path: root/sound/i2c
2009-03-30V4L/DVB (10771): tea575x-tuner: convert it to V4L2 APIMauro Carvalho Chehab
2009-03-17ALSA: drop outdated and broken sa11xx-uda1341 driverDmitry Artamonow
It depends on L3 support from 2.4 kernel (CONFIG_L3) that never got merged into mainline. Since there's no way to use it on any of supported machines (iPaq h3100 or h3600), better drop it for now. It can be reimplemented later using ASoC infrastructure (there's already a driver for uda1341 codec in mainline, so only CPU and machine parts need to be written). Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-02V4L/DVB (10138): v4l2-ioctl: change to long return type to match unlocked_ioctl.Hans Verkuil
Since internal to v4l2 the ioctl prototype is the same regardless of it being called through .ioctl or .unlocked_ioctl, we need to convert it all to the long return type of unlocked_ioctl. Thanks to Jean-Francois Moine for posting an initial patch for this and thus bringing it to our attention. Cc: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10135): v4l2: introduce v4l2_file_operations.Hans Verkuil
Introduce a struct v4l2_file_operations for v4l2 drivers. Remove the unnecessary inode argument. Move compat32 handling (and llseek) into the v4l2-dev core: this is now handled in the v4l2 core and no longer in the drivers themselves. Note that this changeset reverts an earlier patch that changed the return type of__video_ioctl2 from int to long. This change will be reinstated later in a much improved version. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI cardIgor M. Liplianin
The card based on stv0299 or stv0288 demodulators. Signed-off-by: Igor M. Liplianin <liplianin@me.by> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8788): v4l: replace video_get_drvdata(video_devdata(filp)) with ↵Hans Verkuil
video_drvdata(filp) Use the new video_drvdata(filp) function where it is safe to do so. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8777): tea575x-tuner: replace video_exclusive_open/releaseHans Verkuil
Move the video_exclusive_open/release functionality into the driver itself. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-08-25ALSA: revo51: add headphone outputAlexander Beregalov
It is ALSA bug #1754. D6 bit in 02 register is PW4. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-13ALSA: Kill snd_assert() in other placesTakashi Iwai
Kill snd_assert() in other places, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-27V4L/DVB (8523): v4l2-dev: remove unused type and type2 field from video_deviceHans Verkuil
The type and type2 fields were unused and so could be removed. Instead add a vfl_type field that contains the type of the video device. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-26V4L/DVB (8484): videodev: missed two more usages of the removed 'owner' field.Hans Verkuil
2008-05-27[ALSA] remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-19[ALSA] i2c: cs8427.c use put_unaligned helperHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-04-24[ALSA] some fixes and cleanup for ICE1724 cardsPavel Hofman
* removing the hack with NON_AKM ak4xxx type * support for card-specific flags in ak4114_stats * definition of the flags for corresponding cards Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] AK4114 - listing regs in procPavel Hofman
A simple patch for listing AK4114 regs in proc. Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] fm801 - Add mute support for FM-only card with FM801 PCI to tuner bridgeAndy Shevchenko
This is improvement of the early support of the FM-only cards where the fm801 chip represents the PCI to tuner bridge. The tuner initialization isn't included the mute on as well as mute support via V4L request. Proposed patch should fix this at least for 64-PCR model. Signed-off-by: Andy Shevchenko <andy@smile.org.ua> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] switching rate in STAC9460 codec of Prodigy192Pavel Hofman
* support for switching rate in STAC9460 - using set_rate_val of the akm infrastructure * listing all STAC9460 registers in proc * disabling mpu401 device for Prodigy192 - otherwise the currently flawed mpu401 code hangs kernel when opening the midi device * removing old unused commented-out code Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly (in the rest drivers). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] ak4xxx - Check value ranges in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly in ak4xxx-adda driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-22V4L/DVB (6320): v4l core: remove the unused .hardware V4L1 fieldMauro Carvalho Chehab
struct video_device used to define a .hardware field. While initialized on severl drivers, this field is never used inside V4L. However, drivers using it need to include the old V4L1 header. This seems to cause compilation troubles with some random configs. Better just to remove it from all drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] Workaround for invalid signature read of CS8427Takashi Iwai
Reading the signature of CS8427 over SPI/I2C fails on some devices by mysterious reason. In most cases, however, it succeeds at the sequential read. So, let's give a second chance to check the signature again. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Clean up MakefileTakashi Iwai
Clean up Makefile using xxx- style instead of ifeq(CONFIG_XXX,y). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] ice1724 - Add PCM Playback Switch to Revo 7.1Pavel Hofman
This patch adds the support of mute for front channels of M-Audio Revolution 7.1 (the DAC AK4381 features a mute bit). Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Fix misc bugs in i2c/others/ak4114.cPavel Hofman
* correct register for 'IEC958 Non-PCM Bitstream', 'IEC958 DTS Bitstream' to use AK4114_REG_RCS0 * correct check for control name: if (strstr(kctl->id.name, 'Playback')) * correct check: if (!chip->init) in snd_ak4114_external_rate * added PCM control 'IEC958 PPL Lock Status' Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] ak4114 - Fix possible Oops with callbacksTakashi Iwai
ak4114 code may trigger Oops when the parameters are changed without call of snd_ak4114_build(). Now it checks the existence of kctl element, and the workq is triggered after building the necessary kcontrols. Also, did some code clean up. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] snd-ak4114: Fix two array overflowsJean Delvare
Fix the handling of the TXCSB registers cache. There was one array overflow in reg_write() and one in snd_ak4114_reg_write(). Thanks to David Binderman for reporting the latter. The second overflow probably doesn't matter much, given that the function snd_ak4114_reg_write() appears to be never called. I wonder why it exists and why it is exported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Remove delayed work properly at free and suspendTakashi Iwai
Remove delayed work properly at free and suspend in ac97 codec and ak4114 drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add even more 'const' to everything related to TLVTakashi Iwai
Mark TLV data as 'const' Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add some more 'const', but needs changes in i2c/other/ak4*Takashi Iwai
Make data passed to ak4xxx_create 'const'. Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ak4114 - Use global workqueueTakashi Iwai
Use global workqueue for simplicity instead of own workqueue. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Enable the analog loopback of the Revolution 5.1Jochen Voss
Enable the analog loopback of the Revolution 5.1 card. This patch adds support for the PT2258 volume controller and modifies the Revolution 5.1 driver to make use of this facility. This allows to control the analog loopback of the card. Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Enable capture from line-in and CD on Revolution 5.1Jochen Voss
Enable capture from line-in and CD on the Revolution 5.1 card. This patch adds support for switching between the 5 input channels of the AK5365 ADC and modifies the Revolution 5.1 driver to make use of this facility. Previously the capture channel was fixed to channel 0 (microphone on the Revolution 5.1 card). Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-09-23[ALSA] ak4xxx - Remove bogus IPGA controlsTakashi Iwai
Remove IPGA volume controls and merge the IPGA range to ADC volume controls. These two volumes are not really independent but connected simply in different ranges 0-0x7f and 0x80-max. It doesn't make sense to provide two controls. Since both 0x7f and 0x80 specify 0dB, a hack is needed for IPGA range to skip 0x80 (increment one) for such controls. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Clean up and add TLV support to AK4xxx i2c driverTakashi Iwai
- Clean up the code in AK4xxx-ADDA i2c code. - Fix capture gain controls for AK5365 - Changed the static table for DAC/ADC mixer labels to use structs - Implemented TLV entries for each AK codec The volumes in AK4524, AK4528 and AK5365 are corrected with a table to be suitable for dB conversion. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Fix volume control for the AK4358 DACJochen Voss
Fix volume control for the AK4358 DAC. The attenuation control registers of the AK4358 use only 7bit for the volume, the msb is used to enable attenuation output. Without this patch there are 256 volume levels the lower 128 of which are mute. Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Fix compile warnings in ak4xxx-adda.cTakashi Iwai
Fixed compile warnings in ak4xxx-adda.c reagarding missing enum cases in switch. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Revolution 5.1 - complete the AK5365 supportJochen Voss
Complete the AK5365 support. This adds a boolean control to toggle the soft mute feature of the AK5365 chip. Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Revolution 5.1 - add AK5365 ADC supportJochen Voss
Add support for the AK5365 ADC. Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] trivial: Code clean up of i2c/cs8427.cTakashi Iwai
- Fix spaces, wrap lines in 80 columns. - Move EXPORT_SYMBOL() adjacent to each function. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] sound/i2c/cs8427.c: don't export a static functionAdrian Bunk
Static functions shouldn't be exported. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-28[ALSA] ak4xxx-adda - Code clean-upTakashi Iwai
Fix spaces, fold lines to fit 80 columns in ak4xxx-adda driver codes. Split a long reset function to each codec routine just for better readability. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-28[ALSA] Stereo controls for M-Audio Revolution cardsJani Alinikula
This patch adds stereo controls to revo cards by making the ak4xxx driver mixers configurable from the card driver. Signed-off-by: Jani Alinikula <janialinikula@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] i2c - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
Move EXPORT_SYMBOL() to adjacent to each exported function/variable. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] ice1712 & cs8427 - fix problem for S/PDIF input setupJaroslav Kysela
Modules: I2C cs8427,ICE1712 driver See ALSA bug#1785 for more details. Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-03-22[ALSA] semaphore -> mutex (driver part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
