Since commit f2b3614cefb6 (Don't check DMA time-out too shortly),
drivers need no longer restrict their PCM period length to be shorter
than 10 seconds.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
When aborting a PCM stream, the xrun is signaled only if the stream is
running. When disconnecting a PCM stream, calling snd_card_disconnect()
too early would change the stream into a non-running state and thus
prevent the xrun from being noticed by user space.
To prevent this, move the snd_card_disconnect() call after the xrun.
Add an AMDTP stream error state that occurs when we fail to queue
another packet. In this case, the stream is stopped, and the error can
be reported when the application tries to restart the PCM stream.
Add a driver for two playback-only FireWire devices based on the OXFW970
chip.
v2: better AMDTP API abstraction; fix fw_unit leak; small fixes
v3: cache the iPCR value
v4: FireWave constraints; fix fw_device reference counting;
fix PCR caching; small changes and fixes
v5: volume/mute support; fix crashing due to pcm stop races
v6: fix build; one-channel volume for LaCie
v7: use signed values to make volume (range checks) work; fix function
block IDs for volume/mute; always use channel 0 for LaCie volume
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Tested-by: Jay Fenlason <fenlason@redhat.com>
