path: root/sound/isa
2010-05-20Merge branch 'topic/misc' into for-linusTakashi Iwai
2010-05-20Merge branch 'topic/core-cleanup' into for-linusTakashi Iwai
2010-05-17ALSA: es1688: add pedantic range checksDan Carpenter
Smatch complains that if (dev == SNDRV_CARDS) we're one past the end of the array. That's unlikely to happen in real life, I suppose. Also smatch complains about "strcpy(card->shortname, pcm->name);" The "pcm->name" buffer is 80 characters and "card->shortname" is 32 characters. If you follow the call paths it turns out we never actually use more than 16 characters so it's not a problem. But anyway, let's make it easy for people auditing this in the future. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-10ALSA: Merge es1688 and es968 driversKrzysztof Helt
The ESS ES968 chip is nothing more then a PnP companion for a non-PnP audio chip. It was paired with non-PnP ESS' chips: ES688 and ES1688. The ESS' audio chips are handled by the es1688 driver in native mode. The PnP cards are handled by the ES968 driver in SB compatible mode. Move the ES968 chip handling to the es1688 driver so the driver can handle both PnP and non-PnP cards. The es968 is removed. Also, a new PnP id is added for the card I acquired (the change was tested on this card). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-10ALSA: es1688: allocate snd_es1688 structure as a part of snd_card structureKrzysztof Helt
Allocate the snd_es1688 during the snd_card allocation. This allows to remove the card pointer from the snd_es1688 structure. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-26ALSA: es968: fix wrong PnP dma indexKrzysztof Helt
There is only one dma for the ESS ES968 based board. Its index is 0 and not 1. This make the es968 card working. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-13ALSA: info - Implement common llseek for binary modeTakashi Iwai
The llseek implementation is identical for existing driver implementations, so let's merge to the common layer. The same code for the text proc file can be used even for the binary proc file. The driver can provide its own llseek method if needed. Then the common code will be skipped. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-13ALSA: info - Check file position validity in common layerTakashi Iwai
Check the validity of the file position in the common info layer before calling read or write callbacks in assumption that entry->size is set up properly to indicate the max file size. Removed the redundant checks from the callbacks as well. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-13ALSA: info - Use standard types for info callbacksTakashi Iwai
Use loff_t, size_t and ssize_t for arguments of info callbacks to follow the standard procfs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08sound: fix opti92x-ad1848 buildRandy Dunlap
Fix 'else' placement in ifdef block so that build succeeds: sound/isa/opti9xx/opti92x-ad1848.c:221: error: 'else' without a previous 'if' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: fix jazz16 compile (udelay)Meelis Roos
While trying to compile jazz16 isa sound driver on alpha (2.6.33+git), I found a compile failure in jazz16.c (udelay is unknown). Fix it by including delay.h. Signed-foo-by: Meelis Roos <mroos@linux.ee> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-03ALSA: opti92x: use PnP data to select Master Control portKrzysztof Helt
The Master Control port (MC) is available as the last PnP resource (OPT005). Use this value instead fo guessing. Also, add some comments to the code. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-16Merge branch 'topic/misc' of ↵Jaroslav Kysela
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 into devel
2010-01-08sbawe: fix memory detection part 2Krzysztof Helt
The patch "sbawe: fix memory detection" fixed detection for memoryless SB32 cards but broke detection of memory above 512KB. This patch fixes the regression. The patch has been tested on the SB32 card (CT3670) with 0MB, 2MB and 8MB memory installed. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2009-12-25ALSA: jazz16: refine dma and irq selectionKrzysztof Helt
Narrow the dma and irq selection after the DOS driver. Add ALSA configuration description as well. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-22Merge branch 'fix/misc' into topic/miscTakashi Iwai
2009-12-21ALSA: jazz16: Add support for Media Vision Jazz16 chipsetKrzysztof Helt
This is one of Sound Blaster Pro compatible chipsets which is supported by Linux OSS driver and was missing native supoort for ALSA. The Jazz16 audio codec is Crystal CS4216 which is capable of playback and recording up to 48 kHz stereo. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-21ALSA: sbawe: fix memory detectionKrzysztof Helt
Memory amount is increased before a successful write-read sequence is done. Thus, 512 kB of onboard memory is detected on memoryless cards like SB32. Move the increasing of memory counter after successful read is done. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-19ALSA: Use kzalloc for allocating only one thingJulia Lawall
Use kzalloc rather than kcalloc(1,...) The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ @@ - kcalloc(1, + kzalloc( ...) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-15Merge branch 'fixes' of git://git.alsa-project.org/alsa-kernel into for-linusTakashi Iwai
2009-12-14Merge branch 'next/isa' into topic/miscTakashi Iwai
2009-12-14ALSA: sb_mixer: convert pointer tables to mixer control tablesKrzysztof Helt
Convert table of pointers to mixer controls into tables of the mixer controls. It saves about 20% of the snd-sb-common module size reported by lsmod. The als4000 uses part of sb16's control table. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-14ALSA: sound/isa/gus: Correct code taking the size of a pointerJulia Lawall
sizeof(share_id) is just the size of the pointer. On the other hand, block->share_id is an array, so its size seems more appropriate. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression *x; expression f; type T; @@ *f(...,(T)x,...) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Overwrite pin config on intel DG45ID board. intelhdmi - dont power off HDA link ALSA: hrtimer - Fix lock-up ALSA: intelhdmi - add channel mapping for typical configurations ALSA: intelhdmi - channel mapping applies to Pin ALSA: intelhdmi - accept DisplayPort pin ALSA: hda - show HBR(High Bit Rate) pin cap in procfs ALSA: hda - Fix LED GPIO setup for HP laptops with IDT codecs ASoC: Fix build of OMAP sound drivers ALSA: opti93x: fix irq releasing if the irq cannot be allocated
2009-12-12ALSA: opti93x: use dB scale for mixer controlsKrzysztof Helt
Add dB scale for mixer controls. Fix dB scale for Master Volume control. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-11ALSA: opti93x: move controls definitions to opti93x driverKrzysztof Helt
Move OPTi93x controls definitions to the opti93x driver from the common wss-lib library module. These controls are used only by the opti93x driver. Also, fix capture source names. They are the same as opl3sa2 names. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-11ALSA: dt019x: merge into the als100 driverKrzysztof Helt
The als100 driver is so similar to the dt019x/als007 driver that one driver's source can be used for both drivers with only few changes. Merge the dt019x driver into the als100. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-10ALSA: opti93x: fix irq releasing if the irq cannot be allocatedKrzysztof Helt
Use the chip->irq to check if the irq should be released so the irq is not released if it has not been allocated. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: ice1724 - aureon - modify WM8770 Master & DAC volume ALSA: hda/realtek: quirk for D945GCLF2 mainboard ALSA: hda - Terradici HDA controllers does not support 64-bit mode ALSA: document: Add direct git link to grub hda-analyzer ALSA: radio/sound/miro: fix build, cleanup depends/selects ALSA: hda - Generalize EAPD inversion check in patch_analog.c ASoC: Wrong variable returned on error ALSA: snd-usb-us122l: add product IDs of US-122MKII and US-144MKII ALSA: hda - Exclude unusable ADCs for ALC88x ALSA: hda - Add missing Line-Out and PCM switches as slave ALSA: hda - iMac 9,1 sound patch. ALSA: opti93x: set MC indirect registers base from PnP data
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-08ALSA: opti93x: set MC indirect registers base from PnP dataKrzysztof Helt
The PnP data on the OPTI931 and OPTI933 contains io port range for the MC indirect registers. Use the PnP range instead of hardwired value 0xE0E. Also, request region of MC indirect registers so it is marked as used to other drivers (this was missing previously). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-04Merge branch 'topic/misc' into for-linusTakashi Iwai
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-02ALSA: opti9xx: remove snd_opti9xx fieldsKrzysztof Helt
Remove snd_opti9xx fields which are indirect arguments to the snd_opti9xx_configure(). Pass these values as function arguments. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-30ALSA: opti-miro: add PnP detectionKrzysztof Helt
The PCM12 and PCM20 can be set into the ISA PnP mode. The PCM12 PnP was sold as the PnP device. Add code to handle detection of these cards using ISA PnP framework. Tested on the PCM20 in PnP mode. The PCM12 PnP has the same MS Windows INF file except for a card name displayed for user. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-30ALSA: opti-miro: separate comon probing codeKrzysztof Helt
Separate common probing code in order to use it for PnP probing. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-27ALSA: opti-miro: fix OOPS if hardware is not detectedKrzysztof Helt
If a hardware is not detected there is a kernel crash due to not initialized snd_miro->aci pointer. This pointer is initialized after detection of the opti (miro) chip. This bug was introduced by patches to expose ACI mikser outside the snd-miro driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-23ALSA: opti-miro: expose ACI mixer to outside driversKrzysztof Helt
The ACI mixer is used to control the radio FM module installed on the Miro PCM20 sound card. Expose ACI mixer outside the sound card driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-23ALSA: opti-miro: make miro.h header available outside the alsa directoryKrzysztof Helt
Move the miro.h header to the include/sound directory. It can be used in the Miro PCM20 radio driver (v4l). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-21ALSA: opti-miro: remove snd_card pointer from snd_miro structureKrzysztof Helt
Remove the snd_card pointer from the snd_miro structure and do some small code improvements. Also, move Opti chipset detection before detection of the ACI mixer, so the mci_base value is set in one place only. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-19ALSA: cs4236: add dB scale for all volume controlsKrzysztof Helt
Use db scale for all volume controls according to Crystal's datasheets. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-18ALSA: opti-miro: Fix missing semicolonTakashi Iwai
To fix a build error sound/isa/opti9xx/miro.c:1281: error: expected ';' before '}' token Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-18ALSA: opti-miro: use variables directly in the probe functionKrzysztof Helt
Use the fm_port and mpu_port variables directly in a probe function. This completely eliminates a need to copy the fm_port value to the snd_miro structure. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-18ALSA: cs4236: update control namesKrzysztof Helt
Update control names to be more closer to their meaning. Change the "Mono" name to the "Beep" as this line is usually used to forward the PC beeper signal to sound card's output. Update names for both cs423x and wss. Clean up cs4235 controls according to the cs4235 doc. Rename some of the cs4235 controls to be consistent with the cs4236's ones. Also, delete one misnamed cs4231 register define. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-08ALSA: es18xx: code improvementsKrzysztof Helt
1. Set the third argument of the snd_device_new to not NULL, so there is no warning about bug during chip detection. The third argument is not used in this driver. It was changed in my previous patch. 2. Remove the fm_port and mpu_port fields from the snd_es18xx structure. They can be converted to function arguments. 3. Remove the dmaN_size fields from the snd_es18xx structure. These values are used only in pointer functions and can be easily calculated. 4. Remove the ctrl_lock spinlock which is used only in one read function which is called once during chip initialization. There are many writes to the same register and they are not protected on purpose (see the comment ina the snd_es18xx_config_write()). 5. Use the first part of the text5Sources string table as the text4Soruces table (they are the same). 6. Merge the same cases for the ES1887 and ES1888 when setting chip's caps. 7. Move the snd_es18xx_reset() to __devinit section. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-05ALSA: cs4236: detect chip in one passKrzysztof Helt
The cs4236 was two step detection with call to the snd_wss_free() between two steps. The snd_wss_free() did not free a sound device created in the snd_wss_create(). This caused an OOPS during module removal as the same sound device was released twice. The same OOPS happened if the cs4236 module loading failed. Fix this by adapting the snd_cs4236_create() to correctly work with chips less capable then cs4236. The snd_cs4236_create() behaves the same as the snd_wss_create() if the chip is less capable than the cs4236. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-05ALSA: rename "PC Speaker" and "PC Beep" controls to "Beep"Jaroslav Kysela
To avoid confusion in control names for the standard analog PC Beep generator using a small Internal PC Speaker, rename all related "PC Speaker" and "PC Beep" controls to "Beep" only. This name is more universal and can be also used on more platforms without confusion. Introduce also "Internal Speaker" in ControlNames.txt for systems with full-featured build-in internal speaker. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-30ALSA: es18xx: remove snd_audiodrive structureKrzysztof Helt
Remove intermediate snd_audiodrive structure between snd_card structure and snd_es18xx. This reduces size of source code and binary driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-30ALSA: es18xx: remove snd_card pointer from snd_es18xx structureKrzysztof Helt
The snd_card pointer is redundant and code can be easily changed to work without it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
