path: root/sound/i2c
2010-04-16Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-04-15ALSA: i2c: Fixed 8 checkpatch errorsBrian Waters
Fixed 8 checkpatch errors (ERROR: do not use assignment in if condition) in sound/i2c/i2c.c. Signed-off-by: Brian Waters <brianmwaters@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: mixart: range checking proc file ALSA: hda - Fix a wrong array range check in patch_realtek.c ALSA: ASoC: move dma_data from snd_soc_dai to snd_soc_pcm_stream ALSA: hda - Enable amplifiers on Acer Inspire 6530G ASoC: Only do WM8994 bias off transition from standby ASoC: Don't use DCS_DATAPATH_BUSY for WM hubs devices ASoC: Don't do runtime wm_hubs DC servo updates if using offset correction ASoC: Support second DC servo readback method for wm_hubs ASoC: Avoid wraparound in wm_hubs DC servo correction ALSA: echoaudio - Eliminate use after free ALSA: i2c: cleanup: change parameter to pointer ALSA: hda - Add MSI blacklist for Aopen MZ915-M ASoC: OMAP: Fix capture pointer handling for OMAP1510 to work correctly with recent ALSA PCM code ALSA: hda - Update document about MSI and interrupts ALSA: hda: Fix 0 dB offset for Lenovo Thinkpad models using AD1981 ALSA: hda - Add missing printk argument in previous patch ASoC: Fix passing platform_data to ac97 bus users and fix a leak ALSA: hda - Fix ADC/MUX assignment of ALC269 codec ALSA: hda - Fix invalid bit values passed to snd_hda_codec_amp_stereo() ASoC: wm8994: playback => capture
2010-04-04ALSA: i2c: cleanup: change parameter to pointerDan Carpenter
We actually pass an array of 7 chars not 5. This silences a smatch warning. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-04Merge branch 'topic/hda' into for-linusTakashi Iwai
2009-12-03ALSA: tea575x-tuner: fix muteOndrej Zary
Fix mute state reporting in tea575x-tuner. This fixes mute function in kradio on SF64-PCR radio card. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-13ALSA: ice1712: Use bitrev8Akinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-21ALSA: ak4113 supportPavel Hofman
* complete support for ak4113 * based on code for ak4114 and ak4117 Signed-off-by: Pavel Hofman <pavel.hofman@ivitera.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-21ALSA: ak4620 support, codec regs listed in procPavel Hofman
* complete support for ak4620 * codec regs listed in proc for all codecs/chips * adding total regs for each codec * fixing nb. of steps in input attenuation controls Signed-off-by: Pavel Hofman <pavel.hofman@ivitera.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-30V4L/DVB (10771): tea575x-tuner: convert it to V4L2 APIMauro Carvalho Chehab
2009-03-17ALSA: drop outdated and broken sa11xx-uda1341 driverDmitry Artamonow
It depends on L3 support from 2.4 kernel (CONFIG_L3) that never got merged into mainline. Since there's no way to use it on any of supported machines (iPaq h3100 or h3600), better drop it for now. It can be reimplemented later using ASoC infrastructure (there's already a driver for uda1341 codec in mainline, so only CPU and machine parts need to be written). Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-02V4L/DVB (10138): v4l2-ioctl: change to long return type to match unlocked_ioctl.Hans Verkuil
Since internal to v4l2 the ioctl prototype is the same regardless of it being called through .ioctl or .unlocked_ioctl, we need to convert it all to the long return type of unlocked_ioctl. Thanks to Jean-Francois Moine for posting an initial patch for this and thus bringing it to our attention. Cc: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10135): v4l2: introduce v4l2_file_operations.Hans Verkuil
Introduce a struct v4l2_file_operations for v4l2 drivers. Remove the unnecessary inode argument. Move compat32 handling (and llseek) into the v4l2-dev core: this is now handled in the v4l2 core and no longer in the drivers themselves. Note that this changeset reverts an earlier patch that changed the return type of__video_ioctl2 from int to long. This change will be reinstated later in a much improved version. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI cardIgor M. Liplianin
The card based on stv0299 or stv0288 demodulators. Signed-off-by: Igor M. Liplianin <liplianin@me.by> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8788): v4l: replace video_get_drvdata(video_devdata(filp)) with ↵Hans Verkuil
video_drvdata(filp) Use the new video_drvdata(filp) function where it is safe to do so. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8777): tea575x-tuner: replace video_exclusive_open/releaseHans Verkuil
Move the video_exclusive_open/release functionality into the driver itself. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-08-25ALSA: revo51: add headphone outputAlexander Beregalov
It is ALSA bug #1754. D6 bit in 02 register is PW4. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-13ALSA: Kill snd_assert() in other placesTakashi Iwai
Kill snd_assert() in other places, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-27V4L/DVB (8523): v4l2-dev: remove unused type and type2 field from video_deviceHans Verkuil
The type and type2 fields were unused and so could be removed. Instead add a vfl_type field that contains the type of the video device. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-26V4L/DVB (8484): videodev: missed two more usages of the removed 'owner' field.Hans Verkuil
2008-05-27[ALSA] remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-19[ALSA] i2c: cs8427.c use put_unaligned helperHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-04-24[ALSA] some fixes and cleanup for ICE1724 cardsPavel Hofman
* removing the hack with NON_AKM ak4xxx type * support for card-specific flags in ak4114_stats * definition of the flags for corresponding cards Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] AK4114 - listing regs in procPavel Hofman
A simple patch for listing AK4114 regs in proc. Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] fm801 - Add mute support for FM-only card with FM801 PCI to tuner bridgeAndy Shevchenko
This is improvement of the early support of the FM-only cards where the fm801 chip represents the PCI to tuner bridge. The tuner initialization isn't included the mute on as well as mute support via V4L request. Proposed patch should fix this at least for 64-PCR model. Signed-off-by: Andy Shevchenko <andy@smile.org.ua> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] switching rate in STAC9460 codec of Prodigy192Pavel Hofman
* support for switching rate in STAC9460 - using set_rate_val of the akm infrastructure * listing all STAC9460 registers in proc * disabling mpu401 device for Prodigy192 - otherwise the currently flawed mpu401 code hangs kernel when opening the midi device * removing old unused commented-out code Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly (in the rest drivers). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] ak4xxx - Check value ranges in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly in ak4xxx-adda driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-22V4L/DVB (6320): v4l core: remove the unused .hardware V4L1 fieldMauro Carvalho Chehab
struct video_device used to define a .hardware field. While initialized on severl drivers, this field is never used inside V4L. However, drivers using it need to include the old V4L1 header. This seems to cause compilation troubles with some random configs. Better just to remove it from all drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] Workaround for invalid signature read of CS8427Takashi Iwai
Reading the signature of CS8427 over SPI/I2C fails on some devices by mysterious reason. In most cases, however, it succeeds at the sequential read. So, let's give a second chance to check the signature again. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Clean up MakefileTakashi Iwai
Clean up Makefile using xxx- style instead of ifeq(CONFIG_XXX,y). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] ice1724 - Add PCM Playback Switch to Revo 7.1Pavel Hofman
This patch adds the support of mute for front channels of M-Audio Revolution 7.1 (the DAC AK4381 features a mute bit). Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Fix misc bugs in i2c/others/ak4114.cPavel Hofman
* correct register for 'IEC958 Non-PCM Bitstream', 'IEC958 DTS Bitstream' to use AK4114_REG_RCS0 * correct check for control name: if (strstr(kctl->id.name, 'Playback')) * correct check: if (!chip->init) in snd_ak4114_external_rate * added PCM control 'IEC958 PPL Lock Status' Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] ak4114 - Fix possible Oops with callbacksTakashi Iwai
ak4114 code may trigger Oops when the parameters are changed without call of snd_ak4114_build(). Now it checks the existence of kctl element, and the workq is triggered after building the necessary kcontrols. Also, did some code clean up. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] snd-ak4114: Fix two array overflowsJean Delvare
Fix the handling of the TXCSB registers cache. There was one array overflow in reg_write() and one in snd_ak4114_reg_write(). Thanks to David Binderman for reporting the latter. The second overflow probably doesn't matter much, given that the function snd_ak4114_reg_write() appears to be never called. I wonder why it exists and why it is exported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Remove delayed work properly at free and suspendTakashi Iwai
Remove delayed work properly at free and suspend in ac97 codec and ak4114 drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add even more 'const' to everything related to TLVTakashi Iwai
Mark TLV data as 'const' Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add some more 'const', but needs changes in i2c/other/ak4*Takashi Iwai
Make data passed to ak4xxx_create 'const'. Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ak4114 - Use global workqueueTakashi Iwai
Use global workqueue for simplicity instead of own workqueue. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Enable the analog loopback of the Revolution 5.1Jochen Voss
Enable the analog loopback of the Revolution 5.1 card. This patch adds support for the PT2258 volume controller and modifies the Revolution 5.1 driver to make use of this facility. This allows to control the analog loopback of the card. Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Enable capture from line-in and CD on Revolution 5.1Jochen Voss
Enable capture from line-in and CD on the Revolution 5.1 card. This patch adds support for switching between the 5 input channels of the AK5365 ADC and modifies the Revolution 5.1 driver to make use of this facility. Previously the capture channel was fixed to channel 0 (microphone on the Revolution 5.1 card). Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-09-23[ALSA] ak4xxx - Remove bogus IPGA controlsTakashi Iwai
Remove IPGA volume controls and merge the IPGA range to ADC volume controls. These two volumes are not really independent but connected simply in different ranges 0-0x7f and 0x80-max. It doesn't make sense to provide two controls. Since both 0x7f and 0x80 specify 0dB, a hack is needed for IPGA range to skip 0x80 (increment one) for such controls. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Clean up and add TLV support to AK4xxx i2c driverTakashi Iwai
- Clean up the code in AK4xxx-ADDA i2c code. - Fix capture gain controls for AK5365 - Changed the static table for DAC/ADC mixer labels to use structs - Implemented TLV entries for each AK codec The volumes in AK4524, AK4528 and AK5365 are corrected with a table to be suitable for dB conversion. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Fix volume control for the AK4358 DACJochen Voss
Fix volume control for the AK4358 DAC. The attenuation control registers of the AK4358 use only 7bit for the volume, the msb is used to enable attenuation output. Without this patch there are 256 volume levels the lower 128 of which are mute. Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Fix compile warnings in ak4xxx-adda.cTakashi Iwai
Fixed compile warnings in ak4xxx-adda.c reagarding missing enum cases in switch. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
