This makes controls HDA Decode Capability, HDA Maximum PCM Channels
for HDA and AVP DMA channel id for Tegra Soc read only.
Bug 200023797
Change-Id: I3271470354b02f3d1b3aab8fa3963ad19d281f41
Signed-off-by: Rahool Paliwal <rpaliwal@nvidia.com>
Reviewed-on: http://git-master/r/441855
GVS: Gerrit_Virtual_Submit
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
commit 7c66593286bcd153e4868383e675673a27071bd5 upstream.
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit 415d555e6b398b00fc1733f0113065a54df9106a upstream.
The recent fixups for HP laptops to support the mute LED made the
speaker output silent on some machines. It turned out that they use
the NID 0x18 for the speaker while it's also used for controlling the
LED via VREF bits although the current driver code blindly assumes
that such a node is a mic pin (where 0x18 is usually so).
This patch fixes the problem by only changing the VREF bits and
keeping the other pin ctl bits.
Reported-and-tested-by: Hui Wang <hui.wang@canonical.com>
commit a4b7f21d7b42b33609df3f86992a8deff80abfaf upstream.
The `lspci -nnvv` output contains (wrapped for line length):
00:1b.0 Audio device [0403]:
Intel Corporation 7 Series/C210 Series Chipset Family
High Definition Audio Controller [8086:1e20] (rev 04)
Subsystem: ASUSTeK Computer Inc. Device [1043:115d]
Signed-off-by: W. Trevor King <wking@tremily.us>
Change-Id: I30baee4084399b8078232f31296c4d891a903d47
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-on: http://git-master/r/395123
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
commit c5eda4c1bf6214332c46fb2f4e7c42a85e5e5643 upstream.
The mixer widget (NID 0x20) of AD1884 and AD1984 codecs isn't
connected directly to the actual I/O paths but only via another mixer
widget (NID 0x21). We need a similar fix as we did for AD1882.
commit a6b92b6650d010d58b6e6fe42c6271266e0b1134 upstream.
Signed-off-by: Marius Knaust <marius.knaust@gmail.com>
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit 37c367ecdb9a01c9acc980e6e17913570a1788a7 upstream.
HP Folio 13 may have a broken BIOS that doesn't set up the mute LED
GPIO properly, and the driver guesses it wrongly, too. Add a new
fixup entry for setting the GPIO pin statically for this laptop.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=70991
commit 1de7ca5e844866f56bebb2fc47fa18e090677e88 upstream.
The front headphone and mic jackes on a HP desktop model (Vendor Id:
0x111d76c7 Subsystem Id: 0x103c2b17) can not work, the codec on this
machine has 8 physical ports, 6 of them are routed to rear jackes
and all of them work very well, while the remaining 2 ports are
routed to front headphone and mic jackes, but the corresponding
pin complex node are not defined correctly.
After apply this fix, the front audio jackes can work very well.
[trivial fix of enum definition by tiwai]
BugLink: https://bugs.launchpad.net/bugs/1282369
Cc: David Henningsson <david.henningsson@canonical.com>
Tested-by: Gerald Yang <gerald.yang@canonical.com>
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit 13c12dbe3a2ce17227f7ddef652b6a53c78fa51f upstream.
Incorrect ADC is picked in ca0132_capture_pcm_prepare(),
where it assumes multiple streams while there is one stream
per ADC. Note that ca0132_capture_pcm_cleanup() already does
the right thing.
The Chromebook Pixel has a microphone under the keyboard that
is attached to node id 0x8. Before this fix, recording would
always go to the main internal mic (node id 0x7).
Signed-off-by: Hsin-Yu Chao <hychao@chromium.org>
Reviewed-by: Dylan Reid <dgreid@chromium.org>
commit 28fba95087a7f3d107a3a6728aef7dbfaf3fd782 upstream.
When a HDMI stream is opened with the same stream tag
as a following opened stream to ca0132, audio will be
heard from two ports simultaneously.
Fix this issue by change to use snd_hda_codec_setup_stream
and snd_hda_codec_cleanup_stream instead, so that an
inactive stream can be marked as 'dirty' when found
with a conflict stream tag, and then get purified.
Reviewed-by: Chih-Chung Chang <chihchung@chromium.org>
commit f88abaa0d0dc0d1f1a9ae21f8e822918e5aadfdf upstream.
The very same fixup is needed to make the mic on Sony VAIO Pro 11
working as well as VAIO Pro 13 model.
Reported-and-tested-by: Hendrik-Jan Heins <hjheins@gmail.com>
commit c7579fed1f1b2567529aea64ef19871337403ab3 upstream.
The mixer widget on AD1983 at NID 0x0e was missing in the commit
[f2f8be43c5c9: ALSA: hda - Add aamix NID to AD codecs].
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=70011
commit c20f31ec421ea4fabea5e95a6afd46c5f41e5599 upstream.
Mac Pro 1,1 with ALC889A codec needs the VREF setup on NID 0x18 to
VREF50, in order to make the speaker working. The same fixup was
already needed for MacBook Air 1,1, so we can reuse it.
Reported-by: Nicolai Beuermann <mail@nico-beuermann.de>
(This is upstream 75fae117a5db "ALSA: hda/hdmi - allow PIN_OUT to be
dynamically enabled", backported to stable 3.10 through 3.12. 3.13 and
later can take the original patch.)
Commit 384a48d71520 "ALSA: hda: HDMI: Support codecs with fewer cvts
than pins" dynamically enabled each pin widget's PIN_OUT only when the
pin was actively in use. This was required on certain NVIDIA CODECs for
correct operation. Specifically, if multiple pin widgets each had their
mux input select the same audio converter widget and each pin widget had
PIN_OUT enabled, then only one of the pin widgets would actually receive
the audio, and often not the one the user wanted!
However, this apparently broke some Intel systems, and commit
6169b673618b "ALSA: hda - Always turn on pins for HDMI/DP" reverted the
dynamic setting of PIN_OUT. This in turn broke the afore-mentioned NVIDIA
CODECs.
This change supports either dynamic or static handling of PIN_OUT,
selected by a flag set up during CODEC initialization. This flag is
enabled for all recent NVIDIA GPUs.
Reported-by: Uosis <uosisl@gmail.com>
(This is a backport of *part* of upstream 611885bc963a "ALSA: hda -
hdmi: Disallow unsupported 2ch remapping on NVIDIA codecs" to stable
3.10 through 3.12. Later stable already contain all of the original
patch.)
Mainline commit 611885bc963a "ALSA: hda - hdmi: Disallow unsupported 2ch
remapping on NVIDIA codecs" introduces function patch_nvhdmi(). That
function is edited by 75fae117a5db "ALSA: hda/hdmi - allow PIN_OUT to be
dynamically enabled". In order to backport the PIN_OUT patch, I am first
back-porting just the addition of function patch_nvhdmi(), so that the
conflicts applying the PIN_OUT patch are simplified.
Ideally, one might backport all of 611885bc963a. However, that commit
doesn't apply to stable kernels, since it relies on a chain of other
patches which implement new features.
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
[swarren, extracted just a small part of the original patch]
commit e7729a415315fcd9516912050d85d5aaebcededc upstream.
Similarly to other Apple products, MBA 1,1 needs a specific quirk.
Pin 0x18 must be set to VREF_50 to have sound output. This was no
longer done since commit 1a97b7f, resulting in a mute built-in speaker.
This patch corrects the regression by creating a fixup for the MBA 1,1.
Fixes: 1a97b7f22774 ("ALSA: hda/realtek - Remove the last static quirks for ALC882")
Tested-by: Adrien Vergé <adrienverge@gmail.com>
Signed-off-by: Adrien Vergé <adrienverge@gmail.com>
commit 43a8e50a46a4e1dd1451e4a4ffa1f7695fb7d287 upstream.
AD1986A mic pins (0x1d and 0x1f) share the same widget for controlling
the loopback volume/mute, but the generic parser didn't check it.
This ended up with the duplicated controls for the same effect.
This patch adds the check of the duplication for avoiding it.
After this fix, there will be only one control although it affects
both paths; this remaining issue should be fixed later in a different
patch.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=66621
after system resume device state is change to active
and codec power work handler takes care of powering
down if it is idle for some time.
Bug 1447475
Change-Id: Icabb82ebacc7bf79730e2b7aaac1a87675959cf2
Signed-off-by: Mohan Kumar <mkumard@nvidia.com>
Reviewed-on: http://git-master/r/361495
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
commit 693e0cb052c607e2d41edf9e9f1fa99ff8c266c1 upstream.
While enabling these machines, we found we would sometimes lose an
interrupt if we change hardware volume during playback, and that
disabling msi fixed this issue. (Losing the interrupt caused underruns
and crackling audio, as the one second timeout is usually bigger than
the period size.)
The machines were all machines from HP, running AMD Hudson controller,
and Realtek ALC282 codec.
BugLink: https://bugs.launchpad.net/bugs/1260225
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit c9a6338aecdb92f9d015ecc26d203e54250bebbb upstream.
In case a single HDA card has both HDMI and S/PDIF outputs, the S/PDIF
outputs will have their IEC958 controls created starting from index 16
and the HDMI controls will be created starting from index 0.
However, HDMI simple_playback_build_controls() as used by old VIA and
NVIDIA codecs incorrectly requests the IEC958 controls to be created
with an S/PDIF type instead of HDMI.
In case the card has other codecs that have HDMI outputs, the controls
will be created with wrong index=16, causing them to e.g. be unreachable
by the ALSA "hdmi" alias.
Fix that by making simple_playback_build_controls() request controls
with HDMI indexes.
Not many cards have an affected configuration, but e.g. ASUS M3N78-VM
contains an integrated NVIDIA HDA "card" with:
- a VIA codec that has, among others, an S/PDIF pin incorrectly
labelled as an HDMI pin, and
- an NVIDIA MCP7x HDMI codec.
Reported-by: MysterX on #openelec
Tested-by: MysterX on #openelec
commit ebb93c057dda376414fbc499ad6ace9b527dff5a upstream.
Not all channels have been initialized, so far, especially when aamix
NID itself doesn't have amps but its leaves have. This patch fixes
these holes. Otherwise you might get unexpected loopback inputs,
e.g. from surround channels.
commit 3690739b013504d33fe9348dd45f6b126aa370fb upstream.
AD1986A codec is a pretty old codec and has really many hidden
restrictions. One of such is that each DAC is dedicated to certain
pin although there are possible connections. Currently, the generic
parser tries to assign individual DACs as much as possible, and this
lead to two bad situations: connections where the sound actually
doesn't work, and connections conflicting other channels.
We may fix this by trying to find the best connections more harder,
but as of now, it's easier to give some hints for paired DAC/pin
connections and honor them if available, since such a hint is needed
only for specific codecs (right now only AD1986A, and there will be
unlikely any others in future).
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=64971
This is the 3.10.24 stable release
Change-Id: Ibd2734f93d44385ab86867272a1359158635133b
commit eb82594b75b0cf54c667189e061934b7c49b5d42 upstream.
This machine also has mono output if run through DAC node 0x03.
BugLink: https://bugs.launchpad.net/bugs/1256212
Tested-by: David Chen <david.chen@canonical.com>
commit 0756f09c4946fe2d9ce2ebcb6f2e3c58830d22a3 upstream.
MacBook Air 2,1 has a fairly different pin assignment from its brother
MBA 1,1, and yet another quirks are needed for pin 0x18 and 0x19,
similarly like what iMac 9,1 requires, in order to make the sound
working on it.
Reported-and-tested-by: Bruno Prémont <bonbons@linux-vserver.org>
commit d59915d0655c5864b514f21daaeac98c047875dc upstream.
By trial and error, I found this patch could work around an issue
where the headset mic would stop working if you switch between the
internal mic and the headset mic, and the internal mic was muted.
It still takes a second or two before the headset mic actually starts
working, but still better than nothing.
Information update from Kailang:
The verb was ADC digital mute(bit 6 default 1).
Switch internal mic and headset mic will run alc_headset_mode_default.
The coef index 0x11 will set to 0x0041.
Because headset mode was fixed type. It doesn't need to run
alc_determine_headset_type.
So, the value still keep 0x0041. ADC was muted.
BugLink: https://bugs.launchpad.net/bugs/1256840
commit e7ca237bfcf6a288702cb95e94ab94f642ccad88 upstream.
ASUS Z35HL laptop also needs the very same fix as the previous one
that was applied to ASUS W7J.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=66231
commit 6ddf0fd1c462a418a3cbb8b0653820dc48ffbd98 upstream.
The recent kernels got regressions on ASUS W7J with ALC660 codec where
no sound comes out. After a long debugging session, we found out that
setting the pin control on the unused NID 0x10 is mandatory for the
outputs. And, it was found out that another magic of NID 0x0f that is
required for other ASUS laptops isn't needed on this machine.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=66081
Reported-and-tested-by: Andrey Lipaev <lipaev@mail.ru>
commit 2ded3e5b61d61d0bc90bebb8004db6184c7db6eb upstream.
The current generic parser assumes blindly that the volume and mute
amps are found in the aamix node itself. But on some codecs,
typically Analog Devices ones, the aamix amps are separately
implemented in each leaf node of the aamix node, and the current
driver can't establish the correct amp controls. This is a regression
compared with the previous static quirks.
This patch extends the search for the amps to the leaf nodes for
allowing the aamix controls again on such codecs.
In this implementation, I didn't code to loop through the whole paths,
since usually one depth should suffice, and we can't search too
deeply, as it may result in the conflicting control assignments.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=65641
commit 1f0bbf03cb829162ec8e6d03c98aaaed88c6f534 upstream.
Add a fixup entry for the missing bass speaker pin 0x16 on ASUS ET2700
AiO desktop. The channel map will be added in the next patch, so that
this can be backported easily to stable kernels.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=65961
commit ced4cefc75fdb8be95eaee325ad0f6b2fc0a484b upstream.
When a headphone jack is configurable as input, the generic parser
tries to make it retaskable as Headphone Mic. The switching can be
done smoothly if Capture Source control exists (i.e. there is another
input source). Or when user explicitly enables the creation of jack
mode controls, "Headhpone Mic Jack Mode" will be created accordingly.
However, if the headphone mic is the only input source, we have to
create "Headphone Mic Jack Mode" control because there is no capture
source selection. Otherwise, the generic parser assumes that the
input is constantly enabled, thus the headphone is permanently set
as input. This situation happens on the old MacBook Airs where no
input is supported properly, for example.
This patch fixes the problem: now "Headphone Mic Jack Mode" is created
when such an input selection isn't possible.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=65681
commit 16c0cefe8951b2c4b824fd06011ac1b359b1ab3b upstream.
When the hp mic pin has no VREF bits, the driver forgot to set PIN_IN
bit. Spotted during debugging old MacBook Airs.
commit ba4c4d0a9021ab034554d532a98133d668b87599 upstream.
It's compatible with ALC269.
commit 9ad54547cf6f4410eba83bb95dfd2a0966718d6d upstream.
Set the missing pcbeep default amp for ALC668.
commit d08c5ef2a039393eaf2ab2152db5f07790fa0f40 upstream.
Some models (or maybe depending on BIOS version) of Sony VAIO with
ALC260 give no proper pin configurations as default, resulting in the
non-working speaker, etc. Just provide the whole pin configurations
via a fixup.
Reported-by: Matthew Markus <mmarkus@hearit.co>
commit b8362e70cbbb397db50939bc4c7c78dc3246c3eb upstream.
BugLink: https://bugs.launchpad.net/bugs/1253636
commit 0f5a5b8515472a0219768423226b58228001e3d5 upstream.
BIOS sets MISC_NO_PRESENCE bit wrongly to the pin config on NID 0x0f.
commit 0fc28fc030a85aa3d6d14e9e9fca0c8237c9ffb5 upstream.
When a codec is resumed, it keeps the power on while the resuming
phase via hda_keep_power_on(), then turns down via
snd_hda_power_down(). At that point, snd_hda_power_down() notifies
the power down to the controller, and this may confuse the refcount if
the codec was already powered up before the resume.
In the end result, the controller goes to runtime suspend even before
the codec is kicked off to the power save, and the communication
stalls happens.
The fix is to add the power-up notification together with
hda_keep_power_on(), and clears the flag appropriately.
commit d183b4fc463489b6bbe05c99afa0257a6fe578eb upstream.
snd_hda_codec_reset() is called either in resetting the whole setup at
error paths or hwdep clear/reconfig sysfs triggers. But all of these
don't assume that the power has to be off, rather they want to keep
the power state unchanged (e.g. reconfig_codec() calls the power
up/down by itself). Thus, unconditionally clearing the power state in
snd_hda_codec_reset() leads to the inconsistency, confuses the further
operation. This patch gets rid of the lines doing that bad thing.
commit 7a3e6107f94344e65c35bfe62de6c096a7b48965 upstream.
The only EAPD on AD1986A is on NID 0x1b where usually the speaker.
But this doesn't control only the speaker amp but may influence on all
outputs, e.g. Lenovo N100 laptop seems to have this issue.
commit 468ac413045af1e0e4d1272291bed6878f248a69 upstream.
We don't change the EAPD bit in set_pin_eapd() if keep_eapd_on flag is
set by the codec driver and enable is false. But, we also apply the
flipping of enable value according to inv_eapd flag in the same
function, and this confused the former check, handled as if it's
turned ON. The inverted EAPD check must be applied after keep_eapd_on
check, instead.
commit 5959a6bc1124211a359525d209005abc07b0197b upstream.
In case there is both a multifunction headset jack and a Line Out
jack, automuting was not working properly from the Line Out jack.
This patch fixes that issue.
BugLink: https://bugs.launchpad.net/bugs/1250377
Tested-by: Cyrus Lien <cyrus.lien@canonical.com>
commit 487a588d09db0d6508261867df208d8bdc718251 upstream.
BIOS on ASUS W5A laptop with ALC880 codec doesn't provide any pin
configurations, so we have to set up all pins manually.
Reported-and-tested-by: nb <nb@dagami.org>
commit 8f42d7698751a45cd9f7134a5da49bc5b6206179 upstream.
It's a superset of the existing CX2075x codecs, so we can reuse the
existing parser code.
commit d5b6b65e75ce607c2734227524e11574317a1c1a upstream.
Some HP machines with Realtek codecs have mute LEDs connected to VREF pins.
However when these go into runtime suspend, the pin powers down and its
pin control is disabled, thus disabling the LED too.
This patch fixes that issue by making sure that the pin stays in D0 with
correct pin control.
BugLink: https://bugs.launchpad.net/bugs/1248465
Tested-by: Franz Hsieh <franz.hsieh@canonical.com>
commit 24eff328f65c8ef352c90b6adb7c2f39eb94205d upstream.
BIOS on Acer TravelMate 6293 doesn't set up the SPDIF output pin
correctly as default, so enable it via a fixup entry.
Reported-and-tested-by: Hagen Heiduck <heiduck.suse@fmail.postpro.net>
commit 1d04c9de5c76df113e4af7120feb53c628b5efcc upstream.
It's just another variant of ALC269 & co.
