path: root/sound/pci/hda/patch_atihdmi.c
2008-04-24[ALSA] sound: hda: missing includes of hda_patch.hHarvey Harrison
Move the array declaration to hda_codec.c where it is used and add includes where the individual presets are declared. Fixes the following sparse warnings: sound/pci/hda/patch_realtek.c:13744:25: warning: symbol 'snd_hda_preset_realtek' was not declared. Should it be static? sound/pci/hda/patch_cmedia.c:729:25: warning: symbol 'snd_hda_preset_cmedia' was not declared. Should it be static? sound/pci/hda/patch_analog.c:3656:25: warning: symbol 'snd_hda_preset_analog' was not declared. Should it be static? sound/pci/hda/patch_sigmatel.c:3995:25: warning: symbol 'snd_hda_preset_sigmatel' was not declared. Should it be static? sound/pci/hda/patch_si3054.c:286:25: warning: symbol 'snd_hda_preset_si3054' was not declared. Should it be static? sound/pci/hda/patch_atihdmi.c:156:25: warning: symbol 'snd_hda_preset_atihdmi' was not declared. Should it be static? sound/pci/hda/patch_conexant.c:1721:25: warning: symbol 'snd_hda_preset_conexant' was not declared. Should it be static? sound/pci/hda/patch_via.c:1962:25: warning: symbol 'snd_hda_preset_via' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - Correct HDMI transmitter namesTakashi Iwai
Give better names to the new HDMI transmitter chips. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - Add ID for an unknown HDMI codec chipTakashi Iwai
Added the ID for an unknown HDMI codec chip on Jetway J9F2. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-intel - Fix PCM device number assignmentTakashi Iwai
In the current scheme, PCM device numbers are assigned incrementally in the order of codecs. This causes problems when the codec number is irregular, e.g. codec #0 for HDMI and codec #1 for analog. Then the HDMI becomes the first PCM, which is picked up as the default output device. Unfortuantely this doesn't work well with normal setups. This patch introduced the fixed device numbers for the PCM types, namely, analog, SPDIF, HDMI and modem. The PCM devices are assigned according to the corresponding PCM type. After this patch, HDMI will be always assigned to PCM #3, SPDIF to PCM #1, and the first analog to PCM #0, etc. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - Add SI HDMI codec supportTakashi Iwai
Added the support of SI HDMI codec, found in ASUS machines. ALSA bug#3654 https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3654 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] HDA-Intel - Add support for RV6xx HDMI audioWolke Liu
This patch is to add R6xx HDMI audio support. Meanwhile, the device ID in the previous patch is changed. I have checked the patch from Herton Ronaldo Krzesinski, it's right as our spec said. :) Signed-off-by: Wolke Liu <Wolke.Liu@amd.com> Signed-off-by: Andrea Zhang <Andrea.Zhang@amd.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] hda-codec - optimize resume using cachesTakashi Iwai
So far, the driver looked the table of snd_kcontrol_new used for creating mixer elements and forces to call each of its put callbacks in PM resume code. This is too ugly and hackish. Now, the resume is simplified using the codec amp and command register caches. The driver simply restores the values that have been written in the cache table. With this simplification, most codec support codes don't require any special resume callback. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] HDA-Intel - Add support for MSI K9AGM2-FIH motherboardTobin Davis
This patch adds support for the MSI K9AGM2-FIH on-board audio. Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] hda-intel - Add ATI RS780,R600 HDMI audio supportWolke Liu
This patch is for ATI RS780 and R600 HDMI support. Signed-off-by: Wolke Liu <wolke.liu@amd.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] hda-codec - Fix SPDIF outputTakashi Iwai
Fix SPDIF output (at least on Realtek codecs). The DIGI_CONVERT verbs have to be reset before the PCM stream is set up. Otherwise the digital setup is screwed up. Also, check the AMP capability before setting AMP of the digital out widget. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-22[ALSA] hda_intel: add ATI RS690 HDMI audio supportFelix Kuehling
This patch adds support for the HDMI codec of the ATI RS690 IGP northbridge. Signed-off-by: Felix Kuehling <fkuehlin@ati.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] hda - Add support for the ATI RS600 HDMI audio deviceFelix Kuehling
Add support for the ATI RS600 HDMI audio device. It has a one-stream pure digital stereo codec that isn't handled by the generic codec support. Signed-off-by: Felix Kuehling <fkuehlin@ati.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
