synth] [<c02269e8>] __do_softirq+0x78/0x110 [<c044c0fd>] ? _spin_unlock+0x1d/0x20 [<c025915f>] ? handle_level_irq+0xaf/0xe0 [<c0226ac6>] do_softirq+0x46/0x50 [<c0226e26>] irq_exit+0x36/0x40 [<c0204bd2>] do_IRQ+0x42/0xb0 [<c024463c>] ? trace_hardirqs_on_caller+0x12c/0x180 [<c020328e>] common_interrupt+0x2e/0x40 [<c0208d88>] ? default_idle+0x38/0x50 [<c021092f>] apm_cpu_idle+0x10f/0x290 [<c0201b11>] cpu_idle+0x21/0x40 [<c04443cd>] rest_init+0x4d/0x60 [<c055c835>] start_kernel+0x235/0x280 [<c055c210>] ? unknown_bootoption+0x0/0x210 [<c055c066>] i386_start_kernel+0x66/0x70 Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-08ALSA: dummy - Increase MAX_PCM_SUBSTREAMS to 128Takashi Iwai
Increase the limit of PCM substreams to 128. The default value is unchanged; only the max accept value is increased. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-08ALSA: dummy - Add debug proc fileTakashi Iwai
Added the debug proc file to see or change the snd_pcm_hardware fields to emulate. The parameters can be changed by writing to a proc file like: # echo periods_min 4 > /proc/asound/card1/dummy_pcm Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-07ALSA: dummy - Fake buffer allocationsTakashi Iwai
Instead of allocating the real buffers, use a fake buffer and ignore read/write in the dummy driver so that we can save the resources. For mmap, a single page (unique to the direction, though) is reused to all buffers. When the app requires to read/write the real buffers, pass fake_buffer=0 module option at loading time. This will get back to the old behavior. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-04ALSA: dummy - Fix the timer calculation in systimer modeTakashi Iwai
Fix the expire-time calculation in the systimer mode when the buffer size isn't aligned to the period size. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-03ALSA: dummy - Better jiffies handlingTakashi Iwai
In the system-timer mode, snd-dummy driver issues each tick to update the position. This is highly inefficient and even inaccurate if the timer can't be triggered at each tick. Now rewritten to wake up only at the period boundary. The position is calculated from the current jiffies. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-03ALSA: dummy - Support high-res timer modeTakashi Iwai
Allow snd-dummy driver to use high-res timer as its timing source instead of the system timer. The new module option "hrtimer" is added to turn on/off the high-res timer support. It can be switched even dynamically via sysfs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-16time: move PIT_TICK_RATE to linux/timex.hArnd Bergmann
PIT_TICK_RATE is currently defined in four architectures, but in three different places. While linux/timex.h is not the perfect place for it, it is still a reasonable replacement for those drivers that traditionally use asm/timex.h to get CLOCK_TICK_RATE and expect it to be the PIT frequency. Note that for Alpha, the actual value changed from 1193182UL to 1193180UL. This is unlikely to make a difference, and probably can only improve accuracy. There was a discussion on the correct value of CLOCK_TICK_RATE a few years ago, after which every existing instance was getting changed to 1193182. According to the specification, it should be 1193181.818181... Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Len Brown <lenb@kernel.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-29ALSA: clean up the logic for building sequencer modulesMichal Marek
Instead of mangling the CONFIG_* variables in the makefiles over and over, set a few helper variables in Kconfig. Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-20ALSA: pcsp - fix printk format warning againTakashi Iwai
The commit 5a641bcd6398841cc4606b0a732d41a09256fd94 changed the printk format to '%lu', but the value passed seems to be dependent on the architecture. On x86-64, I got a new warning now because an int value is passed actaully. As a workaround, just cast the value always to unsigned long. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-14ALSA: pcsp: fix printk format warningRandy Dunlap
Fix printk format warning: sound/drivers/pcsp/pcsp_mixer.c:54: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-05sound: serial-u16550: fix buffer overflowClemens Ladisch
Remove most of the serial port parameters from the card longname string because it was way too long and overflowed into the mixername string. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-24Merge branch 'topic/misc' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/hwdep-cleanup' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/snd_card_new-err' into for-linusTakashi Iwai
2009-02-26ALSA: sound/drivers/vx: fix sparse warning: different signednessHannes Eder
Fix this sparse warning: sound/drivers/vx/vx_uer.c:301:42: warning: incorrect type in argument 2 (different signedness) Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-15Merge commit 'v2.6.29-rc5' into x86/apicIngo Molnar
2009-02-12ALSA: mtpav - Fix initial value for input hwportTakashi Iwai
Fix the initial value for input hwport. The old value (-1) may cause Oops when an realtime MIDI byte is received before the input port is explicitly given. Instead, now it's set to the broadcasting as default. Tested-by: Holger Dehnhardt <dehnhardt@ahdehnhardt.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-05ALSA: Add missing KERN_* prefix to printk in sound/driversTakashi Iwai
2009-02-05ALSA: Remove superfluous hwdep opsTakashi Iwai
Remove NOP hwdep ops in sound drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-30x86: allow more than 8 cpus to be used on 32-bitYinghai Lu
X86_PC is the only remaining 'sub' architecture, so we dont need it anymore. This also cleans up a few spurious references to X86_PC in the driver space - those certainly should be X86. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-12ALSA: Convert to snd_card_create() in other sound/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in other sound subdirectories. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-30Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: hrtimers: fix warning in kernel/hrtimer.c x86: make sure we really have an hpet mapping before using it x86: enable HPET on Fujitsu u9200 linux/timex.h: cleanup for userspace posix-timers: simplify de_thread()->exit_itimers() path posix-timers: check ->it_signal instead of ->it_pid to validate the timer posix-timers: use "struct pid*" instead of "struct task_struct*" nohz: suppress needless timer reprogramming clocksource, acpi_pm.c: put acpi_pm_read_slow() under CONFIG_PCI nohz: no softirq pending warnings for offline cpus hrtimer: removing all ur callback modes, fix hrtimer: removing all ur callback modes, fix hotplug hrtimer: removing all ur callback modes x86: correct link to HPET timer specification rtc-cmos: export second NVRAM bank Fixed up conflicts in sound/drivers/pcsp/pcsp.c and sound/core/hrtimer.c manually.
2008-12-25Merge branch 'topic/convert-tasklet' into to-pushTakashi Iwai
2008-12-20Merge branch 'topic/pcsp-fix' into topic/miscTakashi Iwai
2008-12-18ALSA: hda - Convert from takslet_hi_schedule() to tasklet_schedule()Takashi Iwai
Replace all tasklet_hi_schedule() callers with the normal tasklet_schedule(). The former often causes troubles with RT-kernels, and has actually no merit. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-28ALSA: ac97 - Remove EXPERIMENTAL from CONFIG_SND_AC97_POWER_SAVETakashi Iwai
It's mature enough now. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-26ALSA: pcsp - Fix starting the stream with HRTIMER_CB_IRQSAFE_UNLOCKTakashi Iwai
With the callback mode HRTIMER_CB_IRQSAFE_UNLOCK, the start of the stream with zero delay doesn't work. Since IRQSAFE mode is removed, we have to change the pcsp start-up code. This patch splits the callback function to two parts, the triggering of the port and the calculation of the expire time, and the update of the ALSA PCM core. The first part is called both from the trigger-start and the hrtimer callback while the latter is handled only in the hrtimer callback. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-26Merge branch 'topic/misc' into topic/pcsp-fixTakashi Iwai
Conflicts: sound/drivers/pcsp/pcsp_lib.c
2008-11-25hrtimer: removing all ur callback modesPeter Zijlstra
Impact: cleanup, move all hrtimer processing into hardirq context This is an attempt at removing some of the hrtimer complexity by reducing the number of callback modes to 1. This means that all hrtimer callback functions will be ran from HARD-irq context. I went through all the 30 odd hrtimer callback functions in the kernel and saw only one that I'm not quite sure of, which is the one in net/can/bcm.c - hence I'm CC-ing the folks responsible for that code. Furthermore, the hrtimer core now calls callbacks directly with IRQs disabled in case you try to enqueue an expired timer. If this timer is a periodic timer (which should use hrtimer_forward() to advance its time) then it might be possible to end up in an inf. recursive loop due to the fact that hrtimer_forward() doesn't round up to the next timer granularity, and therefore keeps on calling the callback - obviously this needs a fix. Aside from that, this seems to compile and actually boot on my dual core test box - although I'm sure there are some bugs in, me not hitting any makes me certain :-) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-14ALSA: pcsp - Use HRTIMER_CB_IRQSAFE_UNLOCKEDTakashi Iwai
HRTIMER_CB_IRQSAFE was removed in the upstream. Try to use HRTIMER_CB_IRQSAFE_UNLOCKED instead. Signed-off-by: Takashi Iwai <tiwai@suse.de>
