path: root/sound/firewire
2013-07-15Merge branch 'for-3.12' into for-nextTakashi Iwai
2013-07-10Merge tag 'firewire-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull firewire updates from Stefan Richter: "Make struct ieee1394_device_id.driver_data actually avaliable to 1394 protocol drivers. This is especially useful to 1394 audio drivers for model-specific parameters and methods" * tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: remove support of fw_driver.driver.probe and .remove methods firewire: introduce fw_driver.probe and .remove methods
2013-07-10ALSA: firewire-speakers: remove not-reused member from structureTakashi Sakamoto
"pcm" member in struct fwspk is used to set pcm operations but is not used again. This commit remove this member and set pcm operations with snd_pcm_set_ops(). Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-25ALSA: snd-firewire-lib: remove unused header inclusionTakashi Sakamoto
spinlock is not used in amdtp.h. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-18ALSA: firewire: fix error return code in scs_probe()Wei Yongjun
Fix to return -ENOMEM in the kmalloc() error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-09firewire: introduce fw_driver.probe and .remove methodsStefan Richter
FireWire upper layer drivers are converted from generic struct driver.probe() and .remove() to bus-specific struct fw_driver.probe() and .remove(). The new .probe() adds a const struct ieee1394_device_id *id argument, indicating the entry in the driver's device identifiers table which matched the fw_unit to be probed. This new argument is used by the snd-firewire-speakers driver to look up device-specific parameters and methods. There is at least one other FireWire audio driver currently in development in which this will be useful too. The new .remove() drops the unused error return code. Although all in-tree drivers are being converted to the new methods, support for the old methods is left in place in this commit. This allows public developer trees to merge this commit and then move to the new fw_driver methods. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Clemens Ladisch <clemens@ladisch.de> (for sound/firewire/) Cc: Peter Hurley <peter@hurleysoftware.com> (for drivers/staging/fwserial/)
2012-12-07ALSA: firewire-speakers: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-12ALSA: firewire: add Stanton SCS.1d/1m driverClemens Ladisch
Add a MIDI driver for the Stanton FireWire DJ controllers. Tested-by: Sean M. Pappalardo - D.J. Pegasus <spappalardo@mixxx.org> Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2012-05-24Merge tag 'firewire-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull IEEE 1394 (FireWire) subsystem updates from Stefan Richter: - Fix mismatch between DMA mapping direction (was wrong) and DMA synchronization direction (was correct) of isochronous reception buffers of userspace drivers if vma-mapped for R/W access. For example, libdc1394 was affected. - more consistent retry stategy in device discovery/ rediscovery, and improved failure diagnostics - various small cleanups, e.g. use SCSI layer's DMA mapping API in firewire-sbp2 * tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: sbp2: document the absence of alignment requirements firewire: sbp2: remove superfluous blk_queue_max_segment_size() call firewire: sbp2: use scsi_dma_(un)map firewire: sbp2: give correct DMA device to scsi framework firewire: core: fw_device_refresh(): clean up error handling firewire: core: log config rom reading errors firewire: core: log error in case of failed bus manager lock firewire: move rcode_string() to core firewire: core: improve reread_config_rom() interface firewire: core: wait for inaccessible devices after bus reset firewire: ohci: omit spinlock IRQ flags where possible firewire: ohci: correct signedness of a local variable firewire: core: fix DMA mapping direction firewire: use module_pci_driver
2012-05-14ALSA: firewire-lib: optimize packet flushingClemens Ladisch
Trying to flush completed packets is pointless when the pointer callback was called from the packet completion callback; avoid it. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-14ALSA: firewire-lib: flush completed packets when reading PCM positionClemens Ladisch
By flushing all completed but not yet reported packets before reading the PCM hardware position, the granularity of the pointer is improved from the interrupt interval to the packet size. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-14ALSA: firewire-lib: taskletize the snd_pcm_period_elapsed() callClemens Ladisch
The following patch might introduce this call chain: PCM .pointer callback + fw_iso_context_flush_completions + packet callback + snd_pcm_period_elapsed + PCM .pointer callback Recursive calls to the pointer callback are not possible due to the PCM group locking, so avoid this by moving the period notification into a separate tasklet. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-17firewire: move rcode_string() to coreClemens Ladisch
There is nothing audio-specific about the rcode_string() helper, so move it from snd-firewire-lib into firewire-core to allow other code to use it. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (fixed sound/firewire/cmp.c)
2012-03-22Merge tag 'firewire-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull IEEE 1394 (FireWire) subsystem updates post v3.3 from Stefan Richter: - Some SBP-2 initiator fixes, side product from ongoing work on a target. - Reintroduction of an isochronous I/O feature of the older ieee1394 driver stack (flush buffer completions); it was evidently rarely used but not actually unused. Matching libraw1394 code is already available. - Be sure to prefix all kernel log messages with device name or card name, and other logging related cleanups. - Misc other small cleanups, among them a small API change that affects sound/firewire/ too. Clemens Ladisch is aware of it. * tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: (26 commits) firewire: allow explicit flushing of iso packet completions firewire: prevent dropping of completed iso packet header data firewire: ohci: factor out iso completion flushing code firewire: ohci: simplify iso header pointer arithmetic firewire: ohci: optimize control bit checks firewire: ohci: remove unused excess_bytes field firewire: ohci: copy_iso_headers(): make comment match the code firewire: cdev: fix IR multichannel event documentation firewire: ohci: fix too-early completion of IR multichannel buffers firewire: ohci: move runtime debug facility out of #ifdef firewire: tone down some diagnostic log messages firewire: sbp2: replace a GFP_ATOMIC allocation firewire: sbp2: Fix SCSI sense data mangling firewire: sbp2: Ignore SBP-2 targets on the local node firewire: sbp2: Take into account Unit_Unique_ID firewire: nosy: Use the macro DMA_BIT_MASK(). firewire: core: convert AR-req handler lock from _irqsave to _bh firewire: core: fix race at address_handler unregistration firewire: core: remove obsolete comment firewire: core: prefix log messages with card name ...
2012-01-15firewire: move fw_device reference counting from drivers to coreStefan Richter
fw_unit device drivers invariably need to talk to the fw_unit's parent (an fw_device) and grandparent (an fw_card). firewire-core already maintains an fw_card reference for the entire lifetime of an fw_device. Likewise, let firewire-core maintain an fw_device reference for the entire lifetime of an fw_unit so that fw_unit drivers don't have to. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-10-31treewide: use __printf not __attribute__((format(printf,...)))Joe Perches
Standardize the style for compiler based printf format verification. Standardized the location of __printf too. Done via script and a little typing. $ grep -rPl --include=*.[ch] -w "__attribute__" * | \ grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \ xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }' [akpm@linux-foundation.org: revert arch bits] Signed-off-by: Joe Perches <joe@perches.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31sound: Add export.h for THIS_MODULE/EXPORT_SYMBOL where neededPaul Gortmaker
These aren't modules, but they do make use of these macros, so they will need export.h to get that definition. Previously, they got it via the implicit module.h inclusion. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-04ALSA: firewire-speakers: fix lockingStefan Richter
There is a lock inversion between fwspk->mutex and pcm->open_mutex reported by lockdep when fwspk_hw_free is called. Fixed by copying the fix from the same former issue in the isight sound driver (commit f3f7c1837f6bcae3601fc535b339426868bf1549 "ALSA: isight: fix locking"). Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-15ALSA: isight: remove superfluous fieldClemens Ladisch
Remove a field that is not used at all. This remained from earlier tests, but the current driver has decided not to handle iris notifications. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-17Merge branch 'fix/hda' into topic/miscTakashi Iwai
2011-06-17ALSA: isight: adjust for new queueing APIClemens Ladisch
Since commit 13882a82ee16 (optimize iso queueing by setting wake only after the last packet), drivers are required to call fw_iso_context_queue_flush() after queueing a batch of packets. The missing call would have an effect only if the controller queue underruns, but then the DMA would stop completely. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-17ALSA: firewire-speakers, oxygen, ua101: allow > 10 s periodsClemens Ladisch
Since commit f2b3614cefb6 (Don't check DMA time-out too shortly), drivers need no longer restrict their PCM period length to be shorter than 10 seconds. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (346 commits) ASoC: core: Don't set "(null)" as a driver name ALSA: hda - Use LPIB for ATI/AMD chipsets as default Revert "ALSA: hda - Use position_fix=3 as default for AMD chipsets" ASoC: Tegra: Fix compile when debugfs not enabled ASoC: spdif-dit: Add missing MODULE_* SOUND: OSS: Remove Au1550 driver. ALSA: hda - add Intel Panther Point HDMI codec id ALSA: emu10k1 - Add dB range to Bass and Treble for SB Live! ALSA: hda - Remove PCM mixer elements from Virtual Master of realtek ALSA: hda - Fix input-src parse in patch_analog.c ASoC: davinci-mcasp: enable ping-pong SRAM buffers ASoC: add iPAQ hx4700 machine driver ASoC: Asahi Kasei AK4641 codec driver ALSA: hda - Enable Realtek ALC269 codec input layer beep ALSA: intel8x0m: enable AMD8111 modem ALSA: HDA: Add jack detection for HDMI ALSA: sound, core, pcm_lib: fix xrun_log ASoC: Max98095: Move existing NULL check before pointer dereference. ALSA: sound, core, pcm_lib: xrun_log: log also in_interrupt ALSA: usb-audio - Add support for USB X-Fi S51 Pro ...
2011-05-11ALSA: isight: fix lockingClemens Ladisch
Lockdep complains about conflicts between isight->mutex, ALSA's register_mutex, mm->mmap_sem, and pcm->open_mutex. This can be fixed by moving the calls to isight_pcm_abort(), snd_card_disconnect(), and fw_iso_resources_update() out of isight->mutex. These functions are designed to be called asynchronously; the mutex needs to protect only the device streaming state modified by isight_start/stop_streaming(). Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Reported-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-11ALSA: isight: remove experimental statusClemens Ladisch
Experiments have shown this driver to work now. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Tested-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-11ALSA: isight: fix hang when unplugging a running deviceClemens Ladisch
When aborting a PCM stream, the xrun is signaled only if the stream is running. When disconnecting a PCM stream, calling snd_card_disconnect() too early would change the stream into a non-running state and thus prevent the xrun from being noticed by user space. To prevent this, move the snd_card_disconnect() call after the xrun. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-11ALSA: isight: wrap up register accessesStefan Richter
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> [cl: removed superfluous variable] Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-11ALSA: isight: add AudioEnable register writeStefan Richter
which is needed to get the iSight to talk. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-11ALSA: isight: fix divide error when queueing packetsClemens Ladisch
Set the .header_size field when queueing packets to avoid a division by zero. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-11ALSA: isight: fix packet requeueingClemens Ladisch
After handling a received packet, we want to resubmit the same packet, so do not increase the packet index too early. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-11ALSA: isight: fix isight_pcm_abort() crashesClemens Ladisch
Fix crashes in isight_pcm_abort() that happen when the driver tries to access isight->pcm->runtime which does not exist when the device is not open. Introduce a new field pcm_active to track this state. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Reported-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-11ALSA: add Apple iSight microphone driverClemens Ladisch
This adds an experimental driver for the front and rear microphones of the Apple iSight web camera. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-10firewire: optimize iso queueing by setting wake only after the last packetClemens Ladisch
When queueing iso packets, the run time is dominated by the two MMIO accesses that set the DMA context's wake bit. Because most drivers submit packets in batches, we can save much time by removing all but the last wakeup. The internal kernel API is changed to require a call to fw_iso_context_queue_flush() after a batch of queued packets. The user space API does not change, so one call to FW_CDEV_IOC_QUEUE_ISO must specify multiple packets to take advantage of this optimization. In my measurements, this patch reduces the time needed to queue fifty skip packets from userspace to one sixth on a 2.5 GHz CPU, or to one third at 800 MHz. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2011-05-10firewire: octlet AT payloads can be stack-allocatedStefan Richter
We do not need slab allocations anymore in order to satisfy streaming DMA mapping constraints, thanks to commit da28947e7e36 "firewire: ohci: avoid separate DMA mapping for small AT payloads". (Besides, the slab-allocated buffers that firewire-core, firewire-sbp2, and firedtv used to provide for 8-byte write and lock requests were still not fully portable since they crossed cacheline boundaries or shared a cacheline with unrelated CPU-accessed data. snd-firewire-lib got this aspect right by using an extra kmalloc/ kfree just for the 8-byte transaction buffer.) This change replaces kmalloc'ed lock transaction scratch buffers in firewire-core, firedtv, and snd-firewire-lib by local stack allocations. Perhaps the most notable result of the change is simpler locking because there is no need to serialize usages of preallocated per-device buffers anymore. Also, allocations and deallocations are simpler. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Clemens Ladisch <clemens@ladisch.de>
2011-03-30ALSA: firewire-speakers: fix hang when unplugging a running deviceClemens Ladisch
2011-03-16ALSA: firewire - msleep needs delay.hStephen Rothwell
fixes this error: sound/firewire/fcp.c: In function 'fcp_avc_transaction': sound/firewire/fcp.c:103: error: implicit declaration of function 'msleep' Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-15ALSA: firewire-lib, firewire-speakers: handle packet queueing errorsClemens Ladisch
Add an AMDTP stream error state that occurs when we fail to queue another packet. In this case, the stream is stopped, and the error can be reported when the application tries to restart the PCM stream. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-15ALSA: firewire-lib: allocate DMA buffer separatelyClemens Ladisch
For correct cache coherency on some architectures, DMA buffers must be allocated in a different cache line than data that is concurrently used by the CPU. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-15ALSA: firewire-lib: use no-info SYT for packets without SYT sampleClemens Ladisch
In non-blocking mode, the SYT_INTERVAL is larger than the number of audio frames in each packet, so there are packets that do not contain any frame to which the SYT could be applied. For these packets, the SYT must not be the timestamp of the next valid SYT frame, but the special no-info SYT value. This fixes broken playback on the FireWave at 44.1 kHz. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-15ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driverClemens Ladisch
Add a driver for two playback-only FireWire devices based on the OXFW970 chip. v2: better AMDTP API abstraction; fix fw_unit leak; small fixes v3: cache the iPCR value v4: FireWave constraints; fix fw_device reference counting; fix PCR caching; small changes and fixes v5: volume/mute support; fix crashing due to pcm stop races v6: fix build; one-channel volume for LaCie v7: use signed values to make volume (range checks) work; fix function block IDs for volume/mute; always use channel 0 for LaCie volume Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Tested-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
