Hack HDA driver to make it the 2nd rather than the first sound card as
the first one should be the SGTL5000 which is always present on our T30
modules. Especially on Ixora where there is no HDA codec on the carrier
board HDA being the first sound card does not make much sense even more
though as there was no primary device (e.g. device=hw:0,0).
Improve the resume time of the HD Audio driver by replacing selected
msleep() functions with mdelay(). msleep() return times are not
deterministic.
Signed-off-by: ScottPeterson <speterson@nvidia.com>
Reviewed-on: http://git-master/r/86896
(cherry picked from commit eccbe7983d1b010cc60b49bfb13d041b3a0957d3)
Change-Id: I261ba51e7f8414bca50076ae73473114a308645c
Reviewed-on: http://git-master/r/88090
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Tested-by: Scott Peterson <speterson@nvidia.com>
Remove snd_hda_power_up()/snd_hda_power_down() sequence from HDA codec
resume since it add around 90ms delay. This code was not essential
for HDA driver to work properly after suspend-resume cycle.
Bug 932606
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/80040
(cherry picked from commit 2ed8667c2bdfd4c8cbe371530b066b537aa9ae62)
Change-Id: I0ffb120eb0a54f6c4e20aaf96c5ac2d0f5ab6949
Reviewed-on: http://git-master/r/87188
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Bug 923312
Change-Id: I7c68f261989d2ca1ef7b273b7d41a519bc91c868
Reviewed-on: http://git-master/r/75700
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/76466
commit 1c89fe3b51a2f8068f2f9faa9c48584151416583 upstream.
For the Asus 1101HA, reporting position by reading the DMA position
buffer map seems unstable and often wrong. The reporter says that
position_fix=LPIB works much better (although not 100%, but this is
probably due to other issues).
The controller chip is an Intel Poulsbo 8086:811b (rev 07) controller,
and complete alsa-info is available here:
https://launchpadlibrarian.net/86691768/alsa-info.txt.1TNwyE5Ea7
BugLink: http://bugs.launchpad.net/bugs/825709
Tested-by: Stefano Lodi
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
Change-Id: Ib024489660295b8842215eb8a3cd25feec25e00d
Reviewed-on: http://git-master/r/74605
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
HDA driver used to enable clocks during suspend only if there is no
active clock. But this logic causes a race condition when hda codec
power work thread disables the active instance of hda clocks in
middle of suspend. To avoid this race condition always enable
HDA clocks at start of suspend operation and disable all active
references of HDA clocks at end of suspend. Since HDA driver
suspend also suspends all active codecs there is no chance of
getting HDA clock disable call after completion of suspend.
Bug 915436
Change-Id: I4956ba28488d6d445ea2d53fb2592897a2ad83bb
Reviewed-on: http://git-master/r/70315
This change is basically a WAR. Tegra T30 HDA controller does not
support presence detect event generateion when all HDA clocks are
off. This change forcefully enables power disabling of HDA chip and
clocks while not in use. As a side effect Tegra HDA driver misses
the unsolicited HDMI plug in event when in power off mode. To overcome
this limitation whenever user space tries to open an HDMI pcm stream
Tegra HDA controller requests HDMI driver to setup presence detect
registers after enabling the chip and waits until it gets valid ELD
data.
Bug 904530
Change-Id: I8c8cb6fe7935ba8b16c421beca68cb1d7f576212
Reviewed-on: http://git-master/r/66972
Add support for disabling of platform driver clocks when HDA is idle
to reduce HDA power consumption. Take care of enabling of HDA clocks
before accessing any hardware register.
Bug 904530
Change-Id: I51be7990e900cef3dac376d9635c48cd1ffbfa99
Reviewed-on: http://git-master/r/66886
Bug 872652
Change-Id: I10c18afb496a605d47a09c7c6dc924459b4728eb
Reviewed-on: http://git-master/r/64335
Tested-by: Gerrit_Virtual_Submit
Rebase-Id: Rbaf53a2382f50c1a552bafd9d54840779160b055
It is possible that some chips have a HD-audio controller which is not
installed on a PCI bus. Nvidia Tegra has Azalia HD-audio controller
but it uses proprietery interface to communicate with the controller.
This commit adds a platform driver interface support to HDA driver
which can be used by non-PCI bus based HDA controller.
Bug 872652
Change-Id: I73fb55858387f511738a09de3f52e7d326353ebf
Reviewed-on: http://git-master/r/59504
Rebase-Id: R51a3866f0cb9889d947d6c7045ad7e8976cb3e69
commit 69f9ba9b0cad67bc03f0a096f7f274de795ca844 upstream.
The regression-fix in 3.1 for the check of DMA-position validity caused
yet another regression for CA0110. As usual, this hardware seems working
only with LPIB properly. Adding the appropriate driver-caps bit to force
LPIB fixes the problem.
Reported-and-tested-by: Andres Freund <andres@anarazel.de>
The previous fix for the position-buffer check gives yet another
regression on a Dell laptop. The safest fix right now is to add a
static quirk for this device (and better to apply it for stable
kernels too).
Reported-by: Éric Piel <Eric.Piel@tremplin-utc.net>
Cc: <stable@kernel.org>
The commit a810364a0424c297242c6c66071a42f7675a5568
ALSA: hda - Handle -1 as invalid position, too
caused a regression on some machines that require the position-buffer
instead of LPIB, e.g. resulting in noises with mic recording with
PulseAudio.
This patch fixes the detection by delaying the test at the timing as
same as 3.0, i.e. doing the position check only when requested in
azx_position_ok().
Reported-and-tested-by: Rocko Requin <rockorequin@hotmail.com>
Add a Kconfig entry to specify the default buffer size.
Distros using PulseAudio can choose a larger value here.
Now that we have changed the position_fix default for ATI and AMD
to be LPIB (see commit 50e3bbf989), we can remove the quirks that
were added for ATI chipsets.
The name argument of request_irq() appears in /proc/interrupts, and
it's quite ugly when the name entry contains a space or special letters.
In general, it's simpler and more readable when the module name appears
there, so let's replace all entries with KBUILD_MODNAME.
The convention for pci_driver.name entry in kernel drivers seem to be
the module name or equivalent ones. But, so far, almost all PCI sound
drivers use more verbose name like "ABC Xyz (12)", and these are fairly
confusing when appearing as a file name.
This patch converts the all pci_driver.name entries in sound/pci/* to
use KBUILD_MODNAME for more unified appearance.
SSYNC register was once defined as 0x34-37 in the old Intel datasheet,
but corrected later to 0x38-3b. For fixing the register usage, a new
bit-flag is introduced for indicating the old ICH SSYNC register, and
ICH* PCI entries are added explicitly to enable this quirk.
Instead of checking the azx_dev index with a fixed number (4), check
the stream direction of the assigned substream.
When reading from the position-buffer results in -1, handle as it's
invalid and falls back to LPIB mode as well as 0.
Currently, the data that backs the kcontrols created by
snd_hda_create_spdif_out_ctls is stored directly in struct hda_codec. When
multiple sets of these controls are stored, they will all manipulate the
same data, causing confusion. Instead, store an array of this data, one
copy per converter, to isolate the controls.
This patch would cause a behavioural change in the case where
snd_hda_create_spdif_out_ctls was called multiple times for a single codec.
As best I can tell, this is never the case for any codec.
This will be relevant at least for some HDMI audio codecs, such as the
NVIDIA GeForce 520 and Intel Ibex Peak. A future change will modify the
driver's handling of those codecs to create multiple PCMs per codec. Note
that this issue isn't affected by whether one creates a PCM-per-converter
or PCM-per-pin; there are multiple of both within a single codec in both
of those codecs.
Note that those codecs don't currently create multiple PCMs for the codec
due to the default HW mux state of all pins being to point at the same
converter, hence there is only a single converter routed to any pin, and
hence only a single PCM.
Commit 9477c58e3308 ("ALSA: hda - Reorganize controller quriks with bit
flags") changed the driver type compares into various quirk bits.
However, the check for AZX_DCAPS_NO_TCSEL got reverted: instead of
clearing TCSEL for chipsets that have that standard capability, it
cleared then when the NO_TCSEL bit was set.
This can lead to noise and repeated sounds - a weird "echo" behavior.
As the comment just above says: "Ensuring these bits are 0 clears
playback static on some HD Audio codecs". Which is definitely true at
least on my Core i5 Westmere system.
Cc: Takashi Iwai <tiwai@suse.de>
Introduce bit-flags indicating the necessary controller quirks, and
set them in pci driver_data field. This simplifies the checks in the
driver code and avoids the pci-id lookup in different places.
Also, this patch adds the PCI ID entry for AMD Hudson. AMD Hudson
requires a similar workaround like ATI SB while other generic ATI and
AMD controllers don't need but some ATI-HDMI quirks. So, we need a
different entry for Hudson.
ATI and AMD chipsets seem not providing the proper position-buffer
information, and it also doesn't provide FIFO register required by
VIACOMBO fix. It's better to use LPIB for these.
Reported-by: David Henningsson <david.henningsson@canonical.com>
This reverts commit 447ee6a7cbbfb5ae7ab8f9b8b058b4a04fe398bf.
The workaround introduced by this commit seems bogus.
The AMD chipsets don't provide proper position-buffer nor FIFO value
required by VIACOMBO fix.
AMD Hudson controllers give noisy outputs when the buffer data is
rewritten on the fly as PulseAudio does. This seems fixed by the
snoop bit enabled just like ATI chipset.
Also, disable 64bit DMA as now, to be sure.
We can revisit this later.
AMD chipsets often behave pretty badly regarding the DMA position
reporting. It results in the bad quality audio recording.
Using position_fix=3 works well in general for them, so let's enable
it as default for AMD.
The workaround for AMD chipset via sync_write flag seems needed for
machines with Realtek codecs. So, it's better to activate it
generically in hda_intel.c from the beginning.
This patch adds the HD Audio Controller DeviceIDs for the Intel Panther Point PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
azx_init_pci() always writes PCI config register ICH6_PCIREG_TCSEL
although this looks to be only defined on Intel systems and has a
different meaning on AMD systems. On AMD systems the PCI interrupt pin
control register is modified instead.
Since the meaning of offset 0x44 in device specific configuration space is
unknown for devices by other vendors, we only exclude AMD systems to
retain the current behaviour.
Signed-off-by: Adam Lackorzynski <adam@os.inf.tu-dresden.de>
The bug reporter claims that position_fix=1 is needed for his
microphone to work. The controller PCI vendor-id is [1002:4383] (rev 40).
Reported-by: Kjell L.
BugLink: http://bugs.launchpad.net/bugs/718402
Cc: stable@kernel.org
When an empty string is passed to patch option, the driver should
ignore it. Otherwise it gets an error by trying to load it.
Add the new PCI ID 0x15ad and device ID 0x1977 for VMware HDAudio
Controller.
[changed to use AZX_DRIVER_GENERIC by tiwai]
Signed-off-by: Bankim Bhavsar <bbhavsar@vmware.com>
Sjoerd Simons reports that, without using position_fix=1, recording
experiences overruns. Work around that by applying the LPIB quirk
for his hardware.
Reported-and-tested-by: Sjoerd Simons <sjoerd@debian.org>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
internal mic
BugLink: https://launchpad.net/bugs/685161
The reporter of the bug states that he must use position_fix=1 to enable
capture for the internal microphone, so set it for his machine's PCI
SSID. Verified using 2.6.35 and the 2010-12-04 alsa-driver build.
Reported-and-tested-by: Ralph Wabel <rwabel@gmx.net>
Allow disabling period wakeup interrupts for HDA PCM streams.
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@intel.com>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Creative IBG controllers require the playback stream-tags to be started
from 1, instead of capture+1. Otherwise the stream stalls.
Reported-by: Wai Yew CHAY <wychay@ctl.creative.com>
Creative HD-audio controller chips require some workarounds:
- Additional delay before RIRB response
- Set the initial RIRB counter to 0xc0
The latter seems to be done in general in Windows driver, so we may
use this value later for all types if it's confirmed to work better.
Position_fix quirks for specific machines now override the default
position_fix behavior for all HDA controllers.
BugLink: http://launchpad.net/bugs/465942
BugLink: http://launchpad.net/bugs/580749
BugLink: http://launchpad.net/bugs/587546
What was previously known as via_dmapos_patch, and hard-coded to be
used for VIA and ATI controllers, is now configurable through a module
option. The background is that some VIA controllers seem to prefer
via_dmapos_patch to be turned off.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Most of Intel controllers work as generic HD-audio without quirks,
and it'll be hopefully so in future. Let's mark pci id with the
PCI_CLASS_MULTIMEDIA_HD_AUDIO for Intel so that the driver will work
with any new control chips in future.
This patch adds the Intel Patsburg (PCH) HD Audio Controller DeviceIDs.
So far, we reset the converter setups like the stream-tag, the
channel-id and format-id in prepare callbacks, and clear them in
cleanup callbacks. This often causes a silence of the digital
receiver for a couple of seconds.
This patch tries to delay the converter setup changes as much as
possible. The converter setups are cached and aren't reset as long
as the same values are used. At suspend/resume, they are cleared
to be recovered properly, too.
Since the pending periods are often bogus and take long time until
actually processed, it often results in a high CPU usage of the hd-audio
workq. Overall it's better to have low CPU consumption by avoiding a
too tight loop rather than the wake-up timing accuracy.
Set bit 15 (Stream Type) of HDA Stream Format to 1 (Non-PCM) when IEC958
channel status bit 1 (AES0 & 0x02) is set to 1 (non-audio).
This is a prequisite for HDMI HBR passthrough.
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
