path: root/sound/pci/emu10k1/tina2.h
2006-06-22[ALSA] emu10k1: Add support for Audigy4 (not Pro)James Courtier-Dutton
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
2006-01-03[ALSA] snd-emu10k1: Attenuate output volume to reduce distortionJames Courtier-Dutton
Modules: EMU10K1/EMU10K2 driver on Audigy 2 ZS Notebook. Set the master volume to about 6 or 8% in alsamixer. This will attenuate the output enough for better sound quality. Note: Only stereo enabled at present. The distortion is caused by the output path after the DSP adding 12dB gain to the output while still in digital mode, resulting in wrap around distortion. Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
