commit ac237c28d5ac1b241d58b1b7b4b9fa10efb22fb5 upstream.
The Creative Audigy SE (SB0570) card currently exhibits an audible pop
whenever playback is stopped or resumed, or during silent periods of an
audio stream. Initialise the IZD bit to the 0 to eliminate these pops.
The Infinite Zero Detection (IZD) feature on the DAC causes the output
to be shunted to Vcap after 2048 samples of silence. This discharges the
AC coupling capacitor through the output and causes the aforementioned
pop/click noise.
The behaviour of the IZD bit is described on page 15 of the WM8768GEDS
datasheet: "With IZD=1, applying MUTE for 1024 consecutive input samples
will cause all outputs to be connected directly to VCAP. This also
happens if 2048 consecutive zero input samples are applied to all 6
channels, and IZD=0. It will be removed as soon as any channel receives
a non-zero input". I believe the second sentence might be referring to
IZD=1 instead of IZD=0 given the observed behaviour of the card.
This change should make the DAC initialisation consistent with
Creative's Windows driver, as this popping persists when initialising
the card in Linux and soft rebooting into Windows, but is not present on
a cold boot to Windows.
Signed-off-by: Alex Stanoev <alex@astanoev.com>
Cc: <stable@vger.kernel.org>
Convert the S_<FOO> symbolic permissions to their octal equivalents as
using octal and not symbolic permissions is preferred by many as more
readable.
see: https://lkml.org/lkml/2016/8/2/1945
Done with automated conversion via:
$ ./scripts/checkpatch.pl -f --types=SYMBOLIC_PERMS --fix-inplace <files...>
Miscellanea:
o Wrapped one multi-line call to a single line
Acked-by: Vinod Koul <vkoul@kernel.org>
snd_ca0106_pcm_open_capture_channel()
Omit an extra message for a memory allocation failure in this function.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Make these const as they are only used during a copy operation.
Done using Coccinelle.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
Declare snd_kcontrol_new structures as const as they are only passed as
an argument to the function snd_ctl_new1. This argument is of type
const, so snd_kcontrol_new structures having the same property can be
made const too.
Done using Coccinelle:
@r1 disable optional_qualifier @
identifier i;
position p;
static struct snd_kcontrol_new i@p = {...};
@ok1@
identifier r1.i;
position p;
expression e1;
snd_ctl_new1(&i@p,e1)
@bad@
position p!={r1.p,ok1.p};
identifier r1.i;
i@p
@depends on !bad disable optional_qualifier@
identifier r1.i;
+const
struct snd_kcontrol_new i;
Now snd_rawmidi_ops is maintained as a const pointer in snd_rawmidi,
we can constify the definitions.
Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
Check for snd_pcm_ops structures that are only stored in the ops field of a
snd_soc_platform_driver structure or passed as the third argument to
snd_pcm_set_ops. The corresponding field or parameter is declared const,
so snd_pcm_ops structures that have this property can be declared as const
also.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct snd_pcm_ops i@p = { ... };
@ok1@
identifier r.i;
struct snd_soc_platform_driver e;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2;
position p;
snd_pcm_set_ops(e1, e2, &i@p)
@bad@
position p != {r.p,ok1.p,ok2.p};
identifier r.i;
struct snd_pcm_ops e;
e@i@p
identifier r.i;
static
+const
struct snd_pcm_ops i = { ... };
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Build ca0106_proc.o conditionally to drop unneeded ifdef.
Some are replaced with the new CONFIG_SND_PROC_FS.
Replace occurences of the pci api by appropriate call to the dma api.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr)
@deprecated@
idexpression id;
position p;
pci_dma_supported@p ( id, ...)
pci_alloc_consistent@p ( id, ...)
@bad1@
idexpression id;
position deprecated.p;
...when != &id->dev
when != pci_get_drvdata ( id )
when != pci_enable_device ( id )
@depends on !bad1@
idexpression id;
expression direction;
- pci_dma_supported@p ( id,
+ dma_supported ( &id->dev,
+ , GFP_ATOMIC
- pci_alloc_consistent@p ( id,
+ dma_alloc_coherent ( &id->dev,
+ , GFP_ATOMIC
Signed-off-by: Quentin Lambert <lambert.quentin@gmail.com>
Nowadays it's recommended. Replace all in a shot.
This is a similar cleanup like the commit [3db084fd0af5: ALSA: fm801:
PCI core handles power state for us].
Since pci_set_power_state(), pci_save_state() and pci_restore_state()
are already done in the PCI core side, so we don't need to it doubly.
Also, pci_enable_device(), pci_disable_device() and pci_set_master()
calls in PM callbacks are superfluous nowadays, too, so get rid of
them as well.
... and reduce the open codes. Also correct the array size and add
missing const to text arrays.
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Convert with dev_err() and co from snd_printk(), etc.
A couple of prints are difficult to convert with dev_err() so they are
converted to pr_err() at least.
Also remove superfluous snd_card_set_dev() calls.
As drvdata is cleared to NULL at probe failure or at removal by the
driver core, we don't have to call pci_set_drvdata(pci, NULL) any
longer in each driver.
The only remaining pci_set_drvdata(NULL) is in azx_firmware_cb() in
hda_intel.c. Since this function itself releases the card instance,
we need to clear drvdata here as well, so that it won't be released
doubly in the remove callback.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Provide channel maps for individual stereo streams of CA0106.
Otherwise we may get compile warnings due to unused functions.
Straightforward conversion to the new pm_ops from the legacy
suspend/resume ops.
Since we change vx222, vx_core and vxpocket have to be converted,
too.
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
The implicit presence of module.h lured several users into
incorrectly thinking that they only needed/used modparam.h
but once we clean up the module.h presence, these will show
up as build failures, so fix 'em now.
The name argument of request_irq() appears in /proc/interrupts, and
it's quite ugly when the name entry contains a space or special letters.
In general, it's simpler and more readable when the module name appears
there, so let's replace all entries with KBUILD_MODNAME.
The convention for pci_driver.name entry in kernel drivers seem to be
the module name or equivalent ones. But, so far, almost all PCI sound
drivers use more verbose name like "ABC Xyz (12)", and these are fairly
confusing when appearing as a file name.
This patch converts the all pci_driver.name entries in sound/pci/* to
use KBUILD_MODNAME for more unified appearance.
The assignment to the local variable 'channel' in
snd_ca0106_pcm_pointer_capture() is a little crazy. Order of assignment is
undefined. This fixes it.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
Signed-off-by: Andy Owen <andy-alsa@ultra-premium.com>
This is to allow a future patch to have card specific mappings between
dacs, which is required since the Sound Blaster 5.1vx seems to have a
different mapping to what was previously used.
This is ground work for a future commit where cards (such as the Sound
Blaster 5.1vx) have different mappings between dacs and channels.
Clean up the playback pointer callback function a bit, and make the
pointer check more strictly to avoid bogus pointers.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to
.devinit.rodata section, so they can be discarded in some cases,
and make them const.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
To avoid confusion in control names for the standard analog PC Beep generator
using a small Internal PC Speaker, rename all related "PC Speaker" and "PC
Beep" controls to "Beep" only. This name is more universal and can be also
used on more platforms without confusion.
Introduce also "Internal Speaker" in ControlNames.txt for systems with
full-featured build-in internal speaker.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
The variables are unsigned so the test `>= 0' is always true,
the `< 0' test always fails. In these cases the other part of
the test catches wrapped values.
In dac_audio_write() there does not occur a test for wrapped
values, but the test appears redundant.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
* fix/misc:
ALSA: ca0106 - Fix the max capture buffer size
ALSA: OSS sequencer should be initialized after snd_seq_system_client_init
ALSA: sound/isa: convert nested spin_lock_irqsave to spin_lock
The capture buffer size with 64kB seems broken with CA0106.
At least, either the update timing or the DMA position is wrong,
and this screws up pulseaudio badly.
This patch restricts the max buffer size less than that to make life
a bit easier.
Cc: <stable@kernel.org>
Here's a patch on top of the others to use CREATIVE and ECTIVA
* topic/pcm-subclass-fix:
ALSA: Remove invalid GENERIC_MIX PCM sublass
The master volume dB scale was wrongly defined as 0.50dB setp while
it must be 0.25dB step.
SNDRV_PCM_SUBCLASS_GENERIC_MIX is mostly for h/w multi-stream playback
devices, but ca0106 and emu10k1x don't support it (unlike emu10k1).
We shouldn't set that flag to avoid confusion.
Although the vmaster controls are created, they aren't registered thus
they don't appear in the real world. Added the missing snd_ctl_add()
calls.
ALSA sound/core/control.c:232: Control name 'Sigmatel Surround Phase
Inversion Playback Switch' truncated to 'Sigmatel Surround Phase
Inversion Playback ' bootup message by omitting weird Sigmatel prefix
in this case; also fix up the related ca0106 mixer control removal
part by using identical naming there.
Signed-off-by: Andreas Mohr <andi@lisas.de>
