Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Lots of sound drivers were getting module.h via the implicit presence
of it in <linux/device.h> but we are going to clean that up. So
fix up those users now.
The name argument of request_irq() appears in /proc/interrupts, and
it's quite ugly when the name entry contains a space or special letters.
In general, it's simpler and more readable when the module name appears
there, so let's replace all entries with KBUILD_MODNAME.
The convention for pci_driver.name entry in kernel drivers seem to be
the module name or equivalent ones. But, so far, almost all PCI sound
drivers use more verbose name like "ABC Xyz (12)", and these are fairly
confusing when appearing as a file name.
This patch converts the all pci_driver.name entries in sound/pci/* to
use KBUILD_MODNAME for more unified appearance.
Use the VENDOR/DEVICE ids provided in pci_ids.h instead of creating
local ids of the same values.
Also, fix the following checkpatch.pl warnings:
WARNING: Use #include <linux/io.h> instead of <asm/io.h>
WARNING: unnecessary whitespace before a quoted newline
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to
.devinit.rodata section, so they can be discarded in some cases,
and make them const.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
Audiowerk2 driver snd-aw2 is bound to any saa7146 device as it does not
check subsystem ids. Many DVB devices are saa7146 based, so aw2 driver
grabs them as well.
According to http://lkml.org/lkml/2008/10/15/311 aw2 devices have the
subsystem ids set to 0, the saa7146 default.
Fix conflicts with DVB devices by checking for subsystem ids = 0
specifically.
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com>
Convert from snd_card_new() to the new snd_card_create() function
in sound/pci/*.
The irq handler may be called before the proper initialization of hardware.
Call snd_aw2_saa7146_setup() before the irq handler registration.
"GPL 2" does not mean that there have to be two MODULE_LICENSE("GPL")
entries. ;-)
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
sparc32:
sound/pci/aw2/aw2-alsa.c: In function 'snd_aw2_create':
sound/pci/aw2/aw2-alsa.c:282: error: 'DMA_32BIT_MASK' undeclared (first use in this function)
sound/pci/aw2/aw2-alsa.c:282: error: (Each undeclared identifier is reported only once
sound/pci/aw2/aw2-alsa.c:282: error: for each function it appears in.)
aw2-tsl.h should be rather a C file to be included since it's referred
only in aw2-saa6146.c and includes a table data.
Removed unnecessary dependency on the little-endianess.
Added the missing declarations for module parameters.
Signed-off-by: Cedric Bregardis <cedric.bregardis@free.fr>
Signed-off-by: Jean-Christian Hassler <jhassler@free.fr>
