Use dev_err() and co for messages from HD-audio controller and codec
drivers. The codec drivers are mostly bound with codec objects, so
some helper macros, codec_err(), codec_info(), etc, are provided.
They merely wrap the corresponding dev_xxx().
There are a few places still calling snd_printk() and its variants
as they are called without the codec or device context.
Some codec drivers still have it since using PCI_VENDOR_ID_*.
According to alsa-info.sh outputs, all three entries with static
quirks have the correct pin configs, so it's safe to remove static
quirks. For now, turn the static quirks off via ifdef. The dead
codes will be removed in later release.
This resulted in non-working auto-mute behavior, of course...
Replace the old parser code for C-Media auto-parser with the latest
generic parser. For compatibility reason, the static bindings are
still left, but they could be cleaned up in future.
Just code shuffles.
Lots of sound drivers were getting module.h via the implicit presence
of it in <linux/device.h> but we are going to clean that up. So
fix up those users now.
sound/pci/hda/patch_cmedia.c: In function ‘cmi9880_fill_multi_init’:
sound/pci/hda/patch_cmedia.c:401:15: warning: unused variable ‘len’
Create snd_hda_get_conn_index() helper function for obtaining the
connection index of the widget. Replaced the similar codes used in
several codec-drivers with this common helper.
The SPDIF output controls apply to converter widgets. A future change
will create a PCM device per pin widget, and hence a set of SPDIF output
controls per pin widget, for certain HDMI codecs. To support this, we
need the ability to virtualize the SPDIF output controls. Specifically:
* Controls can be "unassigned" from real hardware when a converter is
not used for the PCM the control was created for.
* Control puts only write to hardware when they are assigned.
* Controls can be "assigned" to real hardware when a converter is picked
to support output for a particular PCM.
* When a converter is assigned, the hardware is updated to the cached
configuration.
Fix the wrong implementation of NID <-> kctl mapping for capture mixers
introduced by the ocmmit 5b0cb1d850c26893b1468b3a519433a1b7a176be.
So far, the driver returns an error at probe.
This set of changes add missing NID values to some static control
elemenents. Also, it handles all "Capture Source" or "Input Source"
controls.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
To avoid confusion in control names for the standard analog PC Beep generator
using a small Internal PC Speaker, rename all related "PC Speaker" and "PC
Beep" controls to "Beep" only. This name is more universal and can be also
used on more platforms without confusion.
Introduce also "Internal Speaker" in ControlNames.txt for systems with
full-featured build-in internal speaker.
The sentense "Unknown model for xxx, ..." makes people too nervous
and drives them to a direction to a wrong "fix" by giving any
mismatching model option.
Let's rephrase the messages to be more nice and easy (at least that
won't make people suspect conspiracies).
Replace the accessor to pin defaults with the common code for caching.
Split the monolithc HD-audio driver into several pieces:
- snd-hda-intel HD-audio PCI controller driver; loaded via udev
- snd-hda-codec HD-audio codec bus driver
- snd-hda-codec-* Specific HD-audio codec drivers
When built as modules, snd-hda-codec (that is invoked by snd-hda-intel)
looks up the codec vendor ID and loads the corresponding codec module
automatically via request_module().
When built in a kernel, each codec drivers are statically hooked up
before probing the PCI.
This patch adds appropriate EXPORT_SYMBOL_GPL()'s and the module
information for each driver, and driver-linking codes between
codec-bus and codec drivers.
TODO:
- Avoid EXPORT_SYMBOL*() when built-in kernel
- Restore __devinit appropriately depending on the condition
Set the proper model for LG LS75 with CM9880 codec.
See ALSA bug#2105:
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=2105
Please refer to [0003874] on the alsa mantis.
This patch added the pci quirk.
Signed-off-by: Jiang zhe <zhe.jiang@intel.com>
Keep the format verb at closing PCM streams.
Introduced snd_hda_codec_cleanup_stream() for the parcicular purpose.
Move the array declaration to hda_codec.c where it is used and add includes
where the individual presets are declared.
Fixes the following sparse warnings:
sound/pci/hda/patch_realtek.c:13744:25: warning: symbol 'snd_hda_preset_realtek' was not declared. Should it be static?
sound/pci/hda/patch_cmedia.c:729:25: warning: symbol 'snd_hda_preset_cmedia' was not declared. Should it be static?
sound/pci/hda/patch_analog.c:3656:25: warning: symbol 'snd_hda_preset_analog' was not declared. Should it be static?
sound/pci/hda/patch_sigmatel.c:3995:25: warning: symbol 'snd_hda_preset_sigmatel' was not declared. Should it be static?
sound/pci/hda/patch_si3054.c:286:25: warning: symbol 'snd_hda_preset_si3054' was not declared. Should it be static?
sound/pci/hda/patch_atihdmi.c:156:25: warning: symbol 'snd_hda_preset_atihdmi' was not declared. Should it be static?
sound/pci/hda/patch_conexant.c:1721:25: warning: symbol 'snd_hda_preset_conexant' was not declared. Should it be static?
sound/pci/hda/patch_via.c:1962:25: warning: symbol 'snd_hda_preset_via' was not declared. Should it be static?
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Added a new mixer switch to enable/disable the sharing of the default
PCM stream with analog and SPDIF outputs. When "IEC958 Default PCM"
switch is on, the PCM stream is routed both to analog and SPDIF outputs.
This is the behavior in the earlier version.
Turning this switch off has a merit for some codecs, though. Some codec
chips don't support 24bit formats for SPDIF but only for analog outputs.
In this case, you can use 24bit format by disabling this switch.
In the current scheme, PCM device numbers are assigned incrementally
in the order of codecs. This causes problems when the codec number
is irregular, e.g. codec #0 for HDMI and codec #1 for analog. Then
the HDMI becomes the first PCM, which is picked up as the default
output device. Unfortuantely this doesn't work well with normal
setups.
This patch introduced the fixed device numbers for the PCM types,
namely, analog, SPDIF, HDMI and modem. The PCM devices are assigned
according to the corresponding PCM type. After this patch, HDMI will
be always assigned to PCM #3, SPDIF to PCM #1, and the first analog
to PCM #0, etc.
Removed 'FIXME' comments that have been already fixed.
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
dac_nids arrays in each codec support code may have up to 5 items
when assigned from the auto-configurator. Some codec codes have
less numbers than the possible max. This patch defines the constant
and fixes the array definitions.
So far, the driver looked the table of snd_kcontrol_new used for creating
mixer elements and forces to call each of its put callbacks in PM resume
code. This is too ugly and hackish.
Now, the resume is simplified using the codec amp and command register
caches. The driver simply restores the values that have been written
in the cache table. With this simplification, most codec support codes
don't require any special resume callback.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Fix SPDIF output (at least on Realtek codecs). The DIGI_CONVERT verbs
have to be reset before the PCM stream is set up. Otherwise the digital
setup is screwed up.
Also, check the AMP capability before setting AMP of the digital out
widget.
Use snd_pci_quirk_lookup() for looking up a board config table.
The config table is sorted in numerical order of PCI SSIDs.
Modules: HDA Codec driver,HDA generic driver
This patch adds the support of ALC262,ALC883,ALC885,ALC861 to driver
More models and improvements for ALC880, ALC260 and ALC882 codecs, too.
Signed-off-by: Kailang Yang <kailang@realtek.com.tw>
Remove xxx_t typedefs from the HD-Audio codec support codes.
Fix the auto-assignment of speaker pin. Handle it independently from
line-out pins.
Add common channel-mode helper functions for all codec patches.
AD1889 driver,ATIIXP driver,ATIIXP-modem driver,AZT3328 driver
BT87x driver,CMIPCI driver,CS4281 driver,ENS1370/1+ driver
ES1938 driver,ES1968 driver,FM801 driver,Intel8x0 driver
Intel8x0-modem driver,Maestro3 driver,SonicVibes driver,VIA82xx driver
VIA82xx-modem driver,AC97 Codec,AK4531 codec,au88x0 driver
CA0106 driver,CS46xx driver,EMU10K1/EMU10K2 driver,HDA Codec driver
HDA generic driver,HDA Intel driver,ICE1712 driver,ICE1724 driver
KORG1212 driver,MIXART driver,NM256 driver,Trident driver,YMFPCI driver
Replace kcalloc(1,..) with kzalloc().
HDA Codec driver
Added the default config for ASUS P5AD2.
HDA Codec driver
- Correct some index variable inversion in patch_cmedia.c
Signed-off-by: Nicolas Graziano <nicolas.graziano@wanadoo.fr>
Documentation,HDA Codec driver,HDA generic driver,HDA Intel driver
- Fix some invalid configurations, typos in the last patch
- Make init_verbs chainable, so that different configs can share the same
init_verbs
- Reorder and clean up the source codes in patch_realtek.c
- Add the pin default configuration parser, used commonly in cmedia
and realtek patch codes.
- Add 'auto' model to ALC880 for auto-configuration from BIOS
Use this model as default, and 3-stack as fallback
HDA Codec driver
Fix and cleanup of CM9880 automatic PIN configuration.
snd_hda_codec_setup_stream() doesn't do anything when NID is 0.
HDA Codec driver
Patch by C.L. Tien <cltien@cmedia.com.tw>:
The patch makes cm9880 to choose multi-channel jacks automatically.
1. I found the current code has basic_init, which already includes
necessary controls for 6-stack initialization, so I don't need
another model.
2. I add a new model 'auto' to let the driver find a. if there are
option real panel/front panel, b. the jacks to be used for multichannel.
Because the jack color are based on MS's channel sequence, so the 'auto'
model will pick the same jacks for multichannel MS uses. I did this to
hope to minimize users questions. These code can also be applied to other
codecs but I don't have any to test.
HDA Codec driver
The patch_cm9880.c can't play side/C/B channels from front panel jacks.
I fixed it by adding select pin.
Signed-off-by: ChenLi Tien <cltien@cmedia.com.tw>
infrastructure for it.
Let it rip!
