... so that the parser code can overwrite some optional ops. For
Realtek and others, it can be set solely in the spec allocator, so it
results in a good code cleanup, too.
With this change, we can finally remove the local stream_pm setup and
rely on the generic parser's automatic setting.
This patch adds support for Conexant HD Audio codecs
CX20721, CX20722, CX20723 and CX20724.
Cc: stable@vger.kernel.org
BugLink: https://bugs.launchpad.net/bugs/1454656
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
Like the previous patches, this patch converts also to the regmap, at
this time, the cached verb writes are the target. But this conversion
needs a bit more caution than before.
- In the old code, we just record any verbs as is, and restore them at
resume. For the regmap scheme, this doesn't work, since a few verbs
like AMP or DIGI_CONVERT are asymmetrical. Such verbs are converted
either to the dedicated function (snd_hda_regmap_xxx_amp()) or
changed to the unified verb.
- Some verbs have to be declared as vendor-specific ones before
accessing via regmap.
Also, the minor optimization with codec->cached_write flag is dropped
in a few places, as this would confuse the operation. Further
optimizations will be brought in the later patches, if any.
This conversion ends up with a drop of significant amount of codes,
mostly the helper codes that are no longer used.
Now some codes and functionalities of hda_codec struct are moved to
hdac_device struct. A few basic attributes like the codec address,
vendor ID number, FG numbers, etc are moved to hdac_device, and they
are accessed like codec->core.addr. The basic verb exec functions are
moved, too.
A few basic codes for communicating over HD-audio bus are moved to
struct hdac_bus now. It has only command and get_response ops in
addition to the unsolicited event handling.
Note that the codec-side tracing support is disabled temporarily
during this transition due to the code shuffling. It will be
re-enabled later once when all pieces are settled down.
Compaq Presario CQ60 laptop with CX20561 gives a wrong pin for the
built-in mic NID 0x17 instead of NID 0x1d, and it results in the
non-working mic. This patch just remaps the pin correctly via fixup.
Bugzilla: https://bugzilla.opensuse.org/show_bug.cgi?id=920604
Cc: <stable@vger.kernel.org>
Now we create the standard HD-audio bus (/sys/bus/hdaudio), and bind
the codec driver with the codec device over there. This is the first
step of the whole transition so that the changes to each codec driver
are kept as minimal as possible.
Each codec driver needs to register hda_codec_driver struct containing
the currently existing preset via the new helper macro
module_hda_codec_driver(). The old hda_codec_preset_list is replaced
with this infrastructure. The generic parsers (for HDMI and other)
are also included in the preset with the special IDs to bind
uniquely.
In HD-audio core side, the device binding code is split to
hda_bind.c. It provides the snd_hda_bus_type implementation to match
the codec driver with the given codec vendor ID. It also manages the
module auto-loading by itself like before: when the matching isn't
found, it tries to probe the corresponding codec modules, and finally
falls back to the generic drivers. (The special ID mentioned above is
set at this stage.)
The only visible change to outside is that the hdaudio sysfs entry now
appears in /sys/bus/devices, not as a sound class device.
More works to move the suspend/resume and remove ops will be
(hopefully) done in later patches.
... for distinguishing whether it's explicitly enabled via a user hint
or enabled by a driver as a fallback. Now the former case corresponds
to HDA_HINT_STEREO_MIX_ENABLE while the latter to
HDA_HINT_STEREO_MIX_AUTO.
Lenovo Ideapad Z560 has a mute LED that is controlled via EAPD pin
0x1b on CX20585 codec. (EAPD bit on corresponds to mute LED on.)
The machine doesn't need other EAPD, so the fixup concentrates on
controlling EAPD 0x1b following the vmaster state (but inversely).
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=665315
Reported-by: Szymon Kowalczyk <fazerxlo@o2.pl>
Alsa-info at https://launchpadlibrarian.net/186697318/alsa-info.txt.37fYWkaJRc
Reported-by: Tomas Nilsson <tomas.k.nilsson@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next
ASoC: Updates for v3.18
- More componentisation work from Lars-Peter, this time mainly
cleaning up the suspend and bias level transition callbacks.
- Real system support for the Intel drivers and a bunch of fixes and
enhancements for the associated CODEC drivers, this is going to need
a lot quirks over time due to the lack of any firmware description of
the boards.
- Jack detect support for simple card from Dylan Reid.
- A bunch of small fixes and enhancements for the Freescale drivers.
- New drivers for Analog Devices SSM4567, Cirrus Logic CS35L32, Everest
Semiconductor ES8328 and Freescale cards using the ASRC in newer i.MX
processors.
Lemote A1004 is already added in commit a2dd933d01f (ALSA: hda - Add
fixup name lookup for CX5051 and 5066 codecs), but Lemote A1205 has
missing.
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Cc: <stable@vger.kernel.org> # 3.15+
So far, hda_jack infrastructure allows only one callback per jack, and
this makes things slightly complicated when a driver wants to assign
multiple tasks to a jack, e.g. the standard auto-mute with a power
up/down sequence. This can be simplified if the hda_jack accepts
multiple callbacks.
This patch is such an extension: the callback-specific part (the
function and private_data) is split to another struct from
hda_jack_tbl, and multiple such objects can be assigned to a single
hda_jack_tbl entry.
The new struct hda_jack_callback is passed to each callback function
now, thus the patch became bigger than expected. But these changes
are mostly trivial.
Merging for-linus branch for syncing the latest STAC/IDT codec
changes to be affected by the upcoming hda-jack rewrites.
The DACs on Sigmatel/IDT codecs do mute at the lowest volume level,
and in the earlier drivers, we passed TLV_DB_SCALE_MUTE bit for each
volume control element like Speaker and Headphone as well as Master.
Along with the translation to the generic parser, however, the TLV bit
was lost for the slave controls (e.g. Speaker) but set only to
Master. In theory this should have sufficed, but apps, particularly
PA, do care the slave volume bits, so we seem to see a regression in
the volume controls.
This patch adds a flag to hda_gen_spec to specify the DAC mute
feature, and adds the TLV bit properly for all relevant volume
controls. Also, the TLV bit for vmaster is set in hda_generic.c, so
that we can get rid of all tricks from the codec driver side.
As the similar hack is applied to Conexant 5051 stuff, we can get rid
of it as well.
BugLink: https://bugs.launchpad.net/bugs/1357928
Acer Aspire 3830TG with CX20588 codec has a digital built-in mic that
has the same problem like many others, the inverted signal in stereo.
Apply the same fixup to this machine, too.
Conexnat HD-audio driver has a workaround for cx5051 (aka CX20561)
chip to add fake mute controls to each amp (commit 3868137e). This
implies the minimum-as-mute TLV bit in TLV for each corresponding
control. Meanwhile we build the virtual master from these, but the
TLV bit is missing, even though the slaves have it.
This patch simply adds the missing TLV_DB_SCALE_MUTE bit for vmaster,
as already done in patch_sigmatel.c.
The static quirk code has been disabled for a while and it seems
working fine, so it's time to actually get rid of it.
The beep input device is registered via input_register_device(), but
this is called in snd_hda_attach_beep_device() where the sound devices
aren't registered yet. This leads to the binding to non-existing
object, thus results in failure. And, even if the binding worked
(against the PCI object), it's still racy; the input device appears
before the sound objects.
For fixing this, register the input device properly at dev_register
ops of the codec object it's bound with. Also, call
snd_hda_detach_beep_device() at dev_disconnection so that it's
detached at the right timing. As a bonus, since it's called in the
codec's ops, we can get rid of the further call from the other codec
drivers.
Use dev_err() and co for messages from HD-audio controller and codec
drivers. The codec drivers are mostly bound with codec objects, so
some helper macros, codec_err(), codec_info(), etc, are provided.
They merely wrap the corresponding dev_xxx().
There are a few places still calling snd_printk() and its variants
as they are called without the codec or device context.
Some codec drivers still have it since using PCI_VENDOR_ID_*.
Now Realtek and Conexant codec parsers just call snd_hda_gen_free().
The current code for controlling mic mute LED in patch_sigmatel.c
blindly assumes that there is a single capture switch. But, there can
be multiple multiple ones, and each of them flips the state, ended up
in an inconsistent state.
For fixing this problem, this patch adds kcontrol to be passed to the
hook function so that the callee can check which switch is being
accessed. In stac_capture_led_hook(), the state is checked as a
bitmask, and turns on the LED when all capture switches are off.
Now all weird setups have been converted to fixups for the generic
parser, and we can disable the static quirks. This commit just turns
the build off. The bulky static quirk code still remains for a while,
in case we get an overlooked regression. It'll be removed at the next
kernel version.
Both CX20549 and CX20551 codecs have a mixer widget and it can be
connected as the ADC source. Like AD and VIA codecs, enable the
add_stereo_mix_input flag for these codecs.
CX20549 has an aamixer widget at NID 0x17. Let's enable it.
For the generic parser, use the standard fixup matching.
This laptop with CX20549 codec misses the internal mic at NID 0x12.
We need to fix bogus pincfgs on this machine, but it works well else.
Apply the amp cap override for CX20549 mixer widget in case where the
generic parser is used, too.
OLPC XO needs a few special handling. Now these are implemented as a
fixup to the generic parser.
Obviously, the DC BIAS mode had to be added manually. This is mainly
implemented in the mic_autoswitch hook, where the mic pins are
overwritten depending on the DC bias mode. This also required the
override of the mic boost control, since the mic boost is applied only
when the DC mode is disabled.
In addition, the mic pins must be set dynamically at recording time
because these also control the LED.
Like other codecs, apply a specific fixup given by a model string.
Both patch_realtek.c and patch_conexant.c contain the fairy same code
snippet for supporting Thinkpad ACPI LED controls. Split them into
thinkpad_helper.c and include it from both places. Although this
isn't the best approach from the code size POV, the probability for
coexistence of both Realtek and Conexant codecs on a single machine is
pretty low, thus it'll end up with less memory footprint than
splitting to yet another module.
CONFIG_ACPI dependent code should include <linux/acpi.h> instead of
directly including <acpi/acpi.h>. This patch cleans up such wrong
inclusions for Thinkpad ACPI users.
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
I've tested the old Dell Vostro 131 with the latest generic parser
and it works just fine, and as a bonus we get better jack detection
features in userspace. Therefore this quirk can be removed.
Most Thinkpad Edge series laptops use conexant codec, so far although
the codecs have different minor Vendor Id and minor Subsystem Id,
they all belong to the cxt5066 family, this change can make the
mute/mic-mute LEDs support more generic among cxt_5066 family.
This design refers to the similar solution for the realtek codec
ALC269 family in the patch_realtek.c.
Cc: Alex Hung <alex.hung@canonical.com>
Signed-off-by: Hui Wang <hui.wang@canonical.com>
Acked-by: David Henningsson <david.henningsson@canonical.com>
It's a superset of the existing CX2075x codecs, so we can reuse the
existing parser code.
Acer Aspire 3830TG seems requiring GPIO bit 0 as the primary mute
control. When a machine is booted after Windows 8, the GPIO pin is
turned off and it results in the silent output.
This patch adds the manual fixup of GPIO bit 0 for this model.
Reported-by: Christopher <DIDI2002@web.de>
This Conexant codec has a single jack that can be used as either
headphone or mic (but not headset). The existing hp_mic functionality
does not apply here, because the mic and the HP are on separate pins.
Hence make a lighter version of what has been earlier done for Realtek
codecs.
BugLink: https://bugs.launchpad.net/bugs/1198030
Tested-by: Franz Hsieh <franz.hsieh@canonical.com>
Like the X220, this quirk was added to support docking station,
so enable the fixup instead.
According to Jan, the generic parser works equal or better
than the current parser. This was tested under a 3.9 kernel.
Reported-by: Jan Alexander Steffens <jan.steffens@gmail.com>
The older Conexant codecs have up to two EAPDs and these are supposed
to be rather statically turned on. The new generic parser code
assumes the dynamic on/off per path usage, thus it resulted in the
silent output on some machines.
This patch fixes the problem by simply assuming the static EAPD on for
such old Conexant codecs as we did until 3.8 kernel.
Reported-and-tested-by: Christopher K. <c.krooss@gmail.com>
Cc: <stable@vger.kernel.org> [v3.9]
This enables better volume controls than the current model parser.
Also, because the original quirk for X220 was added to fix
docking station support, add the TP410 fixup instead.
Reported-by: Willian Jon McCann <william.jon.mccann@gmail.com>
Instead of calling snd_hda_attach_beep_device() and
snd_hda_detach_beep_device() in each codec driver, move them to the
generic parser. The codec driver just needs to set spec->beep_nid for
activating the digital beep.
Back-merged for refactoring beep stuff.
The argument passed to snd_hda_attach_beep_device() is a widget NID
while spec->beep_amp holds the composed value for amp controls.
This leaks the beep input device after module unload, which leads to
Oops.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=55321
So far, the driver doesn't power down the widget at going down to D3
when the widget node has an EAPD capability and EAPD is actually set
on all codecs unless codec->power_filter is set explicitly.
This caused a problem on some Conexant codecs, leading to click
noises, and we set it as NULL there. But it is very unlikely that the
problem hits only these codecs.
Looking back at the development history, this workaround for EAPD was
introduced just for some laptops with STAC9200 codec, then we applied
it blindly for all. Now, since it's revealed to have an ill effect,
we should disable this workaround per default and apply only for the
known requiring systems.
The EAPD workaround is implemented now as snd_hda_codec_eapd_power_filter(),
and this has to be set explicitly by the codec driver when needed.
As of now, only patch_stac9200() sets this one.
