commit bc26d4d06e337ade069f33d3f4377593b24e6e36 upstream.
A deadlock can be initiated by userspace via ioctl(SNDCTL_SEQ_OUTOFBAND)
on /dev/sequencer with TMR_ECHO midi event.
In this case the control flow is:
sound_ioctl()
-> case SND_DEV_SEQ:
case SND_DEV_SEQ2:
sequencer_ioctl()
-> case SNDCTL_SEQ_OUTOFBAND:
spin_lock_irqsave(&lock,flags);
play_event();
-> case EV_TIMING:
seq_timing_event()
-> case TMR_ECHO:
seq_copy_to_input()
-> spin_lock_irqsave(&lock,flags);
It seems that spin_lock_irqsave() around play_event() is not necessary,
because the only other call location in seq_startplay() makes the call
without acquiring spinlock.
So, the patch just removes spinlocks around play_event().
By the way, it removes unreachable code in seq_timing_event(),
since (seq_mode == SEQ_2) case is handled in the beginning.
Compile tested only.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Cc: Willy Tarreau <w@1wt.eu>
There are three files in oss for which I could not find an easy way to
replace interruptible_sleep_on_timeout with a non-racy version. This
patch instead just adds a private implementation of the function, now
named oss_broken_sleep_on, and changes over the remaining users in
sound/oss/ so we can remove the global interface.
[fixed coding style warnings by tiwai]
The use of interruptible_sleep_on_timeout in the dmasound driver
is questionable and we want to kill off all sleep_on variants.
This replaces the calls with wait_event_interruptible_timeout
where possible, to wait for a particular event instead of blocking
in a racy way. In the sq_write function, the easiest solution is
an open-coded prepare_to_wait loop.
sleep_on is known to be racy and going away because of this. All instances
of interruptible_sleep_on and interruptible_sleep_on_timeout in the midibuf
driver can trivially be replaced with wait_event_interruptible and
wait_event_interruptible_timeout.
Interruptible_sleep_on is racy and we want to remove it. This replaces
the use in the vwsnd driver with an open-coded prepare_to_wait
loop that fixes the race between concurrent open() and close() calls,
and also drops the global mutex while waiting here, which restores
the original behavior that was changed during the BKL removal.
We want to remove all sleep_on variants from the kernel because they are
racy. In case of the pinnacle driver, we can replace
interruptible_sleep_on_timeout with wait_event_interruptible_timeout
by changing the meaning of a few flags used in the driver so they
are cleared at wakeup time, which is a somewhat more appropriate
way to do the same, although probably still racy.
These aren't necessary after switch and if blocks.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next
ASoC: Updates for v3.12
- DAPM is now mandatory for CODEC drivers in order to avoid the repeated
regressions in the special cases for non-DAPM CODECs and make it
easier to integrate with other components on boards. All existing
drivers have had some level of DAPM support added.
- A lot of cleanups in DAPM plus support for maintaining controls in a
specific state while a DAPM widget all contributed by Lars-Peter Clausen.
- Core helpers for bitbanged AC'97 reset from Markus Pargmann.
- New drivers and support for Analog Devices ADAU1702 and ADAU1401(a),
Asahi Kasei Microdevices AK4554, Atmel AT91ASM9x5 and WM8904 based
machines, Freescale S/PDIF and SSI AC'97, Renesas R-Car SoCs, Samsung
Exynos5420 SoCs, Texas Instruments PCM1681 and PCM1792A and Wolfson
Microelectronics WM8997.
- Support for building drivers that can support it cross-platform for
compile test.
We don't actually use the "go" variable so it can be removed.
While the conversion of BKL to mutex in commit 645ef9ef, the mutex
definition was put in a wrong place inside #ifdef WSND_DEBUG, which
leads to the build error. Just move it outside the ifdef.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Only kahlua.c has it.
Commit d4702b189c ("sound: Fix make allmodconfig on MIPS") added a
(negative) dependency on ISA_DMA_SUPPORT_BROKEN. Since that Kconfig
symbol doesn't exist, this dependency will always evaluate to true.
Apparently GENERIC_ISA_DMA_SUPPORT_BROKEN was meant to be used here.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"This contains small fixes since the previous pull request:
- A few regression fixes and small updates of HD-audio
- Yet another fix for Haswell HDMI audio
- A copule of trivial fixes in ASoC McASP, DPAM and WM8994"
* tag 'sound-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
Revert "ALSA: hda - Don't set up active streams twice"
ALSA: Add comment for control TLV API
ALSA: hda - Apply pin-enablement workaround to all Haswell HDMI codecs
ALSA: HDA: Fix Oops caused by dereference NULL pointer
ALSA: mips/sgio2audio: Remove redundant platform_set_drvdata()
ALSA: mips/hal2: Remove redundant platform_set_drvdata()
ALSA: hda - Fix 3.9 regression of EAPD init on Conexant codecs
ALSA: hda - Fix system panic when DMA > 40 bits for Nvidia audio controllers
ALSA: atmel: Remove redundant platform_set_drvdata()
ASoC: McASP: Fix receive clock polarity in DAIFMT_NB_NF mode.
ASoC: wm8994: missing break in wm8994_aif3_hw_params()
ASoC: McASP: Add pins output direction for rx clocks when configured in CBS_CFS format
ASoC: dapm: use clk_prepare_enable and clk_disable_unprepare
Pull sound updates from Takashi Iwai:
"Mostly many small changes spread as seen in diffstat in sound/*
directory by this update. A significant change in the subsystem level
is the introduction of snd_soc_component, which will help more generic
handling of SoC and off-SoC components.
Also, snd_BUG_ON() macro is enabled unconditionally now due to its
misuses, so people might hit kernel warnings (it's a good thing for
us).
- compress-offload: support for capture by Charles Keepax
- HD-audio: codec delay support by Dylan Reid
- HD-audio: improvements/fixes in generic parser: better headphone
mic and headset mic support, jack_modes hint consolidation, proper
beep attach/detachment, generalized power filter controls by David
Henningsson, et al
- HD-audio: Improved management of HDMI codec pins/converters
- HD-audio: Better pin/DAC assignment for VIA codecs
- HD-audio: Haswell HDMI workarounds
- HD-audio: ALC268 codec support, a few new quirks for Chromebooks
- USB: regression fixes: USB-MIDI autopm fix, the recent ISO latency
fix by Clemens Ladisch
- USB: support for DSD formats by Daniel Mack
- USB: A few UAC2 device endian/cock fixes by Eldad Zack
- USB: quirks for Emu 192kHz support, Novation Twitch DJ controller,
Yamaha THRxx devices
- HDSPM: updates for TCO controls by Adrian Knoth
- ASoC: Add a snd_soc_component object type for generic handling of
SoC and off-SoC components by Kuninori Morimoto,
- dmaengine: a large set of cleanups and conversions by Lars-Peter
Clausen
- ASoC DAPM: performance optimizations from Ryo Tsutsui
- ASoC DAPM: support for mixer control sharing by Stephen Warren
- ASoC: multiplatform ARM cleanups from Arnd Bergmann
- ASoC: new codec drivers for AK5385 and TAS5086 from Daniel Mack"
* tag 'sound-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (315 commits)
ALSA: usb-audio: caiaq: fix endianness bug in snd_usb_caiaq_maschine_dispatch
ALSA: asihpi: add format support check in snd_card_asihpi_capture_formats
ALSA: pcm_format_to_bits strong-typed conversion
ALSA: compress: fix the states to check for allowing read
ALSA: hda - Move Thinkpad X220 to use auto parser
ALSA: USB: adjust for changed 3.8 USB API
ALSA: usb - Avoid unnecessary sample rate changes on USB 2.0 clock sources
sound: oss/dmabuf: use dma_map_single
ALSA: ali5451: use mdelay instead of large udelay constants
ALSA: hda - Add the support for ALC286 codec
ALSA: usb-audio: USB quirk for Yamaha THR10C
ALSA: usb-audio: USB quirk for Yamaha THR5A
ALSA: usb-audio: Fix autopm error during probing
ALSA: snd-usb: try harder to find USB_DT_CS_ENDPOINT
ALSA: sound kconfig typo
ALSA: emu10k1: Fix dock firmware loading
ASoC: ux500: forward declare msp_i2s_platform_data
ASoC: davinci-mcasp: Add Support BCLK-to-LRCLK ratio for TDM modes
ASoC: davinci-pcm, davinci-mcasp: Clean up active_serializers
The compile of soundcard.c is broken on MIPS when allmodconfig is used
because of the missing MAX_DMA_CHANNELS definition. As a simple
workaround, just add a Kconfig dependency.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
it is not (and it has never been) an ->fsync() instance...
The virt_to_bus/bus_to_virt functions have been deprecated
for as long as I can remember, and they are used in very
few remaining instances, usually in obscure ISA device
drivers. The OSS sound drivers are the only ones that are
still used on the ARM architecture, and only on some of
the earliest StrongARM machines.
The problem for converting the OSS subsystem to use
dma_map_single instead is that the caller of virt_to_bus
does not have a device pointer, since the subsystem has
never been ported to use the common device infrastructure.
Used kmemdup instead of replicating it's behaviour with kmalloc followed
by memcpy.
Patch found using coccinelle.
Signed-off-by: Alexandru Gheorghiu <gheorghiuandru@gmail.com>
by memcpy.
"chn" here is a number between 0 and 255, but ->chn_info[] only has
16 elements so there is a potential write beyond the end of the
array.
If the seq_mode isn't SEQ_2 then we let the individual drivers
(either opl3.c or midi_synth.c) handle it. Those functions all
do a bounds check on "chn" so I haven't changed anything here.
The opl3.c driver has up to 18 channels and not 16.
Added a fix for hardware dependence bug where a sound card failure
should not result in reading beyond array memory index.
Signed-off-by: Asim Kadav <kadav@cs.wisc.edu>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
We set "s" before we have capped "speed" so it could be the wrong value.
This could lead to a divide by zero bug.
Pull ARM SoC fixes from Olof Johansson:
"A series of fixes (and in some cases, some cleanups):
Via Tony Lindgren:
- A collection of OMAP regression fixes, in particular because
firmware no longer sets up all pin states before starting the
kernel.
- cpufreq fixes for OMAP (Rafael is on vacation and this was
pre-agreed).
- A longer series of misc regression fixes and cleanups, warning
removals, etc for OMAP
From Arnd Bergmann:
- A series of warning fixes for various platforms (defconfig builds)
Misc:
- A couple of tegra fixes, one for i.MX, some vt8500 fixes, etc."
* tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (73 commits)
ARM: pxa: armcore: fix PCI PIO warnings
ARM: integrator: use __iomem pointers for MMIO, part 2
ARM: assabet: fix bogus warning in get_assabet_scr (again)
ARM: shmobile: mark shmobile_init_late as __init
ARM: integrator_cp: fix build failure
ARM: OMAP4/AM335x: hwmod: fix disable_module regression in hardreset handling
ARM: OMAP3: fix workaround for EMU clockdomain
arm/omap: Replace board_ref_clock with enum values
ARM: OMAP2+: remove duplicated include from board-omap3stalker.c
arch/arm/plat-omap/omap-pm-noop.c: Remove unecessary semicolon
arch/arm/mach-omap2: Remove unecessary semicolon
arch/arm/mach-omap1/devices.c: Remove unecessary semicolon
ARM/dts: omap5-evm: pinmux configuration for audio
ARM/dts: Add pinctrl driver entries for omap5
ARM/dts: omap4-panda: pinmux configuration for audio
ARM/dts: omap4-sdp: pinmux configuration for audio
ARM/dts: omap5-evm: Disable unused McBSP3
ARM/dts: omap4-sdp: Disable unused McBSP3
ARM/dts: omap4-panda: Disable unused audio IPs
ARM: OMAP: board-omap4panda: Pin mux configuration for audio needs
"This contains pretty many small commits covering fairly large range of
files in sound/ directory. Partly because of additional API support
and partly because of constantly developed ASoC and ARM stuff.
Some highlights:
- Introduced the helper function and documentation for exposing the
channel map via control API, as discussed in Plumbers; most of PCI
drivers are covered, will follow more drivers later
- Most of drivers have been replaced with the new PM callbacks (if
the bus is supported)
- HD-audio controller got the support of runtime PM and the support
of D3 clock-stop. Also changing the power_save option in sysfs
kicks off immediately to enable / disable the power-save mode.
- Another significant code change in HD-audio is the rewrite of
firmware loading code. Other than that, most of changes in
HD-audio are continued cleanups and standardization for the generic
auto parser and bug fixes (HBR, device-specific fixups), in
addition to the support of channel-map API.
- Addition of ASoC bindings for the compressed API, used by the
mid-x86 drivers.
- Lots of cleanups and API refreshes for ASoC codec drivers and
DaVinci.
- Conversion of OMAP to dmaengine.
- New machine driver for Wolfson Microelectronics Bells.
- New CODEC driver for Wolfson Microelectronics WM0010.
- Enhancements to the ux500 and wm2000 drivers
- A new driver for DA9055 and the support for regulator bypass mode."
Fix up various arm soc header file reorg conflicts.
* tag 'sound-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (339 commits)
ALSA: hda - Add new codec ALC283 ALC290 support
ALSA: hda - avoid unneccesary indices on "Headphone Jack" controls
ALSA: hda - fix indices on boost volume on Conexant
ALSA: aloop - add locking to timer access
ALSA: hda - Fix hang caused by race during suspend.
sound: Remove unnecessary semicolon
ALSA: hda/realtek - Fix detection of ALC271X codec
ALSA: hda - Add inverted internal mic quirk for Lenovo IdeaPad U310
ALSA: hda - make Realtek/Sigmatel/Conexant use the generic unsol event
ALSA: hda - make a generic unsol event handler
ASoC: codecs: Add DA9055 codec driver
ASoC: eukrea-tlv320: Convert it to platform driver
ALSA: ASoC: add DT bindings for CS4271
ASoC: wm_hubs: Ensure volume updates are handled during class W startup
ASoC: wm5110: Adding missing volume update bits
ASoC: wm5110: Add OUT3R support
ASoC: wm5110: Add AEC loopback support
ASoC: wm5110: Rename EPOUT to HPOUT3
ASoC: arizona: Add more clock rates
ASoC: arizona: Add more DSP options for mixer input muxes
This is a series from Arnd that fixes a number of compiler warnings
when building defconfigs on ARM.
* late/fixes:
ARM: footbridge: nw_gpio_lock is raw_spin_lock
ARM: mv78xx0: correct addr_map_cfg __initdata annotation
ARM: footbridge: remove RTC_IRQ definition
ARM: soc: dependency warnings for errata
ARM: ks8695: __arch_virt_to_dma type handling
ARM: rpc: check device_register return code in ecard_probe
ARM: davinci: don't mark da850_register_cpufreq as __init
ARM: iop13xx: fix iq81340sc_atux_map_irq prototype
ARM: iop13xx: mark iop13xx_scan_bus as __devinit
ARM: mv78xx0: mark mv78xx0_timer_init as __init_refok
ARM: s3c24xx: fix multiple section mismatch warnings
ARM: at91: unused variable in at91_pm_verify_clocks
ARM: at91: skip at91_io_desc definition for NOMMU
ARM: pxa: work around duplicate definition of GPIO24_SSP1_SFRM
ARM: pxa: remove sharpsl_fatal_check function
ARM: pxa: define palmte2_pxa_keys conditionally
ARM: pxa: Wunused-result warning in viper board file
ARM: shark: fix shark_pci_init return code
Fixed trivial conflicts in arch/arm/mach-at91/setup.c.
bd31b85960a "locking, ARM: Annotate low level hw locks as raw"
made nw_gpio_lock a raw spinlock, but did not change all the
users in device drivers. This fixes the remaining ones.
sound/oss/waveartist.c: In function 'vnc_mute_spkr':
sound/oss/waveartist.c:1485:2: warning: passing argument 1 of 'spinlock_check' from incompatible pointer type [enabled by default]
include/linux/spinlock.h:272:102: note: expected 'struct spinlock_t *' but argument is of type 'struct raw_spinlock_t *'
drivers/char/ds1620.c: In function 'netwinder_lock':
drivers/char/ds1620.c:77:2: warning: passing argument 1 of 'spinlock_check' from incompatible pointer type [enabled by default]
drivers/char/nwflash.c: In function 'kick_open':
drivers/char/nwflash.c:620:2: warning: passing argument 1 of 'spinlock_check' from incompatible pointer type [enabled by default]
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@r1@
statement S;
position p,p1;
S@p1;@p
@script:python r2@
p << r1.p;
p1 << r1.p1;
if p[0].line != p1[0].line_end:
cocci.include_match(False)
position r1.p;
-;@p
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Pull the trivial tree from Jiri Kosina:
"Tiny usual fixes all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits)
doc: fix old config name of kprobetrace
fs/fs-writeback.c: cleanup riteback_sb_inodes kerneldoc
btrfs: fix the commment for the action flags in delayed-ref.h
btrfs: fix trivial typo for the comment of BTRFS_FREE_INO_OBJECTID
vfs: fix kerneldoc for generic_fh_to_parent()
treewide: fix comment/printk/variable typos
ipr: fix small coding style issues
doc: fix broken utf8 encoding
nfs: comment fix
platform/x86: fix asus_laptop.wled_type module parameter
mfd: printk/comment fixes
doc: getdelays.c: remember to close() socket on error in create_nl_socket()
doc: aliasing-test: close fd on write error
mmc: fix comment typos
dma: fix comments
spi: fix comment/printk typos in spi
Coccinelle: fix typo in memdup_user.cocci
tmiofb: missing NULL pointer checks
tools: perf: Fix typo in tools/perf
tools/testing: fix comment / output typos
Commit d56b9b9c464a10ab1ee51a4c6190a2b57b8ef7a6 ("The scheduled removal
of some OSS drivers") removed all traces of maui_boot.h from the tree.
Remove its entries in dontdiff and oss's .gitignore file.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Additional updates for 3.6
A batch more bugfixes, all driver-specific and fairly small and
unremarkable in a global context. The biggest batch are for the newly
added Arizona drivers.
Speed comes from get_user() in audio_ioctl(). We use it to set the "s"
variable before clamping it to valid values so it could lead to a divide
by zero bug.
Pull sound update from Takashi Iwai:
"This is a fairly quiet release in all sound area. Only a little bit
of changes in the core side while most of changes are seen in the
drivers.
HD-audio:
- A few new codec additions for Nvidia, Realtek and VIA
- Intel Haswell audio support
- Support for "phantom" jacks for consistent jack reporting
- Major clean-ups in HDMI/DP driver codes
- A workaround for inverted digital-mic pins with Realtek codecs
- Removal of beep_mode=2 option
ASoC:
- Added the ability to add and remove DAPM paths dynamically, mostly
for reparenting on clock changes
- New machine drivers for Marvell Brownstone, ST-Ericsson Ux500
reference platform and ttc-dkp
- New CPU drivers for Blackfin BF6xx SPORTs in I2S mode, Marvell MMP,
Synopsis Designware I2S controllers, and SPEAr DMA and S/PDIF
- New CODEC drivers for Dialog DA732x, ST STA529, ST-Ericsson AB8500,
TI Isabelle and Wolfson Microelectronics WM5102 and WM5110
- DAPM fixes for the recent locking changes
- Fix for _PRE and _POST widgets (which have been broken for a few
releases now)
- A couple of minor driver updates
Misc
- Conversion to new dev_pm_ops in platform and PCI drivers
- LTC support and some fixes in PCXHR driver
- A few fixes and PM support for ISA OPti9xx and WSS cards
- Some TLV code cleanup
- Move driver-specific headers from include/sound to local dirs"
* tag 'sound-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (212 commits)
ASoC: dapm: Fix _PRE and _POST events for DAPM performance improvements
ALSA: hda - add dock support for Thinkpad X230 Tablet
ALSA: hda - Turn on PIN_OUT from hdmi playback prepare.
ASoC imx-audmux: add MX31_AUDMUX_PORT7_SSI_PINS_7 define
ASoC: littlemill: Add userspace control of the WM1250 I/O
ASoC: wm8994: Update micdet for irqdomain conversion
ALSA: hda - make sure alc268 does not OOPS on codec parse
ALSA: hda - Add support for Realtek ALC282
ALSA: hda - Fix index number conflicts of phantom jacks
ALSA: opti9xx: Fix section mismatch by PM support
ALSA: snd-opti9xx: Implement suspend/resume
ALSA: hda - Add new GPU codec ID to snd-hda
ALSA: hda - Fix driver type of Haswell controller to AZX_DRIVER_SCH
ALSA: hda - add Haswell HDMI codec id
ALSA: hda - Add DeviceID for Haswell HDA
ALSA: wss_lib: Fix resume on Yamaha OPL3-SAx
ALSA: wss_lib: fix suspend/resume
ALSA: es1938: replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
ALSA: tlv: add DECLARE_TLV_DB_RANGE()
ALSA: tlv: add DECLARE_TLV_CONTAINER()
This patch removes the last usage of linux/ac97_codec.h by
re-defining used AC97 registers.
We can't use sound/ac97_codec.h here, since it is an OSS driver.
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Clemens Ladisch <clemens@ladisch.de>
Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com>
At the point of this error-handling code, HAVE_DSPCODEH may be undefined,
so free INITCODE and PERMCODE as done elsewhere. A jump and label are
introduced to avoid code duplication.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
"A collection of small fixes for 3.4-rc1, including
- mic-recording regression fix for Realtek codec
- clean-up of dmaengine parameter mess
- WM8894 calibration tweak
- minor fixes for asihpi and some bool module parms"
* tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: fix isa/opti9xx module param type
sound: fix oss/msnd_pinnacle module param type
ALSA: asihpi - fix return type of hpios_locked_mem_alloc()
ASoC: dmaengine_pcm: use dmaengine cyclic wrapper
ASoC: Add extra parameter to device_prep_dma_cyclic
ALSA: hda/realtek - Fix ADC assignment with a shared HP/Mic pin
ASoC: wm8994: Update WM8994 DCS calibration
Fix module parameter data type to eliminate build warning.
sound/oss/msnd_pinnacle.c:1727:1: warning: return from incompatible pointer type
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (526 commits)
ASoC: twl6040 - Add method to query optimum PDM_DL1 gain
ALSA: hda - Fix the lost power-setup of seconary pins after PM resume
ALSA: usb-audio: add Yamaha MOX6/MOX8 support
ALSA: virtuoso: add S/PDIF input support for all Xonars
ALSA: ice1724 - Support for ooAoo SQ210a
ALSA: ice1724 - Allow card info based on model only
ALSA: ice1724 - Create capture pcm only for ADC-enabled configurations
ALSA: hdspm - Provide unique driver id based on card serial
ASoC: Dynamically allocate the rtd device for a non-empty release()
ASoC: Fix recursive dependency due to select ATMEL_SSC in SND_ATMEL_SOC_SSC
ALSA: hda - Fix the detection of "Loopback Mixing" control for VIA codecs
ALSA: hda - Return the error from get_wcaps_type() for invalid NIDs
ALSA: hda - Use auto-parser for HP laptops with cx20459 codec
ALSA: asihpi - Fix potential Oops in snd_asihpi_cmode_info()
ALSA: hdsp - Fix potential Oops in snd_hdsp_info_pref_sync_ref()
ALSA: hda/cirrus - support for iMac12,2 model
ASoC: cx20442: add bias control over a platform provided regulator
ALSA: usb-audio - Avoid flood of frame-active debug messages
ALSA: snd-usb-us122l: Delete calls to preempt_disable
mfd: Put WM8994 into cache only mode when suspending
Fix up trivial conflicts in:
- arch/arm/mach-s3c64xx/mach-crag6410.c:
renamed speyside_wm8962 to tobermory, added littlemill right
next to it
- drivers/base/regmap/{regcache.c,regmap.c}:
duplicate diff that had already come in with other changes in
the regmap tree
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Commit 635f0258e5 ("[ARM] clps7500: remove support") missed one instance
of the ARCH_CLPS7500 Kconfig symbol. Drop it now.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (549 commits)
ALSA: hda - Fix ADC input-amp handling for Cx20549 codec
ALSA: hda - Keep EAPD turned on for old Conexant chips
ALSA: hda/realtek - Fix missing volume controls with ALC260
ASoC: wm8940: Properly set codec->dapm.bias_level
ALSA: hda - Fix pin-config for ASUS W90V
ALSA: hda - Fix surround/CLFE headphone and speaker pins order
ALSA: hda - Fix typo
ALSA: Update the sound git tree URL
ALSA: HDA: Add new revision for ALC662
ASoC: max98095: Convert codec->hw_write to snd_soc_write
ASoC: keep pointer to resource so it can be freed
ASoC: sgtl5000: Fix wrong mask in some snd_soc_update_bits calls
ASoC: wm8996: Fix wrong mask for setting WM8996_AIF_CLOCKING_2
ASoC: da7210: Add support for line out and DAC
ASoC: da7210: Add support for DAPM
ALSA: hda/realtek - Fix DAC assignments of multiple speakers
ASoC: Use SGTL5000_LINREG_VDDD_MASK instead of hardcoded mask value
ASoC: Set sgtl5000->ldo in ldo_regulator_register
ASoC: wm8996: Use SND_SOC_DAPM_AIF_OUT for AIF2 Capture
ASoC: wm8994: Use SND_SOC_DAPM_AIF_OUT for AIF3 Capture
sound_timer.info.name is a 32 character buffer. This function only
has one caller (in sound/oss/ad1848.c) and it passes as 128 character
buffer as "name". I don't know if this is a problem in real life,
and I doubt we're going to add more OSS drivers so it's unlikely to
become an issue. But we may as well take care of it.
There are numerous broken references to Documentation files (in other
Documentation files, in comments, etc.). These broken references are
caused by typo's in the references, and by renames or removals of the
Documentation files. Some broken references are simply odd.
Fix these broken references, sometimes by dropping the irrelevant text
they were part of.
sound/oss/pss.c: In function 'configure_nonsound_components':
sound/oss/pss.c:676: warning: 'check_region' is deprecated (declared at include/linux/ioport.h:201)
Signed-off-by: Wang Shaoyan <wangshaoyan.pt@taobao.com>
Update the PAS16 driver to use PIT_TICK_RATE instead
of the more generic CLOCK_TICK_RATE as the two are
equivalent on X86 and we want to depecrate the later.
Signed-off-by: Deepak Saxena <dsaxena@linaro.org>
This collides with powerpc exported functions from bitops.h. Rename the
local copy in the oss soundblaster mixer and ad1848 driver.
Signed-off-by: Andy Whitcroft <apw@canonical.com>
