path: root/sound/pci/hda/Makefile
2008-04-24[ALSA] Keep private TLV entry in vmaster itselfTakashi Iwai
Use a private array for TLV entries of virtual master controls instead of (supposed) static array. This cleans up the existing codes. Also, now vmaster assumes the simple dB-range TLV that is the only type it can handle. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Add virtual master control helpersTakashi Iwai
Added helper functions to implement virtual master volume controls. The virtual master control is a control element that has multiple slave controls. The value of master element is equally added to slave elements. The functions are written for general purpose, but it's put in the HD-audio directory as now, since HD-audio driver is the only user. It should be moved to the common place once after other drivers use vmaster. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] hda-intel - Fix a typo in MakefileTakashi Iwai
Fixed a typo of CONFIG_SND_HDA_GENERIC. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-codec - kernel config for each codecTakashi Iwai
Create kernel configs to choose the codec support codes to build. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-intel - Add hwdep interfaceTakashi Iwai
Added a hwdep interface for each codec (enabled per kconfig). This interface can be used for reading/writing HD-audio verbs and other purposes as future extensions. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] hda-intel - Merge hda-codec module to a single moduleTakashi Iwai
Merge hda-codec module to a single hda-intel module since this is the only user right now. Although hda-codec stuff is designed to be used universally from different controller drivers, currently only one controller interface (and compatibles) are used. So, let's merge them to a single module to save memory. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Add support for VIA VT1708(A) HD audio codecJoseph Chan
This patch is VIA first release for HD audio codec, VT1708(A) and it provides geneneral HD audio driver features. Signed-off-by: Joseph Chan <josephchan@via.com.tw> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add Conexant audio support to the HD Audio driverTobin Davis
This driver adds limited support for the Conexant 5045 and 5047 HD Audio codecs. Some issues still need to be resolved. The code is based primarily on code from the Analog Devices AD1981 support and the Realtek ALC260 support. Some code came from the original code developed by Alex Pototskiy (see alsa bugtracker 2485). Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] hda - Add support for the ATI RS600 HDMI audio deviceFelix Kuehling
Add support for the ATI RS600 HDMI audio device. It has a one-stream pure digital stereo codec that isn't handled by the generic codec support. Signed-off-by: Felix Kuehling <fkuehlin@ati.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] hda-codec - support for Si3054/5 HDA modemsSasha Khapyorsky
HDA generic driver,HDA Codec driver Support for Si3054/5 HDA modem codecs. Signed-off-by: Sasha Khapyorsky <sashak@smlink.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] add sigmatel codec supportMatt
HDA generic driver,HDA Codec driver Add initial SigmaTel codec support for 9200 and 922x. Note that this hda patch relies on the configuration default registers to be set correctly (normally by BIOS/firmware) in order for it to set up pin widgets properly. There's a test switch in the patch so it will work with the SigmaTel reference boards that are usually plugged into a system that doesn't set the configuration default registers. It supports 2 channel analog out and line/mic in. I plan to add >2 channel support and spdif support shortly. Please apply. Signed-off-by: Matt <matt@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
