path: root/sound/isa/cs423x
2008-01-31[ALSA] cs4231: remove one busy waitKrzysztof Helt
This busy_wait is not needed after latest changes to the cs4231-lib Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound/isa: kill pnp_resource_changeRene Herman
This removes the pnp_resource_change use from the ALSA ISAPnP drivers. In 2.4 these were useful in providing an easy path to setting the resources, but in 2.6 they retain function as a layering violation only. This makes for a nice cleanup (-550 lines) of ALSA but moreover, ALSA is the only remaining user of pnp_init_resource_table(), pnp_resource_change() and pnp_manual_config_dev() (and, in fact, of 'struct pnp_resource_table') in the tree outide of drivers/pnp itself meaning it makes for more cleanup potential inside the PnP layer. Thomas Renninger acked their removal from that side, you did from the ALSA side (CC list just copied from that thread). Against current alsa-kernel HG. Many more potential cleanups in there, but this _only_ removes the pnp_resource_change code. Compile tested against current alsa-kernel HG and compile- and use-tested against 2.6.23.x (few offsets). Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Fix thinko in cs4231 mce down checkTakashi Iwai
The last patches to replace with schedule_timeout() don't work as expected. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] cs4231-lib: improved waiting after mce_downKrzysztof Helt
This patch replaces long msleeps in waiting loops with schedule_timeout() calls. Signed-off-by: Krzysztof Helt <krzysztof.h1 at wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] ad1848/cs4231: replace commented out debug code with snd-printd{,d}Rene Herman
While I'm at it another 'while I'm there' -- replace commented out debug code with snd-printd{,d}. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] ad1838/cs4231 - fix MCE timeout upon initial loadRene Herman
When the ad1848/cs2431 is first being initialized, auto-calibration may not be set causing a timeout waiting for it in snd_ad1848/cs4231_mce_down(). This has no dire consequences other than an alarming printk, but since what we need to wait for is for the calibration to _finish_, let's just check for that instead. The early chips need a slight delay (as commented -- 5 sample periods) to be sure that _if_ calibration is going to happen, it has started when we check While the CS4231A datasheet implies it'll happen immediately on downing MCE, some testing is showing that there's a window there as well, so just do the delay everywhere. Thanks to Krysztof Helt for pinpointing this problem. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] cs4231-lib: replace common delay loop by functionKrzysztof Helt
This patch replaces a common delay loop by a function. It also uses ARRAY_SIZE macro for the rates table. Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] isa libs Makefiles cleanupKrzysztof Helt
This patch uses the Kconfig parameters SND_AD1848_LIB and SND_CS4231_LIB instead of mentioning each driver that requires the ad1848-lib or cs4231-lib separately in the Makefiles. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Fix bugs in mode change/recalibration for opl3sa2 driverPaul Vojta
The mode change / recalibration doesn't work always with opl3sa2 devices, e.g. the first time it's played back. The patch fixes the problem. Signed-off-by: Paul Vojta <vojta@math.berkeley.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-16[ALSA] Fix probe of non-PnP ISA devicesRene Herman
isa_register_driver() returns an error if no device is found and it's no fatal error for the drivers with pnp support. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] isa_bus device/driver namingRene Herman
isa_bus: delete snd_ prefix from the (sysfs visible) device/driver names. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Add snd_pcm_group_for_each_entry() for code cleanupTakashi Iwai
Added a new macro snd_pcm_group_for_each_entry() just for code cleanup. Old macros, snd_pcm_group_for_each() and snd_pcm_group_substream_entry(), are removed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Port the rest of ALSA ISA drivers to isa_driverTakashi Iwai
Port the rest of ALSA ISA drivers to use isa_driver framework instead of platform_driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] isa_bus: cs4231Rene Herman
cs4231: port to isa_bus infrastructure. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-12[ALSA] Fix undefined (missing) references in ISA MIRO sound driverRandy Dunlap
WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/sound/isa/opti9xx/snd-miro.ko needs unknown symbol snd_cs4231_create WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/sound/isa/opti9xx/snd-miro.ko needs unknown symbol snd_cs4231_pcm WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/sound/isa/opti9xx/snd-miro.ko needs unknown symbol snd_cs4231_timer WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/sound/isa/opti9xx/snd-miro.ko needs unknown symbol snd_cs4231_mixer WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/fs/reiser4/reiser4.ko needs unknown symbol generic_file_read Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-12[ALSA] unregister platform device again if probe was unsuccessfulRene Herman
Unregister the platform device again if the probe was unsuccessful. This restores the behaviour of not loading the driver on probe() failure. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-12[ALSA] continue on IS_ERR from platform device registrationRene Herman
Continue with the next one on error from device registration. This would seem the correct thing to do, even if it's not the probe() error that we're getting. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-27[PATCH] pnp: cs4236: adjust pnp_register_driver signatureBjorn Helgaas
Remove the assumption that pnp_register_driver() returns the number of devices claimed. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[ALSA] cs4236 - Fix a typoTakashi Iwai
Modules: CS4236+ driver Fixed a typo in snd_cs4236_put_master_digital(), resulting in silence right channel. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] Fix check of enable module optionTakashi Iwai
Fix the check of enable module option in probe of platform_device drivers. It shouldn't break the loop but just ignore if enable[i] is false. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] semaphore -> mutex (ISA part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-24[PATCH] snd-cs4236 typo fixRene Herman
I noticed on 2.6.16-rc4 that my MPU-401 wasn't functional, due to a simple copy & paste error in sound/isa/cs423x/cs4236.c. Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[ALSA] cs4236 - Add PnP ids for Netfinity 3000Lukasz Stemach
Modules: CS4236+ driver PnP ids for Netfinity 3000 builtin soundcard. This one works for me. This patch was submitted through kernel Bugzilla #4214. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] cs4232/cs4236 - moved CS423X_DRIVER define outside CONFIG_PNPJaroslav Kysela
Modules: CS4236+ driver Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-01-22[ALSA] Fix compilation without CONFIG_PNPTakashi Iwai
Fix compilation of some ISA drivers without CONFIG_PNP. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] unregister platform devicesClemens Ladisch
Call platform_device_unregister() for all platform devices that we've registered. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] Fix a compile warningTakashi Iwai
Modules: CS4231 driver Fix a compile warning (unused variable). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Add CS4232 PnP BIOS supportTakashi Iwai
Modules: CS4231 driver,CS4236+ driver Add CS4232 PnP BIOS support. Still experimental. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Fix resume of cs4231Takashi Iwai
Modules: CS4231 driver Use mce_down() again in the resume callback. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] cs4236 - Use platform_deviceTakashi Iwai
Modules: CS4236+ driver Rewrite the probe/remove with platform_device. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] cs4231 - Use platform_deviceTakashi Iwai
Modules: CS4231 driver Rewrite the probe/remove with platform_device. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] cs4231 - Fix PM supportTakashi Iwai
Modules: CS4231 driver Fix PM support. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA CS423xTakashi Iwai
Modules: CS4231 driver,CS4236+ driver Remove xxx_t typedefs from the ISA CS423x drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Clean up ISA cs4231 codeTakashi Iwai
Modules: CS4231 driver Clean up ISA cs4231 code, removing experimental EBUS/SBUS merge, to improve readability. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove superfluous pcm_free callbacksTakashi Iwai
Remove superflous pcm_free callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove vmalloc wrapper, kfree_nocheck()Takashi Iwai
- Remove vmalloc wrapper - Add release_and_free_resource() to remove kfree_nocheck() from each driver and simplify the code Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove snd_runtime_check() macroTakashi Iwai
Remove snd_runtime_check() macro. This macro worsens the readability of codes. They should be either normal if() or removable asserts. Also, the assert displays stack-dump, instead of only the last caller pointer. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Replace with kzalloc() - isa stuffTakashi Iwai
ES18xx driver,OPL3SA2 driver,AD1816A driver,AD1848 driver,CS4231 driver ES1688 driver,GUS Library,Opti9xx drivers,EMU8000 driver SB16/AWE driver,SB drivers Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Add snd_card_set_generic_dev() call to ISA driversTakashi Iwai
ISA,CMI8330 driver,ES18xx driver,OPL3SA2 driver,Sound Galaxy driver Sound Scape driver,AD1848 driver,CS4231 driver,CS4236+ driver ES1688 driver,GUS Classic driver,GUS Extreme driver,GUS MAX driver AMD InterWave driver,Opti9xx drivers,SB16/AWE driver,SB8 driver Wavefront drivers - Added snd_card_set_generic_dev() call. - Added SND_GENERIC_DRIVER to Kconfig. - Clean up the error path in probe if necessary. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] PCM resume cleanupsJaroslav Kysela
Digigram VX core,CS4231 driver,ATIIXP driver,VIA82xx driver VIA82xx-modem driver,au88x0 driver,CS46xx driver,Trident driver This patch disables SNDRV_PCM_INFO_RESUME flag for drivers which does not support the full resume. Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2005-06-22[ALSA] cs4236-irq-handling-fix.patchChristoph Schulz
CS4236+ driver Background: The card/chipset supports an external MIDI interrupt. By default, this interrupt isn't used (because the isapnp mechanism chooses a configuration without an assigned interrupt). If the user wishes to explicitly select an interrupt via the mpu_irq parameter for such a configured device, it doesn't work: The driver always shows: isapnp MPU: port=0x330, irq=-1 (note the 'irq=-1') Problem: The driver only allows to set the irq if pnp_irq_valid returns true for this particular pnp device. This, however, is only true if an interrupt has already been assigned (pnp_valid_irq returns true if the flag IORESOURCE_IRQ is set and IORESOURCE_UNSET is not set). If no interrupt has been assigned so far, IORESOURCE_UNSET is set and pnp_irq_valid returns false, thereby inhibiting the selection of a valid irq. Solution: Don't check for a valid (= already assigned) irq at the point of calling pnp_resource_change. Tested successfully on Linux 2.6.11. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
