* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
Just tyops.
The name argument of request_irq() appears in /proc/interrupts, and
it's quite ugly when the name entry contains a space or special letters.
In general, it's simpler and more readable when the module name appears
there, so let's replace all entries with KBUILD_MODNAME.
The convention for pci_driver.name entry in kernel drivers seem to be
the module name or equivalent ones. But, so far, almost all PCI sound
drivers use more verbose name like "ABC Xyz (12)", and these are fairly
confusing when appearing as a file name.
This patch converts the all pci_driver.name entries in sound/pci/* to
use KBUILD_MODNAME for more unified appearance.
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to
.devinit.rodata section, so they can be discarded in some cases,
and make them const.
I found that the sampling rate locking setting of the ice1712 sound driver
was only half-respected : when the driver was locked to, let's say, 44100Hz,
and a usermode app was requesting 48000Hz playback, the request was succesful
although the soundcard would continue to run at 44100Hz.
Here's a patch that will make those requests to fail.
Signed-off-by: Sebastien Alaiwan <sebastien.alaiwan@gmail.com>
MIXER to PCM type
* PLEASE NOTE - this change requires the corresponding update of
envy24control for ice1712 - kind of an ABI change.
* The "Multi Track Peak" control is read-only level meters indicator.
* The control is VERY confusing to most users since it is currently displayed
in regular mixers. E.g. alsamixer ignores its read-only status
and allows changing the levels with keys which makes no sense.
Signed-off-by: Pavel Hofman <pavel.hofman@ivitera.com>
Acked-by: Jaroslav Kysela <perex@perex.cz>
* get/set routines for GPIO mask and direction
Replace all DMA_28BIT_MASK macro with DMA_BIT_MASK(28)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
Convert from snd_card_new() to the new snd_card_create() function
in sound/pci/*.
Neither has any significance currently to the flow
because err is checked for the same condition before
the place of disagreement.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
before:
total: 113 errors, 169 warnings, 2786 lines checked
total: 26 errors, 24 warnings, 504 lines checked
after:
total: 14 errors, 163 warnings, 2799 lines checked
total: 0 errors, 24 warnings, 504 lines checked
Compile tested only.
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Kill snd_assert() in sound/pci/*, either removed or replaced with
if () with snd_BUG_ON().
free_irq() calls synchronize_irq() for you, so there is no need for
drivers to manually do the same thing (again). Thus, calls where
sync-irq immediately precedes free-irq can be simplified.
However, during this audit several bugs were noticed, where free-irq is
preceded by a "irq >= 0" check... but the sync-irq call is not covered
by the same check.
So, where sync-irq could not be eliminated completely, the missing check
was added.
In all four case, adding a private value to the iooff index,
call it priv_idx.
sound/pci/ice1712/ice1712.c:1300:6: warning: symbol 'index' shadows an earlier one
sound/pci/ice1712/ice1712.c:85:12: originally declared here
sound/pci/ice1712/ice1712.c:1312:6: warning: symbol 'index' shadows an earlier one
sound/pci/ice1712/ice1712.c:1338:6: warning: symbol 'index' shadows an earlier one
sound/pci/ice1712/ice1712.c:1350:6: warning: symbol 'index' shadows an earlier one
[tiwai - fixed coding issues as well]
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Clean up ice1712/ice1724 codes. The board-specific data is allocated
locally in each code instead of having an ungly union in struct ice1712.
Also, fix coding issues in prodigy_hifi.c.
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
There were some places I forgot to replace with snd_ctl_boolean_mono_info.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks.
CC [M] sound/pci/ice1712/ice1712.o
sound/pci/ice1712/ice1712.c:290: error: snd_ice1712_mixer_digmix_route_ac97 causes a section type conflict
sound/pci/ice1712/ice1712.c:1630: error: snd_ice1712_eeprom causes a section type conflict
Gcc like its __devinitdata readable not const, it seems. An alternative
fix would be to remove the __devinitdata attribute but that would result
in slight runtime bloat.
Added a new macro snd_pcm_group_for_each_entry() just for code cleanup.
Old macros, snd_pcm_group_for_each() and snd_pcm_group_substream_entry(),
are removed.
Mark TLV data as 'const'
Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de>
Mark a lot of data as 'const'
Fix IRQ flags for PCI devices.
The shared IRQs for PCI devices shouldn't be allocated with
IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't
be used.
The patch removes unnecessary cast in request_irq and free_irq,
too.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Added the dB scale information for native digital volumes of ice1712 driver.
Fixed 'section mismatch' errors in ALSA PCI drivers:
- removed invalid __devinitdata from pci id tables
- fix/remove __devinit of functions called in suspend/resume
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
To permit use, in ice1712, of the mpu401 info flags recently added to
mpu401_uart, adds info_flags in snd_ice1712_card_info so that additional
flags can be set, if desired. 'MPU401_INFO_INTEGRATED' is always set with
the ice1712. The flags are passed on to snd_mpu401_uart_new().
_INFO_OUTPUT is set for DMX6fire mpu2.
Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk>
Consumer AC97 is not used by the Terratec DMX6fire, but eeprom bit indicates
it is; change the stored value to disable failing consumer mode.
Change the 5th argument of snd_mpu401_uart_new() to bit flags
instead of a boolean. The argument takes bits that consist of
MPU401_INFO_XXX flags.
The callers that used the value 1 there are replaced with
MPU401_INFO_INTEGRATED.
Remove unneeded read/write_size fields in proc text ops.
snd_info_set_text_ops() is fixed, too.
Patch provides for the ice1712 card driver to overwrite the midi port name
string given by default in mpu401_uart, with one specified in
snd_ice1712_card_info.
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de>
There's no reason for #include'ing linux/dma-mapping.h more than once.
I have just discovered I made an error in the register value set in 'Limit
dmx6fire to 6 dacs' patch (bug1472). The value set should be '2a' not '0a'
as in the original patch, which unintentionally disables the 2nd MPU 401
UART.
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask()
and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from
linux/dma-mapping.h.
Signed-off-by: Matthias Gehre <M.Gehre@gmx.de>
This patch introduces the DMA_28BIT_MASK constant in dma-mapping.h
ALSA drivers using this mask are changed to use the new constant.
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
Acked-by: Takashi Iwai <tiwai@suse.de>
Acked-by: Jaroslav Kysela <perex@suse.cz>
Modules: ICE1712 driver
See ALSA bug#1806 for details.
Change the value written to hardware configuration register of envy24 chip
in the case of Terratec DMX6fire to restrict the active ADCs & DACs to 6.
Also add the dxr_enable module option to eventually leave the old behaviour
when user requests.
Modules: I2C cs8427,ICE1712 driver
See ALSA bug#1785 for more details.
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
