path: root/sound/mips/ad1843.c
2013-11-06ALSA: mips/ad1843: Use WARN_ON() instead of BUG_ON()Takashi Iwai
BUG_ON() is rather useless for debugging as it leads to panic(). Use WARN_ON() and handle the error cases accordingly. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-14ALSA: ALSA driver for SGI O2 audio boardThomas Bogendoerfer
This patch adds a new ALSA driver for the audio device found inside most of the SGI O2 workstation. The hardware uses a SGI custom chip, which feeds a AD codec chip. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
