commit 1524f4e47f90b27a3ac84efbdd94c63172246a6f upstream.
The "chip->dsp_spos_instance" can be NULL on some of the ealier error
paths in snd_cs46xx_create().
Reported-by: "Yavuz, Tuba" <tuba@ece.ufl.edu>
Cc: <stable@vger.kernel.org>
Replaced with the new CONFIG_SND_PROC_FS.
Nowadays it's recommended. Replace all in a shot.
Convert with dev_err() and co from snd_printk(), etc.
Otherwise we may get compile warnings due to unused functions.
This is a bit clean up of public sound header directory.
Some header files in include/sound aren't really necessary to be
located there but can be moved to their local directories gracefully.
When reading through sound/pci/cs46xx/dsp_spos.c I noticed a couple of
things in cs46xx_dsp_spos_create().
It seems to me that we don't always free the various memory buffers we
allocate and we also do some work (structure member assignment) early,
that is completely pointless if some of the memory allocations fail and
we end up just aborting the whole thing.
I don't have hardware to test, so the patch below is compile tested only,
but it makes the following changes:
- Make sure we always free all allocated memory on failures.
- Don't do pointless work assigning to structure members before we know
all memory allocations, that may abort progress, have completed
successfully.
- Remove some trailing whitespace.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Tested-by: Ondrej Zary <linux@rainbow-software.org>
Fix the basic suspend/resume of snd-cs46xx drivers with new DSP.
References:
https://bugzilla.redhat.com/show_bug.cgi?id=498287
https://bugzilla.redhat.com/show_bug.cgi?id=160751
Tested-by: Florian Zumbiehl <florz@florz.de>
Kill snd_assert() in sound/pci/*, either removed or replaced with
if () with snd_BUG_ON().
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Fixed PM resume of cs46xx devices. It now restores properly the DSP
image and kick-off the DSP.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
I noticed that many source files include <linux/pci.h> while they do
not appear to need it. Here is an attempt to clean it all up.
In order to find all possibly affected files, I searched for all
files including <linux/pci.h> but without any other occurence of "pci"
or "PCI". I removed the include statement from all of these, then I
compiled an allmodconfig kernel on both i386 and x86_64 and fixed the
false positives manually.
My tests covered 66% of the affected files, so there could be false
positives remaining. Untested files are:
arch/alpha/kernel/err_common.c
arch/alpha/kernel/err_ev6.c
arch/alpha/kernel/err_ev7.c
arch/ia64/sn/kernel/huberror.c
arch/ia64/sn/kernel/xpnet.c
arch/m68knommu/kernel/dma.c
arch/mips/lib/iomap.c
arch/powerpc/platforms/pseries/ras.c
arch/ppc/8260_io/enet.c
arch/ppc/8260_io/fcc_enet.c
arch/ppc/8xx_io/enet.c
arch/ppc/syslib/ppc4xx_sgdma.c
arch/sh64/mach-cayman/iomap.c
arch/xtensa/kernel/xtensa_ksyms.c
arch/xtensa/platform-iss/setup.c
drivers/i2c/busses/i2c-at91.c
drivers/i2c/busses/i2c-mpc.c
drivers/media/video/saa711x.c
drivers/misc/hdpuftrs/hdpu_cpustate.c
drivers/misc/hdpuftrs/hdpu_nexus.c
drivers/net/au1000_eth.c
drivers/net/fec_8xx/fec_main.c
drivers/net/fec_8xx/fec_mii.c
drivers/net/fs_enet/fs_enet-main.c
drivers/net/fs_enet/mac-fcc.c
drivers/net/fs_enet/mac-fec.c
drivers/net/fs_enet/mac-scc.c
drivers/net/fs_enet/mii-bitbang.c
drivers/net/fs_enet/mii-fec.c
drivers/net/ibm_emac/ibm_emac_core.c
drivers/net/lasi_82596.c
drivers/parisc/hppb.c
drivers/sbus/sbus.c
drivers/video/g364fb.c
drivers/video/platinumfb.c
drivers/video/stifb.c
drivers/video/valkyriefb.c
include/asm-arm/arch-ixp4xx/dma.h
sound/oss/au1550_ac97.c
I would welcome test reports for these files. I am fine with removing
the untested files from the patch if the general opinion is that these
changes aren't safe. The tested part would still be nice to have.
Note that this patch depends on another header fixup patch I submitted
to LKML yesterday:
[PATCH] scatterlist.h needs types.h
http://lkml.org/lkml/2007/3/01/141
Cc: Badari Pulavarty <pbadari@us.ibm.com>
- Add the linked list to each proc entry to enable a single-shot
disconnection (unregister)
- Deprecate snd_info_unregister(), use snd_info_free_entry()
- Removed NULL checks of snd_info_free_entry()
Remove unneeded read/write_size fields in proc text ops.
snd_info_set_text_ops() is fixed, too.
Modules: Generic drivers,ES18xx driver,CS46xx driver
This patch fixes two memory leaks spotted by the Coverity checker.
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Optimize the code when compiled without CONFIG_PROC_FS for some pci drivers.
Modules: CS46xx driver
Remove xxx_t typedefs from the PCI CS46xx driver.
infrastructure for it.
Let it rip!
