path: root/sound/pci/es1968.c
2008-04-24[ALSA] Fix synchronize_irq() bugs, redundanciesJeff Garzik
free_irq() calls synchronize_irq() for you, so there is no need for drivers to manually do the same thing (again). Thus, calls where sync-irq immediately precedes free-irq can be simplified. However, during this audit several bugs were noticed, where free-irq is preceded by a "irq >= 0" check... but the sync-irq call is not covered by the same check. So, where sync-irq could not be eliminated completely, the missing check was added. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] es1968 - fix coding style in the last patchAndrew Morton
WARNING: braces {} are not necessary for single statement blocks #40: FILE: sound/pci/es1968.c:1831: + if (diff > 1) { + __maestro_write(chip, IDR0_DATA_PORT, cp1); + } total: 0 errors, 1 warnings, 35 lines checked ./patches/es1968-fix-jitter-on-some-maestro-cards.patch has style problems, please review. If any of these errors are false positives report them to the maintainer, see CHECKPATCH in MAINTAINERS. Please run checkpatch prior to sending patches Cc: Andreas Mueller <andreas@stapelspeicher.org> Tested-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] es1968: fix jitter on some maestro cardsAndreas Mueller
This patch suppresses jitter on several Maestro cards in stereo mode (ALSA of course). The patch is also incorporated in the *BSD drivers where I "ported" it from. Without this patch most of the stereo audio gets out of sync and really distorted (oss-emulation with mplayer at 48000khz worked somehow). Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: es1968.c fox shadowed variable warningHarvey Harrison
id is used when initializing the mixer elements, use elem_id here instead. sound/pci/es1968.c:1963:25: warning: symbol 'id' shadows an earlier one sound/pci/es1968.c:129:13: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-08es1968: fix sleep-while-holding-lock bugArjan van de Ven
snd_es1968_ac97_read() calls snd_es1968_ac97_wait() first outside a locked area, and later, while holding a lock. snd_es1968_ac97_wait() has a polling loop with a cond_resched() inside it.. which sleeps, so the second call is invalid. This patch adds a version of the wait function that just pure polls. While this is not very elegant in principle, it's very likely the easiest thing to do here, we already checked if the chip was ready (while yielding) just before, so it is very unlikely to take a long time here. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] ESS Maestro 1/2/2E Sound Card: Use list_for_each_entryMatthias Kaehlcke
ESS Maestro 1/2/2E Sound Card: Use list_for_each_entry instead of list_for_each Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] es1968 - Fix stuttering captureRene Herman
Looks like the buffer size for the stereo capture has to be a power of two. Now added a constraint to buffer bytes. Also removed unnecessary #if 0 lines. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Remove IRQF_DISABLED for shared PCI irqsTakashi Iwai
Fix IRQ flags for PCI devices. The shared IRQs for PCI devices shouldn't be allocated with IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't be used. The patch removes unnecessary cast in request_irq and free_irq, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] use the ALIGN macroClemens Ladisch
Use the ALIGN macro instead of manual calculations. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] Various fixes for suspend/resume of ALSA PCI driversTakashi Iwai
- Check the return value of pci_enable_device() and request_irq() in the suspend. If any error occurs there, disable the device using snd_card_disconnect(). - Call pci_set_power_state() properly with pci_choose_state(). - Fix the order to call pci_set_power_state(). - Removed obsolete house-made PM codes in some drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-23[ALSA] es1968: Fix hw volumeVille Syrjala
Fix maestro2 hardware volume control. Tested on a Dell Inspiron 7000. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Fix section mismatch errors in ALSA PCI driversTakashi Iwai
Fixed 'section mismatch' errors in ALSA PCI drivers: - removed invalid __devinitdata from pci id tables - fix/remove __devinit of functions called in suspend/resume Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[ALSA] Change an arugment of snd_mpu401_uart_new() to bit flagsTakashi Iwai
Change the 5th argument of snd_mpu401_uart_new() to bit flags instead of a boolean. The argument takes bits that consist of MPU401_INFO_XXX flags. The callers that used the value 1 there are replaced with MPU401_INFO_INTEGRATED. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Remove zero-initialization of static variablesTakashi Iwai
Removed zero-initializations of static variables. A tiny optimization. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] add __devinitdata to all pci_device_idHenrik Kretzschmar
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] sound/pci/: remove duplicate #include'sAdrian Bunk
There's no reason for #include'ing linux/dma-mapping.h more than once. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-28[PATCH] Replace 0xff.. with correct DMA_xBIT_MASKMatthias Gehre
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask() and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from linux/dma-mapping.h. Signed-off-by: Matthias Gehre <M.Gehre@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] Intruduce DMA_28BIT_MASKTobias Klauser
This patch introduces the DMA_28BIT_MASK constant in dma-mapping.h ALSA drivers using this mask are changed to use the new constant. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Jaroslav Kysela <perex@suse.cz>
2006-03-22[ALSA] semaphore -> mutex (PCI part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[ALSA] es1968 - Fix conflict with ISA boardsRene Herman
Modules: ES1968 driver Fix disablement of TDMA and legacy support to prevent confliction of resources with ISA boards. Confirmed with Terratec DMX and CS4236. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] es1968 - Fix PM supportTakashi Iwai
Modules: ES1968 driver Fix PM support on ES1968 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI ES1968Takashi Iwai
Modules: ES1968 driver Remove xxx_t typedefs from the PCI ES1968 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-11-04[ALSA] Add missing KERN_* suffix to printkTakashi Iwai
Add missing KERN_* suffix to printk. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove vmalloc wrapper, kfree_nocheck()Takashi Iwai
- Remove vmalloc wrapper - Add release_and_free_resource() to remove kfree_nocheck() from each driver and simplify the code Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] set owner field in struct pci_driverClemens Ladisch
AD1889 driver,ALS4000 driver,ATIIXP driver,ATIIXP-modem driver AZT3328 driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,FM801 driver Intel8x0 driver,Intel8x0-modem driver,Maestro3 driver,RME32 driver RME96 driver,SonicVibes driver,VIA82xx driver,VIA82xx-modem driver ALI5451 driver,au88x0 driver,CS46xx driver,EMU10K1/EMU10K2 driver HDA Intel driver,ICE1712 driver,ICE1724 driver,KORG1212 driver MIXART driver,NM256 driver,RME HDSP driver,RME9652 driver Trident driver,Digigram VX222 driver,YMFPCI driver Set the module owner field in each driver's struct pci_driver to get the driver symlink in the sysfs device directory. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-09-12[ALSA] Replace with kzalloc() - pci stuffTakashi Iwai
AD1889 driver,ATIIXP driver,ATIIXP-modem driver,AZT3328 driver BT87x driver,CMIPCI driver,CS4281 driver,ENS1370/1+ driver ES1938 driver,ES1968 driver,FM801 driver,Intel8x0 driver Intel8x0-modem driver,Maestro3 driver,SonicVibes driver,VIA82xx driver VIA82xx-modem driver,AC97 Codec,AK4531 codec,au88x0 driver CA0106 driver,CS46xx driver,EMU10K1/EMU10K2 driver,HDA Codec driver HDA generic driver,HDA Intel driver,ICE1712 driver,ICE1724 driver KORG1212 driver,MIXART driver,NM256 driver,Trident driver,YMFPCI driver Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Remove superfluous PCI ID definitionsTakashi Iwai
CS46xx driver,EMU10K1/EMU10K2 driver,PCM Midlevel,Trident driver YMFPCI driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,Intel8x0 driver Intel8x0-modem driver,Maestro3 driver,RME32 driver,RME96 driver SonicVibes driver,VIA82xx driver,ALI5451 driver,ICE1712 driver ICE1724 driver,NM256 driver,RME HDSP driver,RME9652 driver Remove superfluous PCI ID definitions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-07-28[ALSA] sound/pci: fix-up sleeping pathsNishanth Aravamudan
ENS1370/1+ driver,ES1968 driver,Intel8x0 driver,VIA82xx driver VIA82xx-modem driver,AC97 Codec,ALI5451 driver,CS46xx driver MIXART driver,RME HDSP driver,Trident driver,YMFPCI driver Description: Fix-up sleeping in sound/pci. These changes fall under the following two categories: 1) Replace schedule_timeout() with msleep() to guarantee the task delays as expected. This also involved replacing/removing custom sleep functions. 2) Do not assume jiffies will only increment by one if you request a 1 jiffy sleep, i.e. use time_after/time_before in while loops. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-29[ALSA] Add the vendor 0x1558 to PM whitelist of es1968Takashi Iwai
ES1968 driver Added the vendor id 0x1558 to the power management whitelist of es1968 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] Replace pci_module_init() with pci_register_driver()Takashi Iwai
Documentation,ALS4000 driver,ATIIXP driver,ATIIXP-modem driver AZT3328 driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,FM801 driver Intel8x0 driver,Intel8x0-modem driver,Maestro3 driver,RME32 driver RME96 driver,SonicVibes driver,VIA82xx driver,VIA82xx-modem driver ALI5451 driver,au88x0 driver,CA0106 driver,CS46xx driver EMU10K1/EMU10K2 driver,HDA Intel driver,ICE1712 driver,ICE1724 driver KORG1212 driver,MIXART driver,NM256 driver,RME HDSP driver RME9652 driver,Trident driver,Digigram VX222 driver,YMFPCI driver Replace the obsolete pci_module_init() with pci_register_driver(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
