This patch adds support for useable front audio channels,
user controllable headphone channel and optical output.
Signed-off-by: Matt Taylor <mwtaylor@gmail.com>
This patch adds a mixer control which allows the user to switch the Aux
playback between the internal Aux jack, Wavetable, and Rear Line-In on
Aureon Universe cards.
For switching, a PCA9554 (8-line GPIO with I2C interface) and a 74HC4052
(dual 4-way mux/demux) are used. Output 0 and 1 of the PCA9554 are
connected to the select pins of the 74HC4052. The I2C interface of the
PCA9554 is connected to the card's internal SPI bus which is also used
to control the WM8770 and CS8415. SPI and I2C on the same lines...
To communicate with the PCA9554 the WM8770 and CS8415 are disabled and
an I2C Stop Condition is generated before the Start Condition (needed
for synchronisation because other SPI traffic appear to confuse the
PCA9554). Then a normal I2C data transfer takes place. Programming must
be done ridiculously slow; in theory, 4.7us is the minimum delay time
for normal-speed I2C according to the datasheet, but even with 10us
switching was unreliable. The Windows driver from Terratec does the
programming very slowly, too (checked with an oscilloscope).
PCA9554 datasheet:
http://www.semiconductors.philips.com/acrobat/datasheets/PCA9554_9554A_6.pdf
74HC4052 datasheet:
http://www.semiconductors.philips.com/acrobat/datasheets/74HC_HCT4052_4.pdf
Signed-off-by: Maximilian Rehkopf <otakon@gmx.net>
Modules: ICE1712 driver
Fix the access to wrong type values for enum items in aureon.c
(ALSA bug#1527).
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Added the support of Prodigy-7.1LT board.
The patch taken from ALSA BTS bug#1090.
Modules: ICE1724 driver,ICE1712 driver
Remove xxx_t typedefs from the PCI ICE1724 driver.
Fix the return value of ADC mux put callback in aureon.c.
Add missing KERN_* suffix to printk.
AD1889 driver,ATIIXP driver,ATIIXP-modem driver,AZT3328 driver
BT87x driver,CMIPCI driver,CS4281 driver,ENS1370/1+ driver
ES1938 driver,ES1968 driver,FM801 driver,Intel8x0 driver
Intel8x0-modem driver,Maestro3 driver,SonicVibes driver,VIA82xx driver
VIA82xx-modem driver,AC97 Codec,AK4531 codec,au88x0 driver
CA0106 driver,CS46xx driver,EMU10K1/EMU10K2 driver,HDA Codec driver
HDA generic driver,HDA Intel driver,ICE1712 driver,ICE1724 driver
KORG1212 driver,MIXART driver,NM256 driver,Trident driver,YMFPCI driver
Replace kcalloc(1,..) with kzalloc().
infrastructure for it.
Let it rip!
