commit 46a049dae771b95e77ac6c823330f4a60f600236 upstream.
gcc-7 caught what it considers a NULL pointer dereference:
sound/pci/hda/patch_ca0132.c: In function 'dspio_scp.constprop':
sound/pci/hda/patch_ca0132.c:1487:4: error: argument 1 null where non-null expected [-Werror=nonnull]
This is plausible from looking at the function, as we compare 'reply'
to NULL earlier in it. I have not tried to analyze if there are constraints
that make it impossible to hit the bug, but adding another NULL check in
the end kills the warning and makes the function more robust.
commit b5337cfe067e96b8a98699da90c7dcd2bec21133 upstream.
I'm using an Alienware 15 R2 and had to use the alienware quirks to
get my headphone output working.
I fixed it by adding, SND_PCI_QUIRK(0x1028, 0x0708, "Alienware 15 R2
2016", QUIRK_ALIENWARE) to the patch.
Signed-off-by: Sven Hahne <hahne@zeitkunst.eu>
For structure types defined in the same file or local header files, find
top-level static structure declarations that have the following
properties:
1. Never reassigned.
2. Address never taken
3. Not passed to a top-level macro call
4. No pointer or array-typed field passed to a function or stored in a
variable.
Declare structures having all of these properties as const.
Done using Coccinelle.
Based on a suggestion by Joe Perches <joe@perches.com>.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
The hda_jack_tbl entries are managed by snd_array for allowing
multiple jacks. It's good per se, but the problem is that struct
hda_jack_callback keeps the hda_jack_tbl pointer. Since snd_array
doesn't preserve each pointer at resizing the array, we can't keep the
original pointer but have to deduce the pointer at each time via
snd_array_entry() instead. Actually, this resulted in the deference
to the wrong pointer on codecs that have many pins such as CS4208.
This patch replaces the pointer to the NID value as the search key.
As an unexpected good side effect, this even simplifies the code, as
only NID is needed in most cases.
Cc: <stable@vger.kernel.org>
The Alienware 17 (2015) has the same card and pin configuration of the
Alienware 15, so the same quirks must be applied.
Signed-off-by: Gabriele Martino <g.martino@gmx.com>
Use codec_*() macro instead of pr_*() for improving the log
information. The current form even slips from alsa-info.sh.
Finally we have a proper infrastructure to generate the modaliases
automatically, let's move to hda_device_id from the legacy
hda_codec_preset that contains basically the same information.
The patch function hook is stored in driver_data field, which is long,
and we need an explicit cast. Other than that, the conversion is
mostly straightforward. Each entry is even simplified using a macro,
and the lengthy (and error-prone) manual modaliases got removed.
As a result, we achieved a quite good diet:
14 files changed, 407 insertions(+), 595 deletions(-)
Reviewed-by: Vinod Koul <vinod.koul@intel.com>
Tested-by: Subhransu S Prusty <subhransu.s.prusty@intel.com>
Alienware 15 has CA0132 codec for its onboard sound, but the pin
config and mapping seem quite different from other Creative boards.
This patch corrects them, at least, for providing the right headphone
and mic jack notification, as well as removing the non-existing SPDIF
pins.
Even with this fix, not all stuff works perfectly yet, mainly because
of the badly written ca0132 driver code -- it has too many implicit
assumptions of pin configs and maps. Nevertheless, this is a small
good step forward.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=101981
... so that the parser code can overwrite some optional ops. For
Realtek and others, it can be set solely in the spec allocator, so it
results in a good code cleanup, too.
With this change, we can finally remove the local stream_pm setup and
rely on the generic parser's automatic setting.
This patch adds quirks detection to the Creative CA0132 codec, and the
quirk for Alienware 15 (2015).
Some quirks may need different pin configuration, so the relevant
compile-time configuration has been removed.
The pin configuration and related initialization verbs are generated at
runtime instead, in ca0132_config() and ca0132_prepare_verbs().
Currently, snd_hdac_power_up()/down() helpers checks whether the codec
is being in pm (suspend/resume), and skips the call of runtime get/put
during it. This is needed as there are lots of power up/down
sequences called in the paths that are also used in the PM itself. An
example is found in hda_codec.c::codec_exec_verb(), where this can
power up the codec while it may be called again in its power up
sequence, too.
The above works in most cases, but sometimes we really want to wait
for the real power up. For example, the control element get/put may
want explicit power up so that the value change is assured to reach to
the hardware. Using the current snd_hdac_power_up(), however,
results in a race, e.g. when it's called during the runtime suspend is
being performed. In the worst case, as found in patch_ca0132.c, it
can even lead to the deadlock because the code assumes the power up
while it was skipped due to the check above.
For dealing with such cases, this patch makes snd_hdac_power_up() and
_down() to two variants: with and without in_pm flag check. The
version with pm flag check is named as snd_hdac_power_up_pm() while
the version without pm flag check is still kept as
snd_hdac_power_up(). (Just because the usage of the former is fewer.)
Then finally, the patch replaces each call potentially done in PM with
the new _pm() variant.
In theory, we can implement a unified version -- if we can distinguish
the current context whether it's in the pm path. But such an
implementation is cumbersome, so leave the code like this a bit messy
way for now...
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=96271
Now some codes and functionalities of hda_codec struct are moved to
hdac_device struct. A few basic attributes like the codec address,
vendor ID number, FG numbers, etc are moved to hdac_device, and they
are accessed like codec->core.addr. The basic verb exec functions are
moved, too.
The events that are handled by HD-audio drivers are no frequent and
urgent ones, so we can use the standard workqueue without any problem
nowadays.
So far, the hda_codec object kept the hda_pcm list in an array, and
the codec driver was expected to assign the array. However, this
makes the object life cycle management harder, because the assigned
array is freed at the codec driver detach while it might be still
accessed by the opened streams.
In this patch, we allocate each hda_pcm object dynamically and manage
it as a linked list. Each object has a kref refcount, and both the
codec driver binder and the PCM open/close touches it, so that the
object won't be freed while in use.
Allow the codec object to have an individual card pointer. Not only
this simplifies the redirections in many places, also this will allow
us to make each codec assigned to a different card object.
Now we create the standard HD-audio bus (/sys/bus/hdaudio), and bind
the codec driver with the codec device over there. This is the first
step of the whole transition so that the changes to each codec driver
are kept as minimal as possible.
Each codec driver needs to register hda_codec_driver struct containing
the currently existing preset via the new helper macro
module_hda_codec_driver(). The old hda_codec_preset_list is replaced
with this infrastructure. The generic parsers (for HDMI and other)
are also included in the preset with the special IDs to bind
uniquely.
In HD-audio core side, the device binding code is split to
hda_bind.c. It provides the snd_hda_bus_type implementation to match
the codec driver with the given codec vendor ID. It also manages the
module auto-loading by itself like before: when the matching isn't
found, it tries to probe the corresponding codec modules, and finally
falls back to the generic drivers. (The special ID mentioned above is
set at this stage.)
The only visible change to outside is that the hdaudio sysfs entry now
appears in /sys/bus/devices, not as a sound class device.
More works to move the suspend/resume and remove ops will be
(hopefully) done in later patches.
For its headphone, mic and DSP responses, we can use the standard
hda_jack infrastructure in CA0132 driver, too. The only point to
handle carefully is the delayed headphone jack handling. It tries to
react after a certain delay. Here we use the existing block_report
flag in hda_jack_tbl (that was implemented for HDMI).
The action value assigned to each hda_jack_tbl entry is mostly
superfluous. The actually used values are either the widget NID or a
value specific to the callback.
The former case can be simply replaced by a reference to widget NID
itself. The only place doing the latter is STAC/IDT codec driver for
the powermap handling. But, the code doesn't need to check the action
field at all -- the function jack_update_power() is called either with
a specific pin or with NULL. So the check of jack->action can be
removed completely there, too.
CA0132 driver tries to reload the firmware at resume. Usually this
works since the firmware loader core caches the firmware contents by
itself. However, if the driver failed to load the firmwares
(e.g. missing files), reloading the firmware at resume goes through
the actual file loading code path, and triggers a kernel WARNING like:
WARNING: CPU: 10 PID:11371 at drivers/base/firmware_class.c:1105 _request_firmware+0x9ab/0x9d0()
For avoiding this situation, this patch makes CA0132 skipping the f/w
loading at resume when it failed at probe time.
Reported-and-tested-by: Janek Kozicki <cosurgi@gmail.com>
Pass the codec object so that we can replace all the rest of
snd_print*() usages with the proper device-specific print helpers.
Use dev_err() and co for messages from HD-audio controller and codec
drivers. The codec drivers are mostly bound with codec objects, so
some helper macros, codec_err(), codec_info(), etc, are provided.
They merely wrap the corresponding dev_xxx().
There are a few places still calling snd_printk() and its variants
as they are called without the codec or device context.
Incorrect ADC is picked in ca0132_capture_pcm_prepare(),
where it assumes multiple streams while there is one stream
per ADC. Note that ca0132_capture_pcm_cleanup() already does
the right thing.
The Chromebook Pixel has a microphone under the keyboard that
is attached to node id 0x8. Before this fix, recording would
always go to the main internal mic (node id 0x7).
Signed-off-by: Hsin-Yu Chao <hychao@chromium.org>
Reviewed-by: Dylan Reid <dgreid@chromium.org>
When a HDMI stream is opened with the same stream tag
as a following opened stream to ca0132, audio will be
heard from two ports simultaneously.
Fix this issue by change to use snd_hda_codec_setup_stream
and snd_hda_codec_cleanup_stream instead, so that an
inactive stream can be marked as 'dirty' when found
with a conflict stream tag, and then get purified.
Reviewed-by: Chih-Chung Chang <chihchung@chromium.org>
Some codec drivers still have it since using PCI_VENDOR_ID_*.
'codec_send_command' is used only in this file. Make it static.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
The char arrays with size 44 are for the name string of
snd_ctl_elem_id. Define the constant and replace the raw numbers with
it for clarifying better.
The DSP in the CA0132 codec adds a variable latency to audio depending
on what processing is being done. Add a new patch op to return that
latency for capture and playback streams. The latency is determined
by which blocks are enabled and knowing how much latency is added by
each block.
Signed-off-by: Dylan Reid <dgreid@chromium.org>
Turing on the headphone amp interferes with the impedance measurement
used to detect a TRRS style headset microphone. Delay the HP turn on
until 500ms after the jack is detected, allowing the mic detection
state machine to run to completion.
Signed-off-by: Chih-Chung Chang <chihchung@chromium.org>
spec->dsp_state is initialized to DSP_DOWNLOAD_INIT, no need to reset
and check it in ca0132_download_dsp().
Instead of using the dspload_is_loaded() function, check the dsp_state
that is kept in the spec. The dspload_is_loaded() function returns
true if the DSP transfer was never started. This false-positive leads
to multiple second delays when ca0132_setup_efaults() times out on
each write.
If dspload_image() fails, it was ignored and dspload_wait_loaded() was
still called. dsp_loaded should never be set to true in this case,
skip it. The check in dspload_wait_loaded() return true if the DSP is
loaded or if it never started.
Move the zero check `hda_frame_size_words == 0' before the modulus
`buffer_size_words % hda_frame_size_words'.
Also remove the redundant null check `buffer_addx == NULL'.
Signed-off-by: Xi Wang <xi.wang@gmail.com>
The chip address is 32bit long but INVALID_CHIP_ADDRESS is defined as
an unsigned long. This makes dsp_chip_to_dsp_addx() misbehaving on
64bit architectures. Fix the INVALID_CHIP_ADDRESS definition to be
32bit.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
This reduces the resultant binary size.
This patch fixes a few obvious bugs in DSP loader stuff:
- Fix possible memory leaks in the error path
- Avoid double-free calls in dma_reset()
- Properly set/unset WC bits for DMA buffers
- Add missing error status checks
Base the DSP firmware transfer and communication timeouts on jiffy values.
Signed-off-by: Ian Minett <ian_minett@creativelabs.com>
sound/pci/hda/patch_ca0132.c: In function ‘ca0132_is_vnode_effective’:
sound/pci/hda/patch_ca0132.c:3331:15: warning: ‘nid’ may be used uninitialized in this function [-Wmaybe-uninitialized]
sound/pci/hda/patch_ca0132.c:4345:13: warning: ‘ca0132_download_dsp’ defined but not used [-Wunused-function]
... to be less confusing for the update path.
This new kconfig will choose CONFIG_SND_HDA_DSP_LOADER, which is
basically a device-independent feature in hda_intel.c.
sound/pci/hda/patch_ca0132.c:387:19: sparse: symbol 'ca0132_voicefx' was not declared. Should it be static?
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
sound/pci/hda/patch_ca0132.c: In function ‘ca0132_effects_set’:
sound/pci/hda/patch_ca0132.c:3391:2: warning: too many arguments for
format [-Wformat-extra-args]
... in the error path in dspxfr_image().
Spotted by smatch,
sound/pci/hda/patch_ca0132.c:1950 dspxfr_image() error: potential
null dereference 'dma_engine'. (kzalloc returns null)
sound/pci/hda/patch_ca0132.c:1950 dspxfr_image() error: we
previously assumed 'dma_engine' could be null (see line 1857)
sound/pci/hda/patch_ca0132.c:1781 dspxfr_one_seg() info: why not
propagate 'status' from dsp_dma_stop() instead of (-5)?
Fix a warning by smatch,
sound/pci/hda/patch_ca0132.c:714 dspio_send() warn: always true
condition '(res >= 0) => (0-u32max >= 0)'
The recent update of ca0132 driver replaced the pinctl setup to the
direct write via snd_hda_codec_write() again. This should be covered
by snd_hda_set_pin_ctl() to be safer.
