This patch fixes some warnings from klockwork.
These warnings are not the real issues. The patch
adds the sanity check.
Signed-off-by: Libin Yang <libin.yang@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next
ASoC: Updates for v4.4
Not much core work here, a few small tweaks to interfaces but mainly the
changes here are driver ones. Highlights include:
- Updates to the topology userspace interface
- Big updates to the Renesas support from Morimoto-san
- Most of the support for Intel Sky Lake systems.
- New drivers for Asahi Kasei Microdevices AK4613, Allwinnner A10,
Cirrus Logic WM8998, Dialog DA7219, Nuvoton NAU8825 and Rockchip
S/PDIF.
- A new driver for the Atmel Class D speaker drivers
The HDA codec driver issues snd_hda_codec_reset() at the error path of
PCM build. This was needed in the earlier code base, but the recent
rewrite to use the standard bus binding made this a deadlock:
modprobe D 0000000000000005 0 720 716 0x00000080
Call Trace:
[<ffffffff816a5dbe>] schedule+0x3e/0x90
[<ffffffff816a61a5>] schedule_preempt_disabled+0x15/0x20
[<ffffffff816a7ae5>] __mutex_lock_slowpath+0xb5/0x120
[<ffffffff816a7b6b>] mutex_lock+0x1b/0x30
[<ffffffff8148656b>] device_release_driver+0x1b/0x30
[<ffffffff81485c15>] bus_remove_device+0x105/0x180
[<ffffffff814822b9>] device_del+0x139/0x260
[<ffffffffa05e0ec5>] snd_hdac_device_unregister+0x25/0x30 [snd_hda_core]
[<ffffffffa074fa6a>] snd_hda_codec_reset+0x2a/0x70 [snd_hda_codec]
[<ffffffffa075007b>] snd_hda_codec_build_pcms+0x18b/0x1b0 [snd_hda_codec]
[<ffffffffa074a44e>] hda_codec_driver_probe+0xbe/0x140 [snd_hda_codec]
[<ffffffff81486ac4>] driver_probe_device+0x1f4/0x460
[<ffffffff81486dc0>] __driver_attach+0x90/0xa0
[<ffffffff81484844>] bus_for_each_dev+0x64/0xa0
[<ffffffff814862de>] driver_attach+0x1e/0x20
[<ffffffff81485e7b>] bus_add_driver+0x1eb/0x280
[<ffffffff81487680>] driver_register+0x60/0xe0
[<ffffffffa074a0da>] __hda_codec_driver_register+0x5a/0x60 [snd_hda_codec]
[<ffffffffa070a01e>] realtek_driver_init+0x1e/0x1000 [snd_hda_codec_realtek]
[<ffffffff810002f3>] do_one_initcall+0xb3/0x200
[<ffffffff816a1fc5>] do_init_module+0x60/0x1f8
[<ffffffff810ee5c3>] load_module+0x1653/0x1bd0
[<ffffffff810eed48>] SYSC_finit_module+0x98/0xc0
[<ffffffff810eed8e>] SyS_finit_module+0xe/0x10
[<ffffffff816aa032>] entry_SYSCALL_64_fastpath+0x16/0x75
The simple fix is just to remove this call, since we don't need to
think about unbinding at there any longer.
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=948758
Cc: <stable@vger.kernel.org> # v4.1+
The recent commit [7fbe824a0f0e: ALSA: hda - Update mixer name for the
lower codec address] tried to improve the mixer chip name assignment
in the order of codec address. However, this fix was utterly bogus;
it checks the field set in each codec, thus this value is reset at
each codec creation, of course. For really handling this priority,
the assignment has to be remembered in the common place, namely in
hda_bus, instead of hda_codec.
Fixes: 7fbe824a0f0e ('ALSA: hda - Update mixer name for the lower codec address')
In most cases, we prefer the onboard codec as the primary device, thus
it's better to set it as the mixer name. Currently, however, the
mixer name is updated per the device instantiation order, and user
gets often HDMI/DP or other seen as a mixer chip name. Also, if a
codec name is renamed by the driver, the old chip name might be left
still as the mixer name.
This patch addresses these issues by remembering the chip address that
was referred as the mixer name. When a codec with the same or lower
address gives its name, renew the mixer name accordingly, as it's
either the update of the codec name or we get likely the more
appropriate chip as the reference.
Now that we have introduced the core fns we should make hda use these
helpers
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
The variable pcm can be never NULL since it was rewritten with
list_for_each_entry().
Suggested-by: Markus Osterhoff <linux-kernel@k-raum.org>
In the commit [fa4f18b4f402: ALSA: hda - Refresh widgets sysfs at
probing Haswell+ HDMI codecs], snd_hdac_refresh_widget_sysfs() is
explicitly called in the codec driver. But this results in refreshing
twice, as snd_hdac_refresh_widget_sysfs() itself calls
snd_hdac_refresh_widgets() function.
Instead, we can replace the call in snd_hda_codec_update_widgets()
with snd_hdac_refresh_widget_sysfs(). This also fixes the missing
sysfs update for ca0132, too.
After a for-loop was replaced by list_for_each_entry, see
Commit bbbc7e8502c9 ("ALSA: hda - Allocate hda_pcm objects dynamically"),
Commit 751e2216899c ("ALSA: hda: fix possible null dereference"),
a possible NULL pointer dereference has been introduced; this patch adds
the NULL check on pcm->pcm, while leaving a potentially superfluous
check on pcm itself untouched.
Signed-off-by: Markus Osterhoff <linux-kernel@k-raum.org>
Cc: <stable@vger.kernel.org> #v4.1+
A few helper functions to convert the pin information to strings have
been exported with assumption that they were used by other drivers.
But they are referred only in the proc interface in the end.
Let's make them local so that we can get rid of a few exports.
In kstrdup we should return -ENOMEM when it reports an
memory allocation failure, while the -ENODEV is referred
to a failure in finding the cpu node in the device tree.
Signed-off-by: Heloise NH <kernelpatch_update@163.com>
Yet another non-trivial conflicts resolution for the recent HD-audio fix.
sound/pci/hda/hda_intel.c
snd_hdac_link_power() has to be called after unregistering the codec
device. Otherwise the device might be already runtime-suspended, thus
the refcount goes under zero, triggering a warning like:
WARNING: CPU: 7 PID: 2014 at sound/hda/hdac_i915.c:63 snd_hdac_display_power+0x106/0x120 [snd_hda_core]()
CPU: 7 PID: 2014 Comm: modprobe Not tainted 4.1.0-rc7-test+ #1
Call Trace:
[<ffffffff81697fe3>] dump_stack+0x4c/0x6e
[<ffffffff810696da>] warn_slowpath_common+0x8a/0xc0
[<ffffffff810697ca>] warn_slowpath_null+0x1a/0x20
[<ffffffffa02dd526>] snd_hdac_display_power+0x106/0x120 [snd_hda_core]
[<ffffffffa030b422>] azx_intel_link_power+0x12/0x20 [snd_hda_intel]
[<ffffffffa037139f>] azx_link_power+0x1f/0x30 [snd_hda_codec]
[<ffffffffa02d89fe>] snd_hdac_link_power+0x2e/0x40 [snd_hda_core]
[<ffffffffa0368524>] snd_hda_codec_dev_free+0x34/0x50 [snd_hda_codec]
[<ffffffffa0252061>] __snd_device_free+0x51/0xa0 [snd]
Yet another regression by the transition to regmap cache; for better
usability, we had the fake mute control using the zero amp value for
Conexant codecs, and this was forgotten in the new hda core code.
Since the bits 4-7 are unused for the amp registers (as we follow the
syntax of AMP_GET verb), the bit 4 is now used to indicate the fake
mute. For setting this flag, snd_hda_codec_amp_update() becomes a
function from a simple macro. The bonus is that it gained a proper
function description.
Enable runtime PM of the HDMI audio codec on the latest Intel platforms.
So the HD-A controller or HDMI codec can suspend when idle timeout by
default and release the GFX power well.
The patch influences HSW/BDW/BYT/BSW/SKL. Eariler platforms and third
party analog codecs will not be influenced.
Signed-off-by: Lu, Han <han.lu@intel.com>
Resolve the non-trivial conflict due to the hdac regmap API changes.
The new regmap code seems to cache this, which isn't helpful
for the hotplug dock situation where this gets updated.
Use the uncached query for this.
A flag "link_power_control" is added to indicate whether a codec needs to
control the link power. And a new bus ops link_power() is defined for the
codec to request to enable/disable the link power.
Signed-off-by: Mengdong Lin <mengdong.lin@intel.com>
Reported by coverity CID 1296024.
The mute-LED mode control has the fixed on/off states that are
supposed to remain on/off regardless of the master switch. However,
this doesn't work actually because the vmaster hook is called in the
vmaster code itself.
This patch fixes it by calling the hook indirectly after checking the
mute LED mode.
Reported-and-tested-by: Pali Rohár <pali.rohar@gmail.com>
Originally hda_bus takes its own ops (hda_bus_ops) to allow different
controller drivers giving individual implementations of PCM
attachment, etc. But this never happened and we finally merged both
codec and controller helper codes. Thus there is no merit to keep the
indirect accesses to functions via hda_bus_ops.
This patch replaces these calls with the direct local function calls
for simplification.
The commit [a551d91473e5: ALSA: hda - Use regmap for command verb
caches, too] introduced a regression due to a typo in the conversion;
the IEC958 status bits of slave digital devices aren't updated
correctly. This patch corrects it.
Fixes: a551d91473e5 ('ALSA: hda - Use regmap for command verb caches, too')
Reported-and-tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
... and replace with the existing hda-core helper codes.
This reduces lots of lines, finally.
Since struct hda_bus is now embedded into struct azx,
snd_hda_bus_new() is moved and expanded from hda_codec.c to
hda_controller.c, accordingly. Also private_free bus ops and
private_data field are removed because we no longer need to point azx
object from bus (we can use container_of())
The spin locks are consolidated into the single one, bus->reg_lock.
One less redirection again. This also requires the change of the call
order in the toplevel divers. Namely, the bus has to be created at
first before other initializations since the memory allocation ops are
called through bus object now.
One less redirection.
This patch adds the controller helper codes to hda-core library.
The I/O access ops are added to the bus ops. The CORB/RIRB, the basic
attributes like irq# and iomap address, some locks and the list of
streams are added to the bus object, together with the stream object
and its helpers.
Currently the codes are just copied from the legacy driver, so you can
find duplicated codes in both directories. Only constants are removed
from the original hda_controller.h. More integration work will follow
in the later patches.
... and drop bus->rirb_error flag. This makes the code simpler.
We treat -EAGAIN from get_response ops as a special meaning: it allows
the caller to retry after bus reset.
Currently, snd_hdac_power_up()/down() helpers checks whether the codec
is being in pm (suspend/resume), and skips the call of runtime get/put
during it. This is needed as there are lots of power up/down
sequences called in the paths that are also used in the PM itself. An
example is found in hda_codec.c::codec_exec_verb(), where this can
power up the codec while it may be called again in its power up
sequence, too.
The above works in most cases, but sometimes we really want to wait
for the real power up. For example, the control element get/put may
want explicit power up so that the value change is assured to reach to
the hardware. Using the current snd_hdac_power_up(), however,
results in a race, e.g. when it's called during the runtime suspend is
being performed. In the worst case, as found in patch_ca0132.c, it
can even lead to the deadlock because the code assumes the power up
while it was skipped due to the check above.
For dealing with such cases, this patch makes snd_hdac_power_up() and
_down() to two variants: with and without in_pm flag check. The
version with pm flag check is named as snd_hdac_power_up_pm() while
the version without pm flag check is still kept as
snd_hdac_power_up(). (Just because the usage of the former is fewer.)
Then finally, the patch replaces each call potentially done in PM with
the new _pm() variant.
In theory, we can implement a unified version -- if we can distinguish
the current context whether it's in the pm path. But such an
implementation is cumbersome, so leave the code like this a bit messy
way for now...
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=96271
we are dereferencing pcm first then checking pcm. instead now lets put
them in same if condition so that pcm is checked first.
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
Like the previous patches, this patch converts also to the regmap, at
this time, the cached verb writes are the target. But this conversion
needs a bit more caution than before.
- In the old code, we just record any verbs as is, and restore them at
resume. For the regmap scheme, this doesn't work, since a few verbs
like AMP or DIGI_CONVERT are asymmetrical. Such verbs are converted
either to the dedicated function (snd_hda_regmap_xxx_amp()) or
changed to the unified verb.
- Some verbs have to be declared as vendor-specific ones before
accessing via regmap.
Also, the minor optimization with codec->cached_write flag is dropped
in a few places, as this would confuse the operation. Further
optimizations will be brought in the later patches, if any.
This conversion ends up with a drop of significant amount of codes,
mostly the helper codes that are no longer used.
The amp hash table was used for recording the cached reads of some
capability values like pin caps or amp caps. Now all these are moved
to regmap as well.
One addition to the regmap helper is codec->caps_overwriting flag.
This is set in snd_hdac_override_parm(), and the regmap helper accepts
any register while this flag is set, so that it can overwrite even the
read-only verb like AC_VERB_PARAMETERS. The flag is cleared
immediately in snd_hdac_override_parm(), as it's a once-off flag.
Along with these changes, the no longer needed amp hash and relevant
fields are removed from hda_codec struct now.
This patch converts the amp access functions to the regmap helpers.
The amp values were formerly cached in the own hash table. Now it's
dropped by the regmap's cache.
The only tricky conversion is snd_hda_codec_amp_init(). This function
shouldn't do anything if the amp was already initialized. For
achieving this behavior, a value is read once at first temporarily in
the cache-only mode. Only if it returns an error, i.e. the item
still doesn't exist in the cache, it proceeds to the update.
Sometimes we need the uncached reads, e.g. for refreshing the tree.
This patch provides the helper function for that and uses it for
refreshing widgets, reading subtrees and the whole proc reads.
This patch adds an infrastructure to support regmap-based verb
accesses. Because o the asymmetric nature of HD-audio verbs,
especially the amp verbs, we need to translate the verbs as a sort of
pseudo registers to be mapped uniquely in regmap.
In this patch, a pseudo register is built from the NID, the
AC_VERB_GET_* and 8bit parameters, i.e. almost in the form to be sent
to HD-audio bus but without codec address field. OTOH, for writing,
the same pseudo register is translated to AC_VERB_SET_* automatically.
The AC_VERB_SET_AMP_* verb is re-encoded from the corresponding
AC_VERB_GET_AMP_* verb and parameter at writing.
Some verbs has a single command for read but multiple for writes. A
write for such a verb is split automatically to multiple verbs.
The patch provides also a few handy helper functions. They are
designed to be accessible even without regmap. When no regmap is set
up (e.g. before the codec device instantiation), the direct hardware
access is used. Also, it tries to avoid the unnecessary power-up.
The power up/down sequence is performed only on demand.
The codec driver needs to call snd_hdac_regmap_exit() and
snd_hdac_regmap_exit() at probe and remove if it wants the regmap
access.
There is one flag added to hdac_device. When the flag lazy_cache is
set, regmap helper ignores a write for a suspended device and returns
as if it was actually written. It reduces the hardware access pretty
much, e.g. when adjusting the mixer volume while in idle. This
assumes that the driver will sync the cache later at resume properly,
so use it carefully.
This will be used by the regmap support.
When the driver is unloaded before the codec is bound, it still keeps
the runtime PM refcount up, and results in the unbalance. This patch
covers these cases by introducing a flag indicating the runtime PM
initialization and handling the codec registration procedure more
properly. It also fixes the missing input beep device as a gratis,
too.
Add an overriding exec_verb op to struct hdac_device so that the call
via snd_hdac_exec_verb() can switch to a different route depending on
the setup. The codec driver sets this field so that it can handle the
errors or applying quirks appropriately. Furthermore, this mechanism
will be used for smooth transition for the regmap support in later
patches.
This patch changes the sysfs files assigned to the codec device on the
bus which were formerly identical with hwdep sysfs files. Now it
shows only a few core parameter, vendor_id, subsystem_id, revision_id,
afg, mfg, vendor_name and chip_name.
In addition, now a widget tree is added to the bus device sysfs
directory for showing the widget topology and attributes. It's just a
flat tree consisting of subdirectories named as the widget NID
including various attributes like widget capability bits. The AFG
(usually NID 0x01) is always found there, and it contains always
amp_in_caps, amp_out_caps and power_caps files. Each of these
attributes show a single value. The rest are the widget nodes
belonging to that AFG. Note that the child node might not start from
0x02 but from another value like 0x0a.
Each child node may contain caps, pin_caps, amp_in_caps, amp_out_caps,
power_caps and connections files. The caps (representing the widget
capability bits) always contain a value. The rest may contain
value(s) if the attribute exists on the node. Only connections file
show multiple values while other attributes have zero or one single
value.
An example of ls -R output is like below:
% ls -R /sys/bus/hdaudio/devices/hdaudioC0D0/
/sys/bus/hdaudio/devices/hdaudioC0D0/widgets/:
01/ 04/ 07/ 0a/ 0d/ 10/ 13/ 16/ 19/ 1c/ 1f/ 22/
02/ 05/ 08/ 0b/ 0e/ 11/ 14/ 17/ 1a/ 1d/ 20/ 23/
03/ 06/ 09/ 0c/ 0f/ 12/ 15/ 18/ 1b/ 1e/ 21/
/sys/bus/hdaudio/devices/hdaudioC0D0/widgets/01:
amp_in_caps amp_out_caps power_caps
/sys/bus/hdaudio/devices/hdaudioC0D0/widgets/02:
amp_in_caps amp_out_caps caps connections pin_caps pin_cfg
power_caps
/sys/bus/hdaudio/devices/hdaudioC0D0/widgets/03:
Now some codes and functionalities of hda_codec struct are moved to
hdac_device struct. A few basic attributes like the codec address,
vendor ID number, FG numbers, etc are moved to hdac_device, and they
are accessed like codec->core.addr. The basic verb exec functions are
moved, too.
A few basic codes for communicating over HD-audio bus are moved to
struct hdac_bus now. It has only command and get_response ops in
addition to the unsolicited event handling.
Note that the codec-side tracing support is disabled temporarily
during this transition due to the code shuffling. It will be
re-enabled later once when all pieces are settled down.
Define the common hd-audio driver and device types to bind over
snd_hda_bus_type publicly. This allows to implement other type of
device and driver code over hd-audio bus.
Now both struct hda_codec and struct hda_codec_driver inherit these
new struct hdac_device and struct hdac_driver, respectively.
The bus registration is done in subsys_initcall() to assure it
before any other driver registrations.
This patch enables the finer power state control of each widget
depending on the jack plug state and streaming state in addition to
the existing power_down_unused power optimization. The new feature is
enabled only when codec->power_mgmt flag is set.
Two new flags, pin_enabled and stream_enabled, are introduced in
nid_path struct for marking the two individual power states: the pin
plug/unplug and DAC/ADC stream, respectively. They can be set
statically in case they are static routes (e.g. some mixer paths),
too.
The power up and down events for each pin are triggered via the
standard hda_jack table. The call order is hard-coded, relying on the
current implementation of jack event chain (a la FILO/stack order).
One point to be dealt carefully is that DAC/ADC cannot be powered
on/off while streaming. They are pinned as long as the stream is
running. For controlling the power of DAC/ADC, a new patch_ops is
added. The generic parser provides the default callback for that.
As of this patch, only IDT/Sigmatel codec driver enables the flag.
The support on other codecs will follow.
An assumption we made in this code is that the widget state (e.g. amp,
pinctl, connections) remains after the widget power transition (not
about FG power transition). This is true for IDT codecs, at least.
But if the widget state is lost at widget power transition, we'd need
to implement additional code to sync the cached amp/verbs for the
specific NID.
The driver shutdown ops is simpler than registering reboot notifier
manually. There should be no functional change by this -- the codec
driver calls its own callback while the bus driver just calls
azx_stop() like before.
Move the destructor code to device release callback for the codec
object instead. This is a safer place to release the resources than
dev_free callback in general.
The events that are handled by HD-audio drivers are no frequent and
urgent ones, so we can use the standard workqueue without any problem
nowadays.
This makes the code flow easier -- instead of the controller driver
calling snd_hda_build_pcms() and snd_hda_build_controls() explicitly,
the codec driver itself builds PCMs and controls at probe time. Then
the controller driver only needs to call snd_card_register().
Also, this allows us the full bind/unbind control, too. Even when a
codec driver is bound later, it automatically registers the new PCM
and controls by itself.
