commit 2ebab40eb74a0225d5dfba72bfae317dd948fa2d upstream.
The hda_jack_tbl entries are managed by snd_array for allowing
multiple jacks. It's good per se, but the problem is that struct
hda_jack_callback keeps the hda_jack_tbl pointer. Since snd_array
doesn't preserve each pointer at resizing the array, we can't keep the
original pointer but have to deduce the pointer at each time via
snd_array_entry() instead. Actually, this resulted in the deference
to the wrong pointer on codecs that have many pins such as CS4208.
This patch replaces the pointer to the NID value as the search key.
As an unexpected good side effect, this even simplifies the code, as
only NID is needed in most cases.
The HDMI codec parser may create a phantom jack, but the helper
function snd_hda_jack_add_kctl() treats always as a normal jack. This
is superfluous as the jack query is executed at each time the jack
sync is performed.
Since the HDMI codec parser is the only caller of this function, it's
easier to change back this directly calling the original
__snd_hda_jack_add_kctl() with phantom_jack parameter.
Jack snd_kcontrols can now be created during snd_jack_new()
or by later calling snd_jack_add_new_kctls().
This patch creates the jacks during the initialisation stage
for both phantom and non phantom jacks.
Signed-off-by: Jie Yang <yang.jie@intel.com>
Dont create input devices for phantom jacks.
Here, we extend snd_jack_new() to support phantom jack creating:
pass in a bool param for [non-]phantom flag, and a bool param
initial_jack to indicate whether we need to create a kctl at
this stage.
We can also add a kctl to the jack after its created meaning we
can now integrate the HDA and ASoC jacks.
This patch adds a static method get_available_index() to
allocate the index of new jack kcontrols and also adds
jack_kctl_name_gen() which is used to ensure compatibility
with jack naming by removing " Jack" from some incorrectly
passed names.
Allow the codec object to have an individual card pointer. Not only
this simplifies the redirections in many places, also this will allow
us to make each codec assigned to a different card object.
Put more kerneldoc comments to the exported functions.
Still the generic parser code and the HD-audio controller code aren't
covered yet, though.
Complete the missing parameters and fix anything wrong there.
Just comment changes.
So far, hda_jack infrastructure allows only one callback per jack, and
this makes things slightly complicated when a driver wants to assign
multiple tasks to a jack, e.g. the standard auto-mute with a power
up/down sequence. This can be simplified if the hda_jack accepts
multiple callbacks.
This patch is such an extension: the callback-specific part (the
function and private_data) is split to another struct from
hda_jack_tbl, and multiple such objects can be assigned to a single
hda_jack_tbl entry.
The new struct hda_jack_callback is passed to each callback function
now, thus the patch became bigger than expected. But these changes
are mostly trivial.
STAC/IDT driver calls snd_hda_jack_tbl_get() again after calling
snd_hda_jack_detect_enable_callback(). For simplifying this, let's
make snd_hda_jack_detect_enable_callback() returning the pointer while
handling the error with the standard IS_ERR() & co.
It's called only in hda_jack.c, so make it local.
The action value assigned to each hda_jack_tbl entry is mostly
superfluous. The actually used values are either the widget NID or a
value specific to the callback.
The former case can be simply replaced by a reference to widget NID
itself. The only place doing the latter is STAC/IDT codec driver for
the powermap handling. But, the code doesn't need to check the action
field at all -- the function jack_update_power() is called either with
a specific pin or with NULL. So the check of jack->action can be
removed completely there, too.
Replace all with the standard EXPORT_SYMBOL_GPL().
If the jack should not be reported to userspace (e g, because it is
in some transitional state), one can set this flag.
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
The snd_hda_jack_set_gating_jack() call didn't work when
auto_{mute,mic} is suppressed because (1) am_entry is
not filled with nid of the mic pin. (2) The jacks are not
created (by snd_hda_jack_detect_enable_callback) before the
snd_hda_jack_set_gating_jack call.
Now we use the first input pin nid directly, and create the jack if it
doesn't exist yet.
Signed-off-by: Chih-Chung Chang <chihchung@chromium.org>
snd_hda_jack_detect() function returns a boolean value for a jack
plugged in or not, but it also returns always true when the
corresponding pin is phantom (i.e. fixed). This is OK in most cases,
but it makes the generic parser misbehaving about the auto-mute or
auto-mic switching, e.g. when one of headphone pins is a fixed.
Namely, the driver decides whether to mute the speaker or not, just
depending on the headphone plug state: if one of the headphone jacks
is seen as active, then the speaker is muted. Thus this will result
always in the muted speaker output.
So, the problem is the function returns a boolean, after all, although
we need to think of "phantom" jack. Now a new function,
snd_hda_jack_detect_state() is introduced to return these tristates.
The generic parser uses this function for checking the headphone or
mic jack states.
Meanwhile, the behavior of snd_hda_jack_detect() is kept as is, for
keeping compatibility in other driver codes.
Acked-by: David Henningsson <david.henningsson@canonical.com>
The char arrays with size 44 are for the name string of
snd_ctl_elem_id. Define the constant and replace the raw numbers with
it for clarifying better.
Now that we have a flag for headphone mics, we can use that flag
in the jack creation instead of creating the jack manually.
Let is_jack_detectable() return true when the jack polling is enabled
for the codec. VT1708 uses the polling explicitly so we need to allow
it.
Yet another broken hardware workaround: there are hardware indicating
the inverted jack detection bit result.
This is a preliminary patch for introducing a protection to access
races of snd_array instances. Call snd_array_init() appropriately
at the initialization time and don't call it twice.
Also the allocations of codec-spec structs are cleaned up by helper
functions in patch_sigmatel.c and patch_analog.c.
Introduce the concept of a "gated" jack. The gated jack's pin sense
is
only valid when the "gating" jack is plugged. This requires checking
the gating jack when the gated jack changes and re-checking the gated
jack when the gating jack is plugged/unplugged.
This allows handling of devices where the mic jack detect floats when
the headphone jack is unplugged.
[Rewritten for fixing the possible snd_array reallocation, covering
the missing callback calls and jack sync operations, as well as some
code cleanups -- tiwai]
Signed-off-by: Dylan Reid <dgreid@chromium.org>
This will greatly reduce the frequency for detection errors in
those cases where the hardware is "flaky", i e, rapidly changing
between plugged and unplugged states even without user interaction.
Now that we have a generic unsol mechanism, we can implement a generic
poll loop, which can be used for debugging, or if a codec's unsol
mechanism is broken.
Moving towards less duplication of code between codecs - this patch
takes some of the common code of unsol event handling and makes it
generic.
The purpose of this flag is unclear. If the problem is that some machines
have broken misc/NO_PRESENCE bits, they should be fixed by pin fixups.
In addition, this causes jack detection functionality to be flawed on
the M31EI, where there are two jacks without jack detection (which is
properly marked as NO_PRESENCE), but due to ignore_misc_bit, these
jacks are instead being reported as being present but always unplugged.
BugLink: https://bugs.launchpad.net/bugs/939161
Since some jack controls may be renamed as phantom jacks, the existing
check for index conflicts doesn't work because it simply compares the
name with the last used name, assuming that the controls with the same
name continue. Thus, it would result in the duplicated controls when
two or more phantom jacks with the very same type exist, and the
driver gives up with an error.
This patch fixes the problem by checking the index number conflicts
more intensively (but dumbly).
PulseAudio sometimes have difficulties knowing that there is a
"Speaker" or "Internal Mic", if they have no individual volume
controls or selectors. As a result, only e g "Headphone" might
be created for a laptop, but no "Speaker".
To help out, create phantom jacks (that are always present,
at least for now) for "Speaker", "Internal Mic" etc, in case we
detect them.
The naming convention is e g "Speaker Phantom Jack".
In order not to pollute the /dev/input namespace with even more
devices, these are added to the kcontrols only, not the input devices.
Just code shuffles.
Add a new flag to indicate that the codec has no jack-detection cap.
This flag should be set for hardwares that have no jack-detect
implementation although the codec chip itself supports it.
It's a bit too big and used too often as an inline function.
If a codec has both a front and a rear Line In, two controls both
named "Line Jack" will be created, which causes parsing to fail.
While a long term solution might be to name the jacks differently,
this extra check is consistent with what is already being done in many
auto-parsers, and will also protect against other cases when two
inputs have the same label.
BugLink: https://bugs.launchpad.net/bugs/923409
Instead of managing input-jack stuff separately, call all stuff inside
the kctl-jack creation, deletion and report. The caller no longer needs
to care about input-jack.
The better integration between input-jack and kctl-jack should be done
in the upper layer in near future, but for now, it's implemented locally
for more tests.
The function now gives more unique names for the output pins by adding
some prefix and suffix for the location and the channels. Otherwise, it
can pass the index number.
This is needed newly since 3.2...
Otherwise the jack kctls will report invalid values until the jack
is re-plugged.
Reported-by: David Henningsson <david.henningsson@canonical.com>
The type field was lost during the transition. Restored.
At probing time, the elements that aren't assigned to kctl or jack may
be called. Need proper NULL-checks.
These two functions are being used by the codec-idt and codec-hdmi
modules, so they need to be exported properly.
We can use the very same table in hda_jack.c for managing the list for
input-jack elements, too.
Now move the helper function for creating and reporting the jack-detection
to the common place. The driver that needs this functionality should
select CONFIG_SND_KCTL_JACK kconfig.
Manage the tags assigned for unsolicited events dynamically together
with the jack-detection routines. Basically this is almost same as what
we've done in patch_sigmatel.c. Assign the new tag number for each new
unsol event, associate with the given NID and the action type, etc.
With this change, now all pins looked over in snd_hda_jack_add_kctls()
are actually enabled for detection now even if the pins aren't used for
jack-retasking by the driver.
Create kcontrols for pin jack-detections, which work similarly like
jack-input layer. Each control will notify when the jack is plugged or
unplugged, and also user can read the value at any time via the normal
control API.
The control elements are created with iface=CARD, so that they won't
appear in the mixer apps.
So far, only the pins that enabled the jack-detection are registered.
For covering all pins, the transition of the common unsol-tag handling
would be needed. Stay tuned.
Introduce a table containing the pins and their jack-detection states
for avoiding the unnecessary verbs to check the pin status at each time.
When the unsol event is enabled via snd_hda_jack_detect_enable(), it
automatically adds the given NID to the table. Then the driver supposes
that the codec driver will set the dirty flag appropariately when an
unsolicited event is invoked for that pin.
The behavior for reading other pins that aren't registered in the table
doesn't change. Only the pins assigned to the table are cached, so far.
In near futre, this table can be extended to use the central place for
the unsolicited events of all pins, etc, and eventually include the
jack-detect kcontrols that replace the current input-jack stuff.
