path: root/sound/oss
2015-04-18sound/oss: fix deadlock in sequencer_ioctl(SNDCTL_SEQ_OUTOFBAND)Alexey Khoroshilov
A deadlock can be initiated by userspace via ioctl(SNDCTL_SEQ_OUTOFBAND) on /dev/sequencer with TMR_ECHO midi event. In this case the control flow is: sound_ioctl() -> case SND_DEV_SEQ: case SND_DEV_SEQ2: sequencer_ioctl() -> case SNDCTL_SEQ_OUTOFBAND: spin_lock_irqsave(&lock,flags); play_event(); -> case EV_TIMING: seq_timing_event() -> case TMR_ECHO: seq_copy_to_input() -> spin_lock_irqsave(&lock,flags); It seems that spin_lock_irqsave() around play_event() is not necessary, because the only other call location in seq_startplay() makes the call without acquiring spinlock. So, the patch just removes spinlocks around play_event(). By the way, it removes unreachable code in seq_timing_event(), since (seq_mode == SEQ_2) case is handled in the beginning. Compile tested only. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-03-24sound: Deparenthesize negative error returnsJoe Perches
Make the returns a bit more kernel standard style. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-02-25sound/sb_midi: a couple indenting fixesDan Carpenter
Let's make things line up a little bit better. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-02-25sound/sb_ess: white space cleanupsDan Carpenter
These weren't aligned on the same lines as the surrounding code and the printk was quite messy. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-02-25sound/oss/opl3: remove some stray whitespaceDan Carpenter
Removed an extra tab and a extra space character. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-02-25sound: sys_timer: indent poll_def_tmr() correctlyDan Carpenter
The indenting here was really whacky and not consistent from one line to the next. I also reverse the "if (opened)" and "if (tmr_running)" tests so that I could remove two indent levels. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-02-11Merge tag 'sound-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "In this batch, you can find lots of cleanups through the whole subsystem, as our good New Year's resolution. Lots of LOCs and commits are about LINE6 driver that was promoted finally from staging tree, and as usual, there've been widely spread ASoC changes. Here some highlights: ALSA core changes - Embedding struct device into ALSA core structures - sequencer core cleanups / fixes - PCM msbits constraints cleanups / fixes - New SNDRV_PCM_TRIGGER_DRAIN command - PCM kerneldoc fixes, header cleanups - PCM code cleanups using more standard codes - Control notification ID fixes Driver cleanups - Cleanups of PCI PM callbacks - Timer helper usages cleanups - Simplification (e.g. argument reduction) of many driver codes HD-audio - Hotkey and LED support on HP laptops with Realtek codecs - Dock station support on HP laptops - Toshiba Satellite S50D fixup - Enhanced wallclock timestamp handling for HD-audio - Componentization to simplify the linkage between i915 and hd-audio drivers for Intel HDMI/DP USB-audio - Akai MPC Element support - Enhanced timestamp handling ASoC - Lots of refactoringin ASoC core, moving drivers to more data driven initialization and rationalizing a lot of DAPM usage - Much improved handling of CDCLK clocks on Samsung I2S controllers - Lots of driver specific cleanups and feature improvements - CODEC support for TI PCM514x and TLV320AIC3104 devices - Board support for Tegra systems with Realtek RT5677 - New driver for Maxim max98357a - More enhancements / fixes for Intel SST driver Others - Promotion of LINE6 driver from staging along with lots of rewrites and cleanups - DT support for old non-ASoC atmel driver - oxygen cleanups, XIO2001 init, Studio Evolution SE6x support - Emu8000 DRAM size detection fix on ISA(!!) AWE64 boards - A few more ak411x fixes for ice1724 boards" * tag 'sound-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (542 commits) ALSA: line6: toneport: Use explicit type for firmware version ALSA: line6: Use explicit type for serial number ALSA: line6: Return EIO if read/write not successful ALSA: line6: Return error if device not responding ALSA: line6: Add delay before reading status ASoC: Intel: Clean data after SST fw fetch ALSA: hda - Add docking station support for another HP machine ALSA: control: fix failure to return new numerical ID in 'replace' event data ALSA: usb: update trigger timestamp on first non-zero URB submitted ALSA: hda: read trigger_timestamp immediately after starting DMA ALSA: pcm: allow for trigger_tstamp snapshot in .trigger ALSA: pcm: don't override timestamp unconditionally ALSA: off by one bug in snd_riptide_joystick_probe() ASoC: rt5670: Set use_single_rw flag for regmap ASoC: rt286: Add rt288 codec support ASoC: max98357a: Fix build in !CONFIG_OF case ASoC: Intel: fix platform_no_drv_owner.cocci warnings ARM: dts: Switch Odroid X2/U2 to simple-audio-card ARM: dts: Exynos4 and Odroid X2/U3 sound device nodes update ALSA: control: fix failure to return numerical ID in 'add' event ...
2015-01-15sound: dmasound_atari: Remove obsolete IRQ_TYPE_SLOWGeert Uytterhoeven
IRQ_TYPE_SLOW is no longer used by the Atari platform interrupt code since commit 734085651c9b80aa ("[PATCH] m68k: convert atari irq code") in v2.6.18-rc1, so drop it. Note that its value has been reused for a different purpose (IRQ_TYPE_NONE) since commit 6a6de9ef5850d063 ("[PATCH] genirq: core") in v2.6.18-rc1. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Reviewed-by: Takashi Iwai <tiwai@suse.de>
2015-01-15sound/oss: use current->state helpersDavidlohr Bueso
Call __set_current_state() instead of assigning the new state directly. These interfaces also aid CONFIG_DEBUG_ATOMIC_SLEEP environments, keeping track of who changed the state. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-01-04sound: oss: Deletion of unnecessary checks before the function call "vfree"Markus Elfring
The vfree() function performs also input parameter validation. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-11-22sound: oss: uart401: remove unneeded NULL checkDan Carpenter
"devc" can't be NULL here so there is no need to check. Also I removed the "devc = NULL" assignment because devc is stored on stack so it's a no-op. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-10-20OSS: dmasound: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-08-15Merge tag 'sound-fix-3.17-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Here is the additional fix patches that have been queued up since the previous pull request. A few HD-audio fixes, a USB-audio quirk addition, and a couple of trivial cleanup for the legacy OSS codes" * tag 'sound-fix-3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Set TLV_DB_SCALE_MUTE bit for cx5051 vmaster ALSA: hda/ca0132 - Don't try loading firmware at resume when already failed ALSA: hda - Fix pop noises on reboot for Dell XPS 13 9333 ALSA: hda - Set internal mic as default input source on Dell XPS 13 9333 ALSA: usb-audio: fix BOSS ME-25 MIDI regression ALSA: hda - Fix parsing of CMI8888 codec ALSA: hda - Fix probing and stuttering on CMI8888 HD-audio controller ALSA: hda/realtek - Fixed ALC286/ALC288 recording delay for Headset Mic sound: oss: Remove typedefs wanc_info and wavnc_port_info sound: oss: uart401: Remove typedef uart401_devc
2014-08-12PCI: Remove DEFINE_PCI_DEVICE_TABLE macro useBenoit Taine
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to meet kernel coding style guidelines. This issue was reported by checkpatch. A simplified version of the semantic patch that makes this change is as follows (http://coccinelle.lip6.fr/): // <smpl> @@ identifier i; declarer name DEFINE_PCI_DEVICE_TABLE; initializer z; @@ - DEFINE_PCI_DEVICE_TABLE(i) + const struct pci_device_id i[] = z; // </smpl> [bhelgaas: add semantic patch] Signed-off-by: Benoit Taine <benoit.taine@lip6.fr> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-08-06sound: oss: Remove typedefs wanc_info and wavnc_port_infoHimangi Saraogi
The Linux kernel coding style guidelines suggest not using typedefs for structure types. This patch gets rid of the typedefs for wanc_info and wavnc_port_info. A simplified version of the Coccinelle semantic patch that finds the case is: @tn@ identifier i; type td; @@ -typedef struct i { ... } -td ; @@ type tn.td; identifier tn.i; @@ -td + struct i Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-06sound: oss: uart401: Remove typedef uart401_devcHimangi Saraogi
The Linux kernel coding style guidelines suggest not using typedefs for structure types. This patch gets rid of the typedef for uart401_devc. The following Coccinelle semantic patch detects the case. @tn@ identifier i; type td; @@ -typedef struct i { ... } -td ; @@ type tn.td; identifier tn.i; @@ -td + struct i Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-05sound/oss/pss: Remove typedefs pss_mixerdata and pss_confdataHimangi Saraogi
The Linux kernel coding style guidelines suggest not using typedefs for structure types. This patch gets rid of the typedefs for pss_mixerdata and pss_confdata. The following Coccinelle semantic patch is used to make the change. @tn@ identifier i; type td; @@ -typedef struct i { ... } -td ; @@ type tn.td; identifier tn.i; @@ -td + struct i Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-05sound/oss/opl3: Remove typedef opl_devinfoHimangi Saraogi
This typedef is unnecessary and should just be removed as they are never used. The following Coccinelle semantic patch detects the case. @tn@ identifier i; type td; @@ -typedef struct i { ... } -td ; @@ type tn.td; identifier tn.i; @@ -td + struct i Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-06-25sound: oss: mpu401.c: Cleaning up variable is set more than onceRickard Strandqvist
A struct member variable is set to the same value more than once This was found using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-06-24sound: oss: mpu401.c: Cleaning up missing break in a caseRickard Strandqvist
Added a missed break in a case statement This was found using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-05-30sound: remove checks for CONFIG_BCM_CS4297A_CSWARMPaul Bolle
Checks for CONFIG_BCM_CS4297A_CSWARM were added in v2.6.11. The related Kconfig symbol was never added so these checks always evaluated to true. Remove them. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-05-19sound: mpu401.c: make return of 0 explicitJulia Lawall
Delete unnecessary local variable whose value is always 0 and that hides the fact that the result is always 0. A simplified version of the semantic patch that fixes this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ local idexpression ret; expression e; position p; @@ -ret = 0; ... when != ret = e return - ret + 0 ; // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-04-10Merge tag 'sound-fix-3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Here is a bunch of small fixes that have been collected since the previous pull request. In addition to various misc fixes, the following are included: - HD-audio quirks for Dell, HP, Chromebook, and ALC28x codecs - HD-audio AMD HDMI regression fix - Continued PM support/fixes for ice1712 driver - Multiplatform fixes for ASoC samsung drivers - Addition of device id tables to a few ASoC drivers - Bit clock polarity config and error flag fixes in ASoC fsl_sai" * tag 'sound-fix-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (32 commits) ALSA: usb-audio: Suppress repetitive debug messages from retire_playback_urb() ALSA: hda - Make full_reset boolean ALSA: hda - add headset mic detect quirk for a Dell laptop sound: dmasound: use module_platform_driver_probe() ALSA: au1x00: use module_platform_driver() ALSA: hda - Use runtime helper to check active state. ALSA: ice1712: Fix boundary checks in PCM pointer ops ASoC: davinci-mcasp: Fix bit clock polarity settings ASoC: samsung: Fix build on multiplatform ASoC: fsl_sai: Fix Bit Clock Polarity configurations ALSA: hda - Do not assign streams in reverse order ALSA: hda/realtek - Add eapd shutup to ALC283 ALSA: hda/realtek - Change model name alias for ChromeOS ASoC: da732x: Print correct major id ALSA: hda/realtek - Improve HP depop when system change power state on Chromebook ASoC: cs42l52: Fix mask for REVID sound/oss: Remove uncompilable DBG macro use ALSA: ice1712: Save/restore routing and rate registers ALSA: ice1712: restore AK4xxx volumes on resume ASoC: alc56(23|32): fix undefined return value of probing code ...
2014-04-09sound: dmasound: use module_platform_driver_probe()Christoph Jaeger
Eliminate boilerplate code by using module_platform_driver_probe(). Signed-off-by: Christoph Jaeger <christophjaeger@linux.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-04-04sound/oss: Remove uncompilable DBG macro useJoe Perches
Most of it duplicates function tracing and one of them has an uncompilable printf %P use. Others have format/argument mismatches. Remove unused DBG1 macro definition Neaten uart401.c use of ok test around this DBG macro removal. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-04-02Merge branch 'x86-nuke-platforms-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 old platform removal from Peter Anvin: "This patchset removes support for several completely obsolete platforms, where the maintainers either have completely vanished or acked the removal. For some of them it is questionable if there even exists functional specimens of the hardware" Geert Uytterhoeven apparently thought this was a April Fool's pull request ;) * 'x86-nuke-platforms-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, platforms: Remove NUMAQ x86, platforms: Remove SGI Visual Workstation x86, apic: Remove support for IBM Summit/EXA chipset x86, apic: Remove support for ia32-based Unisys ES7000
2014-02-27x86, platforms: Remove SGI Visual WorkstationH. Peter Anvin
The SGI Visual Workstation seems to be dead; remove support so we don't have to continue maintaining it. Cc: Andrey Panin <pazke@donpac.ru> Cc: Michael Reed <mdr@sgi.com> Link: http://lkml.kernel.org/r/530CFD6C.7040705@zytor.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-02-07sound: Move prototype declaration to header file oss/pas2.h from oss/pas2_card.cRashika Kheria
Move prototype declaration of function to header file oss/pas2.h from oss/pas2_card.c because it is used by more than one file. This eliminates the following warnings in oss/pas2_mixer.c: sound/oss/pas2_mixer.c:62:1: warning: no previous prototype for ‘mix_write’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-01-14sound: oss: remove last sleep_on usersArnd Bergmann
There are three files in oss for which I could not find an easy way to replace interruptible_sleep_on_timeout with a non-racy version. This patch instead just adds a private implementation of the function, now named oss_broken_sleep_on, and changes over the remaining users in sound/oss/ so we can remove the global interface. [fixed coding style warnings by tiwai] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-01-14sound: oss: dmasound: kill SLEEP() macro to avoid raceArnd Bergmann
The use of interruptible_sleep_on_timeout in the dmasound driver is questionable and we want to kill off all sleep_on variants. This replaces the calls with wait_event_interruptible_timeout where possible, to wait for a particular event instead of blocking in a racy way. In the sq_write function, the easiest solution is an open-coded prepare_to_wait loop. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-01-14sound: oss: midibuf: fix sleep_on racesArnd Bergmann
sleep_on is known to be racy and going away because of this. All instances of interruptible_sleep_on and interruptible_sleep_on_timeout in the midibuf driver can trivially be replaced with wait_event_interruptible and wait_event_interruptible_timeout. [fixed coding style warnings by tiwai] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-01-14sound: oss: vwsnd: avoid interruptible_sleep_onArnd Bergmann
Interruptible_sleep_on is racy and we want to remove it. This replaces the use in the vwsnd driver with an open-coded prepare_to_wait loop that fixes the race between concurrent open() and close() calls, and also drops the global mutex while waiting here, which restores the original behavior that was changed during the BKL removal. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-01-14sound: oss: msnd_pinnacle: avoid interruptible_sleep_on_timeoutArnd Bergmann
We want to remove all sleep_on variants from the kernel because they are racy. In case of the pinnacle driver, we can replace interruptible_sleep_on_timeout with wait_event_interruptible_timeout by changing the meaning of a few flags used in the driver so they are cleared at wakeup time, which is a somewhat more appropriate way to do the same, although probably still racy. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-10-14sound: Remove unnecessary semicolonsJoe Perches
These aren't necessary after switch and if blocks. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-08-23Merge tag 'asoc-v3.12' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next ASoC: Updates for v3.12 - DAPM is now mandatory for CODEC drivers in order to avoid the repeated regressions in the special cases for non-DAPM CODECs and make it easier to integrate with other components on boards. All existing drivers have had some level of DAPM support added. - A lot of cleanups in DAPM plus support for maintaining controls in a specific state while a DAPM widget all contributed by Lars-Peter Clausen. - Core helpers for bitbanged AC'97 reset from Markus Pargmann. - New drivers and support for Analog Devices ADAU1702 and ADAU1401(a), Asahi Kasei Microdevices AK4554, Atmel AT91ASM9x5 and WM8904 based machines, Freescale S/PDIF and SSI AC'97, Renesas R-Car SoCs, Samsung Exynos5420 SoCs, Texas Instruments PCM1681 and PCM1792A and Wolfson Microelectronics WM8997. - Support for building drivers that can support it cross-platform for compile test.
2013-08-09sound: oss/dmabuf: remove an unneeded temporary variableDan Carpenter
We don't actually use the "go" variable so it can be removed. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-07-15sound: oss/vwsnd: Always define vwsnd_mutexTakashi Iwai
While the conversion of BKL to mutex in commit 645ef9ef, the mutex definition was put in a wrong place inside #ifdef WSND_DEBUG, which leads to the build error. Just move it outside the ifdef. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-07-15sound: oss/vwsnd: Add missing inclusion of linux/delay.hTakashi Iwai
2013-05-29sound: OSS: Remove superfluous pci_set_dvdata(pci, NULL)Takashi Iwai
Only kahlua.c has it. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-13sound: Fix make allmodconfig on MIPS correctlyPaul Bolle
Commit d4702b189c ("sound: Fix make allmodconfig on MIPS") added a (negative) dependency on ISA_DMA_SUPPORT_BROKEN. Since that Kconfig symbol doesn't exist, this dependency will always evaluate to true. Apparently GENERIC_ISA_DMA_SUPPORT_BROKEN was meant to be used here. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-10Merge tag 'sound-3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "This contains small fixes since the previous pull request: - A few regression fixes and small updates of HD-audio - Yet another fix for Haswell HDMI audio - A copule of trivial fixes in ASoC McASP, DPAM and WM8994" * tag 'sound-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: Revert "ALSA: hda - Don't set up active streams twice" ALSA: Add comment for control TLV API ALSA: hda - Apply pin-enablement workaround to all Haswell HDMI codecs ALSA: HDA: Fix Oops caused by dereference NULL pointer ALSA: mips/sgio2audio: Remove redundant platform_set_drvdata() ALSA: mips/hal2: Remove redundant platform_set_drvdata() ALSA: hda - Fix 3.9 regression of EAPD init on Conexant codecs sound: Fix make allmodconfig on MIPS ALSA: hda - Fix system panic when DMA > 40 bits for Nvidia audio controllers ALSA: atmel: Remove redundant platform_set_drvdata() ASoC: McASP: Fix receive clock polarity in DAIFMT_NB_NF mode. ASoC: wm8994: missing break in wm8994_aif3_hw_params() ASoC: McASP: Add pins output direction for rx clocks when configured in CBS_CFS format ASoC: dapm: use clk_prepare_enable and clk_disable_unprepare
2013-05-03Merge tag 'sound-3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "Mostly many small changes spread as seen in diffstat in sound/* directory by this update. A significant change in the subsystem level is the introduction of snd_soc_component, which will help more generic handling of SoC and off-SoC components. Also, snd_BUG_ON() macro is enabled unconditionally now due to its misuses, so people might hit kernel warnings (it's a good thing for us). - compress-offload: support for capture by Charles Keepax - HD-audio: codec delay support by Dylan Reid - HD-audio: improvements/fixes in generic parser: better headphone mic and headset mic support, jack_modes hint consolidation, proper beep attach/detachment, generalized power filter controls by David Henningsson, et al - HD-audio: Improved management of HDMI codec pins/converters - HD-audio: Better pin/DAC assignment for VIA codecs - HD-audio: Haswell HDMI workarounds - HD-audio: ALC268 codec support, a few new quirks for Chromebooks - USB: regression fixes: USB-MIDI autopm fix, the recent ISO latency fix by Clemens Ladisch - USB: support for DSD formats by Daniel Mack - USB: A few UAC2 device endian/cock fixes by Eldad Zack - USB: quirks for Emu 192kHz support, Novation Twitch DJ controller, Yamaha THRxx devices - HDSPM: updates for TCO controls by Adrian Knoth - ASoC: Add a snd_soc_component object type for generic handling of SoC and off-SoC components by Kuninori Morimoto, - dmaengine: a large set of cleanups and conversions by Lars-Peter Clausen - ASoC DAPM: performance optimizations from Ryo Tsutsui - ASoC DAPM: support for mixer control sharing by Stephen Warren - ASoC: multiplatform ARM cleanups from Arnd Bergmann - ASoC: new codec drivers for AK5385 and TAS5086 from Daniel Mack" * tag 'sound-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (315 commits) ALSA: usb-audio: caiaq: fix endianness bug in snd_usb_caiaq_maschine_dispatch ALSA: asihpi: add format support check in snd_card_asihpi_capture_formats ALSA: pcm_format_to_bits strong-typed conversion ALSA: compress: fix the states to check for allowing read ALSA: hda - Move Thinkpad X220 to use auto parser ALSA: USB: adjust for changed 3.8 USB API ALSA: usb - Avoid unnecessary sample rate changes on USB 2.0 clock sources sound: oss/dmabuf: use dma_map_single ALSA: ali5451: use mdelay instead of large udelay constants ALSA: hda - Add the support for ALC286 codec ALSA: usb-audio: USB quirk for Yamaha THR10C ALSA: usb-audio: USB quirk for Yamaha THR5A ALSA: usb-audio: USB quirk for Yamaha THR10 ALSA: usb-audio: Fix autopm error during probing ALSA: snd-usb: try harder to find USB_DT_CS_ENDPOINT ALSA: sound kconfig typo ALSA: emu10k1: Fix dock firmware loading ASoC: ux500: forward declare msp_i2s_platform_data ASoC: davinci-mcasp: Add Support BCLK-to-LRCLK ratio for TDM modes ASoC: davinci-pcm, davinci-mcasp: Clean up active_serializers ...
2013-05-03sound: Fix make allmodconfig on MIPSTakashi Iwai
The compile of soundcard.c is broken on MIPS when allmodconfig is used because of the missing MAX_DMA_CHANNELS definition. As a simple workaround, just add a Kconfig dependency. Reported-by: Andrew Morton <akpm@linux-foundation.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-29dmasound_core: saner arguments for sq_fsync()Al Viro
it is not (and it has never been) an ->fsync() instance... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-26sound: oss/dmabuf: use dma_map_singleArnd Bergmann
The virt_to_bus/bus_to_virt functions have been deprecated for as long as I can remember, and they are used in very few remaining instances, usually in obscure ISA device drivers. The OSS sound drivers are the only ones that are still used on the ARM architecture, and only on some of the earliest StrongARM machines. The problem for converting the OSS subsystem to use dma_map_single instead is that the caller of virt_to_bus does not have a device pointer, since the subsystem has never been ported to use the common device infrastructure. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-02sound: oss: sb_common: Used kmemdup instead of kmalloc and memcpyAlexandru Gheorghiu
Used kmemdup instead of replicating it's behaviour with kmalloc followed by memcpy. Patch found using coccinelle. Signed-off-by: Alexandru Gheorghiu <gheorghiuandru@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-02sound: oss: uart401: Used kmemdup instead of kmalloc and memcpyAlexandru Gheorghiu
2013-03-15sound: sequencer: cap array index in seq_chn_common_event()Dan Carpenter
"chn" here is a number between 0 and 255, but ->chn_info[] only has 16 elements so there is a potential write beyond the end of the array. If the seq_mode isn't SEQ_2 then we let the individual drivers (either opl3.c or midi_synth.c) handle it. Those functions all do a bounds check on "chn" so I haven't changed anything here. The opl3.c driver has up to 18 channels and not 16. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-02-22new helper: file_inode(file)Al Viro
