path: root/sound/pci/hda/hda_patch.h
2008-04-24[ALSA] sound: hda: missing includes of hda_patch.hHarvey Harrison
Move the array declaration to hda_codec.c where it is used and add includes where the individual presets are declared. Fixes the following sparse warnings: sound/pci/hda/patch_realtek.c:13744:25: warning: symbol 'snd_hda_preset_realtek' was not declared. Should it be static? sound/pci/hda/patch_cmedia.c:729:25: warning: symbol 'snd_hda_preset_cmedia' was not declared. Should it be static? sound/pci/hda/patch_analog.c:3656:25: warning: symbol 'snd_hda_preset_analog' was not declared. Should it be static? sound/pci/hda/patch_sigmatel.c:3995:25: warning: symbol 'snd_hda_preset_sigmatel' was not declared. Should it be static? sound/pci/hda/patch_si3054.c:286:25: warning: symbol 'snd_hda_preset_si3054' was not declared. Should it be static? sound/pci/hda/patch_atihdmi.c:156:25: warning: symbol 'snd_hda_preset_atihdmi' was not declared. Should it be static? sound/pci/hda/patch_conexant.c:1721:25: warning: symbol 'snd_hda_preset_conexant' was not declared. Should it be static? sound/pci/hda/patch_via.c:1962:25: warning: symbol 'snd_hda_preset_via' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2007-10-16[ALSA] hda-codec - kernel config for each codecTakashi Iwai
Create kernel configs to choose the codec support codes to build. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Add support for VIA VT1708(A) HD audio codecJoseph Chan
This patch is VIA first release for HD audio codec, VT1708(A) and it provides geneneral HD audio driver features. Signed-off-by: Joseph Chan <josephchan@via.com.tw> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add Conexant audio support to the HD Audio driverTobin Davis
This driver adds limited support for the Conexant 5045 and 5047 HD Audio codecs. Some issues still need to be resolved. The code is based primarily on code from the Analog Devices AD1981 support and the Realtek ALC260 support. Some code came from the original code developed by Alex Pototskiy (see alsa bugtracker 2485). Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] hda - Add support for the ATI RS600 HDMI audio deviceFelix Kuehling
Add support for the ATI RS600 HDMI audio device. It has a one-stream pure digital stereo codec that isn't handled by the generic codec support. Signed-off-by: Felix Kuehling <fkuehlin@ati.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] hda-codec - support for Si3054/5 HDA modemsSasha Khapyorsky
HDA generic driver,HDA Codec driver Support for Si3054/5 HDA modem codecs. Signed-off-by: Sasha Khapyorsky <sashak@smlink.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] add sigmatel codec supportMatt
HDA generic driver,HDA Codec driver Add initial SigmaTel codec support for 9200 and 922x. Note that this hda patch relies on the configuration default registers to be set correctly (normally by BIOS/firmware) in order for it to set up pin widgets properly. There's a test switch in the patch so it will work with the SigmaTel reference boards that are usually plugged into a system that doesn't set the configuration default registers. It supports 2 channel analog out and line/mic in. I plan to add >2 channel support and spdif support shortly. Please apply. Signed-off-by: Matt <matt@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
