path: root/sound/pci/ca0106
2008-04-24[ALSA] Fix possible races at free_irq in PCI driversTakashi Iwai
The irq handler of PCI drivers must be released before releasing other resources since the handler for a shared irq can be still called and may access the freed resource again. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: ca0106_mixer.c fix shadowed variable warningsHarvey Harrison
Change the variable err to _err within the ADD_CTLS macro to avoid shadowing the local variable. sound/pci/ca0106/ca0106_mixer.c:710:2: warning: symbol 'err' shadows an earlier one sound/pci/ca0106/ca0106_mixer.c:663:6: originally declared here sound/pci/ca0106/ca0106_mixer.c:712:3: warning: symbol 'err' shadows an earlier one sound/pci/ca0106/ca0106_mixer.c:663:6: originally declared here sound/pci/ca0106/ca0106_mixer.c:721:3: warning: symbol 'err' shadows an earlier one sound/pci/ca0106/ca0106_mixer.c:663:6: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: ca0106_main.c fix shadowed variable warningsHarvey Harrison
change to intr_enable as per the two functions it is defined in. sound/pci/ca0106/ca0106_main.c:438:15: warning: symbol 'enable' shadows an earlier one sound/pci/ca0106/ca0106_main.c:159:12: originally declared here sound/pci/ca0106/ca0106_main.c:449:15: warning: symbol 'enable' shadows an earlier one sound/pci/ca0106/ca0106_main.c:159:12: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] ca0106 - Add master volume controlsTakashi Iwai
Added master volume and switch controls for ca0106 using vmaster. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound/pci: remove line duplications in definesNicolas Kaiser
Remove line duplications in defines. Acked-by: Thomas Sailer <sailer@ife.ee.ethz.ch> Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-20[ALSA] ca0106 - Fix write proc assignmentTakashi Iwai
The driver assigns the write proc callback to read wrongly. Fixed now. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-19[ALSA] ca0106 - Check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly. Some callbacks may access a wrong pointer depending on the value passed. Also, fixed the access to the wrong field for enum values, and fixed some callbacks to return the proper error code. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] remove incorrect usage of SNDRV_PCM_INFO_SYNC_START and ↵Clemens Ladisch
snd_pcm_set_sync() Set the SNDRV_PCM_INFO_SYNC_START flag and the substream's sync ID (only) if the substream actually can be linked to another one. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Coding style fix sound/pci/ca0106/ca_midi.hMichal Piotrowski
Coding style fix Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] check for linked substreams of different cardsClemens Ladisch
It is possible to have linked substreams that belong to different cards and/or different drivers. This patch changes some drivers to make sure that they do not incorrectly try to handle substreams of a different card. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] ca0106: remove extra commands in SPI DAC init sequenceTrent Piepho
The init sequence set a number of registers more than once to different values. It's only necessary to set them once to their final values. It also never actually updated the digital attenuation settings. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] ca0106: Add more symbol SPI register names and use themTrent Piepho
Add more symbol name for SPI register values. Change the SPI_XXX_BIT defines from the bit number to a mask. Saves having to write (1<<SPI_XXX_BIT) all the time to convert to mask. We never end up wanting the bit number. Use all the symbol names for the SPI DAC init sequence. The sequence is exactly the same as it was before. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] ca0106: power down SPI DAC channels when not in useTrent Piepho
For cards with an SPI DAC (SB Live 24-bit / Audigy SE), power down channels 0-2 when not in use. They are powered up on PCM open and down again on PCM close. Channel 4 (== Front) is not powered down, as it is used for capture feedback. Powering it down would effectively kill line in pass-through. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] ca0106: replaced control add sequences with macroTrent Piepho
Turn a rather long lined for loop that is duplicated multiple times into a macro. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] ca0106: Add analog mute controls for cards with SPI DACTrent Piepho
Add four mute controls for the analog output channels for cards that use an SPI DAC, like the SB0570 SB Live! 24-bit / Audigy SE. The Wolfson DAC doesn't support muting left/right so the controls are mono. The chip state struct gets a 32-byte array to act as a shadow of the spi dac registers. Only two registers are used for mute, but more would be needed for analog gain, de-emphasis, DAC power down, phase inversion, and other features. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] snd-ca0106:Add recognition for new variant. Fixes ALSA bug#3251James Courtier-Dutton
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] snd-ca0106: Add support for X-Fi Extreme Audio.James Courtier-Dutton
This card is just a normal SB Live 24bit, but under a different marketing name. Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-11[ALSA] Add snd_pcm_group_for_each_entry() for code cleanupTakashi Iwai
Added a new macro snd_pcm_group_for_each_entry() just for code cleanup. Old macros, snd_pcm_group_for_each() and snd_pcm_group_substream_entry(), are removed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-09[ALSA] ca0106 - Add missing sysfs device assignmentTakashi Iwai
Added the missing device assignment before creating sysfs tree. This caused the insufficient device permissions. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add even more 'const' to everything related to TLVTakashi Iwai
Mark TLV data as 'const' Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ca0106: Fix sound capture on Audigy LS via AC97.James Courtier-Dutton
Fixes ALSA bug#2286 Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] snd-ca0106: Updated Enum control names.James Courtier-Dutton
2006-12-20[ALSA] snd-ca0106: Fix typos.James Courtier-Dutton
2006-12-20[ALSA] snd-ca0106: Add new card variant.James Courtier-Dutton
Fixed ALSA bug#2326 Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Remove IRQF_DISABLED for shared PCI irqsTakashi Iwai
Fix IRQ flags for PCI devices. The shared IRQs for PCI devices shouldn't be allocated with IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't be used. The patch removes unnecessary cast in request_irq and free_irq, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Fix invalid assignment of PCI revisionTakashi Iwai
Fix the type of PCI revision to char from int and avoid invalid assignment with pointer cast. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-23[ALSA] Fix compile errors with older gccTakashi Iwai
Fixed compile errors with older gcc for initialization of a union. sound/pci/ca0106/ca0106_mixer.c: At top level: sound/pci/ca0106/ca0106_mixer.c:499: unknown field 'p' specified in initializer sound/pci/ca0106/ca0106_mixer.c:499: warning: missing braces around initializer sound/pci/ca0106/ca0106_mixer.c:499: warning: (near initialization for 'snd_ca0106_volume_ctls[0].tlv') Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] snd-ca0106: Fix dB gain TLVs.James Courtier-Dutton
2006-09-23[ALSA] HDA codec & CA0106 - add/fix TLV supportJaroslav Kysela
2006-09-23[ALSA] Control API - TLV implementation for additional information like dB scaleJaroslav Kysela
This patch implements a TLV mechanism to transfer an additional information like dB scale to the user space. The types might be extended in future. Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Fix section mismatch errors in ALSA PCI driversTakashi Iwai
Fixed 'section mismatch' errors in ALSA PCI drivers: - removed invalid __devinitdata from pci id tables - fix/remove __devinit of functions called in suspend/resume Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[ALSA] snd-ca0106: Update playback to 24bit. Fix typo is comment.James Courtier-Dutton
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] ca0106: Fixes MSI K8N's SB Live 24 bit, no sound from line-in.James Courtier-Dutton
Fixed bug#1331 Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
2006-06-22[ALSA] ca0106: Add analog capture controls.James Courtier-Dutton
2006-04-27[ALSA] add __devinitdata to all pci_device_idHenrik Kretzschmar
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] snd-ca0106: Fixed ALSA bug#1600James Courtier-Dutton
Modules: CA0106 driver Description: Shuttle XPC SD11G5 which has an onboard Creative Labs Sound Blaster Live! 24-bit EAX high-definition 7.1 audio processor'. Fixes ALSA bug#1600 Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
2006-01-03[ALSA] snd-ca0106: Fix SPI driver code. Fixes speaker output.James Courtier-Dutton
Modules: CA0106 driver Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
2006-01-03[ALSA] snd-ca0106: Fixes sound output for Creative Audigy SE aka.SB0570.James Courtier-Dutton
Modules: CA0106 driver Fixes ALSA bug#1636 Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
2006-01-03[ALSA] snd-ca0106: update SPDIF to IEC958 in mixer control names.James Courtier-Dutton
2006-01-03[ALSA] Optimize for config without PROC_FS (pci drivers)Takashi Iwai
Optimize the code when compiled without CONFIG_PROC_FS for some pci drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI CA0106Takashi Iwai
Modules: CA0106 driver Remove xxx_t typedefs from the PCI CA0106 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] ca0106 - Code clean upTakashi Iwai
Modules: CA0106 driver Clean up snd-ca0106 driver code: - Fix spaces and indents - Remove unnecessary spinlocks - Clean up the mixer callbacks using private_value - Clean up mixer constructors using an array Signed-off-by: Takashi Iwai <tiwai@suse.de>
