path: root/sound/isa/opti9xx
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-17ALSA: opti9xx: constify pnp_card_device_idArvind Yadav
pnp_card_device_id are not supposed to change at runtime. All functions working with pnp_card_device_id provided by <linux/pnp.h> work with const pnp_card_device_id. So mark the non-const structs as const. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2017-07-18ALSA: opti9xx: fix format string overflow warningArnd Bergmann
We pass a long name from "codec->pcm->name" into the longname string of the same length: sound/isa/opti9xx/miro.c: In function 'snd_miro_probe': sound/isa/opti9xx/miro.c:1356:39: error: '%s' directive writing up to 79 bytes into a region of size between 35 and 72 [-Werror=format-overflow=] sprintf(card->longname, "%s: OPTi%s, %s at 0x%lx, irq %d, dma %d&%d", ^~ sound/isa/opti9xx/miro.c:1356:26: note: using the range [0, 4294967295] for directive argument sprintf(card->longname, "%s: OPTi%s, %s at 0x%lx, irq %d, dma %d&%d", ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ sound/isa/opti9xx/miro.c:1356:2: note: 'sprintf' output between 32 and 185 bytes into a destination of size 80 sprintf(card->longname, "%s: OPTi%s, %s at 0x%lx, irq %d, dma %d&%d", There is no easy way to avoid the theoretical overflow in this case, but using snprintf() will turn it into a harmless truncation. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2017-04-20Annotate hardware config module parameters in sound/isa/David Howells
When the kernel is running in secure boot mode, we lock down the kernel to prevent userspace from modifying the running kernel image. Whilst this includes prohibiting access to things like /dev/mem, it must also prevent access by means of configuring driver modules in such a way as to cause a device to access or modify the kernel image. To this end, annotate module_param* statements that refer to hardware configuration and indicate for future reference what type of parameter they specify. The parameter parser in the core sees this information and can skip such parameters with an error message if the kernel is locked down. The module initialisation then runs as normal, but just sees whatever the default values for those parameters is. Note that we do still need to do the module initialisation because some drivers have viable defaults set in case parameters aren't specified and some drivers support automatic configuration (e.g. PNP or PCI) in addition to manually coded parameters. This patch annotates drivers in sound/isa/. Suggested-by: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> cc: Jaroslav Kysela <perex@perex.cz> cc: Takashi Iwai <tiwai@suse.com> cc: alsa-devel@alsa-project.org
2015-01-28ALSA: Include linux/io.h instead of asm/io.hTakashi Iwai
Nowadays it's recommended. Replace all in a shot. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-01-02ALSA: wss: Remove (almost) always NULL parametersLars-Peter Clausen
Most callers of snd_wss_pcm(), snd_wss_timer() and snd_cs4236_pcm() pass NULL as the last parameter, some callers pass a pointer but never use it after the function has been called and only a few callers pass a pointer and actually use it. The later is only the case for snd_wss_pcm() for snd_cs4236_pcm() and it is possible to get the same PCM object by accessing the pcm field of the snd_wss struct that was passed as the first parameter. This function removes the last parameters from the functions mentioned above and updates the callers which used it to use chip->pcm instead. This allows us to slightly simplify the functions since they don't have to check and set the last parameter anymore which makes the code slightly shorter and cleaner. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-12ALSA: isa: Convert to snd_card_new() with a device pointerTakashi Iwai
Also remove superfluous snd_card_set_dev() calls. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-08-28ALSA: opti9xx: Fix conflicting driver object nameTakashi Iwai
The recent commit to delay the release of kobject triggered NULL dereferences of opti9xx drivers. The cause is that all snd-opti92x-ad1848, snd-opti92x-cs4231 and snd-opti93x drivers register the PnP card driver with the very same name, and also snd-opti92x-ad1848 and -cs4231 drivers register the ISA driver with the same name, too. When these drivers are built in, quick "register-release-and-re-register" actions occur, and this results in Oops because of the same name is assigned to the kobject. The fix is simply to assign individual names. As a bonus, by using KBUILD_MODNAME, the patch reduces more lines than it adds. The fix is based on the suggestion by Russell King. Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-29ALSA: ISA: Remove superfluous *_set_drvdata(NULL) callsTakashi Iwai
Similarly like the previous commit for PCI drivers, remove dev_set_drvdata(NULL) and pnp_set_drvdata(NULL) calls in ISA drivers now. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-07ALSA: isa: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-10-21ALSA: sound/isa/opti9xx/miro.c: eliminate possible double freeJulia Lawall
snd_miro_probe is a static function that is only called twice in the file that defines it. At each call site, its argument is freed using snd_card_free. Thus, there is no need for snd_miro_probe to call snd_card_free on its argument on any of its error exit paths. Because snd_card_free both reads the fields of its argument and kfrees its argments, the results of the second snd_card_free should be unpredictable. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ identifier f,free,a; parameter list[n] ps; type T; expression e; @@ f(ps,T a,...) { ... when any when != a = e if(...) { ... free(a); ... return ...; } ... when any } @@ identifier r.f,r.free; expression x,a; expression list[r.n] xs; @@ * x = f(xs,a,...); if (...) { ... free(a); ... return ...; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-03ALSA: isa: Move snd_legacy_find_free_ioport to initval.hOndrej Zary
Move snd_legacy_find_free_ioport() function back to initval.h as it is used by two drivers. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-17ALSA: opti9xx: Fix section mismatch by PM supportTakashi Iwai
In the previous commit, snd_opti9xx_configure() is called from the resume handler but it's still marked as __devinit. Fix it. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-17ALSA: snd-opti9xx: Implement suspend/resumeOndrej Zary
Implement suspend/resume support for Opti 92x and 93x chips. Tested with Opti 929A+AD1848 and Opti 931. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-18ALSA: snd-opti9xx: fixes for MED3931 card (opti931)Ondrej Zary
MED3931 card did not work (failed with "OPTI chip not found") because snd-opti9xx gets mc_indir_index from pnp by adding 2 to the pnp-reported port. It probably works for some cards but not for this one. Datasheet says that the port is always at 0xe?e so just force the lowest nibble to be 0xe. Also this card powers up with (ugly) 3D sound enabled. As there's no mixer control for this, just disable it. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-03-29ALSA: fix isa/opti9xx module param typeRandy Dunlap
Fix module parameter data type to eliminate build warnings. sound/isa/opti9xx/opti92x-ad1848.c:87:1: warning: return from incompatible pointer type sound/isa/opti9xx/opti92x-ad1848.c:87:1: warning: return from incompatible pointer type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-19ALSA: module_param: make bool parameters really boolRusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-10-31sound: fix drivers needing module.h not moduleparam.hPaul Gortmaker
The implicit presence of module.h lured several users into incorrectly thinking that they only needed/used modparam.h but once we clean up the module.h presence, these will show up as build failures, so fix 'em now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-22sound: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-09-14ALSA: mpu401: clean up interrupt specificationClemens Ladisch
The semantics of snd_mpu401_uart_new()'s interrupt parameters are somewhat counterintuitive: To prevent the function from allocating its own interrupt, either the irq number must be invalid, or the irq_flags parameter must be zero. At the same time, the irq parameter being invalid specifies that the mpu401 code has to work without an interrupt allocated by the caller. This implies that, if there is an interrupt and it is allocated by the caller, the irq parameter must be set to a valid-looking number which then isn't actually used. With the removal of IRQF_DISABLED, zero becomes a valid irq_flags value, which forces us to handle the parameters differently. This patch introduces a new flag MPU401_INFO_IRQ_HOOK for when the device interrupt is handled by the caller, and makes the allocation of the interrupt to depend only on the irq parameter. As suggested by Takashi, the irq_flags parameter was dropped because, when used, it had the constant value IRQF_DISABLED. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08sound: fix opti92x-ad1848 buildRandy Dunlap
Fix 'else' placement in ifdef block so that build succeeds: sound/isa/opti9xx/opti92x-ad1848.c:221: error: 'else' without a previous 'if' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-03ALSA: opti92x: use PnP data to select Master Control portKrzysztof Helt
The Master Control port (MC) is available as the last PnP resource (OPT005). Use this value instead fo guessing. Also, add some comments to the code. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-14Merge branch 'next/isa' into topic/miscTakashi Iwai
2009-12-12ALSA: opti93x: use dB scale for mixer controlsKrzysztof Helt
Add dB scale for mixer controls. Fix dB scale for Master Volume control. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-11ALSA: opti93x: move controls definitions to opti93x driverKrzysztof Helt
Move OPTi93x controls definitions to the opti93x driver from the common wss-lib library module. These controls are used only by the opti93x driver. Also, fix capture source names. They are the same as opl3sa2 names. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-10ALSA: opti93x: fix irq releasing if the irq cannot be allocatedKrzysztof Helt
Use the chip->irq to check if the irq should be released so the irq is not released if it has not been allocated. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: ice1724 - aureon - modify WM8770 Master & DAC volume ALSA: hda/realtek: quirk for D945GCLF2 mainboard ALSA: hda - Terradici HDA controllers does not support 64-bit mode ALSA: document: Add direct git link to grub hda-analyzer ALSA: radio/sound/miro: fix build, cleanup depends/selects ALSA: hda - Generalize EAPD inversion check in patch_analog.c ASoC: Wrong variable returned on error ALSA: snd-usb-us122l: add product IDs of US-122MKII and US-144MKII ALSA: hda - Exclude unusable ADCs for ALC88x ALSA: hda - Add missing Line-Out and PCM switches as slave ALSA: hda - iMac 9,1 sound patch. ALSA: opti93x: set MC indirect registers base from PnP data
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-08ALSA: opti93x: set MC indirect registers base from PnP dataKrzysztof Helt
The PnP data on the OPTI931 and OPTI933 contains io port range for the MC indirect registers. Use the PnP range instead of hardwired value 0xE0E. Also, request region of MC indirect registers so it is marked as used to other drivers (this was missing previously). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-02ALSA: opti9xx: remove snd_opti9xx fieldsKrzysztof Helt
Remove snd_opti9xx fields which are indirect arguments to the snd_opti9xx_configure(). Pass these values as function arguments. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-30ALSA: opti-miro: add PnP detectionKrzysztof Helt
The PCM12 and PCM20 can be set into the ISA PnP mode. The PCM12 PnP was sold as the PnP device. Add code to handle detection of these cards using ISA PnP framework. Tested on the PCM20 in PnP mode. The PCM12 PnP has the same MS Windows INF file except for a card name displayed for user. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-30ALSA: opti-miro: separate comon probing codeKrzysztof Helt
Separate common probing code in order to use it for PnP probing. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-27ALSA: opti-miro: fix OOPS if hardware is not detectedKrzysztof Helt
If a hardware is not detected there is a kernel crash due to not initialized snd_miro->aci pointer. This pointer is initialized after detection of the opti (miro) chip. This bug was introduced by patches to expose ACI mikser outside the snd-miro driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-23ALSA: opti-miro: expose ACI mixer to outside driversKrzysztof Helt
The ACI mixer is used to control the radio FM module installed on the Miro PCM20 sound card. Expose ACI mixer outside the sound card driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-23ALSA: opti-miro: make miro.h header available outside the alsa directoryKrzysztof Helt
Move the miro.h header to the include/sound directory. It can be used in the Miro PCM20 radio driver (v4l). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-21ALSA: opti-miro: remove snd_card pointer from snd_miro structureKrzysztof Helt
Remove the snd_card pointer from the snd_miro structure and do some small code improvements. Also, move Opti chipset detection before detection of the ACI mixer, so the mci_base value is set in one place only. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-18ALSA: opti-miro: Fix missing semicolonTakashi Iwai
To fix a build error sound/isa/opti9xx/miro.c:1281: error: expected ';' before '}' token Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-18ALSA: opti-miro: use variables directly in the probe functionKrzysztof Helt
Use the fm_port and mpu_port variables directly in a probe function. This completely eliminates a need to copy the fm_port value to the snd_miro structure. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-16Merge branch 'topic/snd_card_new-err' into topic/cs423x-mergeTakashi Iwai
2009-02-05ALSA: isa/*: Add missing KERN_* prefix to printkTakashi Iwai
2009-01-21ALSA: do not create OPL3 timers if there is no OPL3 irq wiredKrzysztof Helt
Most cards have OPL3 FM synthetiser but they do not have OPL3 interrupt wired to a sound chip or CPU. Do not create OPL3 timers for such cards as the timers are useless witthout interrupt. This patch removes OPL3 timers for following alsa drivers: snd-ad1816a, snd-opti93x, snd-opti92x, snd-sc6000, snd-cmi8330. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-14ALSA: opti9xx - Fix build breakage by snd_card_create() conversionTakashi Iwai
Add a missing variable declaration. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Return proper error code at probe in sound/isa/*Takashi Iwai
Some drivers in sound/isa/* don't handle the error code properly from snd_card_create(). This patch fixes these places. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in sound/isa/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-13ALSA: Kill snd_assert() in sound/isa/*Takashi Iwai
Kill snd_assert() in sound/isa/*, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: opti92x-ad1848 WSS_HW_DETECT fixRene Herman
snd-opti92x-ad1848 mistakingly passes WSS_HW_OPTI93X currently. This fixes it as tested with a OPTi 82C929A/AD1848 card. Signed-off-by: Rene Herman <rene.herman@gmail.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: use wss detection code instead of ad1848 oneKrzysztof Helt
Use the wss detection code and kill the ad1848 library. The library is fully assimilated into the new wss library. This required reworking of the AD1848 family code so the code is changed to correctly detect chips from the AD1848 and CS4231 families. I have tested it on following cards: Gallant SC-6600 (codec: AD1848, driver: snd-sc6600) SoundScape VIVO/90 (codec: AD1845, driver: snd-sscape) SG Waverider (codec: CS4231A, driver: Rene Herman's snd-galaxy) Opti930 (codec: built-in - CS4231 compatible, driver: snd-opti93x) Opti931 (codec: built-in - CS4231 compatible, driver: snd-opti93x) Gallant SC-70P (chip/codec: CS4237B, driver: snd-cs4236) Audio Plus 3D (chip/codec: CMI8330A, driver: snd-cmi8330) Dell Latitude CP (chip/codec: cs4236, driver snd-cs4232) Sound playback and recording works on all these cards. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: use wss pcm code instead of ad1848 oneKrzysztof Helt
Use the wss pcm code and kill the ad1848 pcm code. The AD1848 chip is much slower than CS4231 chips so the waiting loop was increased 100x (10x is not enough). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
