commit 0f925660a7bc49b269c163249a5d06da3a0c7b0a upstream.
In error path of snd_dice_stream_init_duplex(), stream data for incoming
packet can be left to be initialized.
This commit fixes it.
Fixes: 436b5abe2224 ('ALSA: dice: handle whole available isochronous streams')
Cc: <stable@vger.kernel.org> # v4.6+
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
commit 10412c420af9ba1f3de8483a95d360e5eb5bfc84 upstream.
OUI for TC Electronic is 0x000166, for TC GROUP A/S. 0x001486 is for Echo
Digital Audio Corporation.
Fixes: 7cafc65b3aa1 ('ALSA: dice: force to add two pcm devices for listed models')
Reference: http://standards-oui.ieee.org/oui/oui.txt
Check for snd_pcm_ops structures that are only stored in the ops field of a
snd_soc_platform_driver structure or passed as the third argument to
snd_pcm_set_ops. The corresponding field or parameter is declared const,
so snd_pcm_ops structures that have this property can be declared as const
also.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct snd_pcm_ops i@p = { ... };
@ok1@
identifier r.i;
struct snd_soc_platform_driver e;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2;
position p;
snd_pcm_set_ops(e1, e2, &i@p)
@bad@
position p != {r.p,ok1.p,ok2.p};
identifier r.i;
struct snd_pcm_ops e;
e@i@p
@depends on !bad disable optional_qualifier@
identifier r.i;
static
+const
struct snd_pcm_ops i = { ... };
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
Acked-by: Clemens Ladisch <clemens@ladisch.de>
M-Audio Profire 610 has an unexpected value in version field of its config
ROM, thus ALSA dice driver is not assigned to the model due to a mismatch
of modalias.
This commit adds an entry to support the model. I expect the entry is
also for Profire 2626.
I note that Profire 610 uses TCD2220 (so-called Dice Jr.), and supports a
part of Extended Application Protocol (EAP).
$ cd linux-firewire-utils/src
$ ./crpp < /sys/bus/firewire/devices/fw1/config_rom
ROM header and bus information block
400 04047689 bus_info_length 4, crc_length 4, crc 30345
404 31333934 bus_name "1394"
408 e0ff8112 irmc 1, cmc 1, isc 1, bmc 0, pmc 0, cyc_clk_acc 255,
max_rec 8 (512), max_rom 1, gen 1, spd 2 (S400)
40c 000d6c04 company_id 000d6c |
410 04400002 device_id 0404400002 | EUI-64 000d6c0404400002
root directory
414 000695fe directory_length 6, crc 38398
418 03000d6c vendor
41c 8100000a --> descriptor leaf at 444
420 17000011 model
424 8100000d --> descriptor leaf at 458
428 0c0087c0 node capabilities per IEEE 1394
42c d1000001 --> unit directory at 430
430 0004fb14 directory_length 4, crc 64276
434 12000d6c specifier id
438 130100d1 version
43c 17000011 model
440 8100000c --> descriptor leaf at 470
444 0004b8e4 leaf_length 4, crc 47332
448 00000000 textual descriptor
44c 00000000 minimal ASCII
450 4d2d4175 "M-Au"
454 64696f00 "dio"
458 00053128 leaf_length 5, crc 12584
45c 00000000 textual descriptor
460 00000000 minimal ASCII
464 50726f46 "ProF"
468 69726520 "ire "
46c 36313000 "610"
470 00053128 leaf_length 5, crc 12584
474 00000000 textual descriptor
478 00000000 minimal ASCII
47c 50726f46 "ProF"
480 69726520 "ire "
484 36313000 "610"
$ cat /proc/asound/card1/dice
sections:
global: offset 10, size 90
tx: offset 100, size 142
rx: offset 242, size 282
ext_sync: offset 524, size 4
unused2: offset 0, size 0
global:
owner: ffc0:000100000000
notification: 00000040
nick name: FW610
clock select: internal 48000
enable: 1
status: locked 48000
ext status: 00000040
sample rate: 48000
version: 1.0.4.0
clock caps: 32000 44100 48000 88200 96000 176400 192000 aes1 aes4 aes adat tdif wc arx1 arx2 internal
clock source names: SPDIF\AES34\AES56\TOS\AES_ANY\ADAT\ADAT_AUX\Word Clock\Unused\Unused\Unused\Unused\Internal\\
registration
In former commit, ALSA dice driver postpone sound card registration after
IEEE 1394 bus is calm. This idea has advantages for the other drivers.
This commit adds a helper function for it to firewire-lib module. The
function is really for the specific purpose. Callers should initialize
delayed work structure with callback function.
In former commit, ALSA dice driver doesn't generate kernel warnings
when unplugging units before initializing stream data.
This commit moves the initialization to delayed registration of sound
card, to simplify unit probe processing.
When sound card is going to be released, dice private data is
also released. Then all of data should be released. However,
stream data is not released. This causes memory leak when
unplugging dice unit.
This commit fixes the bug.
Fixes: 4bdc495c87b3('ALSA: dice: handle several PCM substreams when any isochronous streams are available')
with basic type element
In dice interface, two blocks of register are accessible via IEEE 1394
asynchronous transaction to represent the number of supported isochronous
streams and the number of quadlets for stream information.
Current ALSA dice driver uses array with 'unsigned int' element for
temporary cache of these information. But using structure is preferable
for begin easily comprehensible.
This commit applies a local structure for this aim.
Some models reduce the number of available isochronous streams for higher
sampling transfer frequency. Such models bring an issue about how to add
PCM substreams. When at lower sampling transfer frequency, the
models reports whole available streams, thus this driver can add enough
number of PCM substreams at probing time. On the other hand, at higher
sampling transfer frequency, this driver can just add reduced number of
PCM substreams. After probed, even if the sampling transfer frequency is
changed to lower rate, fewer PCM substreams are actually available. This
is inconvenience.
For the reason, this commit adds a list so that this driver assume models
on the list to have two pairs of PCM substreams. This list keeps the name
of model in which the number of available streams differs depending on
available
In former commits, ALSA dice driver can handle available isochronous
streams. This commit adds support for several PCM substreams on the
streams.
The additional PCM substreams are available via another ALSA PCM character
devices so that one ALSA PCM application can handle them without cumbersome
operations. For example, two PCM substreams are available on each stream,
two ALSA character devices are added for them. In configuration space of
alsa-lib, it's represented with 'hw:0,0' and 'hw:0,1'.
The PCM substreams are constraint to parameters of the corresponding
streams. If the PCM substreams are unavailable for some reasons,
open(2) to ALSA PCM character device returns error and reports ENXIO.
This commit enables ALSA dice driver to handle whole available streams.
In Dice, certain registers represent the number of available streams at
current sampling transfer frequency for both directions. The parameters
of each stream are represented in a block of register. This block is
aligned sequentially. These streams start simultaneously by writing
enable bit to a register.
This commit operates these registers when starting/stopping streams.
Currently ALSA dice driver handles a pair of isochronous resources for
IEC 61883-1/6 packet streaming. While, according to some documents about
ASICs named as 'Dice', several isochronous streams are available.
Here, I start to describe ASICs produced under 'Dice' name.
* Dice II (designed by wavefront semiconductor, including TCAT's IP)
* STD (with limited functionality of DTCP)
* CP (with full functionality of DTCP)
* TCD2210/2210-E (so-called 'Dice Mini')
* TCD2220/2220-E (so-called 'Dice Jr.')
* TCD3070-CH (so-called 'Dice III')
Some documents are public and we can see hardware design of them. We can
find some articles about hardware internal register definitions
(not registers exported to IEEE 1394 bus).
* DICE II User Guide
* http://www.tctechnologies.tc/archive/downloads/dice_ii_user_guide.pdf
* 6.1 AVS Audio Receivers
* Table 6.1: AVS Audio Receiver Memory Map
* ARX1-ARX4
* 6.2 AVS Audio Transmitters
* Table 6.2: AVS Audio Transmitter Memory Map
* ATX1, ATX2
* TCD22xx User Guide
* http://www.tctechnologies.tc/downloads/tcd22xx_user_guide.pdf
* Table 66: AVS Audio Receiver Memory Map
* ARX1, ARX2
* 6/2 AVS Audio Transmitters
* Table 67: AVS Audio Transmitter Memory Map
* ATX1, ATX2
* DICE III
* http://www.tctechnologies.tc/downloads/TCD3070-CH.pdf
* Dual stream 63 channel transmitter/receiver
For Dice II and TCD22xx series, maximum 16 data channels are transferred in
an AMDTP packet, while for Dice III, maximum 32 data channels are
transferred.
According to the design of the series of these ASICs, this commit allows
this driver to handle additional set of isochronous resources. For
practical reason, two pair of isochronous resources are added. As of this
commit, this driver still use a pair of the first isochronous resources.
This commit drops implementation of duplex streams synchronization
from ALSA dice driver, due to a reason of hardware design. This patch
allows dice-based units to generate sounds correctly when isochronous
packet streaming starts at first time.
In IEC 61883-6:2005, CIP packetization layer for AM824 data format
utilizes the value of SYT field in CIP header of received packet for
a reference to phase lock loop. Figure 3 in clause 4.3 describes it.
The value is an offset from cycle_time field of every cycle start packet
from cycle master on IEEE 1394 bus. The time calculated with these two
fields is called as 'presentation timestamp' which represents the time
to play data included in the packet.
Although, this idea includes some problems due to accuracy of timekeep in
cycle master, accuracy of transmission of cycle start packet on the bus
with the other units, accuracy of sampling clock in data transmitter side
and accuracy of replay in data receiver side. In most case, these
accuracies somewhat worse because there's no such ideal hardwares in this
world.
For the issues, ASICs for Dice include Jitter Elimination Technologies
(JET) PLL. The PLL can handle several sources of clock and compensate it
with high-precision internal clock source. The sequence of value in syt
field of received AMDTP packets is one of the sources, therefore
transmitters on IEEE 1394 bus should transfer it.
On the other hand, current ALSA dice driver is programmed with a mode of
duplex streams with synchronization. In this mode, the driver outputs
packets after some incoming packets are handled, to re-use the value of
SYT field in incoming packets to the value for outgoing packets. This mode
is enabled when source signal of sampling clock is set to internal, and
this is a major use case. Thus, in most cases, the unit receives no packets
during a short time after packet streaming starts.
As long as I experienced, this causes the units to generate no sounds at
first time to receive packets. This issue occurs only with Dice II. I guess
this is due to a quirk of the PLL. In short, the PLL cannot generate firm
signals to ADCs/DACs or the other ICs when no packets are received in the
beginning of packet streaming. While, on second time or later, the unit
generates sound correctly. I guess that starting packet streaming at first
time sets the PLL correctly.
Well, still based on my hypothesis and no way to prove it, this commit
drops duplex streams synchronization from this driver. At least, the PLL
requires the sequence of value in SYT field of received AMDTP packets as
one of source of clock signals with internal clock source.
As long as I tested, Dice-based models produced by TC Electronic with
factory-configured settings transfer no notification within
ensure_phase_lock(). On the other hand, with upgraded firmwares, it
starts to transfer the notification. This seems to be a quirk of earlier
firmwares.
This commit ensures phase lock by reading a register after waiting for
the notification. Even if it's timed-out, ensure_phase_lock() return
success as long as the register has expected clock status.
With former patchset, ALSA dice driver doesn't change clock parameters
anymore, while the driver still touch clock configuration for phase lock.
Although the locking status is in Dice notification, the driver doesn't
detect it. Usually, this causes no issues because in most case
NOTIFY_LOCK_CHG notification transfers after NOTIFY_CLOCK_ACCEPTED
notification, while it's better to detect locking status.
This commit changes notification mask just to detect lock status change.
In former commits, probing process has no need to set sampling transfer
frequency. Although it's OK to drop a function to change the frequency
from this module, some models require it before streaming. This seems to
be due to phase lock of clock source.
This commit moves the function from transaction layer to stream layer, and
rename it according to the purpose.
Dice interface design doesn't allow drivers to read supported combination
between sampling transfer frequencies and the number of Multi bit linear
audio data channels. Due to the design, ALSA dice driver changes current
sampling transfer frequency to generate cache of the combinations at
device probing processing.
Although, this idea is worse because ALSA dice driver changes the state of
clock. This is not what users want when they save favorite configuration
to the device in advance.
Furthermore, there's a possibility that the format of data block is decided
not only according to current sampling transfer frequency, but also the
other factors, i.e. data format for digital interface. It's not good to
generate channel cache according to the sampling transfer frequency only.
This commit purges processing cache data and related structure members. As
a result, users must set preferable sampling transfer frequency before
using ALSA PCM applications, as long as they want to start any PCM
substreams at the rate except for current one.
This commit is a preparation to remove members related to channel cache
for the number of channels for multi bit linear audio data and MIDI
ports. This commit changes the way to get the number of multi bit linear
audio data channel. It's directly retrieved by asynchronous transactions
to some registers.
This commit changes the way to add ALSA MIDI ports. This driver read the
number of multiplexed MIDI substreams from hardware register, then adds the
same number of ALSA MIDI ports. This commit is based on my assumption that
the number is fixed at all of supported sampling transfer frequency.
In previous commit, ALSA Dice driver limits PCM substreams at current
sampling transfer frequency and current number of Multi bit linear audio
data channel. Thus, the driver has no need to start AMDTP streams at
the other sampling transfer frequency except for current one. This is due
to Dice interface design.
This commit limits AMDTP stream at current sampling transfer frequency,
according to the design.
ALSA PCM core has a functionality for rule of PCM substream parameters.
Typically, when userspace opens PCM character devices, each driver adds
its own rules to PCM substream according to design of hardware. When the
userspace executes hw_params ioctl with favorite parameters, the actual
parameters are calculated according to the rules and the given parameters.
Then, the result is returned to userspace.
Currently, ALSA Dice driver has the rule between channels and rates, while
Dice interface design doesn't allow drivers to retrieve all of the
combinations. Dice drivers are just allowed to get current sampling
transfer frequency and the number of multi bit linear audio data channels
in an data block of an AMDTP packet.
This commit purges the rule, and limit PCM substreams to current sampling
transfer frequency, following to the interface design.
Some users have reported that their Dice based models generate ETIMEDOUT
when starting PCM playback. It means that current timeout (=100msec) is
not enough for their models to transfer notifications.
This commit expands the timeout up to 2 sec. As a result, in a worst case,
any operations to start AMDTP streams takes 2 sec or more. Then, in
userspace, snd_pcm_hw_params(), snd_pcm_prepare(), snd_pcm_recover(),
snd_rawmidi_open(), snd_seq_connect_from() and snd_seq_connect_to() may
take the time.
In previous commit, card registration is processed under situation
with few bus reset. There's no need to add a workaround of transaction
re-initialization at timeout.
This commit purges the re-initialization.
Some models based on ASIC for Dice II series (STD, CP) change their
hardware configurations after appearing on IEEE 1394 bus. This is due to
interactions of boot loader (RedBoot), firmwares (eCos) and vendor's
configurations. This causes current ALSA dice driver to get wrong
information about the hardware's capability because its probe function
runs just after detecting unit of the model.
As long as I investigated, it takes a bit time (less than 1 second) to load
the firmware after bootstrap. Just after loaded, the driver can get
information about the unit. Then the hardware is initialized according to
vendor's configurations. After, the got information becomes wrong.
Between bootstrap, firmware loading and post configuration, some bus resets
are observed.
This commit offloads most processing of probe function into workqueue and
schedules the workqueue after successive bus resets. This has an effect to
get correct hardware information and avoid involvement to bus reset storm.
For code simplicity, this change effects all of Dice-based models, i.e.
Dice II, Dice Jr., Dice Mini and Dice III.
I use a loose strategy to manage a race condition between the work and the
bus reset. This is due to a specification of dice transaction. When bus
reset occurs, registered address for the transaction is cleared. Drivers
must re-register their own address again. While, this operation is required
for the work because the work includes to wait for the transaction. This
commit uses no lock primitives for the race condition. Instead, checking
'registered' member of 'struct snd_dice' avoid executing the work again.
If sound card is not registered, the work can be scheduled again by bus
reset handler.
When .remove callback is executed, the sound card is going to be released.
The work should not be pending or executed in the releasing. This commit
uses cancel_delayed_work_sync() in .remove callback and wait till the
pending work finished. After .remove callback, .update callback is not
executed, therefore no works are scheduled again.
Before allocating an instance of sound card, ALSA dice driver checks
chip_ID_hi in Bus information block of Config ROM, then also checks
subaddresses. The former operation reads cache of Config ROM in Linux
FireWire subsystem, while the latter operation sends read transaction.
The latter can be merged into initialization of transaction system.
This commit splits these two operations to reduce needless transactions
in probe processing.
Commit a471fcde8c2c ("ALSA: dice: fix detection of Weiss devices") adds
a quirk of Weiss models. According to users' reports, Loud models also
have the similar quirk. They have 0x10 in the category field.
This commit adds support for Mackie Onyx Blackbird and Onyx-i series.
As long as I know, Dice-based models produced by
Focusrite/Alesis/PreSonus/M-Audio/TC Electronic have default value (0x04)
in their category field, thus it may be reasonable to add a condition
statement for Loud models, instead of removing the check of category value.
Reported-by: Rouge Etienne <erouge.externe@m6.fr>
Reported-by: Etilem <contact@etilem.net>
In former commit, u32 data was assigned to __be32 variable instead of an
int variable. This is not enough solution because it still causes sparse
warnings.
dice.c:80:23: warning: incorrect type in assignment (different base types)
dice.c:80:23: expected restricted __be32 [usertype] value
dice.c:80:23: got unsigned int
dice.c:81:21: warning: restricted __be32 degrades to integer
dice.c:81:46: warning: restricted __be32 degrades to integer
This commit fixes this bug.
Fixes: 7c2d4c0cf5ba('ALSA: dice: Split transaction functionality into a file')
Some local variables in some functions are typed as unsigned int, while
__be32 value is assigned to them. This causes sparse warnings.
dice-stream.c:50:17: warning: incorrect type in assignment (different base types)
dice-stream.c:50:17: expected unsigned int [unsigned] channel
dice-stream.c:50:17: got restricted __be32 [usertype] <noident>
dice-stream.c:74:17: warning: incorrect type in assignment (different base types)
dice-stream.c:74:17: expected unsigned int [unsigned] channel
dice-stream.c:74:17: got restricted __be32 [usertype] <noident>
Fixes: 288a8d0cb04f('ALSA: dice: Change the way to start stream')
When committed to upstream, these four modules had wrong entries for
Makefile. This forces them to be loadable modules even if they're set
as built-in.
Fixes: b5b04336015e('ALSA: fireworks: Add skelton for Fireworks based devices')
Fixes: fd6f4b0dc167('ALSA: bebob: Add skelton for BeBoB based devices')
Fixes: 1a4e39c2e5ca('ALSA: oxfw: Move to its own directory')
Fixes: 14ff6a094815('ALSA: dice: Move file to its own directory')
This commit renames some macros just related to AM824 format. In later
commit, they're moved to AM824 layer.
Setting the format of PCM substream to AMDTP stream structure is important
to set a handler to copy actual PCM samples between buffers. The
processing should be in data block processing layer because essentially
it has no relationship to packet streaming.
This commit renames PCM format setting function to prepare for integrating
AM824 layer.
In IEC 61883-6, MIDI messages are transferred in MIDI conformant data
channel. Essentially, packet streaming layer is not responsible for MIDI
functionality.
This commit moves MIDI trigger helper function from the layer to AM824
layer. The rest of codes related to MIDI functionality will be moved in
later commits.
In IEC 61883-6, several types of data are available in AM824 format. The
data is transferred in each data channel. The position of data channel in
data block differs depending on model.
Current implementation has an array to map the index of data channel in an
data block to the position of actual data channel. The implementation
allows each driver to access the mapping directly.
In later commit, the mapping is in specific structure pushed into an
opaque pointer. Helper functions are required.
This commit adds the helper functions for this purpose. In IEC 61883-6,
AM824 format supports many data types, while this specification easily
causes over-engineering. Current AM824 implementation is allowed to handle
two types of data, Multi Bit Linear Audio data (=PCM samples) and MIDI
conformant data (=MIDI messages).
In IEC 61883-6, PCM frames are transferred in Multi Bit Linear Audio data
channel. The data channel transfers 16/20/24 bit PCM samples. Thus, PCM
substream has a constrain about it.
This commit moves codes related to the constraint from packet streaming
layer to AM824 data block processing layer.
The value of FDF field in CIP header is protocol-dependent. Thus, it's
better to allow data block processing layer to decide the value in any
timing.
In AM824 data format, the value of FDF field in CIP header indicates
N-flag and Nominal Sampling Frequency Code (sfc). The N-flag is for
switching 'Clock-based rate control mode' and 'Command-based rate control
mode'. In our implementation, 'Clock-based rate control mode' is just
supported. Therefore, When sampling transfer frequency is decided, then
the FDF can be set.
This commit replaces 'amdtp_stream_set_parameters' with
'amdtp_am824_set_parameters' to set the FDF. This is the same timing
to decide the ration between the number of data blocks and the number of
PCM frames.
This commit adds data block processing layer for AM824 format. The new
layer initializes streaming layer with its value for fmt field.
Currently, most implementation of data block processing still remains
streaming layer. In later commits, these codes will be moved to the layer.
functional separation
In later commit, data block processing layer will be newly added. This
layer will be named as 'amdtp-am824'.
This commit renames current amdtp file to amdtp-stream, to distinguish it
from the new layer.
In IEC 61883-6, one data block represents one event. In ALSA, the event is
one PCM frame. Therefore, when processing one data block, current
implementation counts one PCM frame.
On the other hand, Dice platform has a quirk called as 'dual wire' at
higher sampling rate. In detail, see comment of commit 6eb6c81eee2a
("ALSA: dice: Split stream functionality into a file").
Currently, to handle this quirk, AMDTP stream structure has a
'double_pcm_frames' member. When this is enabled, two PCM frames are
counted. Each driver set this flag by accessing the structure member
directly.
In future commit, some members related to AM824 data block will be moved
to specific structure, to separate packet streaming layer and data block
processing layer. The access will be limited by opaque pointer.
For this reason, this commit adds an argument into
amdtp_stream_set_parameter() to set the flag.
detects error
Currently, amdtp_stream_set_parameters() returns no error even if wrong
arguments are given. This is not good for streaming layer because drivers
can continue processing ignoring capability of streaming layer.
This commit changes this function to return error code.
In PCM core, when hw_params() in each driver returns error, the state of
PCM substream is kept as 'open'. In this case, current drivers for sound
units on IEEE 1394 bus doesn't decrement substream counter in hw_free()
correctly. This causes these drivers to keep streams even if not
required.
This commit fixes this bug. When snd_pcm_lib_alloc_vmalloc_buffer()
fails, hw_params function in each driver returns without incrementing the
counter.
Reported-by: Takashi Iwai <tiwai@suse.de>
This reverts commit 8cdebf71098c07168ef6335e2f1f35d85dbe3049.
The reverted commit breaks out-stream functionality of Dice driver.
For received packet stream, the offset of 'RX_SEQ_START' locates after
the offset of 'RX_NUMBER_MIDI', although current macro and proc output
includes wrong offsets.
Fortunately, this bug doesn't affect streaming functionality because
these macro is not used.
This commit fixes these wrong macro and outputs.
A part of these drivers, especially BeBoB driver, are programmed to wait
some events. Thus the drivers should not destroy any data in .remove()
context.
This commit moves some destructors from 'struct fw_driver.remove()' to
'struct snd_card.private_free()' to shutdown safely.
Cc: <stable@vger.kernel.org> # 3.19+
Currently stream destructor in each driver has a problem to be called in
a context in which sound card object is released, because the destructors
call amdtp_stream_pcm_abort() and touch PCM runtime data.
The PCM runtime data is destroyed in application's context with
snd_pcm_close(), on the other hand PCM substream data is destroyed after
sound card object is released, in most case after all of ALSA character
devices are released. When PCM runtime is destroyed and PCM substream is
remained, amdtp_stream_pcm_abort() touches PCM runtime data and causes
Null-pointer-dereference.
This commit changes stream destructors and allows each driver to call
it after releasing runtime.
Fireworks and Dice drivers try to touch instances of FireWire unit after
sound card object is released, while references to the unit is decremented
in .remove(). When unplugging during streaming, sound card object is
released after .remove(), thus Fireworks and Dice drivers causes GPF or
Null-pointer-dereferencing to application processes because an instance of
FireWire unit was already released.
This commit adds reference-counting for FireWire unit in drivers to allow
them to touch an instance of FireWire unit after .remove(). In most case,
any operations after .remove() may be failed safely.
This commit adds a support for MIDI capture/playback
When MIDI substrams already start streaming and PCM substreams are going to
join at different sampling rate, streams are stopped once. Then sampling rate
is changed and streams are restarted.
This commit adds a support for capturing PCM samples.
When opposite PCM substream is already running, available sampling rate is
limited at current one.
This commit allows this driver to handle devices with non SYT-Match
sampling clock source.
When sampling clock source is SYT-Match mode, devices handle
'presentation timestamp' in received packets and generates sampling clock
according to the information. In this case, driver is synchronization master
and must transfer correct value in SYT field of each packets in outgoing
stream, then the outgoing stream is a master stream.
On the other hand, non SYT-Match mode, devices do this. So drivers must pick
up the value in SYT field of incoming packets and use the value for outgoing
stream. Currently firewire-lib module achieve this work.
Furthermore, without SYT-Match and internal clock source, the sampling rate
should be fixed for the other devices connected to the handled device. This
commit add a restriction of sampling rate at this situation.
With these implementations, this driver has no need to set clock source.
This commit remove set function.
This commit adds support for AMDTP in-stream. As a result, Dice driver
supports full duplex streams with synchronization.
AMDTP can transfer timestamps in its packets. By handling the timestamp,
devices can synchronize to the other devices or drivers on the same bus.
When Dice chipset is 'enabled', it starts streams with correct settings.
This 'enable' register is global, thus, when a stream is started to run,
an opposite stream can't start unless turning off 'enable'. Therefore
a pair of streams must be running. This causes a loss of CPU usage when
single stream is needed for neither playbacking or capturing.
This commit assumes that playback-only models also have a functionality
to transmit stream for delivering timestamps.
Currently, sampling clock source is restricted to SYT-Match mode. This is
improved in followed commit. I note that at SYT-Match mode, Dice can select
from 4 streams for synchronization but this driver uses the 1st stream only
for simplicity.
Streaming functionality can start streams when rate is given but currently
some codes are in PCM functionality.
This commit changes the way to start stream and add some arrangement
to make it easy to understand the way.
