path: root/sound/pci/emu10k1
2011-06-14Merge branch 'test/pci-rename' into topic/miscTakashi Iwai
2011-06-12ALSA: emu10k1: Add details for E-mu 0404 PCIe versionFlorian Zeitz
This patch adds the necessary details to support the PCIe version of E-MU's 0404 card. From comparing the PCBs it seems the PCIe version just added a PCIe chipset and left all other components pretty much in place. For anyone intrigued to take a look at the PCB there are pictures I took at <http://babelmonkeys.de/~florob/E-MU%200404/>. Signed-off-by: Florian Zeitz <florob@babelmonkeys.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: use KBUILD_MODNAME for request_irq argument in sound/pci/*Takashi Iwai
The name argument of request_irq() appears in /proc/interrupts, and it's quite ugly when the name entry contains a space or special letters. In general, it's simpler and more readable when the module name appears there, so let's replace all entries with KBUILD_MODNAME. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: Use KBUILD_MODNAME for pci_driver.name entriesTakashi Iwai
The convention for pci_driver.name entry in kernel drivers seem to be the module name or equivalent ones. But, so far, almost all PCI sound drivers use more verbose name like "ABC Xyz (12)", and these are fairly confusing when appearing as a file name. This patch converts the all pci_driver.name entries in sound/pci/* to use KBUILD_MODNAME for more unified appearance. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-22Merge branch 'topic/misc' into for-linusTakashi Iwai
2011-05-20ALSA: emu10k1 - Add dB range to Bass and Treble for SB Live!Raymond Yau
As the "Wave", "Wave Surround" or "Front" Playback Volume must be changed to 70% (i.e. -12 dB) so that distortion won't occur when increase Bass and Treble from 50% to 100%, so the maximum gain in Bass and Treble are +12 dB. Signed-off-by: Raymond Yau <superquad.vortex2@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-04-20ALSA: emu10k1 - Remove "Front" controls only for STAC9758/59Raymond Yau
Remove "Front Playback Volume" and "Front Playback Switch" from emu10k1 only for STAC9758/59 Since commit 7eae36fbd5ea9db3d3fe0d671199121be782a5b3 "Fix the confliction of 'Front' control", the "Front Playback Volume" control created by commit edf8e4565c44bffbb4d09e8984df941d0ae9e6e8 "emu10k1: Front channels via fxbus 8 and 9" was removed "Front Playback Volume" and "Surround Playback Volume" have same dB range since I2S DAC of SB Live! and SB Live! Platinum does not has any hardware volume control. Signed-off-by: Raymond Yau <superquad.vortex2@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-04-06ALSA: emu10k1 - Remove CLFE-related controls for SB Live! Platinum CT4760PRaymond Yau
SB Live! Platinum CT4760P is just a 4 channels sound card with STAC9721 and Philips UDA1334 DAC. Signed-off-by: Raymond Yau <superquad.vortex2@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-25ALSA: emu10k1 - emu10k1_main.c remove one to many l's in the word.Justin P. Mattock
The patch below removes an extra "l" in the word. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-07sound: Remove unnecessary casts of private_dataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-18ALSA: emu10k1 - delay the PCM interrupts (add pcm_irq_delay parameter)Jaroslav Kysela
With some hardware combinations, the PCM interrupts are acknowledged before the period boundary from the emu10k1 chip. The midlevel PCM code gets confused and the playback stream is interrupted. It seems that the interrupt processing shift by 2 samples is enough to fix this issue. This default value does not harm other, non-affected hardware. More information: Kernel bugzilla bug#16300 [A copmile warning fixed by tiwai] Signed-off-by: Jaroslav Kysela <perex@perex.cz> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-25ALSA: emu10k1: allow high-resolution mixer controlsClemens Ladisch
Add a module option to allow the GPR mixer controls to have the full resolution of the hardware, i.e., 0...2^31-1 instead of 0...100. Because of bugs in userspace tools like alsactl and alsamixer, this is not yet enabled by default. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (250 commits) ALSA: hda: Storage class should be before const qualifier ASoC: tpa6130a2: Remove CPVSS and HPVdd supplies ASoC: tpa6130a2: Define output pins with SND_SOC_DAPM_OUTPUT ASoC: sdp4430 - add sdp4430 pcm ops to DAI. ASoC: TWL6040: Enable earphone path in codec ASoC: SDP4430: Add support for Earphone speaker ASoC: SDP4430: Add sdp4430 machine driver ASoC: tlv320dac33: Avoid powering off while in BIAS_OFF ASoC: tlv320dac33: Use dev_dbg in dac33_hard_power function ALSA: sound/pci/asihpi: Use kzalloc ALSA: hdmi - dont fail on extra nodes ALSA: intelhdmi - add id for the CougarPoint chipset ALSA: intelhdmi - user friendly codec name ALSA: intelhdmi - add dependency on SND_DYNAMIC_MINORS ALSA: asihpi: incorrect range check ALSA: asihpi: testing the wrong variable ALSA: es1688: add pedantic range checks ARM: McBSP: Add support for omap4 in McBSP driver ARM: McBSP: Fix request for irq in OMAP4 OMAP: McBSP: Add 32-bit mode support ...
2010-04-23Merge branch 'master' into for-nextJiri Kosina
2010-04-13ALSA: info - Check file position validity in common layerTakashi Iwai
Check the validity of the file position in the common info layer before calling read or write callbacks in assumption that entry->size is set up properly to indicate the max file size. Removed the redundant checks from the callbacks as well. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-13ALSA: info - Use standard types for info callbacksTakashi Iwai
Use loff_t, size_t and ssize_t for arguments of info callbacks to follow the standard procfs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-16Fix typos in commentsThomas Weber
[Ss]ytem => [Ss]ystem udpate => update paramters => parameters orginal => original Signed-off-by: Thomas Weber <swirl@gmx.li> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-09sound: use DEFINE_PCI_DEVICE_TABLEAlexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to .devinit.rodata section, so they can be discarded in some cases, and make them const. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-05ALSA: rename "PC Speaker" and "PC Beep" controls to "Beep"Jaroslav Kysela
To avoid confusion in control names for the standard analog PC Beep generator using a small Internal PC Speaker, rename all related "PC Speaker" and "PC Beep" controls to "Beep" only. This name is more universal and can be also used on more platforms without confusion. Introduce also "Internal Speaker" in ControlNames.txt for systems with full-featured build-in internal speaker. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-30ALSA: Cleanup redundant tests on unsignedRoel Kluin
The variables are unsigned so the test `>= 0' is always true, the `< 0' test always fails. In these cases the other part of the test catches wrapped values. In dac_audio_write() there does not occur a test for wrapped values, but the test appears redundant. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-25sound: Use PCI_VDEVICE for CREATIVE and ECTIVAJoe Perches
Here's a patch on top of the others to use CREATIVE and ECTIVA Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-10Merge branch 'topic/seq-kconfig-cleanup' into for-linusTakashi Iwai
* topic/seq-kconfig-cleanup: ALSA: clean up the logic for building sequencer modules
2009-06-10Merge branch 'topic/pcm-subclass-fix' into for-linusTakashi Iwai
* topic/pcm-subclass-fix: ALSA: Remove invalid GENERIC_MIX PCM sublass
2009-06-08ALSA: emu10k1 - Fix minimum periods for efx playbackTakashi Iwai
EFX playback stream should have periods_min = 2 to avoid the buffer position overflow (due to restrictions of the pcm-indirect helper). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-02ALSA: Remove invalid GENERIC_MIX PCM sublassTakashi Iwai
SNDRV_PCM_SUBCLASS_GENERIC_MIX is mostly for h/w multi-stream playback devices, but ca0106 and emu10k1x don't support it (unlike emu10k1). We shouldn't set that flag to avoid confusion. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-29ALSA: clean up the logic for building sequencer modulesMichal Marek
Instead of mangling the CONFIG_* variables in the makefiles over and over, set a few helper variables in Kconfig. Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-19Merge branch 'fix/misc' into for-linusTakashi Iwai
* fix/misc: ALSA: MAINTAINERS - Update SOUND ALSA: emu10k1 - off by 1 in snd_emu10k1_wait()
2009-04-17ALSA: emu10k1 - off by 1 in snd_emu10k1_wait()Roel Kluin
With `while (count++ < 16384)' count reaches 16385. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-14ALSA: sound/pci: use memdup_user()Li Zefan
Remove open-coded memdup_user(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-07dma-mapping: replace all DMA_28BIT_MASK macro with DMA_BIT_MASK(28)Yang Hongyang
Replace all DMA_28BIT_MASK macro with DMA_BIT_MASK(28) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24Merge branch 'topic/emu10k1' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/snd_card_new-err' into for-linusTakashi Iwai
2009-02-26ALSA: sound/pci/emu10k1: fix sparse warning: different signednessHannes Eder
Fix this sparse warnings: sound/pci/emu10k1/emu10k1_main.c:723:66: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:724:68: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:748:74: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:751:66: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:759:73: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:760:73: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:837:50: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:845:50: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:881:50: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:889:57: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:890:57: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:895:60: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:897:60: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:899:60: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:910:56: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:914:57: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:918:56: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:922:57: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:924:58: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:936:60: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:1073:60: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:1088:60: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emu10k1_main.c:1093:58: warning: incorrect type in argument 3 (different signedness) Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-24ALSA: emu10k1 - Fix digital/analog switch on audigy2 ZSTakashi Iwai
Fix the inverted logic of shared spdif switch. Reference: Novell bnc#478496 https://bugzilla.novell.com/show_bug.cgi?id=478496 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-05ALSA: emu10k1 - Add missing KERN_* prefix to printkTakashi Iwai
2009-01-12ALSA: Convert to snd_card_create() in sound/pci/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in sound/pci/*. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-25Merge branch 'topic/ca0106' into to-pushTakashi Iwai
2008-12-02ALSA: emu10k1 - Add capture boost mixer switch for AudigyTakashi Iwai
Due to the conversion (drop) from 24bit in the DSP to 16bit in AC97, the maximum capture level on Audigy seems lower than it could be. This patch adds a workaround to enable the artificial capture boost switch. When this switch is on, the whole analog capature level is boost up. However, this results in the lower capture resolution. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-07Merge branch 'topic/fix/misc' into topic/miscTakashi Iwai
2008-11-03ALSA: emu10k1 - Add more invert_shared_spdif flag to Audigy modelsTakashi Iwai
Reported in Novell bnc#440862: https://bugzilla.novell.com/show_bug.cgi?id=440862 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-23ALSA: emu10k1: fix coding style for emu10k1_main.cVedran Miletic
I fixed all of coding style errors and some warnings, now it is down to: checkpatch.pl-0.24 --no-tree --file --strict --terse emu10k1_main.c total: 0 errors, 62 warnings, 7 checks, 2075 lines checked Signed-off-by: Vedran Miletic <rivanvx@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-21ALSA: emu10k1: fix faulty commit 18c71092Vedran Miletic
Commit 18c7109289625106cdc810b20b628cd13b46d6dd had #endif leftoff from compilation. This patch fixes it. Also, I replaced a misplaced comment by a useful one, that explains why are here #ifdef and #endif added in compilation. Signed-off-by: Vedran Miletic <rivanvx@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-21ALSA: emu10k1: fix device names for Live!/Audigy1/2/4/E-muVedran Miletic
* added missing SBxxxx, CTxxxx, PCxxx and MAEMxxxx where they were missing, and fixed some of them which were wrong (according to kx.inf, which is pretty accurate compared to anything out there) * fixed device names to make them more consistent across various cards * fixed order of devices where appropriate Signed-off-by: Vedran Miletic <rivanvx@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-25ALSA: Clean up SG-buffer helper functions and macrosTakashi Iwai
Clean up SG-buffer helper functions and macros. Helpers take substream as arguments now. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
