path: root/sound/oss
2005-12-15[PATCH] Au1550 AC'97 OSS driver spinlock fixesSergei Shtylylov
We have found some issues with Au1550 AC'97 OSS driver in 2.6 (sound/oss/au1550_ac97.c), though it also should concern 2.4 driver (drivers/sound/au1550_psc.c). start_dac() grabs a spinlock already held by its caller, au1550_write(). This doesn't show up with the standard UP spinlock impelmentation but when the different one (mutex based) is in use, a lockup happens. And the interrupt handlers also didn't grab the spinlock -- that's OK in the usual kernel but not when the IRQ handlers are threaded. So, they're grabbing the spinlock now (as every correct interrupt handler should do). Signed-off-by: Konstantin Baidarov <kbaidarov@ru.mvista.com> Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] move pm_register/etc. to CONFIG_PM_LEGACY, pm_legacy.hJeff Garzik
Since few people need the support anymore, this moves the legacy pm_xxx functions to CONFIG_PM_LEGACY, and include/linux/pm_legacy.h. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] schedule obsolete OSS drivers for removalAdrian Bunk
This patch schedules obsolete OSS drivers (with ALSA drivers that support the same hardware) for removal. Scheduling the via82cxxx driver for removal was ACK'ed by Jeff Garzik. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
2005-11-07Merge master.kernel.org:/pub/scm/linux/kernel/git/dtor/inputLinus Torvalds
2005-11-07OSS MIPS drivers: "extern inline" -> "static inline"Adrian Bunk
"extern inline" doesn't make much sense. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-07[PATCH] sound/oss/sequencer_syms: unexport reprogram_timerAdrian Bunk
This patch remoes an unneeded EXPORT_SYMBOL. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-02Input: convert dmasound_awacs (OSS) to dynamic input allocationIan Wienand
Signed-off-by: Ian Wienand <ianw@gelato.unsw.edu.au> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Typo fix: dot after newline in printk stringsJean Delvare
Typo fix: dots appearing after a newline in printk strings. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] remove some more check_region stuffJeff Garzik
Removed some more references to check_region(). I checked these changes into the 'checkreg' branch of rsync://rsync.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6.git The only valid references remaining are in: drivers/scsi/advansys.c drivers/scsi/BusLogic.c drivers/cdrom/sbpcd.c sound/oss/pss.c Remove last vestiges of ide_check_region() drivers/char/specialix: trim trailing whitespace drivers/char/specialix: eliminate use of check_region() Remove outdated and unused references to check_region() [sound oss] remove check_region() usage from cs4232, wavfront [netdrvr eepro] trim trailing whitespace [netdrvr eepro] remove check_region() usage Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Useless includes of everything, the kitchen sink and version.h ...Ralf Baechle
2005-10-28[PATCH] pci_ids: macros: replace partial with whole symbolsGrant Coady
pci_ids cleanup: replace symbols built by macros with whole symbols to aid grep searches. Signed-off-by: Grant Coady <gcoady@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/video/cirrusfb.c | 24 ++++++++++++------------ sound/oss/ymfpci.c | 17 +++++++++-------- sound/pci/bt87x.c | 11 +++++++---- 3 files changed, 28 insertions(+), 24 deletions(-)
2005-10-28Merge ../bleed-2.6Greg KH
2005-10-28[PATCH] Driver Core: fix up all callers of class_device_create()Greg Kroah-Hartman
The previous patch adding the ability to nest struct class_device changed the paramaters to the call class_device_create(). This patch fixes up all in-kernel users of the function. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] gfp_t: soundAl Viro
2005-09-22[PATCH] oss: don't concatenate __FUNCTION__ with stringsClemens Buchacher
It's deprecated. Use "%s", __FUNCTION__ instead. Signed-off-by: Clemens Buchacher <drizzd@aon.at> Signed-off-by: Maximilian Attems <janitor@sternwelten.at> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] patch] remove sound/oss/skeleton.cAdrian Bunk
We do no longer need a template for OSS drivers. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] timer initialization cleanup: DEFINE_TIMERIngo Molnar
Clean up timer initialization by introducing DEFINE_TIMER a'la DEFINE_SPINLOCK. Build and boot-tested on x86. A similar patch has been been in the -RT tree for some time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Remove non-arch consumers of asm/segment.hKumar Gala
asm/segment.h varies greatly on different architectures but is clearly deprecated. Removing all non-architecture consumers will make it easier for us to get ride of asm/segment.h all together. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23Merge head 'upstream-fixes' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6
2005-08-23[PATCH] ad1980 makefile fixAl Viro
ac97_plugin_ad1980 should trigger build of ac97_codec Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (missing dependencies on PCI in sound/*)Al Viro
a bunch of PCI-only drivers didn't have the right dependency Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] vidc gcc4 fixAl Viro
removes an extern for a static variable. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (ISA_DMA_API and sound/*)Al Viro
fixed kconfig dependencies on ISA_DMA_API for parts of sound/* that rely on it. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] i810_audio: fix release_region misordering in error exit from i810_probeJohn W. Linville
Re-order release_region calls in i810_probe to properly unwind preceding allocations. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] turn many #if $undefined_string into #ifdef $undefined_stringOlaf Hering
turn many #if $undefined_string into #ifdef $undefined_string to fix some warnings after -Wno-def was added to global CFLAGS Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] pm: more u32 vs. pm_message_t fixesPavel Machek
Few more u32 vs. pm_message_t fixes. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] ppc32: Remove CONFIG_PMAC_PBOOKBenjamin Herrenschmidt
This patch removes CONFIG_PMAC_PBOOK (PowerBook support). This is now split into CONFIG_PMAC_MEDIABAY for the actual hotswap bay that some powerbooks have, CONFIG_PM for power management related code, and just left out of any CONFIG_* option for some generally useful stuff that can be used on non-laptops as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27Merge 'upstream' branch of ↵Linus Torvalds
2005-06-27Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/dtor/input.git manuallyLinus Torvalds
Some manual fixups required due to clashes with the PF_FREEZE cleanups.
2005-06-27[PATCH] sound/oss/via82cxxx_audio: Use the DMA_32BIT_MASK constantTobias Klauser
Use the DMA_32BIT_MASK constant from dma-mapping.h when calling pci_set_dma_mask() or pci_set_consistent_dma_mask() See http://marc.theaimsgroup.com/?t=108001993000001&r=1&w=2 for details Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org>
2005-06-25[PATCH] sound/oss/cmpci: Use the DMA_32BIT_MASK constantTobias Klauser
Use the DMA_32BIT_MASK constant from dma-mapping.h when calling pci_set_dma_mask() or pci_set_consistent_dma_mask() See http://marc.theaimsgroup.com/?t=108001993000001&r=1&w=2 for details Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sound/oss/es1370: Use the DMA_32BIT_MASK constantTobias Klauser
2005-06-25[PATCH] sound/oss/es1371: Use the DMA_32BIT_MASK constantTobias Klauser
2005-06-25[PATCH] sound/oss/esssolo1: Use the DMA_32BIT_MASK constantTobias Klauser
2005-06-25[PATCH] change the SOUND_PRIME handlingAdrian Bunk
SOUND_PRIME (for OSS) is a tristate. This doesn't make much sense if most users are checking for SOUND_PRIME!=0. This patch changes the semantics of SOUND_PRIME to being a limit for all OSS modules, IOW: SOUND_PRIME=m does now say that all OSS drivers can only be modular. As a side effect, since SOUND_PRIME already depends on SOUND, there's no longer a reason for drivers depending on SOUND_PRIME to additionally depend on SOUND. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sound/oss/sscape.c: remove dead codeAdrian Bunk
The Coverity checker found that sscape_sb_enable never get's assigned any value different from 0, and therefore some code paths are impossible. This patch removes this variable and the dead code paths. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sound/oss/rme96xx.c: remove kernel 2.2 #if'sAdrian Bunk
This patch removes #if's for kernel 2.2 . Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] nm256 oss build failureDave Jones
static declaration follows non static Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sound/oss/: cleanupsAdrian Bunk
This patch contains cleanups including the following: - make needlessly global code static Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] remove redundant NULL checks before kfree() in sound/ and avoid ↵Jesper Juhl
casting pointers about to be kfree()'ed Checking a pointer for NULL before calling kfree() on it is redundant, kfree() deals with NULL pointers just fine. This patch removes such checks from sound/ This patch also makes another, but closely related, change. It avoids casting pointers about to be kfree()'ed. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] rme96xx: fix PageReserved rangeHugh Dickins
rme96xx busmaster_malloc miscalculates and fails to set PageReserved on any page of char *buf; but busmaster_free does it right, so do the same (I don't have the card, just noticed this while sifting for rmap BUGs). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] class: convert sound/* to use the new class api instead of class_simplegregkh@suse.de
2005-06-01Input: ES1371 (OSS) - do not carry around gameport code if gameportDmitry Torokhov
core support is disabled. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-06-01Input: ES1370 (OSS) - do not carry around gameport code if gameportDmitry Torokhov
2005-06-01Input: make sure that joystick support in CMPCI driver can only beDmitry Torokhov
selected if either gameport is built-in or _both_ gameport and cmpci are built as modules. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-06-01Input: mad16 (OSS) - do not carry around gameport code if gameport coreDmitry Torokhov
