path: root/sound/isa/cmi8330.c
2011-10-31sound: fix drivers needing module.h not moduleparam.hPaul Gortmaker
The implicit presence of module.h lured several users into incorrectly thinking that they only needed/used modparam.h but once we clean up the module.h presence, these will show up as build failures, so fix 'em now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-14ALSA: mpu401: clean up interrupt specificationClemens Ladisch
The semantics of snd_mpu401_uart_new()'s interrupt parameters are somewhat counterintuitive: To prevent the function from allocating its own interrupt, either the irq number must be invalid, or the irq_flags parameter must be zero. At the same time, the irq parameter being invalid specifies that the mpu401 code has to work without an interrupt allocated by the caller. This implies that, if there is an interrupt and it is allocated by the caller, the irq parameter must be set to a valid-looking number which then isn't actually used. With the removal of IRQF_DISABLED, zero becomes a valid irq_flags value, which forces us to handle the parameters differently. This patch introduces a new flag MPU401_INFO_IRQ_HOOK for when the device interrupt is handled by the caller, and makes the allocation of the interrupt to depend only on the irq parameter. As suggested by Takashi, the irq_flags parameter was dropped because, when used, it had the constant value IRQF_DISABLED. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-05ALSA: rename "PC Speaker" and "PC Beep" controls to "Beep"Jaroslav Kysela
To avoid confusion in control names for the standard analog PC Beep generator using a small Internal PC Speaker, rename all related "PC Speaker" and "PC Beep" controls to "Beep" only. This name is more universal and can be also used on more platforms without confusion. Introduce also "Internal Speaker" in ControlNames.txt for systems with full-featured build-in internal speaker. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-07-07ALSA: cmi8330: Allow MPU-401-less operationOndrej Zary
Adding MPU-401 support to cmi8330 driver could cause a regression (non-working sound) on a system where there is no free IRQ for the MPU-401 device (which is not very uncommon as this card requires two separate IRQs plus a third one for MPU-401). When MPU-401 PnP configuration fails (mostly because of unavailable IRQ), just ignore MPU-401 and continue without it. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-07-07ALSA: cmi8330: find OPL3 port automaticallyOndrej Zary
My CMI8329 had OPL3 port specified in SB16 resources. But now I found out that it was my modification of the card's PnP EEPROM a couple of years ago (can be done using C9SETROM.EXE utility). I did it because the OPL3 port was completely missing from PnP data. It seems to be hardwired to 0x388 on CMI8329. Find OPL3 port automatically by searching in WSS and SB16 resources. If not found, assume that it's hardwired to 0x388. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-07-05cmi8330: Add basic CMI8329 supportOndrej Zary
Add basic support for CMI8329 cards. Makes PCM and OPL3 work. Does not break CMI8330 (tested). Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-29ALSA: cmi8330: revert comments about AD1848 backOndrej Zary
In ALSA 1.0.20, the comments were changed to say CMI8330 instead of AD1848. The CMI8330 chip includes two codecs - AD1848 and SB16, so the comments were correct and are misleading now. Revert them back. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-29ALSA: cmi8330: fix MPU-401 PnP init copy&paste bugOndrej Zary
Fix copy&paste bug in PnP MPU-401 initialization. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-16Merge branch 'topic/snd_card_new-err' into topic/cs423x-mergeTakashi Iwai
2009-01-29ALSA: cmi8330: add MPU-401 supportKrzysztof Helt
Add MPU-401 port support for the chip. Also, update some error messages and description. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-21ALSA: do not create OPL3 timers if there is no OPL3 irq wiredKrzysztof Helt
Most cards have OPL3 FM synthetiser but they do not have OPL3 interrupt wired to a sound chip or CPU. Do not create OPL3 timers for such cards as the timers are useless witthout interrupt. This patch removes OPL3 timers for following alsa drivers: snd-ad1816a, snd-opti93x, snd-opti92x, snd-sc6000, snd-cmi8330. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-21ALSA: cmi8330: add OPL3 supportKrzysztof Helt
Add OPL3 handling to the driver and volume control for FM synthesis. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in sound/isa/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-06ALSA: wss_lib: use wss detection code instead of ad1848 oneKrzysztof Helt
Use the wss detection code and kill the ad1848 library. The library is fully assimilated into the new wss library. This required reworking of the AD1848 family code so the code is changed to correctly detect chips from the AD1848 and CS4231 families. I have tested it on following cards: Gallant SC-6600 (codec: AD1848, driver: snd-sc6600) SoundScape VIVO/90 (codec: AD1845, driver: snd-sscape) SG Waverider (codec: CS4231A, driver: Rene Herman's snd-galaxy) Opti930 (codec: built-in - CS4231 compatible, driver: snd-opti93x) Opti931 (codec: built-in - CS4231 compatible, driver: snd-opti93x) Gallant SC-70P (chip/codec: CS4237B, driver: snd-cs4236) Audio Plus 3D (chip/codec: CMI8330A, driver: snd-cmi8330) Dell Latitude CP (chip/codec: cs4236, driver snd-cs4232) Sound playback and recording works on all these cards. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: use wss pcm code instead of ad1848 oneKrzysztof Helt
Use the wss pcm code and kill the ad1848 pcm code. The AD1848 chip is much slower than CS4231 chips so the waiting loop was increased 100x (10x is not enough). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: replace ad1848 mixer element macros with wss onesKrzysztof Helt
Use the wss macros instead of ad1848 ones. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: use wss constants instead of ad1848 onesKrzysztof Helt
Use wss constants for mode. Move ad1848 hardware constants to the wss.h. Move mixer tlv macros into the ad1848_lib.c from the ad1848.h. Drop the MODE_RUNNING spurious IRQ guard on AD1848 as it doesn not seem to be needed. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: use struct snd_wss instead of snd_ad1848Krzysztof Helt
The snd_wss is superset of the snd_ad1848 so kill the latter and replace it with the snd_wss. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound/isa: kill pnp_resource_changeRene Herman
This removes the pnp_resource_change use from the ALSA ISAPnP drivers. In 2.4 these were useful in providing an easy path to setting the resources, but in 2.6 they retain function as a layering violation only. This makes for a nice cleanup (-550 lines) of ALSA but moreover, ALSA is the only remaining user of pnp_init_resource_table(), pnp_resource_change() and pnp_manual_config_dev() (and, in fact, of 'struct pnp_resource_table') in the tree outide of drivers/pnp itself meaning it makes for more cleanup potential inside the PnP layer. Thomas Renninger acked their removal from that side, you did from the ALSA side (CC list just copied from that thread). Against current alsa-kernel HG. Many more potential cleanups in there, but this _only_ removes the pnp_resource_change code. Compile tested against current alsa-kernel HG and compile- and use-tested against 2.6.23.x (few offsets). Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-05-16[ALSA] Fix probe of non-PnP ISA devicesRene Herman
isa_register_driver() returns an error if no device is found and it's no fatal error for the drivers with pnp support. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] isa_bus device/driver namingRene Herman
isa_bus: delete snd_ prefix from the (sysfs visible) device/driver names. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Port the rest of ALSA ISA drivers to isa_driverTakashi Iwai
Port the rest of ALSA ISA drivers to use isa_driver framework instead of platform_driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-14[ALSA] Fix __devinit and __devexit issues with sound driversPrarit Bhargava
Fix __devinit and __devexit issues with sound drivers. Resolves MODPOST warnings similar to: WARNING: sound/drivers/snd-dummy.o - Section mismatch: reference to .init.text:snd_dummy_probe from .data.rel.local between 'snd_dummy_driver' (at offset 0x0) and 'snd_dummy_controls' WARNING: sound/drivers/snd-mtpav.o - Section mismatch: reference to .init.text:snd_mtpav_probe from .data.rel.local between 'snd_mtpav_driver' (at offset 0x0) and 'snd_mtpav_input' WARNING: sound/drivers/snd-virmidi.o - Section mismatch: reference to .init.text:snd_virmidi_probe from .data.rel.local after 'snd_virmidi_driver' (at offset 0x0) Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] sound/isa/cmi8330.c: check kmalloc() return valueAmit Choudhary
Check the return value of kmalloc() in function snd_cmi8330_pnp(), in file sound/isa/cmi8330.c. Signed-off-by: Amit Choudhary <amit2030@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-04-12[ALSA] unregister platform device again if probe was unsuccessfulRene Herman
Unregister the platform device again if the probe was unsuccessful. This restores the behaviour of not loading the driver on probe() failure. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-12[ALSA] continue on IS_ERR from platform device registrationRene Herman
Continue with the next one on error from device registration. This would seem the correct thing to do, even if it's not the probe() error that we're getting. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-31[ALSA] ISA drivers bailing on first !enable[i]Rene Herman
Fix the wrong check of enable option in cmi8330 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-27[PATCH] PNP: adjust pnp_register_card_driver() signature: cmi8330Bjorn Helgaas
Remove the assumption that pnp_register_card_driver() returns the number of devices claimed. And fix some __init/__devinit issues. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-22[ALSA] Fix compilation without CONFIG_PNPTakashi Iwai
Fix compilation of some ISA drivers without CONFIG_PNP. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] unregister platform devicesClemens Ladisch
Call platform_device_unregister() for all platform devices that we've registered. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] cmi8330 - Use platform_device, add PM supportTakashi Iwai
Modules: CMI8330 driver Rewrite the probe/remove with platform_device. Also, add the PM support. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA CMI8330Takashi Iwai
Modules: CMI8330 driver Remove xxx_t typedefs from the ISA CMI8330 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove superfluous pcm_free callbacksTakashi Iwai
Remove superflous pcm_free callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Add snd_card_set_generic_dev() call to ISA driversTakashi Iwai
ISA,CMI8330 driver,ES18xx driver,OPL3SA2 driver,Sound Galaxy driver Sound Scape driver,AD1848 driver,CS4231 driver,CS4236+ driver ES1688 driver,GUS Classic driver,GUS Extreme driver,GUS MAX driver AMD InterWave driver,Opti9xx drivers,SB16/AWE driver,SB8 driver Wavefront drivers - Added snd_card_set_generic_dev() call. - Added SND_GENERIC_DRIVER to Kconfig. - Clean up the error path in probe if necessary. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] use SNDRV_CTL_NAME_IEC958 macroClemens Ladisch
CMI8330 driver,ENS1370/1+ driver,FM801 driver,VIA82xx driver,AC97 Codec ALI5451 driver,CS46xx driver,EMU10K1/EMU10K2 driver,HDA Codec driver ICE1712 driver,ICE1724 driver Where appropriate, use the SNDRV_CTL_NAME_IEC958 instead of a literal string. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
