path: root/sound/pci/intel8x0.c
2011-07-15ALSA: intel8x0: Apply headphones+mute LED quirk for Dell Inspiron 9300Daniel T Chen
BugLink: https://bugs.launchpad.net/bugs/774895 The original reporter states that his volume keys do not change the desired Master and PCM mixer elements together, so apply the hp+mute led quirk for his PCI SSID. Reported-by: Jeffrey Finkelstein Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: use KBUILD_MODNAME for request_irq argument in sound/pci/*Takashi Iwai
The name argument of request_irq() appears in /proc/interrupts, and it's quite ugly when the name entry contains a space or special letters. In general, it's simpler and more readable when the module name appears there, so let's replace all entries with KBUILD_MODNAME. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: Use KBUILD_MODNAME for pci_driver.name entriesTakashi Iwai
The convention for pci_driver.name entry in kernel drivers seem to be the module name or equivalent ones. But, so far, almost all PCI sound drivers use more verbose name like "ABC Xyz (12)", and these are fairly confusing when appearing as a file name. This patch converts the all pci_driver.name entries in sound/pci/* to use KBUILD_MODNAME for more unified appearance. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: ac97: Apply quirk for Dell Latitude D610 binding Master and Headphone ↵Daniel T Chen
controls BugLink: https://launchpad.net/bugs/669279 The original reporter states: "The Master mixer does not change the volume from the headphone output (which is affected by the headphone mixer). Instead it only seems to control the on-board speaker volume. This confuses PulseAudio greatly as the Master channel is merged into the volume mix." Fix this symptom by applying the hp_only quirk for the reporter's SSID. The fix is applicable to all stable kernels. Reported-and-tested-by: Ben Gamari <bgamari@gmail.com> Cc: <stable@kernel.org> [2.6.32+] Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-19ALSA: intel8x0: Mute External Amplifier by default for ThinkPad X31Daniel T Chen
BugLink: https://bugs.launchpad.net/bugs/619439 This ThinkPad model needs External Amplifier muted for audible playback, so set the inv_eapd quirk for it. Reported-and-tested-by: Dennis Bell <dennis.bell@parkerg.co.uk> Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-09sound: use DEFINE_PCI_DEVICE_TABLEAlexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to .devinit.rodata section, so they can be discarded in some cases, and make them const. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-25ALSA: intel8x0: Mute External Amplifier by default for Gateway 4525GZDaniel T Chen
BugLink: https://bugs.launchpad.net/bugs/487884 This Gateway model needs External Amplifier muted for audible playback, so set the inv_eapd quirk for it. Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-05ALSA: intel8x0: Mute External Amplifier by default for another Sony modelDaniel T Chen
BugLink: https://bugs.launchpad.net/bugs/474972 This Sony model needs External Amplifier muted for audible playback, so make sure we set the inv_eapd quirk. Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-02ALSA: intel8x0 - Mute External Amplifier by default for Sony VAIO VGN-B1VPDaniel T Chen
BugLink: https://bugs.launchpad.net/bugs/410933 This Sony VAIO model also needs External Amplifier unmuted for audible playback, so make sure we set the inv_eapd quirk. Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-01ALSA: intel8x0 - Mute External Amplifier by default for Sony VAIO VGN-T350PDaniel T Chen
BugLink: https://bugs.launchpad.net/bugs/410933 This Sony VAIO model needs External Amplifier unmuted for audible playback, so make sure we set the inv_eapd quirk. Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-25sound: Use PCI_VDEVICEJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-15ALSA: intel8x0 - Fix PCM position crazinessTakashi Iwai
The PCM pointer callback sometimes returns invalid positions and this screws up the hw_ptr updater in PCM core. Especially since now the jiffies check is optional with xrun_debug, the invalid position is handled as is, and causes serious sound skips, etc. This patch simplifies the position-fix strategy in intel8x0 to be more robust: - just falls back to the last position if bogus position is detected - another sanity check for the backward move of the position due to a race of register update and the base-index update This patch is applicable also for 2.6.30. Tested-by: David Miller <davem@davemloft.net> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-22Merge commit 'alsa/master' into for-linusTakashi Iwai
* commit 'alsa/master': [ALSA] intel8x0: another attempt to fix ac97_clock measure routine [ALSA] ac97_codec: increase timeout for analog subsections
2009-04-21[ALSA] intel8x0: another attempt to fix ac97_clock measure routineJaroslav Kysela
Appearently, a big delay ~300ms is required before hw is settled and ready to transfer samples on some hardware variants. Also, return back "clocking to 48000Hz" message when something fails. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2009-04-16ALSA: Intel8x0: Add hp_only quirk for SSID 0x1028016a (Dell Inspiron 8600)Daniel T Chen
Subject says it all. Briefly, use hp_only for another Dell Inspiron 8600. Reference: Ubuntu #41015 (https://launchpad.net/bugs/41015) Signed-off-by: Daniel T Chen <seven.steps@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-16ALSA: Intel8x0: Remove conflicting quirk for SSID 0x103c0934Daniel T Chen
While cleaning up quirks, I noticed that there is a duplicated quirk for the SSID 0x103c0934. Looking back through the bug reports, I've concluded that there is only one necessary quirk (hp_mute_led), so this patch removes the conflicting one. Reference: Ubuntu #44066 (https://launchpad.net/bugs/44066) Signed-off-by: Daniel T Chen <seven.steps@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-15[ALSA] intel8x0: add one retry to the ac97_clock measurement routineJaroslav Kysela
It seems that on some hardware platforms, the first measurement is wrong. This patch adds second measurement to this case. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2009-04-14[ALSA] intel8x0: fix wrong conditions in ac97_clock measure routineJaroslav Kysela
Also add a little code cleanup. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2009-04-13[ALSA] intel8x0: do not use zero value from PICB registerJaroslav Kysela
It seems that the zero value from the PICB (position in current buffer) register is not reliable. Use jiffies to correct returned value from the ring buffer pointer callback. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2009-04-13[ALSA] intel8x0: an attempt to make ac97_clock measurement more reliableJaroslav Kysela
- use monotonic posix clock to measure time - try to avoid reading zero from PICB (position in current buffer) register - show also measured samples - when clock is near 41000 or 44100, use exactly these values (they appears to be reference clocks for hardware manufacturers) Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2009-03-24Merge branch 'topic/intel8x0' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/snd_card_new-err' into for-linusTakashi Iwai
2009-02-05ALSA: intel8x0 - Add missing KERN_* prefix to printkTakashi Iwai
2009-01-31ALSA: alsa: time reaches -1, tested 0Roel Kluin
With a postfix decrement time will reach -1 rather than 0, so the warning will not be issued. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-28ALSA: intel8x0 - Fix build with CONFIG_SND_AC97_POWERSAVE=nTakashi Iwai
2009-01-28ALSA: Don't cold reset AC97 codecs in some ICH chipsetsThadeu Lima de Souza Cascardo
Check in a quirk list if it should do cold reset when AC97 power saving is enabled. Some devices do not resume properly when cold reset, although power saving works OK. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in sound/pci/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in sound/pci/*. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-29ALSA: intel8x0 - add Dell Optiplex GX620 (AD1981B) to AC97 clock whitelistBastien Nocera
alsa-info.sh output at: https://bugzilla.redhat.com/show_bug.cgi?id=441087#c49 Signed-off-by: Bastien Nocera <hadess@hadess.net> Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-10ALSA: intel8x0 - Add quirk for Fujitsu Lifebook P7010Takashi Iwai
Fujitsu Lifebook P7010 requires ac97_quirk=hp_only. http://bugzilla.kernel.org/show_bug.cgi?id=9100 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-09-04ALSA: intel8x0 - use snd_pci_quirk for clock listTakashi Iwai
2008-08-29ALSA: intel8x0: implement ac97_clock whitelistJaroslav Kysela
The AC97 clock detection is not accurate in some cases. This patch adds an initial whitelist for audio devices gathered from RedHat's bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=441087 As a side effect, white-listing might speedup kernel booting (AC97 clock measuring code is not activated). Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-13ALSA: sound/pci: supported cards updateAlexander Beregalov
sound/pci: supported cards update Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-13ALSA: Kill snd_assert() in sound/pci/*Takashi Iwai
Kill snd_assert() in sound/pci/*, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-04-24[ALSA] Fix synchronize_irq() bugs, redundanciesJeff Garzik
free_irq() calls synchronize_irq() for you, so there is no need for drivers to manually do the same thing (again). Thus, calls where sync-irq immediately precedes free-irq can be simplified. However, during this audit several bugs were noticed, where free-irq is preceded by a "irq >= 0" check... but the sync-irq call is not covered by the same check. So, where sync-irq could not be eliminated completely, the missing check was added. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: replace remaining __FUNCTION__ occurencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] intel8x0 - Add support of 8 channel soundTakashi Iwai
Added the support of 8 channel sound for codecs that are known to work. So far, only ALC850 is marked as a 8ch-support codec. This fix is a modified version of the patch on ALSA BTS#2097 by Martin Ellis: https://bugtrack.alsa-project.org/alsa-bug/view.php?id=2097 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-02-29[ALSA] intel8x0 - Add quirk for Compaq Deskpro ENTakashi Iwai
Added the ac97_quirk hp_only for Compaq Deskpro EN. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-02-29[ALSA] intel8x0 - Add quirk for Acer Travelmate 2310Takashi Iwai
Added ac97_quirk=hp-only for Acer Travelmate 2310. ALSA bug#3656 https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3656 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound/pci: Drop unnecessary continueJulia Lawall
Continue is not needed at the bottom of a loop. The semantic patch implementing this change is as follows: @@ @@ for (...;...;...) { ... if (...) { ... - continue; } } Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-30x86: cpa: move flush to cpaThomas Gleixner
The set_memory_* and set_pages_* family of API's currently requires the callers to do a global tlb flush after the function call; forgetting this is a very nasty deathtrap. This patch moves the global tlb flush into each of the callers Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: convert CPA users to the new set_page_ APIArjan van de Ven
This patch converts various users of change_page_attr() to the new, more intent driven set_page_*/set_memory_* API set. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-05-16[ALSA] Include quirks from Ubuntu Dapper/Edgy/FeistyDaniel T Chen
Included is a patch against current alsa-kernel hg tip adding quirks that Ubuntu Dapper/Edgy/Feisty contains. Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] intel8x0 - Fix Oops in crash kernelTakashi Iwai
When intel8x0 driver is loaded in the crash kernel, it gets Oops occasionally. This is because the irq handler gets called before the proper hardware initialization. Now defer it after snd_intel8x0_chip_init(). (reference: http://lkml.org/lkml/2007/3/5/252) Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-03-14[ALSA] intel8x0 - Fix Oops at kdump crash kernelTakashi Iwai
Fixed Oops at crash kernel from intel8x0 driver that is triggered from interrupt handler. Proper irqsave version seems needed for kexec/kdump. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-03-14[ALSA] intel8x0 - Fix speaker output after S2RAMTommi Kyntola
Fixed the mute speaker problem after S2RAM on some laptops: http://bugme.osdl.org/show_bug.cgi?id=6181 Signed-off-by: Tommi Kyntola <tommi.kyntola@ray.fi> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
