path: root/sound/pci/hda/hda_codec.c
2008-04-24[ALSA] hda-codec - Fix unbalanced mutexFrederik Deweerdt
On Wed, Apr 02, 2008 at 08:19:29AM -0400, Miles Lane wrote: > [ 48.765906] [ BUG: bad unlock balance detected! ] > [ 48.765912] ------------------------------------- > [ 48.765918] pulseaudio/4277 is trying to release lock > (&codec->spdif_mutex) at: > [ 48.765930] [<c03031b7>] mutex_unlock+0x8/0xa > [ 48.765945] but there are no more locks to release! > [ 48.765950] > [ 48.765952] other info that might help us debug this: > [ 48.765959] 2 locks held by pulseaudio/4277: > [ 48.765965] #0: (&pcm->open_mutex){--..}, at: [<f89f134b>] > snd_pcm_open+0xc1/0x1ba [snd_pcm] > [ 48.766003] #1: (&chip->open_mutex){--..}, at: [<f8b4f13d>] > azx_pcm_open+0x36/0x184 [snd_hda_intel] > [ 48.766057] > [ 48.766059] stack backtrace: > [ 48.766066] Pid: 4277, comm: pulseaudio Not tainted 2.6.25-rc8-mm1 #12 > [ 48.766086] [<c013afc6>] print_unlock_inbalance_bug+0xce/0xd8 > [ 48.766107] [<c0109e1c>] ? save_stack_trace+0x1d/0x3b > [ 48.766130] [<c012f54e>] ? __kernel_text_address+0x1b/0x27 > [ 48.766146] [<c0104533>] ? dump_trace+0xcd/0xd9 > [ 48.766160] [<c0109d9e>] ? save_stack_address+0x0/0x2c > [ 48.766176] [<c013b80a>] ? find_usage_backwards+0xa4/0xc3 > [ 48.766193] [<c013cfb5>] lock_release_non_nested+0x84/0x120 > [ 48.766209] [<c03031b7>] ? mutex_unlock+0x8/0xa > [ 48.766222] [<c013d1bb>] lock_release+0x16a/0x199 > [ 48.766238] [<c0303137>] __mutex_unlock_slowpath+0xa9/0x121 > [ 48.766252] [<c03031b7>] mutex_unlock+0x8/0xa > [ 48.766263] [<f8b4ffd8>] snd_hda_multi_out_analog_open+0xd3/0xef > [snd_hda_intel] The following patch should fix it. Cc: "Miles Lane" <miles.lane@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - keep the format verb at closing PCM streamsTakashi Iwai
Keep the format verb at closing PCM streams. Introduced snd_hda_codec_cleanup_stream() for the parcicular purpose. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: hda: missing includes of hda_patch.hHarvey Harrison
Move the array declaration to hda_codec.c where it is used and add includes where the individual presets are declared. Fixes the following sparse warnings: sound/pci/hda/patch_realtek.c:13744:25: warning: symbol 'snd_hda_preset_realtek' was not declared. Should it be static? sound/pci/hda/patch_cmedia.c:729:25: warning: symbol 'snd_hda_preset_cmedia' was not declared. Should it be static? sound/pci/hda/patch_analog.c:3656:25: warning: symbol 'snd_hda_preset_analog' was not declared. Should it be static? sound/pci/hda/patch_sigmatel.c:3995:25: warning: symbol 'snd_hda_preset_sigmatel' was not declared. Should it be static? sound/pci/hda/patch_si3054.c:286:25: warning: symbol 'snd_hda_preset_si3054' was not declared. Should it be static? sound/pci/hda/patch_atihdmi.c:156:25: warning: symbol 'snd_hda_preset_atihdmi' was not declared. Should it be static? sound/pci/hda/patch_conexant.c:1721:25: warning: symbol 'snd_hda_preset_conexant' was not declared. Should it be static? sound/pci/hda/patch_via.c:1962:25: warning: symbol 'snd_hda_preset_via' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - Add more names to vendor listTakashi Iwai
Added more known names to the vendor id list. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - Add "IEC958 Default PCM" switchTakashi Iwai
Added a new mixer switch to enable/disable the sharing of the default PCM stream with analog and SPDIF outputs. When "IEC958 Default PCM" switch is on, the PCM stream is routed both to analog and SPDIF outputs. This is the behavior in the earlier version. Turning this switch off has a merit for some codecs, though. Some codec chips don't support 24bit formats for SPDIF but only for analog outputs. In this case, you can use 24bit format by disabling this switch. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - More fix-up for auto-configurationTakashi Iwai
In some cases, the BIOS sets up only the HP pins with different assoc and sequence numbers, e.g. on FSC Esprimo with ALC262. This patch adds a fix-up for such a case. When multiple HPs are defined and no line-outs is found, the configurator tries to re-assign some pins from HP list to line-out, judging from the sequence number. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - Allow multiple SPDIF devicesTakashi Iwai
The current code doesn't allow multiple SPDIF devices, and causes errors when multiple SPDIF devices are found (e.g. SPDIF out and HDMI). This patch allows multiple SPDIF devices by incrementing the index automatically. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-02-22[ALSA] hda-codec - Don't create vmaster if no slaves foundTakashi Iwai
Don't create vmaster controls if no slaves are found in the given list. This prevents the error due to an empty vmaster control. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-22[ALSA] hda-codec - Fix race condition in generic bound volume/swtich controlsSerge A. Suchkov
Attached patch fix race condition in hd_codec generic bound volume/swtich controls oops on this bug can be easy reproduced by two mixer apps on SMP system with PREEMPT kernel dmesg: ALSA /home/ss/ALSA/alsa-driver-1.0.16/pci/hda/../../alsa-kernel/pci/hda/hda_intel.c:596: hda_intel: azx_get_response timeout, switching to polling mode: las t cmd=0x014f0900 BUG: unable to handle kernel paging request at virtual address 00070006 printing eip: f8f43e95 *pde = 00000000 Oops: 0000 [#1] PREEMPT SMP Modules linked in: i915 drm snd_seq_dummy snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss bnep rfcomm hidp l2cap bluetooth w lan_wep acpi_cpufreq coretemp hwmon mmc_block pcspkr psmouse wlan_scan_sta ath_rate_sample snd_hda_intel ath_pci serio_raw wlan tg3 sdhci snd_pcm firewire_o hci mmc_core i2c_i801 snd_timer firewire_core snd_page_alloc ath_hal(P) snd_hwdep snd iTCO_wdt crc_itu_t iTCO_vendor_support shpchp video output acer_acpi b acklight led_class wmi_acer Pid: 3969, comm: gkrellm Tainted: P (2.6.24-jm #4) EIP: 0060:[<f8f43e95>] EFLAGS: 00010292 CPU: 0 EIP is at snd_hda_mixer_bind_ctls_info+0x20/0x43 [snd_hda_intel] EAX: 00000000 EBX: f7478e00 ECX: f763e000 EDX: f764f788 ESI: 00070002 EDI: edce5e00 EBP: edc3fe64 ESP: edc3fe54 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process gkrellm (pid: 3969, ti=edc3e000 task=f1e4e000 task.ti=edc3e000) Stack: f764f77c f7478e00 edce5e00 f6dd6000 edc3fe84 f8e590e8 edc7a239 f6d14034 f764f34c f6c0f7e0 edc3ff30 f6d14034 edc3fea8 f8e591b7 edc3ff30 edc3ff2c 00000000 f70aa668 f6d14034 f8e59165 bfbfadb0 edc3ff40 f8e587aa edc3ff2c Call Trace: [<c0104fbb>] show_trace_log_lvl+0x1a/0x2f [<c010506d>] show_stack_log_lvl+0x9d/0xa5 [<c0105119>] show_registers+0xa4/0x1bd [<c0105354>] die+0x122/0x206 [<c03daccc>] do_page_fault+0x535/0x623 [<c03d940a>] error_code+0x72/0x78 [<f8e590e8>] snd_mixer_oss_get_volume1_vol+0x74/0xf1 [snd_mixer_oss] [<f8e591b7>] snd_mixer_oss_get_volume1+0x52/0xa5 [snd_mixer_oss] [<f8e587aa>] snd_mixer_oss_ioctl1+0x673/0x71e [snd_mixer_oss] [<f8e588af>] snd_mixer_oss_ioctl+0xb/0xd [snd_mixer_oss] [<c017af0a>] do_ioctl+0x22/0x67 [<c017b186>] vfs_ioctl+0x237/0x24a [<c017b1ca>] sys_ioctl+0x31/0x4b [<c010402e>] syscall_call+0x7/0xb ======================= Code: 3f 49 c7 89 f8 59 5b 5e 5f 5d c3 55 89 e5 57 89 d7 56 53 89 c3 83 ec 04 8b 70 5c 8b 40 60 05 7c 01 00 00 89 45 f0 e8 c0 3f 49 c7 <8b> 46 04 89 fa 89 4 3 5c 89 d8 8b 0e ff 11 89 73 5c 89 c7 8b 45 EIP: [<f8f43e95>] snd_hda_mixer_bind_ctls_info+0x20/0x43 [snd_hda_intel] SS:ESP 0068:edc3fe54 ---[ end trace 0a20bc209e9397cc ]--- similar issue report present in ALSA bugtracking system https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3652 Signed-off-by: Serge A. Suchkov <Serge.A.S@tochka.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[ALSA] hda: Add dynamic mono mixer support for STAC92xx codecsMatthew Ranostay
Allows for dynamically creating mono out mixer controls and well as mono mux controls. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda: Added mono_out_pin to autoconfigMatthew Ranostay
Added a mono_out_pin field to autocfg struct, and code to parse for the mono_out_line. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - Optimize snd_hda_pser_pin_def_config()Takashi Iwai
Don't read the widget list again as we already have it at the beginning. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - Add afg and mfg preset maskMarc Boucher
Added afg and mfg preset masks for more finer codec-preset selection. Signed-off-by: Marc Boucher <marc@linuxant.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - Add a delay after power state changeMarc Boucher
Added a delay after the power state change as a partial workaround for 'hda_intel: azx_get_response timeout' problem on Cxt codecs. Signed-off-by: Marc Boucher <marc@linuxant.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - print control name in error messagesTakashi Iwai
Print the name of the defect controls in error messages in amp info callback. This will make debugging easier. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - Add virtual master controlsTakashi Iwai
Add master controls using vmaster to codecs that have no real hardware master volume registers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - Add missing #defines (and 1 rename) in hda_codec.hAndrew Paprocki
Added AC_VERB_GET_DIGI_CONVERT_2 and renamed AC_VERB_GET_DIGI_CONVERT to AC_VERB_GET_DIGI_CONVERT_1 to stay consistent with the SET variants. Added AC_VERB_GET_GPIO_UNSOLICITED_RSP_MASK, AC_VERB_SET_GPIO_UNSOLICITED_RSP_MASK, and AC_PINCAP_LR_SWAP. The missing fields were listed in the ALC883 datasheet rev 1.3. Signed-off-by: Andrew Paprocki <andrew@ishiboo.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - Check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly so that invalid values won't be stored or written to registers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - Improve the auto-configurationTakashi Iwai
Some small improvements on autocfg stuff: - sort HP pins by sequence number, too - move sole mic pin to AUTO_PIN_MIC instead of AUTO_PIN_FRONT_MIC - ditto for line-in pin Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - Add STAC9228 DMIC supportMatthew Ranostay
Added the missing STAC9228 DMIC support. Also added a new vendor id tag for IDT. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-19[ALSA] hda-codec - Check PINCAP only for PIN widgetsTakashi Iwai
The recent addition of checking PINCAP for EAPD seems to break some systems due to unexpected response from the codec chip. We shouldn't issue GET_PINCAP verb to non-PIN widgets. Now checks the widget type before checking EAPD bit. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-19[ALSA] hda-codec - Disable shared stream on AD1986ATakashi Iwai
AD1986A has a hardware problem that it cannot share a stream with multiple pins properly. The problem occurs e.g. when a volume is changed during playback. So far, hda-intel driver unconditionally assigns the stream to multiple output pins in copy-front mode, and this should be avoided for AD1986A codec. The original fix patch was by zhejiang <zhe.jiang@intel.com>. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-23[ALSA] hda-codec - Fix build without CONFIG_SND_HDA_GENERICTakashi Iwai
Fixed the build error from patch_sigmatel.c when built without CONFIG_SND_HDA_GENERIC by defining a dummy function to return error. Also, clean up hda_codec.c by removing unneeded ifdefs (the compiler will optimize out). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] hda-codec - Fix Gateway laptops with STAC9200Takashi Iwai
Fix the output of Gateway laptops with STAC9200 codec chip. They require the EAPD control for some pins. These pins shouldn't be powered down. To enable EAPD control, a new model 'gateway' was added to STAC9200. The known PCI SSIDs are included in the quirk list. The fix was originally suggested by Brian Hinz, in ALSA bug#2948. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-codec - Add zero checks in input-mux helper functionsTakashi Iwai
Added zero checks in input-mux helper functions to avoid Oops. Some devices may have no input pins while the driver registers control elements calling these functions. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Add default values for power-saving as Kconfig optionsTakashi Iwai
Added CONFIG_SND_AC97_POWER_SAVE_DEFAULT and CONFIG_SND_HDA_POWER_SAVE_DEFAULT Kconfig options as the default values for power-saving mode of AC97 and HD-audio drivers, respectively. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-intel - Improve HD-audio codec probing robustnessDanny Tholen
When modem is disabled in the BIOS, detection of the number of codecs always fails after booting if STATESTS is not cleared first. This patch fixes this problem and also adds an error check in a place where a read error would lead to a very large number of pointless loops. Signed-off-by: Danny Tholen <obiwan@mailmij.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-intel - Fix resume logic, when dynamic power managment is onMaxim Levitsky
Comment in hda_intel.c states that 'the explicit resume is needed only when POWER_SAVE isn't set', but this is not true. There is no code that will automaticly power up the codec on resume, but only code that powers it up when user accesses it. So if user leaves a sound playing, codec will not be powered To fix that I check if there are any codecs that should be powered codec->power_count, and if so I power them up together with main controller. Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-intel - fix a race in dynamic power managmentMaxim Levitsky
codec->power_transition is supposed to be true while codec is going to be shut off if in the mean time somebody calls snd_hda_power_up, hda_power_work will not shut down the codec, but nether will clear codec->power_transition, thus it stays on forever. Fix this. Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-intel - Fix compile with gcc-3.xTakashi Iwai
gcc-3.x doesn't like forward inlining: CC [M] sound/pci/hda/hda_codec.o sound/pci/hda/hda_codec.c: In function 'snd_hda_codec_free': sound/pci/hda/hda_codec.c:517: sorry, unimplemented: inlining failed in call to 'free_hda_cache': function body not available sound/pci/hda/hda_codec.c:534: sorry, unimplemented: called from here sound/pci/hda/hda_codec.c:517: sorry, unimplemented: inlining failed in call to 'free_hda_cache': function body not available sound/pci/hda/hda_codec.c:535: sorry, unimplemented: called from here Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-intel - Avoid unnecessary work schedulingTakashi Iwai
Avoid unnecessary work scheduling for power-off. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-intel - Add flush_scheduled_work() in snd_hda_codec_free()Takashi Iwai
Added flush_scheduled_work() in snd_hda_codec_free() to make sure that the all work is gone. Also, optimized the condition to schedule the delayed work in snd_hda_power_down(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-intel - Don't do suspend if already powered downTakashi Iwai
In the power-saving mode, the suspend is done dynamically at power-down. So we don't have to call suspend stuff explicitly if it's already powered down. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-intel - Fix NULL dereference in resumeTakashi Iwai
codec->patch_ops.init can be NULL. Check before calling it. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-intel - Fix resume with power saveTakashi Iwai
The controller power wasn't turned on properly at resume due to the power-saving patch. Now fixed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-intel - Add POWER_SAVE optionTakashi Iwai
Added CONFIG_SND_HDA_POWER_SAVE kconfig. It's an experimental option to achieve an aggressive power-saving. With this option, the driver will turn on/off the power of each codec and controller chip dynamically on demand. The patch introduces a new module option 'power_save'. It specifies the second of time-out for automatic power-down. As default, it's 10 seconds. Setting 0 means to suppress the power-saving feature. The codec may have analog-input loopbacks, which are usually represented by mixer elements such as 'Mic Playback Switch' or 'CD Playback Switch'. When these are on, we cannot turn off the mixer and the codec chip has to be kept on. For bookkeeping these states, a new codec-callback is introduced. For the bus-controller side, a new callback pm_notify is introduced, which can be used to turn on/off the contoller appropriately. Note that this power-saving might cause slight click-noise at power-on/off. Also, it might take some time to wake up the codec, and might even drop some tones at the very beginning. This seems to be the side-effect of turning off the controller chip. This turn-off of the controller can be disabled by undefining HDA_POWER_SAVE_RESET_CONTOLLER in hda_intel.c. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-codec - add snd_hda_codec_stereo() functionTakashi Iwai
Added snd_hda_codec_amp_stereo() function that changes both of stereo channels with the same mask and value bits. It simplifies most of amp-handling codes. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-codec - optimize resume using cachesTakashi Iwai
So far, the driver looked the table of snd_kcontrol_new used for creating mixer elements and forces to call each of its put callbacks in PM resume code. This is too ugly and hackish. Now, the resume is simplified using the codec amp and command register caches. The driver simply restores the values that have been written in the cache table. With this simplification, most codec support codes don't require any special resume callback. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-codec - introduce command register cacheTakashi Iwai
This patch adds the cache for codec command registers. snd_hda_codec_write_cache() and snd_hda_sequence_write_cache() do the write operations with caching, which values can be resumed via snd_hda_codec_resume_cache(). The patch introduces only the framework, and no codec code is using this cache yet. It'll be implemented in the following patch. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-codec - rewrite amp cache more genericTakashi Iwai
Rewrite the code to handle amp cache and hash tables to be more generic. This routine will be used by the register caches in the next patch. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-intel - Remove invalid __devinitTakashi Iwai
Some functions in hda_codec.c are called from patch ops, which are kept in the codec instance even after initialization. Thus they shouldn't be marked as __devinit. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-codec - kernel config for each codecTakashi Iwai
Create kernel configs to choose the codec support codes to build. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-codec - Add a generic bind-control helperTakashi Iwai
Added callbacks for a generic bind-control of mixer elements. This can be used for creating a mixer element controlling multiple widgets at the same time. Two macros, HDA_BIND_VOL() and HDA_BIND_SW(), are introduced for creating bind-volume and bind-switch, respectively. It taks the mixer element name and struct hda_bind_ctls pointer, which contains the real control callbacks in ops field and long array for private_value of each bound widget. All widgets have to be the same type (i.e. the same amp capability). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-intel - Add hwdep interfaceTakashi Iwai
Added a hwdep interface for each codec (enabled per kconfig). This interface can be used for reading/writing HD-audio verbs and other purposes as future extensions. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-31[ALSA] hda-codec - Fix STAC922x capture boost levelTakashi Iwai
STAC922x provides the capture boost level up to 4, but actually it works only up to 2. Since the range of the mixer is automatically defined from amp-capability bits, we need to override the value beforehand. snd_hda_override_amp_caps() is introduced for this purpose. The function patch_stac922x() calls this for NID 0x12 (Mux Capture Volume). This should fix another recording problem on Intel Macs. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-16[ALSA] hda-codec - Make the mixer capability check more robustTakashi Iwai
In some cases, mixer elements return -EINVAL because it couldn't obtain proper amp_cap bits. The patch improves the robustness, trying the amp_cap query again in such a case. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Add speaker pin sequencing to hda_codec.c:snd_hda_parse_pin_def_config()Steve Longerbeam
Some verb tables (such as an Asus VT sent by IDT) contain only speaker outs in the default pin configs, and no line-outs. In such a case the speaker sequence numbers have to be used to order the speaker out pins, just as is being done for line-out pins. Then, when speaker-outs are copied to line-outs, the line-outs will be ordered properly. Signed-off-by: Steve Longerbeam <stevel@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] hda-codec - Prefer audio codec name as the mixer nameTakashi Iwai
Prefer the name of audio codecs as the mixer name even if modem codecs are probed before the audio codecs. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
