path: root/sound/parisc
2014-02-14ALSA: parisc: Convert to snd_card_new() with a device pointerTakashi Iwai
Also remove superfluous snd_card_set_dev() calls. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-29ALSA: Remove the rest of *_set_drvdata(NULL) callsTakashi Iwai
A few calls are still left in parport drivers after this commit, which I'm not quite sure yet. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-07ALSA: parisc/harmony: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: linux-parisc@vger.kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-30ALSA: sound/parisc: Move dereference after NULL testJulia Lawall
If the NULL test on h is needed in snd_harmony_mixer_init, then the dereference should be after the NULL test. Actually, there is a sequence of calls: snd_harmony_create, then snd_harmony_pcm_init, and then snd_harmony_mixer_init. snd_harmony_create initializes h, but may indeed leave it as NULL. There was no NULL test at the beginning of snd_harmony_pcm_init, so I have added one. The NULL test in snd_harmony_mixer_init is then not necessary, but in case the ordering of the calls changes, I have left it, and moved the dereference after it. A simplified version of the semantic match that detects this problem is as follows (http://coccinelle.lip6.fr/): // <smpl> @match exists@ expression x, E; identifier fld; @@ * x->fld ... when != \(x = E\|&x\) * x == NULL // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-10Merge branch 'topic/section-fix' into for-linusTakashi Iwai
* topic/section-fix: ALSA: Add missing __devexit_p() markers ALSA: powermac - Replace the rest of __init* ALSA: sound/ppc: update annotations of serveral functions
2009-06-04ALSA: Add missing __devexit_p() markersJean Delvare
3 ISA sound drivers lack their __devexit_p() markers, which would cause build failures when the kernel is built without hotplug support. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-15ALSA: parisc/harmony: fix printk format warningAlexander Beregalov
Fix this warning: sound/parisc/harmony.c:938: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in other sound/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in other sound subdirectories. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-09-04ALSA: harmony - fix a typoTakashi Iwai
Fix a typo in the patch to remove snd_assert(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-13ALSA: Kill snd_assert() in other placesTakashi Iwai
Kill snd_assert() in other places, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-05-27sound: Convert to menuconfigTakashi Iwai
Convert menu in sound Kconfig files to menuconfig and if. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-02-17[PARISC] fix section mismatch warnings in harmony sound driverHelge Deller
fix for two warnings: - Section mismatch: reference to .init.text:snd_harmony_mixer_init from .text.snd_harmony_probe after 'snd_harmony_probe' - Section mismatch: reference to .init.text:snd_harmony_mixer_reset from .text.snd_harmony_mixer_init after 'snd_harmony_mixer_init' Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-01-03[ALSA] Remove xxx_t typedefs: PARISC HarmonyTakashi Iwai
Modules: PARISC Harmony driver Remove xxx_t typedefs from the PARIC Harmony driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] harmony - Code clean upTakashi Iwai
Modules: PARISC Harmony driver Clean up snd-harmony driver code: - Give standard module options - Fix spinlocks - Fix the error path of request_irq() - Clean up redundant codes Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-21[PARISC] Update harmony from parisc treeStuart Brady
o Added a control for the input source (which can be either "line" or "mic") o Mute the speaker/line-out/headphone outputs by default. o Increased the buffer size from 10 pages to 16. Signed-off-by: Stuart Brady <sdb@parisc-linux.org> ALSA Harmony was resetting the capture position when preparing the capture substream, which it shouldn't do. This should fix the problem. Signed-off-by: Stuart Brady <sdb@parisc-linux.org> ALSA Harmony should no longer play junk (left in the buffers from a previous stream) at the start of a new stream. Implement the monitor mixer channel for ALSA Harmony. Also prevent snd_harmony_volume_get from returning negative values. Signed-off-by: Stuart Brady <sdb@parisc-linux.org> Use the graveyard/silence buffers in ALSA Harmony. Signed-off-by: Stuart Brady <sdb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Convert parisc_device to use struct resource for hpaMatthew Wilcox
Convert pa_dev->hpa from an unsigned long to a struct resource. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Fix up users of ->hpa to use ->hpa.start instead. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-09-12[ALSA] Add snd_card_set_dev()Takashi Iwai
ARM AACI PL041 driver,PARISC Harmony driver Added snd_card_set_dev() calls to register the device pointer for the card. Signed-off-by: Takashi Iwai <tiwai@suse.de>
