path: root/sound/i2c
2013-03-24[media] v4l2: add const to argument of write-only s_tuner ioctlHans Verkuil
This ioctl is defined as IOW, so pass the argument as const. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-24[media] v4l2: add const to argument of write-only s_frequency ioctlHans Verkuil
This ioctl is defined as IOW, so pass the argument as const. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-11-04ALSA: Fix typo in drivers soundMasanari Iida
Correct spelling typo in debug messages within drivers/sound Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-10-07Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "The first part of the media updates for Kernel 3.7. This series contain: - A major tree renaming patch series: now, drivers are organized internally by their used bus, instead of by V4L2 and/or DVB API, providing a cleaner driver location for hybrid drivers that implement both APIs, and allowing to cleanup the Kconfig items and make them more intuitive for the end user; - Media Kernel developers are typically very lazy with their duties of keeping the MAINTAINERS entries for their drivers updated. As now the tree is more organized, we're doing an effort to add/update those entries for the drivers that aren't currently orphan; - Several DVB USB drivers got moved to a new DVB USB v2 core; the new core fixes several bugs (as the existing one that got bitroted). Now, suspend/resume finally started to work fine (at least with some devices - we should expect more work with regards to it); - added multistream support for DVB-T2, and unified the API for DVB-S2 and ISDB-S. Backward binary support is preserved; - as usual, a few new drivers, some V4L2 core improvements and lots of drivers improvements and fixes. There are some points to notice on this series: 1) you should expect a trivial merge conflict on your tree, with the removal of Documentation/feature-removal-schedule.txt: this series would be adding two additional entries there. I opted to not rebase it due to this recent change; 2) With regards to the PCTV 520e udev-related breakage, I opted to fix it in a way that the patches can be backported to 3.5 even without your firmware fix patch. This way, Greg doesn't need to rush backporting your patch (as there are still the firmware cache and firmware path customization issues to be addressed there). I'll send later a patch (likely after the end of the merge window) reverting the rest of the DRX-K async firmware request, fully restoring its original behaviour to allow media drivers to initialize everything serialized as before for 3.7 and upper. 3) I'm planning to work on this weekend to test the DMABUF patches for V4L2. The patches are on my queue for several Kernel cycles, but, up to now, there is/was no way to test the series locally. I have some concerns about this particular changeset with regards to security issues, and with regards to the replacement of the old VIDIOC_OVERLAY ioctl's that is broken on modern systems, due to GPU drivers change. The Overlay API allows direct PCI2PCI transfers from a media capture card into the GPU framebuffer, but its API is crappy. Also, the only existing X11 driver that implements it requires a XV extension that is not available anymore on modern drivers. The DMABUF can do the same thing, but with it is promising to be a properly-designed API. If I can successfully test this series and be happy with it, I should be asking you to pull them next week." * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (717 commits) em28xx: regression fix: use DRX-K sync firmware requests on em28xx drxk: allow loading firmware synchrousnously em28xx: Make all em28xx extensions to be initialized asynchronously [media] tda18271: properly report read errors in tda18271_get_id [media] tda18271: delay IR & RF calibration until init() if delay_cal is set [media] MAINTAINERS: add Michael Krufky as tda827x maintainer [media] MAINTAINERS: add Michael Krufky as tda8290 maintainer [media] MAINTAINERS: add Michael Krufky as cxusb maintainer [media] MAINTAINERS: add Michael Krufky as lg2160 maintainer [media] MAINTAINERS: add Michael Krufky as lgdt3305 maintainer [media] MAINTAINERS: add Michael Krufky as mxl111sf maintainer [media] MAINTAINERS: add Michael Krufky as mxl5007t maintainer [media] MAINTAINERS: add Michael Krufky as tda18271 maintainer [media] s5p-tv: Report only multi-plane capabilities in vidioc_querycap [media] s5p-mfc: Fix misplaced return statement in s5p_mfc_suspend() [media] exynos-gsc: Add missing static storage class specifiers [media] exynos-gsc: Remove <linux/version.h> header file inclusion [media] s5p-fimc: Fix incorrect condition in fimc_lite_reqbufs() [media] s5p-tv: Fix potential NULL pointer dereference error [media] s5k6aa: Fix possible NULL pointer dereference ...
2012-09-26[media] radio drivers: in non-blocking mode return EAGAIN in hwseekHans Verkuil
VIDIOC_S_HW_FREQ_SEEK should return EAGAIN when called in non-blocking mode. This might change in the future if we add support for this in the future, but right now this is not supported. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-26[media] v4l2: make vidioc_s_freq_hw_seek constHans Verkuil
Write-only ioctls should have a const argument in the ioctl op. Do this conversion for vidioc_s_freq_hw_seek. Adding const for write-only ioctls was decided during the 2012 Media Workshop. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-13[media] radio-shark: Add support for suspend & resumeHans de Goede
Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-13[media] snd_tea575x: Add support for tuning AMHans de Goede
Add support for tuning AM (on devices with the necessary additional hardware components), and advertise the available bands using the new VIDIOC_ENUM_FREQ_BANDS ioctl. Signed-off-by: Hans de Goede <hdegoede@redhat.com> CC: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-07-30[media] snd_tea575x: Add a cannot_mute flagHans de Goede
Some devices which use the tea575x tuner chip don't allow direct control over the IO pins, and thus cannot mute the audio output. Signed-off-by: Hans de Goede <hdegoede@redhat.com> CC: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-30[media] snd_tea575x: Add write_/read_val operationsHans de Goede
Some devices which use the tea575x tuner chip don't allow bit banging the lines, instead they offer a method to directly set / get the contents of the 25 bit shift-register in the chip. Notably the Griffin radioSHARK USB radio receiver does this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> CC: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-27Merge branch 'v4l_for_linus' into staging/for_v3.6Mauro Carvalho Chehab
* v4l_for_linus: (44 commits) [media] smia: Fix compile failures [media] Fix VIDIOC_DQEVENT docbook entry [media] s5p-fimc: Fix control creation function [media] s5p-mfc: Fix checkpatch error in s5p_mfc_shm.h file [media] s5p-mfc: Fix setting controls [media] v4l/s5p-mfc: added image size align in VIDIOC_TRY_FMT [media] v4l/s5p-mfc: corrected encoder v4l control definitions [media] v4l: mem2mem_testdev: Fix race conditions in driver [media] s5p-mfc: Bug fix of timestamp/timecode copy mechanism [media] cxd2820r: Fix an incorrect modulation type bitmask [media] em28xx: Show a warning if the board does not support remote controls [media] em28xx: Add remote control support for Terratec's Cinergy HTC Stick HD [media] USB: Staging: media: lirc: initialize spinlocks before usage [media] Revert "[media] media: mx2_camera: Fix mbus format handling" [media] bw-qcam: driver and pixfmt documentation fixes [media] cx88: fix firmware load on big-endian systems [media] cx18: support big-endian systems [media] ivtv: fix support for big-endian systems [media] tuner-core: return the frequency range of the correct tuner [media] v4l2-dev.c: fix g_parm regression in determine_valid_ioctls() ... Conflicts: Documentation/DocBook/media/v4l/vidioc-create-bufs.xml drivers/media/video/em28xx/em28xx-cards.c
2012-06-18[media] S_HW_FREQ_SEEK: set capability flags and return ENODATA instead of ↵Hans Verkuil
EAGAIN Set the new capability flags in G_TUNER and return ENODATA if no channels were found. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11[media] snd_tea575x: set_freq: update cached freq to the actual achieved ↵Hans de Goede
frequency Signed-off-by: Hans de Goede <hdegoede@redhat.com> CC: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11[media] snd_tea575x: Make the module using snd_tea575x the fops ownerHans de Goede
Before this patch the owner field of the /dev/radio# device fops was set to the snd-tea575x-tuner module itself. Meaning that the module which was using it could be rmmod-ed while the device is open, and then BAD things happen. I know, as I found out the hard way :) Note that there is no need to also somehow increase the refcount of the snd-tea575x-tuner module itself, since any drivers using it will have symbolic references to it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> CC: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11[media] snd_tea575x: Report correct frequency range for EU/US versus JA modelsHans de Goede
My EU/US 5757 cannot tune below approx 86 Mhz, that is below that it does not even generate the standard not tuned to anything radio noise anymore, so clearly the 5757 cannot tune to the Japanese frequencies. This patch assumes that likewise the 5759 cannot tune to the EU/US frequencies. Signed-off-by: Hans de Goede <hdegoede@redhat.com> CC: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l2-dev: rename two functionsHans Verkuil
Rename the function v4l2_dont_use_lock to v4l2_disable_ioctl_locking, and rename v4l2_dont_use_cmd to v4l2_disable_ioctl. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] tea575x-tuner: mark VIDIOC_S_HW_FREQ_SEEK as an invalid ioctlHans Verkuil
The tea575x-tuner framework can support the VIDIOC_S_HW_FREQ_SEEK for only some of the tea575x-based boards. Mark this ioctl as invalid if the board doesn't support it. This fixes an issue with S_HW_FREQ_SEEK in combination with priority handling: since the priority check is done first it could return -EBUSY, even though calling the S_HW_FREQ_SEEK ioctl would return -ENOTTY. It should always return ENOTTY in such a case. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] tea575x: fix HW seekHans Verkuil
Fix HW seek in TEA575x to work properly: - a delay must be present after search start and before first register read or the seek does weird things - when the search stops, the new frequency is not available immediately, we must wait until it appears in the register (fortunately, we can clear the frequency bits when starting the search as it starts at the frequency currently set, not from the value written) - sometimes, seek remains on the current frequency (or moves only a little), so repeat it until it moves by at least 50 kHz Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] tea575x-tuner: update to latest V4L2 framework requirementsHans Verkuil
The tea575x-tuner module has been updated to use the latest V4L2 framework functionality. This also required changes in the drivers that rely on it. The tea575x changes are: - The drivers must provide a v4l2_device struct to the tea module. - The radio_nr module parameter must be part of the actual radio driver, and not of the tea module. - Changed the frequency range to the normal 76-108 MHz range instead of 50-150. - Add hardware frequency seek support. - Fix broken rxsubchans/audmode handling. - The application can now select between stereo and mono. - Support polling for control events. - Add V4L2 priority handling. And radio-sf16fmr2.c now uses the isa bus kernel framework. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Thanks-to: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-10-31sound: Add module.h to the previously silent sound usersPaul Gortmaker
Lots of sound drivers were getting module.h via the implicit presence of it in <linux/device.h> but we are going to clean that up. So fix up those users now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-27[media] tea575x: remove useless input ioctlsOndrej Zary
Remove empty and useless g_input and s_input ioctls. This fixes one fail of v4l2-compliance test. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] tea575x: allow multiple opensOndrej Zary
Change locking to allow tea575x-radio device to be opened multiple times. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] tea575x: convert to control frameworkOndrej Zary
Convert tea575x-tuner to use the new V4L2 control framework. Also add ext_init() callback that can be used by a card driver for additional initialization right before registering the video device (for SF16-FMR2). Also embed struct video_device to struct snd_tea575x to simplify the code. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-13ALSA: tea575x: use better card and bus namesOndrej Zary
Provide real card and bus_info instead of hardcoded values. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-13ALSA: tea575x: remove freq_fixup from structOndrej Zary
freq_fixup is a constant, no need to hold it in struct snd_tea575x and set in each driver. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-10ALSA: tea575x: unify read/write functionsOndrej Zary
Implement generic read/write functions to access TEA575x tuners. They're now implemented 4 times (once in es1968 and 3 times in fm801). This also allows mute to work on all cards. Also improve tuner detection/initialization. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-21ALSA: es1968: add radio (tea575x tuner) supportOndrej Zary
Add TEA5757 radio tuner support to es1968 driver. This is found at least on MediaForte SF64-PCE2 sound cards. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-21ALSA: tea575x-tuner: various improvementsOndrej Zary
Improve tea575x-tuner with various good things from radio-maestro: - extend frequency range to 50-150MHz - fix querycap(): card name, CAP_RADIO - improve g_tuner(): CAP_STEREO, stereo and tuned indication - improve g_frequency(): tuner index checking and reading frequency from HW - improve s_frequency(): tuner index and type checking Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-13sound: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is deprecated and scheduled to be removed. * cancel[_delayed]_work() + flush_scheduled_work() -> cancel[_delayed]_work_sync(). * wm8350, wm8753 and soc-core use custom code to cancel a delayed work, execute it immediately if it was pending and wait for its completion. This is equivalent to flush_delayed_work_sync(). Use it instead. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-11Merge branch 'fix/misc' into topic/miscTakashi Iwai
2010-09-30ALSA: i2c/other/ak4xx-adda: Fix a compile warning with CONFIG_PROCFS=nTakashi Iwai
2010-09-07sound: Remove unnecessary casts of private_dataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-16Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-04-15ALSA: i2c: Fixed 8 checkpatch errorsBrian Waters
Fixed 8 checkpatch errors (ERROR: do not use assignment in if condition) in sound/i2c/i2c.c. Signed-off-by: Brian Waters <brianmwaters@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: mixart: range checking proc file ALSA: hda - Fix a wrong array range check in patch_realtek.c ALSA: ASoC: move dma_data from snd_soc_dai to snd_soc_pcm_stream ALSA: hda - Enable amplifiers on Acer Inspire 6530G ASoC: Only do WM8994 bias off transition from standby ASoC: Don't use DCS_DATAPATH_BUSY for WM hubs devices ASoC: Don't do runtime wm_hubs DC servo updates if using offset correction ASoC: Support second DC servo readback method for wm_hubs ASoC: Avoid wraparound in wm_hubs DC servo correction ALSA: echoaudio - Eliminate use after free ALSA: i2c: cleanup: change parameter to pointer ALSA: hda - Add MSI blacklist for Aopen MZ915-M ASoC: OMAP: Fix capture pointer handling for OMAP1510 to work correctly with recent ALSA PCM code ALSA: hda - Update document about MSI and interrupts ALSA: hda: Fix 0 dB offset for Lenovo Thinkpad models using AD1981 ALSA: hda - Add missing printk argument in previous patch ASoC: Fix passing platform_data to ac97 bus users and fix a leak ALSA: hda - Fix ADC/MUX assignment of ALC269 codec ALSA: hda - Fix invalid bit values passed to snd_hda_codec_amp_stereo() ASoC: wm8994: playback => capture
2010-04-04ALSA: i2c: cleanup: change parameter to pointerDan Carpenter
We actually pass an array of 7 chars not 5. This silences a smatch warning. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-04Merge branch 'topic/hda' into for-linusTakashi Iwai
2009-12-03ALSA: tea575x-tuner: fix muteOndrej Zary
Fix mute state reporting in tea575x-tuner. This fixes mute function in kradio on SF64-PCR radio card. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-13ALSA: ice1712: Use bitrev8Akinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-21ALSA: ak4113 supportPavel Hofman
* complete support for ak4113 * based on code for ak4114 and ak4117 Signed-off-by: Pavel Hofman <pavel.hofman@ivitera.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-21ALSA: ak4620 support, codec regs listed in procPavel Hofman
* complete support for ak4620 * codec regs listed in proc for all codecs/chips * adding total regs for each codec * fixing nb. of steps in input attenuation controls Signed-off-by: Pavel Hofman <pavel.hofman@ivitera.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-30V4L/DVB (10771): tea575x-tuner: convert it to V4L2 APIMauro Carvalho Chehab
2009-03-17ALSA: drop outdated and broken sa11xx-uda1341 driverDmitry Artamonow
It depends on L3 support from 2.4 kernel (CONFIG_L3) that never got merged into mainline. Since there's no way to use it on any of supported machines (iPaq h3100 or h3600), better drop it for now. It can be reimplemented later using ASoC infrastructure (there's already a driver for uda1341 codec in mainline, so only CPU and machine parts need to be written). Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-02V4L/DVB (10138): v4l2-ioctl: change to long return type to match unlocked_ioctl.Hans Verkuil
Since internal to v4l2 the ioctl prototype is the same regardless of it being called through .ioctl or .unlocked_ioctl, we need to convert it all to the long return type of unlocked_ioctl. Thanks to Jean-Francois Moine for posting an initial patch for this and thus bringing it to our attention. Cc: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10135): v4l2: introduce v4l2_file_operations.Hans Verkuil
Introduce a struct v4l2_file_operations for v4l2 drivers. Remove the unnecessary inode argument. Move compat32 handling (and llseek) into the v4l2-dev core: this is now handled in the v4l2 core and no longer in the drivers themselves. Note that this changeset reverts an earlier patch that changed the return type of__video_ioctl2 from int to long. This change will be reinstated later in a much improved version. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI cardIgor M. Liplianin
The card based on stv0299 or stv0288 demodulators. Signed-off-by: Igor M. Liplianin <liplianin@me.by> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8788): v4l: replace video_get_drvdata(video_devdata(filp)) with ↵Hans Verkuil
video_drvdata(filp) Use the new video_drvdata(filp) function where it is safe to do so. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8777): tea575x-tuner: replace video_exclusive_open/releaseHans Verkuil
Move the video_exclusive_open/release functionality into the driver itself. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
