path: root/sound/oss
2013-05-13sound: Fix make allmodconfig on MIPS correctlyPaul Bolle
Commit d4702b189c ("sound: Fix make allmodconfig on MIPS") added a (negative) dependency on ISA_DMA_SUPPORT_BROKEN. Since that Kconfig symbol doesn't exist, this dependency will always evaluate to true. Apparently GENERIC_ISA_DMA_SUPPORT_BROKEN was meant to be used here. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-10Merge tag 'sound-3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "This contains small fixes since the previous pull request: - A few regression fixes and small updates of HD-audio - Yet another fix for Haswell HDMI audio - A copule of trivial fixes in ASoC McASP, DPAM and WM8994" * tag 'sound-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: Revert "ALSA: hda - Don't set up active streams twice" ALSA: Add comment for control TLV API ALSA: hda - Apply pin-enablement workaround to all Haswell HDMI codecs ALSA: HDA: Fix Oops caused by dereference NULL pointer ALSA: mips/sgio2audio: Remove redundant platform_set_drvdata() ALSA: mips/hal2: Remove redundant platform_set_drvdata() ALSA: hda - Fix 3.9 regression of EAPD init on Conexant codecs sound: Fix make allmodconfig on MIPS ALSA: hda - Fix system panic when DMA > 40 bits for Nvidia audio controllers ALSA: atmel: Remove redundant platform_set_drvdata() ASoC: McASP: Fix receive clock polarity in DAIFMT_NB_NF mode. ASoC: wm8994: missing break in wm8994_aif3_hw_params() ASoC: McASP: Add pins output direction for rx clocks when configured in CBS_CFS format ASoC: dapm: use clk_prepare_enable and clk_disable_unprepare
2013-05-03Merge tag 'sound-3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "Mostly many small changes spread as seen in diffstat in sound/* directory by this update. A significant change in the subsystem level is the introduction of snd_soc_component, which will help more generic handling of SoC and off-SoC components. Also, snd_BUG_ON() macro is enabled unconditionally now due to its misuses, so people might hit kernel warnings (it's a good thing for us). - compress-offload: support for capture by Charles Keepax - HD-audio: codec delay support by Dylan Reid - HD-audio: improvements/fixes in generic parser: better headphone mic and headset mic support, jack_modes hint consolidation, proper beep attach/detachment, generalized power filter controls by David Henningsson, et al - HD-audio: Improved management of HDMI codec pins/converters - HD-audio: Better pin/DAC assignment for VIA codecs - HD-audio: Haswell HDMI workarounds - HD-audio: ALC268 codec support, a few new quirks for Chromebooks - USB: regression fixes: USB-MIDI autopm fix, the recent ISO latency fix by Clemens Ladisch - USB: support for DSD formats by Daniel Mack - USB: A few UAC2 device endian/cock fixes by Eldad Zack - USB: quirks for Emu 192kHz support, Novation Twitch DJ controller, Yamaha THRxx devices - HDSPM: updates for TCO controls by Adrian Knoth - ASoC: Add a snd_soc_component object type for generic handling of SoC and off-SoC components by Kuninori Morimoto, - dmaengine: a large set of cleanups and conversions by Lars-Peter Clausen - ASoC DAPM: performance optimizations from Ryo Tsutsui - ASoC DAPM: support for mixer control sharing by Stephen Warren - ASoC: multiplatform ARM cleanups from Arnd Bergmann - ASoC: new codec drivers for AK5385 and TAS5086 from Daniel Mack" * tag 'sound-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (315 commits) ALSA: usb-audio: caiaq: fix endianness bug in snd_usb_caiaq_maschine_dispatch ALSA: asihpi: add format support check in snd_card_asihpi_capture_formats ALSA: pcm_format_to_bits strong-typed conversion ALSA: compress: fix the states to check for allowing read ALSA: hda - Move Thinkpad X220 to use auto parser ALSA: USB: adjust for changed 3.8 USB API ALSA: usb - Avoid unnecessary sample rate changes on USB 2.0 clock sources sound: oss/dmabuf: use dma_map_single ALSA: ali5451: use mdelay instead of large udelay constants ALSA: hda - Add the support for ALC286 codec ALSA: usb-audio: USB quirk for Yamaha THR10C ALSA: usb-audio: USB quirk for Yamaha THR5A ALSA: usb-audio: USB quirk for Yamaha THR10 ALSA: usb-audio: Fix autopm error during probing ALSA: snd-usb: try harder to find USB_DT_CS_ENDPOINT ALSA: sound kconfig typo ALSA: emu10k1: Fix dock firmware loading ASoC: ux500: forward declare msp_i2s_platform_data ASoC: davinci-mcasp: Add Support BCLK-to-LRCLK ratio for TDM modes ASoC: davinci-pcm, davinci-mcasp: Clean up active_serializers ...
2013-05-03sound: Fix make allmodconfig on MIPSTakashi Iwai
The compile of soundcard.c is broken on MIPS when allmodconfig is used because of the missing MAX_DMA_CHANNELS definition. As a simple workaround, just add a Kconfig dependency. Reported-by: Andrew Morton <akpm@linux-foundation.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-29dmasound_core: saner arguments for sq_fsync()Al Viro
it is not (and it has never been) an ->fsync() instance... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-26sound: oss/dmabuf: use dma_map_singleArnd Bergmann
The virt_to_bus/bus_to_virt functions have been deprecated for as long as I can remember, and they are used in very few remaining instances, usually in obscure ISA device drivers. The OSS sound drivers are the only ones that are still used on the ARM architecture, and only on some of the earliest StrongARM machines. The problem for converting the OSS subsystem to use dma_map_single instead is that the caller of virt_to_bus does not have a device pointer, since the subsystem has never been ported to use the common device infrastructure. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-02sound: oss: sb_common: Used kmemdup instead of kmalloc and memcpyAlexandru Gheorghiu
Used kmemdup instead of replicating it's behaviour with kmalloc followed by memcpy. Patch found using coccinelle. Signed-off-by: Alexandru Gheorghiu <gheorghiuandru@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-02sound: oss: uart401: Used kmemdup instead of kmalloc and memcpyAlexandru Gheorghiu
2013-03-15sound: sequencer: cap array index in seq_chn_common_event()Dan Carpenter
"chn" here is a number between 0 and 255, but ->chn_info[] only has 16 elements so there is a potential write beyond the end of the array. If the seq_mode isn't SEQ_2 then we let the individual drivers (either opl3.c or midi_synth.c) handle it. Those functions all do a bounds check on "chn" so I haven't changed anything here. The opl3.c driver has up to 18 channels and not 16. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-02-22new helper: file_inode(file)Al Viro
2013-01-04sound: oss/pas2: Fix possible access out of arrayAsim Kadav
Added a fix for hardware dependence bug where a sound card failure should not result in reading beyond array memory index. Signed-off-by: Asim Kadav <kadav@cs.wisc.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-07sound: oss: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-18sound: oss/sb_audio: cap value in sb201_audio_set_speed()Dan Carpenter
We set "s" before we have capped "speed" so it could be the wrong value. This could lead to a divide by zero bug. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-10-11Merge tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC fixes from Olof Johansson: "A series of fixes (and in some cases, some cleanups): Via Tony Lindgren: - A collection of OMAP regression fixes, in particular because firmware no longer sets up all pin states before starting the kernel. - cpufreq fixes for OMAP (Rafael is on vacation and this was pre-agreed). - A longer series of misc regression fixes and cleanups, warning removals, etc for OMAP From Arnd Bergmann: - A series of warning fixes for various platforms (defconfig builds) Misc: - A couple of tegra fixes, one for i.MX, some vt8500 fixes, etc." * tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (73 commits) ARM: pxa: armcore: fix PCI PIO warnings ARM: integrator: use __iomem pointers for MMIO, part 2 ARM: assabet: fix bogus warning in get_assabet_scr (again) ARM: shmobile: mark shmobile_init_late as __init ARM: integrator_cp: fix build failure ARM: OMAP4/AM335x: hwmod: fix disable_module regression in hardreset handling ARM: OMAP3: fix workaround for EMU clockdomain arm/omap: Replace board_ref_clock with enum values ARM: OMAP2+: remove duplicated include from board-omap3stalker.c arch/arm/plat-omap/omap-pm-noop.c: Remove unecessary semicolon arch/arm/mach-omap2: Remove unecessary semicolon arch/arm/mach-omap1/devices.c: Remove unecessary semicolon ARM/dts: omap5-evm: pinmux configuration for audio ARM/dts: Add pinctrl driver entries for omap5 ARM/dts: omap4-panda: pinmux configuration for audio ARM/dts: omap4-sdp: pinmux configuration for audio ARM/dts: omap5-evm: Disable unused McBSP3 ARM/dts: omap4-sdp: Disable unused McBSP3 ARM/dts: omap4-panda: Disable unused audio IPs ARM: OMAP: board-omap4panda: Pin mux configuration for audio needs ...
2012-10-09Merge tag 'sound-3.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "This contains pretty many small commits covering fairly large range of files in sound/ directory. Partly because of additional API support and partly because of constantly developed ASoC and ARM stuff. Some highlights: - Introduced the helper function and documentation for exposing the channel map via control API, as discussed in Plumbers; most of PCI drivers are covered, will follow more drivers later - Most of drivers have been replaced with the new PM callbacks (if the bus is supported) - HD-audio controller got the support of runtime PM and the support of D3 clock-stop. Also changing the power_save option in sysfs kicks off immediately to enable / disable the power-save mode. - Another significant code change in HD-audio is the rewrite of firmware loading code. Other than that, most of changes in HD-audio are continued cleanups and standardization for the generic auto parser and bug fixes (HBR, device-specific fixups), in addition to the support of channel-map API. - Addition of ASoC bindings for the compressed API, used by the mid-x86 drivers. - Lots of cleanups and API refreshes for ASoC codec drivers and DaVinci. - Conversion of OMAP to dmaengine. - New machine driver for Wolfson Microelectronics Bells. - New CODEC driver for Wolfson Microelectronics WM0010. - Enhancements to the ux500 and wm2000 drivers - A new driver for DA9055 and the support for regulator bypass mode." Fix up various arm soc header file reorg conflicts. * tag 'sound-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (339 commits) ALSA: hda - Add new codec ALC283 ALC290 support ALSA: hda - avoid unneccesary indices on "Headphone Jack" controls ALSA: hda - fix indices on boost volume on Conexant ALSA: aloop - add locking to timer access ALSA: hda - Fix hang caused by race during suspend. sound: Remove unnecessary semicolon ALSA: hda/realtek - Fix detection of ALC271X codec ALSA: hda - Add inverted internal mic quirk for Lenovo IdeaPad U310 ALSA: hda - make Realtek/Sigmatel/Conexant use the generic unsol event ALSA: hda - make a generic unsol event handler ASoC: codecs: Add DA9055 codec driver ASoC: eukrea-tlv320: Convert it to platform driver ALSA: ASoC: add DT bindings for CS4271 ASoC: wm_hubs: Ensure volume updates are handled during class W startup ASoC: wm5110: Adding missing volume update bits ASoC: wm5110: Add OUT3R support ASoC: wm5110: Add AEC loopback support ASoC: wm5110: Rename EPOUT to HPOUT3 ASoC: arizona: Add more clock rates ASoC: arizona: Add more DSP options for mixer input muxes ...
2012-10-07Merge branch 'late/fixes' into fixesOlof Johansson
This is a series from Arnd that fixes a number of compiler warnings when building defconfigs on ARM. * late/fixes: ARM: footbridge: nw_gpio_lock is raw_spin_lock ARM: mv78xx0: correct addr_map_cfg __initdata annotation ARM: footbridge: remove RTC_IRQ definition ARM: soc: dependency warnings for errata ARM: ks8695: __arch_virt_to_dma type handling ARM: rpc: check device_register return code in ecard_probe ARM: davinci: don't mark da850_register_cpufreq as __init ARM: iop13xx: fix iq81340sc_atux_map_irq prototype ARM: iop13xx: mark iop13xx_scan_bus as __devinit ARM: mv78xx0: mark mv78xx0_timer_init as __init_refok ARM: s3c24xx: fix multiple section mismatch warnings ARM: at91: unused variable in at91_pm_verify_clocks ARM: at91: skip at91_io_desc definition for NOMMU ARM: pxa: work around duplicate definition of GPIO24_SSP1_SFRM ARM: pxa: remove sharpsl_fatal_check function ARM: pxa: define palmte2_pxa_keys conditionally ARM: pxa: Wunused-result warning in viper board file ARM: shark: fix shark_pci_init return code Fixed trivial conflicts in arch/arm/mach-at91/setup.c. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-10-07ARM: footbridge: nw_gpio_lock is raw_spin_lockArnd Bergmann
bd31b85960a "locking, ARM: Annotate low level hw locks as raw" made nw_gpio_lock a raw spinlock, but did not change all the users in device drivers. This fixes the remaining ones. sound/oss/waveartist.c: In function 'vnc_mute_spkr': sound/oss/waveartist.c:1485:2: warning: passing argument 1 of 'spinlock_check' from incompatible pointer type [enabled by default] include/linux/spinlock.h:272:102: note: expected 'struct spinlock_t *' but argument is of type 'struct raw_spinlock_t *' drivers/char/ds1620.c: In function 'netwinder_lock': drivers/char/ds1620.c:77:2: warning: passing argument 1 of 'spinlock_check' from incompatible pointer type [enabled by default] include/linux/spinlock.h:272:102: note: expected 'struct spinlock_t *' but argument is of type 'struct raw_spinlock_t *' drivers/char/nwflash.c: In function 'kick_open': drivers/char/nwflash.c:620:2: warning: passing argument 1 of 'spinlock_check' from incompatible pointer type [enabled by default] include/linux/spinlock.h:272:102: note: expected 'struct spinlock_t *' but argument is of type 'struct raw_spinlock_t *' Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk>
2012-10-06sound: Remove unnecessary semicolonPeter Senna Tschudin
A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r1@ statement S; position p,p1; @@ S@p1;@p @script:python r2@ p << r1.p; p1 << r1.p1; @@ if p[0].line != p1[0].line_end: cocci.include_match(False) @@ position r1.p; @@ -;@p // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-10-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull the trivial tree from Jiri Kosina: "Tiny usual fixes all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) doc: fix old config name of kprobetrace fs/fs-writeback.c: cleanup riteback_sb_inodes kerneldoc btrfs: fix the commment for the action flags in delayed-ref.h btrfs: fix trivial typo for the comment of BTRFS_FREE_INO_OBJECTID vfs: fix kerneldoc for generic_fh_to_parent() treewide: fix comment/printk/variable typos ipr: fix small coding style issues doc: fix broken utf8 encoding nfs: comment fix platform/x86: fix asus_laptop.wled_type module parameter mfd: printk/comment fixes doc: getdelays.c: remember to close() socket on error in create_nl_socket() doc: aliasing-test: close fd on write error mmc: fix comment typos dma: fix comments spi: fix comment/printk typos in spi Coccinelle: fix typo in memdup_user.cocci tmiofb: missing NULL pointer checks tools: perf: Fix typo in tools/perf tools/testing: fix comment / output typos ...
2012-09-01oss: remove maui_boot.h from .gitignore and dontdiffPaul Bolle
Commit d56b9b9c464a10ab1ee51a4c6190a2b57b8ef7a6 ("The scheduled removal of some OSS drivers") removed all traces of maui_boot.h from the tree. Remove its entries in dontdiff and oss's .gitignore file. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-08-20Merge tag 'asoc-3.6' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Additional updates for 3.6 A batch more bugfixes, all driver-specific and fairly small and unremarkable in a global context. The biggest batch are for the newly added Arizona drivers.
2012-08-20sound: oss/sb_audio: prevent divide by zero bugDan Carpenter
Speed comes from get_user() in audio_ioctl(). We use it to set the "s" variable before clamping it to valid values so it could lead to a divide by zero bug. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-24Merge tag 'sound-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound update from Takashi Iwai: "This is a fairly quiet release in all sound area. Only a little bit of changes in the core side while most of changes are seen in the drivers. HD-audio: - A few new codec additions for Nvidia, Realtek and VIA - Intel Haswell audio support - Support for "phantom" jacks for consistent jack reporting - Major clean-ups in HDMI/DP driver codes - A workaround for inverted digital-mic pins with Realtek codecs - Removal of beep_mode=2 option ASoC: - Added the ability to add and remove DAPM paths dynamically, mostly for reparenting on clock changes - New machine drivers for Marvell Brownstone, ST-Ericsson Ux500 reference platform and ttc-dkp - New CPU drivers for Blackfin BF6xx SPORTs in I2S mode, Marvell MMP, Synopsis Designware I2S controllers, and SPEAr DMA and S/PDIF - New CODEC drivers for Dialog DA732x, ST STA529, ST-Ericsson AB8500, TI Isabelle and Wolfson Microelectronics WM5102 and WM5110 - DAPM fixes for the recent locking changes - Fix for _PRE and _POST widgets (which have been broken for a few releases now) - A couple of minor driver updates Misc - Conversion to new dev_pm_ops in platform and PCI drivers - LTC support and some fixes in PCXHR driver - A few fixes and PM support for ISA OPti9xx and WSS cards - Some TLV code cleanup - Move driver-specific headers from include/sound to local dirs" * tag 'sound-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (212 commits) ASoC: dapm: Fix _PRE and _POST events for DAPM performance improvements ALSA: hda - add dock support for Thinkpad X230 Tablet ALSA: hda - Turn on PIN_OUT from hdmi playback prepare. ASoC imx-audmux: add MX31_AUDMUX_PORT7_SSI_PINS_7 define ASoC: littlemill: Add userspace control of the WM1250 I/O ASoC: wm8994: Update micdet for irqdomain conversion ALSA: hda - make sure alc268 does not OOPS on codec parse ALSA: hda - Add support for Realtek ALC282 ALSA: hda - Fix index number conflicts of phantom jacks ALSA: opti9xx: Fix section mismatch by PM support ALSA: snd-opti9xx: Implement suspend/resume ALSA: hda - Add new GPU codec ID to snd-hda ALSA: hda - Fix driver type of Haswell controller to AZX_DRIVER_SCH ALSA: hda - add Haswell HDMI codec id ALSA: hda - Add DeviceID for Haswell HDA ALSA: wss_lib: Fix resume on Yamaha OPL3-SAx ALSA: wss_lib: fix suspend/resume ALSA: es1938: replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE ALSA: tlv: add DECLARE_TLV_DB_RANGE() ALSA: tlv: add DECLARE_TLV_CONTAINER() ...
2012-06-20sound: swarm_cs4297: Provide definitions for AC97 registersEzequiel Garcia
This patch removes the last usage of linux/ac97_codec.h by re-defining used AC97 registers. We can't use sound/ac97_codec.h here, since it is an OSS driver. Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-03Fix comment typo multipy -> multiplyRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-04-10sound: sound/oss/msnd_pinnacle.c: add vfreesJulia Lawall
At the point of this error-handling code, HAVE_DSPCODEH may be undefined, so free INITCODE and PERMCODE as done elsewhere. A jump and label are introduced to avoid code duplication. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-03-30Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "A collection of small fixes for 3.4-rc1, including - mic-recording regression fix for Realtek codec - clean-up of dmaengine parameter mess - WM8894 calibration tweak - minor fixes for asihpi and some bool module parms" * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: fix isa/opti9xx module param type sound: fix oss/msnd_pinnacle module param type ALSA: asihpi - fix return type of hpios_locked_mem_alloc() ASoC: dmaengine_pcm: use dmaengine cyclic wrapper ASoC: Add extra parameter to device_prep_dma_cyclic ALSA: hda/realtek - Fix ADC assignment with a shared HP/Mic pin ASoC: wm8994: Update WM8994 DCS calibration
2012-03-29sound: fix oss/msnd_pinnacle module param typeRandy Dunlap
Fix module parameter data type to eliminate build warning. sound/oss/msnd_pinnacle.c:1727:1: warning: return from incompatible pointer type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-01-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (526 commits) ASoC: twl6040 - Add method to query optimum PDM_DL1 gain ALSA: hda - Fix the lost power-setup of seconary pins after PM resume ALSA: usb-audio: add Yamaha MOX6/MOX8 support ALSA: virtuoso: add S/PDIF input support for all Xonars ALSA: ice1724 - Support for ooAoo SQ210a ALSA: ice1724 - Allow card info based on model only ALSA: ice1724 - Create capture pcm only for ADC-enabled configurations ALSA: hdspm - Provide unique driver id based on card serial ASoC: Dynamically allocate the rtd device for a non-empty release() ASoC: Fix recursive dependency due to select ATMEL_SSC in SND_ATMEL_SOC_SSC ALSA: hda - Fix the detection of "Loopback Mixing" control for VIA codecs ALSA: hda - Return the error from get_wcaps_type() for invalid NIDs ALSA: hda - Use auto-parser for HP laptops with cx20459 codec ALSA: asihpi - Fix potential Oops in snd_asihpi_cmode_info() ALSA: hdsp - Fix potential Oops in snd_hdsp_info_pref_sync_ref() ALSA: hda/cirrus - support for iMac12,2 model ASoC: cx20442: add bias control over a platform provided regulator ALSA: usb-audio - Avoid flood of frame-active debug messages ALSA: snd-usb-us122l: Delete calls to preempt_disable mfd: Put WM8994 into cache only mode when suspending ... Fix up trivial conflicts in: - arch/arm/mach-s3c64xx/mach-crag6410.c: renamed speyside_wm8962 to tobermory, added littlemill right next to it - drivers/base/regmap/{regcache.c,regmap.c}: duplicate diff that had already come in with other changes in the regmap tree
2011-12-19ALSA: module_param: make bool parameters really boolRusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-22sound: Kconfig: drop unknown symbol ARCH_CLPS7500Paul Bolle
Commit 635f0258e5 ("[ARM] clps7500: remove support") missed one instance of the ARCH_CLPS7500 Kconfig symbol. Drop it now. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (549 commits) ALSA: hda - Fix ADC input-amp handling for Cx20549 codec ALSA: hda - Keep EAPD turned on for old Conexant chips ALSA: hda/realtek - Fix missing volume controls with ALC260 ASoC: wm8940: Properly set codec->dapm.bias_level ALSA: hda - Fix pin-config for ASUS W90V ALSA: hda - Fix surround/CLFE headphone and speaker pins order ALSA: hda - Fix typo ALSA: Update the sound git tree URL ALSA: HDA: Add new revision for ALC662 ASoC: max98095: Convert codec->hw_write to snd_soc_write ASoC: keep pointer to resource so it can be freed ASoC: sgtl5000: Fix wrong mask in some snd_soc_update_bits calls ASoC: wm8996: Fix wrong mask for setting WM8996_AIF_CLOCKING_2 ASoC: da7210: Add support for line out and DAC ASoC: da7210: Add support for DAPM ALSA: hda/realtek - Fix DAC assignments of multiple speakers ASoC: Use SGTL5000_LINREG_VDDD_MASK instead of hardcoded mask value ASoC: Set sgtl5000->ldo in ldo_regulator_register ASoC: wm8996: Use SND_SOC_DAPM_AIF_OUT for AIF2 Capture ASoC: wm8994: Use SND_SOC_DAPM_AIF_OUT for AIF3 Capture ...
2011-09-29sound: oss: use strlcpy() in sound_timer_init()Dan Carpenter
sound_timer.info.name is a 32 character buffer. This function only has one caller (in sound/oss/ad1848.c) and it passes as 128 character buffer as "name". I don't know if this is a problem in real life, and I doubt we're going to add more OSS drivers so it's unlikely to become an issue. But we may as well take care of it. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-08-08sound: pss - don't use the deprecated function check_regionWang Shaoyan
sound/oss/pss.c: In function 'configure_nonsound_components': sound/oss/pss.c:676: warning: 'check_region' is deprecated (declared at include/linux/ioport.h:201) Signed-off-by: Wang Shaoyan <wangshaoyan.pt@taobao.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-04sound: oss/pas2: Remove CLOCK_TICK_RATE dependency from PAS16 driverDeepak Saxena
Update the PAS16 driver to use PIT_TICK_RATE instead of the more generic CLOCK_TICK_RATE as the two are equivalent on X86 and we want to depecrate the later. Signed-off-by: Deepak Saxena <dsaxena@linaro.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-27sound: oss: rename local change_bits to avoid powerpc bitsops.h definitionAndy Whitcroft
This collides with powerpc exported functions from bitops.h. Rename the local copy in the oss soundblaster mixer and ad1848 driver. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-20SOUND: OSS: Remove Au1550 driver.Ralf Baechle
This driver does no longer build since at least 2.6.30 and there is a modern ALSA replacement for it. RIP, Rot In Pieces. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-23sound/oss/opl3: validate voice and channel indexesDan Rosenberg
User-controllable indexes for voice and channel values may cause reading and writing beyond the bounds of their respective arrays, leading to potentially exploitable memory corruption. Validate these indexes. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-23sound/oss: remove offset from load_patch callbacksDan Rosenberg
Was: [PATCH] sound/oss/midi_synth: prevent underflow, use of uninitialized value, and signedness issue The offset passed to midi_synth_load_patch() can be essentially arbitrary. If it's greater than the header length, this will result in a copy_from_user(dst, src, negative_val). While this will just return -EFAULT on x86, on other architectures this may cause memory corruption. Additionally, the length field of the sysex_info structure may not be initialized prior to its use. Finally, a signed comparison may result in an unintentionally large loop. On suggestion by Takashi Iwai, version two removes the offset argument from the load_patch callbacks entirely, which also resolves similar issues in opl3. Compile tested only. v3 adjusts comments and hopefully gets copy offsets right. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11Merge branch 'fix/misc' into topic/miscTakashi Iwai
2011-03-09sound: Use sound_register_*() for additional OSS minor devicesTakashi Iwai
Since OSS driver creates the device entries for /dev/audio* and /dev/dspW* by itself without coping with sound_core, it leads to conflicts with others and let sysfs spewing warnings. This patch rewrites the registration part of OSS driver to use the standard method also for additional minor devices. Reported-by: Steven Rostedt <rostedt@goodmis.org> (with ktest.pl) Tested-by: Steven Rostedt <rostedt@goodmis.org> (with ktest.pl) Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-31sound: silent echo'ed messages in MakefileAmerigo Wang
Silent these echo's, please. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-30sound: Prevent buffer overflow in OSS load_mixer_volumesDan Rosenberg
The load_mixer_volumes() function, which can be triggered by unprivileged users via the SOUND_MIXER_SETLEVELS ioctl, is vulnerable to a buffer overflow. Because the provided "name" argument isn't guaranteed to be NULL terminated at the expected 32 bytes, it's possible to overflow past the end of the last element in the mixer_vols array. Further exploitation can result in an arbitrary kernel write (via subsequent calls to load_mixer_volumes()) leading to privilege escalation, or arbitrary kernel reads via get_mixer_levels(). In addition, the strcmp() may leak bytes beyond the mixer_vols array. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: stable <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-11sound/oss: Remove unnecessary casts of void ptrJesper Juhl
The [vk][cmz]alloc(_node) family of functions return void pointers which it's completely unnecessary/pointless to cast to other pointer types since that happens implicitly. This patch removes such casts from sound/oss/ Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-11sound/oss/dev_table.c: Use vzallocJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: usb-audio: automatically detect feedback format ASoC: sound/wm9090: add missing __devexit marker ASoC: sound/max98088: add missing __devexit marker ASoC: sound/ad73311: add missing __devexit marker ASoC: fsl - fix build error in pcm030-audio-fabric.c sound/oss/sb_ess.c: delete double assignment ALSA: hda - Change BTL amp level on some HP notebooks
2010-10-26sound/oss/sb_ess.c: delete double assignmentJulia Lawall
Delete successive assignments to the same location. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression i; @@ *i = ...; i = ...; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
