It makes little sense to enable power-saving without PM.
This removes SND_HDA_NEEDS_RESUME define so that we can use CONFIG_PM
in all places.
Some HP laptops with AD1981 have SPDIF connections, but currently the
driver disables it statically. Better to check the pin default config
to judge whether to enable or disable the SPDIF.
The SPDIF output controls apply to converter widgets. A future change
will create a PCM device per pin widget, and hence a set of SPDIF output
controls per pin widget, for certain HDMI codecs. To support this, we
need the ability to virtualize the SPDIF output controls. Specifically:
* Controls can be "unassigned" from real hardware when a converter is
not used for the PCM the control was created for.
* Control puts only write to hardware when they are assigned.
* Controls can be "assigned" to real hardware when a converter is picked
to support output for a particular PCM.
* When a converter is assigned, the hardware is updated to the cached
configuration.
Check whether the pin supports EAPD in ad198x_power_eapd_write.
Signed-off-by: Raymond Yau <superquad.vortex2@gmail.com>
In ad198x_power_eapd(), wrong pin NIDs are used for controlling EAPD for
HP and Front outputs of AD1988/AD1989. These are actually same with the
ones for AD1984 & co, port-A is 0x11 and port-D 0x12.
Reported-by: Raymond Yau <superquad.vortex2@gmail.com>
The microphone input on the back panel (pink connector)
stopped operating correctly after an upgrade from
2.6.35 to 2.6.38; the actual problem manifests itself
as a lack of microphone bias voltage (VREF_HIZ) on
node 0x17.
With AD1988_6STACK_DIG the maximum bias voltage (VREF_80)
is applied and the headset operates correctly.
Signed-off-by: Tony Vroon <tony@linx.net>
Tested-by: Doug Redlich <pbrigade@nxltech.net>
Compare pin type enum to the pin type and not the array index.
Fixes bug#0005368.
Signed-off-by: Adrian Wilkins <adrian.wilkins@nhs.net>
Cc: <stable@kernel.org> (2.6.37 and later)
Also fixed the assignment of multiout.dac_nids to satisfy const.
EAPD power-down should be called also for normal shutup cases.
Let's move to there. This also fixes the compile warnings when
CONFIG_PM isn't set automatically.
For codec AD1984A, add a new model to support Dell Precision R5500
or the microphone jack won't work correctly.
BugLink: http://bugs.launchpad.net/bugs/741516
Tested-by: Kent Baxley <kent.baxley@canonical.com>
Cc: stable@kernel.org
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
Attached a patch which add a new model to support multi-streaming
playback for ad1988.
playback another stereo stream through the front panel headphone on
device 2 while playback through the speakers connected to rear panel
on device 0 at the same time.
Tested with ad1988a rev2 codec on asus P5B-V motherboard.
BugLink: http://bugs.launchpad.net/bugs/697240
If the "Volume" suffix is not given, alsa-lib gets confused and
loses the dB information at the simple element level.
Boosts generally affects both playback and capture, as they are
applied early in the chain. Hence no "Playback" or "Capture" in
the suffix.
The sticky PCM stream assignment introduced in 2.6.36 kernel seems
causing problems on AD codecs. At some time later, the streaming no
longer works by unknown reason. A simple workaround is to disable
sticky-assignment for these codecs.
Tested-by: Vasily Khoruzhick <anarsoul@gmail.com>
BugLink: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/643891
Set the Dell Latitude E6400 (1028:0233) SSID to use AD1984_DELL_DESKTOP
Signed-off-by: Luke Yelavich <luke.yelavich@canonical.com>
This patch improves the input-source label strings to be generated from
the pin information instead of fixed strings per AUTO_PIN_* type.
This gives more suitable labels, especially for mic and line-in pins.
We can assign multiple pins to a single role now, let's reduce the
redundant FRONT_MIC and FRONT_LINE. Also, autocfg->input_pins[] is
no longer used, so this is removed as well.
Keep char array in the input_mux item itself instead of pointing to
an external string. This is a preliminary work for improving the
input-mux name based on the pin role.
Just as with the X301. The X300 does not have a way to do SPDIF either.
It does not have a dock connector, nor does it have the SPDIF through
the headphone jack.
This patch fixes it so X300 does not show SPDIF, since it cannot do it.
To add all Lenovo Thinkpads had different codec subsytem IDs:
X300:
http://launchpadlibrarian.net/34862838/Card0.Codecs.codec.0.txt
Signed-off-by: Jerone Young <jerone.young@canonical.com>
When HP laptop with AD1981 codec is suspended and the docking-station
is connected before the resume, the outputs get confused, and wrongly
routed still to the speaker. This is because of a change in 2.6.34-rc1
ea52bf260ecbb175339af3178c15788df21b7516
ALSA: hda: Add powerdown for Analog Devices HDA codecs
The problem was the added resume callback that doesn't consider the
modified init hook. The fix is simply remove the resume callback here
and make the resume normally. This doesn't change any behavior intended
in the commit above (for shutting down the sound at suspend) but only
fixes the resume.
Reported-and-tested-by: Frans Pop <elendil@planet.nl>
BugLink: https://launchpad.net/bugs/551606
The OR's hardware distorts at PCM 100% because it does not correspond to
0 dB. Fix this in patch_ad1981() for all models using the Thinkpad
quirk.
Reported-by: Jane Silber
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
For Lenovo Thinkpad T61/X61, the analog beep input is connected
to node 0x20, index 3. Move the digital beep mute/volume controls
as "Digital Beep" and create analog beep controls for mentioned node.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
BugLink: https://bugs.launchpad.net/bugs/524948
The OR has verified that the existing model=laptop-eapd quirk does not
function correctly but instead needs model=3stack. Make this change
so that manual corrections to module-init-tools file(s) are not
required.
Reported-by: Lasse Havelund <lasse@havelund.org>
CC: <stable@kernel.org>
The SPDIF-input pin 0x1c is muted by default in hardware. Unmute appropriate
pin to get captured samples instead zeros. Tested on Lenovo Thinkstation.
sound/pci/hda/patch_realtek.c
This patch ports powerdown fixes to AD198x. Currently we only turn off
Front and HP for suspend, but this is easily extended for additional
nids.
Analog Device codecs seem to have problems with the triggering of
pin-sensing although their pincaps give the trigger requirements.
Some reported that constant CPU load on HP laptops with AD codecs.
For avoiding this regression, add a flag to codec struct to notify
explicitly that the codec doesn't suppot the trigger at pin-sensing.
Tested-by: Maciej Rutecki <maciej.rutecki@gmail.com>
Fix the wrong implementation of NID <-> kctl mapping for capture mixers
introduced by the ocmmit 5b0cb1d850c26893b1468b3a519433a1b7a176be.
So far, the driver returns an error at probe.
The HDA_SUBDEV_NID_FLAG is duplicate for amplifier control elements. Move
get_amp_nid_() call to the snd_hda_ctl_add() function.
The purpose of this changeset is to show information about amplifier
setting in the codec proc file. Something like:
Control: name="Front Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Control: name="Front Playback Switch", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
This set of changes add missing NID values to some static control
elemenents. Also, it handles all "Capture Source" or "Input Source"
controls.
BugLink: https://bugs.launchpad.net/bugs/461062
The original reporter states that PCM maxes at +12 dB and results in
very bad distortion. Cap PCM at 0 dB to resolve this symptom.
Add a flag to spec field so that the EAPD inversion can be checked
outside the relevant control callbacks.
Disable beep-related codes when CONFIG_SND_HDA_INPUT_BEEP isn't set.
Define a proper const for a magic 31bit flag for subdev / NID setup
with a brief comment.
This patch adds support for dynamically created controls to proc codec file
(Control: lines).
This is an initial patch to show universal control<->NID assigment in
proc codec file. The change helps to debug codec related problems.
Original implementation was keeping registered input device for SND_BEEP
and SND_TONE events all time. This patch changes this behaviour:
If digital PC Beep is turned off using universal control switch,
the input device is unregistered.
Explanation: The kd_mksound() send SND_BEEP and SND_TONE only to last
registered device acceping those events. It means that the HDA Intel
audio driver blocks also the internal PC Speaker device (pcspkr.c
driver) even if the HDA Beep is muted. The user can easy disable
all beeps using 'setterm -blength 0' or 'xset b off' command.
Reference: ALSA bug #0004614
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=4614
port-A (0x11) - front hp-out
port-D (0x12) - rear line out
port-E (0x1c) - front mic-in
port-F (0x16) - Internal speakers
digital-mic (0x17) - Internal mic
init verbs, mixers, jack sensing and PCI_QUIRK to support this hardware
Signed-off-by: Miguel de Barros <miguel.de.barros@bluewin.ch>
Unmute the docking-station line-out as default on machines with
AD1984A codec chip. It can be still muted via "Dock" mixer switch.
